Heidenhain 11(micro)App sinusoidal linear encoders
- jCandlish
- Thank you received: 4
09 Dec 2011 12:58 - 09 Dec 2011 12:58 #15511
by jCandlish
Heidenhain 11(micro)App sinusoidal linear encoders was created by jCandlish
Specifically LS-303
Does the 7i49 support these scales directly or is a digitizing interpolator (like the EXE 600 series) necessary?
If an interpolator is necessary, other than Heidenhain, what is working?
_jC
_jC
Last edit: 09 Dec 2011 12:58 by jCandlish.
- Thank you received: 5137
09 Dec 2011 15:55 #15516
Replied by PCW on topic Re:Heidenhain 11(micro)App sinusoidal linear encoders
The 7I49 is really for resolvers, it might be possible to change the firmware to read the Heidenhain encoders but its not trivial. Also the 7I49 analog inputs are not right for the 11 uA Heidenhain signals
You really want a current/voltage (trransconductance amp) front end. This is possible but requires changing lots of 0603 SMD resistors on the card.
So if you have the interpolator, keep it...
We've kicked around the idea of using a DSPIC as a cheap Heidehain interpolator but have never developed sufficient ambition to actually lay one out, maybe next year...
Also Andy Pugh has a resolver interface in a Arduino, Its firmware could be modified to read the Heidenhain signals
A resolver interface and a interpolator do very similar things, the main difference is that the resolver
interface uses a carrier (AC excitation) so is a little more involved than an interpolator which effectively has DC excitation
- jCandlish
09 Dec 2011 16:23 - 09 Dec 2011 17:04 #15518
by jCandlish
Replied by jCandlish on topic Re:Heidenhain 11(micro)App sinusoidal linear encoders
Great info PCW! Thanks so much.
Unfortunately I don't have an interpolator, execpt the one integrated into an old Elesta control.
I was thinking Arduino, checked their site and go-ogle, and came up empty.
Maybe Andy will chime in with his resolver solution, or is that documented somewhere on this site?
Are there any other non-Heidenhain (read less-expensive) off-the-shelf ways to interface Heidenhain linear encoders?
Thanks again
_jC
Thanks again
_jC
Last edit: 09 Dec 2011 17:04 by jCandlish. Reason: sspeling
- Thank you received: 2147
10 Dec 2011 03:14 #15525
Replied by cmorley on topic Re:Heidenhain 11(micro)App sinusoidal linear encoders
if you have time to search. Ebay often has heidenhain EXE interpolators for around $50.
www.ebay.com/itm/HEIDENHAIN-EXE-602-D-5-...&hash=item19cb5339d1
- Thank you received: 4954
11 Dec 2011 01:32 #15541
Replied by andypugh on topic Re:Heidenhain 11(micro)App sinusoidal linear encoders
_jC wrote:
<chime>
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Res...oQuadratureConverter
I am not sure what the Heidenhains need, but some bits of that might help.
<chime>
Time to create page: 0.134 seconds
