color coded text editor
- JRied
17 Sep 2014 01:48 #51244
by JRied
color coded text editor was created by JRied
Hey guys... new user... but I really like the program.
We switched from Ubuntu to Debian and now the text editor no longer has those fancy colors to tell me if I have entered a coordinate (pink) a parameter (blue) or whatever.
Is there a way in the new software (mousepad) to change this?
Thanks in advance
Thanks in advance
- Thank you received: 5013
17 Sep 2014 05:56 #51248
It doesn't seem that mousepad supports syntax-highlighting. I think you may need to install a different text editor if you want that feature.
gedit seems to be available, and is known to work. (if you find the highlighting to be strange for G-code then there is a better scheme available at cnclub.ru)
Replied by andypugh on topic color coded text editor
The following user(s) said Thank You: JRied
- ArcEye
- Thank you received: 758
17 Sep 2014 13:38 #51259
by ArcEye
Replied by ArcEye on topic color coded text editor
Hi
sudo apt-get install gedit gedit-plugins
will get you back to the way you were with Ubuntu
A couple of the plugins are only in the jessie repo, depends what you use as to whether you need to backport it.
There are a few highlighting schemes for gcode, including the one Andy linked to
- ArcEye
17 Sep 2014 22:05 - 17 Sep 2014 22:07 #51272
by ArcEye
See this wiki
wiki.linuxcnc.org/cgi-bin/wiki.pl?Highlighting_In_Gedit
and this is what andy refered to
cnc-club.ru/forum/viewtopic.php?f=33&t=80
Last edit: 17 Sep 2014 22:07 by ArcEye.
