Encoder Voltage?
- Thank you received: 1467
18 Jul 2015 00:17 #60698
Encoder Voltage? was created by Todd Zuercher
I am trying to replace a control that died and had to change the drive too. I picked up an AMC DR100EE30A40NAC
link to the spec sheet for the drive
www.a-m-c.com/download/datasheet/dr100ee30a40nac.pdf
Like most drives this is set up for 5v encoder (either single or double ended).
The problem is that the encoder from the old system was set up using a 10v single ended signal. The old encoder was an Eltra EH63GB500S8/24P10X3PR8
link to the encoder specs
rankinusa.com/products/files/932e6_15.%20EH-EF%2080%20C-P-K.pdf
Any one know if there is an easy way to make this encoder work with this drive?
- Thank you received: 5291
18 Jul 2015 02:46 #60706
Replied by PCW on topic Encoder Voltage?
Looks like the outputs are push pull at the supply voltage (10v?)
so a low impedance 2 --> 1 voltage divider should work
Say two 330 Ohm 1/4 W resistors in series for each 10V output signal:
10V-QUADA --> R1.1 --> R1.2, AMC input, R2.1 --> R2.2 --> GND
10V-QUADB --> R3.1 --> R3.2, AMC input, R4.1 --> R4.2 --> GND
The following user(s) said Thank You: Todd Zuercher
19 Jul 2015 23:48 #60763
Replied by Todd Zuercher on topic Encoder Voltage?
I'm no electronics expert, just trying to understand why your suggesting two 330ohm in series rather than one 660?
20 Jul 2015 05:11 #60767
because we are making a voltage divider with 2 resistors
20 Jul 2015 09:25 #60771
That makes more sense. 2 resisters making one voltage divider per input. Your first messages appeared (to me) to be suggesting 4 resistors per voltage divider. That was the part that confused me. Maybe you were referring to the two contacts on the 1st resister as R1.1 and R1.2. I read it as 2 separate resisters.
20 Jul 2015 11:28 #60772
sorry, R.1.1 is netlist shorthand for R1 pin 1
Time to create page: 0.174 seconds
