save tool number in var file and load on start
10 years 11 months ago #65590 by viski
I have automatic tool changer with 12 tools. Every switch represent one tool. What do i have to do ,to save current tool into .var file and to be loaded when emc start , to avoid tool changer indexing(ref) ?
10 years 11 months ago #65596 by ArcEye
At the end of your code run
#4999=#5400
Current tool is already in #5400 but it is volatile
If #4999 is in your var file it will be preserved
Next start up run
M61 Q#4999
The following user(s) said Thank You: Shu
10 years 11 months ago #65627 by viski
I have found this about parameters:
System Parameters
#<_current_tool> - Return number of the current tool in spindle. Same as #5400.
#4999=#5400
.... can i make assigment in classicladder ?
Where to put M61 Q#4999 into ini file to auto run code?
10 years 11 months ago #65653 by ArcEye
No idea, but why would you want to, doing it in gcode is simple.
There is no provision in the ini file for that.
You could put the code in one of the ini file halui MDI strings and connect via a flipflop say to the last homed of your axes
via the haui.axis.N.ishomed, so that the tool would be set when you home all axes for the first time.
Time to create page: 0.256 seconds
