latency 2.7.2 install on Raspberry Pi
- tjmarch
- Thank you received: 22
First results screen shot of latency-test
Second results screen shot latenct-plot
Third results screen shot latency-histogram
I would like to use a Mesa 7i92 everything I/O Ethernet card
Results seem to very allot between programs are these programs each using a different scale?
Also I have observed that when a latency test is started there is a spike then thing settle down I was able to capture this spike in screen shot provided in latency-plot. Latency-plot shows good results just not sure what to believe with such a difference in each test.
If someone could please take a look at these result and explain, it would be appreciated
Tim March
- Thank you received: 5326
(the RPI2 looks like it is having big troubles running the 40 KHz base thread)
Also the RPI2 Ethernet is not suited to real time since its conveyed over a USB interface
- tjmarch
Thanks for the quick reply. After studying pic's in my previous post more, I see last intervals base thread in latenct-test was 11667us. which makes more sense to me now for what I was seeing in latency-histogram which was around 1E4 (10000us). But I still can not wrap my head around latency-plot which shows base thread max less than 100us.
The site where I downloaded Sd card image,
docs.emlid.com/navio/Downloads/Real-time-Linux-RPi2/
claims latency readings of around 100us and has graph at above link.
If anyone is reading this only problem is image has no desktop but is easy to add, I used xfce.
I did not know about problem with Ethernet on Rpi thank-you for pointing that out. Will not waste much more time on Rpi am thinking of buying a different board I have some Amozon x-mass gift money to spend. I like this board, your thoughts PCW.
www.amazon.com/dp/B012RLN51A/ref=wl_it_d...oliid=I1SBHFKXIUKA4F
Should be able to run same image file, if kernel in image used is not set up to use 1000Mbps Ethernet should fall back to 10/100, that will work correct?
Also was wondering PCW said,
I would run the latency histogram without the base thread or with a much slower base thread
I plain on using Mesa 7i92 with a 5 axis BOB and stepping, so am only interested in base thread. But why did think Rpi was having trouble with base thread, it is because of multiple peaks in latency-histograph? Plus what would the syntax be to start latency-histogram from command line at slower KHz and what Khz would you recommend.
I know lots of questions, sorry, thanks in advance
Tim March
You can get all the latency-histogram command line options with:
latency-histogram --help
- tjmarch
Ok looks like I need to do some more reading I thought base thread was important for running stepper motors.
Tim march
These are done in hardware on the 7I92, effectively the basethread is the 7I92s low speed clock
(100 MHz)
- jepler
- User is blocked
- Thank you received: 33
- tjmarch
I am currently at work will not pull trigger on buying new board until I see how servo thread works out on Rpi
but was able to run
In Vm on my work laptop so syntax is
latency-histogram --nobase
To run without Base Thread
I do not see option to lower or change Khz in help screen
Usage:
latency-histogram --help | -?
or
latency-histogram [Options]
Options:
--base nS (base thread interval, default: 25000, min: 5000)
--servo nS (servo thread interval, default: 1000000, min: 25000)
--bbinsize nS (base bin size, default: 100
--sbinsize nS (servo bin size, default: 100
--bbins n (base bins, default: 200
--sbins n (servo bins, default: 200
--logscale 0|1 (y axis log scale, default: 1)
--text note (additional note, default: "" )
--show (show count of undisplayed bins)
--nobase (servo thread only)
--verbose (progress and debug)
Notes:
Linuxcnc and Hal should not be running, stop with halrun -U.
Large number of bins and/or small binsizes will slow updates.
For single thread, specify --nobase (and options for servo thread).
Measured latencies outside of the +/- bin range are reported
with special end bars. Use --show to show count for
the off-chart [pos|neg] bin
- tjmarch
Thank-you for help
Got out of work and tried latency test I am happy with results going to purchase other board below are screen shots of test.
Worth noting a little message box pops up about memory usage during latency-plot if you close it , latency-plot will also shut down. Must be because base thread is being used. Also tried isolcpus=1,2,3 in /boot/cmdline.txt latency was a little better but system bogged way down.
Tim
- tjmarch
www.amazon.com/gp/product/B0121A5Q5U?psc...i_detailpage_o07_s00
Have it setup with Debian Wheezy, XFCE and linuxcnc 2.7.4 the Raspberry PI image would not work with this board. I have compiled latest stable kernel from kernel.org, (4.4.1) with RT PREEMPT patch and installed system to sdcard. Test are very promising, I have a little more work to do with it here are some screen shots, Latency-histogram without base running for just over a hour plus latency plot. Banana board acks the same as Raspberry seems to have trouble running base thread. But banana board has no warnig message about memory usage.
