  • Hartwig
  • Hartwig
15 Aug 2025 12:13 - 16 Oct 2025 18:24
MESA 7i97 - connection of DC TachMotor amplifiers - power supplies
Dear members,
my MESA card has arrived. It would be nice, if you could give me some information and direction, My questions are:
#1 Can I use every simple and cheap 5 VDC plug-in power supply unit or is a special quality required? How many Amps are needed?
#2 My DC Tacho-Motor amplifiers need an input signal from 0 - 10 VDC for the speed, I would assume, that I have to supply also something like 12 VDC to the MESA card so that the card can provide the +.10V output on TB3 PINs 4, 8 etc.  -  or where does the card get the 10VDC power from?
#3 My DC motor amplifiers (Mattke M1Q 24/5) connections are shown as below. The power for the amplifier and the DC Servo-Motor is provided separately. The only connection to the MESA should be the "Enable+" PIN to KL 8 and the 0-10 VDC set-value to the KL 7 - right?
Is there any critical interference between the GND of the MESA and the GND of the amplifier (because of KL7) to be feared ?
How can the direction of the DC-motor be reversed - would I need some relais to change the motor input cables for the case, that "Enable-" is activated?
Thanks a lot and best regards
Hartwig
  • rodw
  • rodw's Avatar
15 Aug 2025 09:49
Replied by rodw on topic Leadshine EL7-EC400N ethercat error 818
Category: EtherCAT
My XML config is for Rtelligent drives so it will need reworking for your drives
  • rodw
  • rodw's Avatar
15 Aug 2025 08:43
Replied by rodw on topic Search for Google document from rodw
@Marc_P, did you get the document?
  • aDm1N
  • aDm1N's Avatar
15 Aug 2025 07:40
Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Category: Installing LinuxCNC
Until the official source supports Debian 13, I quickly created the .deb files and created a repo. It works for me. Feel free to test it to see if it works on other computers; then you'd have a temporary alternative to Debian 13.
apt.dryba.com/
  • unknown
  • unknown
15 Aug 2025 07:01
Replied by unknown on topic Debian Trixie upgrade/install to 2.9.4
My Odroid H2 is now on Trixie.
Insalled rt headers, r8125-dkms, blacklisted r8169.
Touchscreen works.
  • Hakan
  • Hakan
15 Aug 2025 06:37 - 15 Aug 2025 06:39
Replied by Hakan on topic initCmds examples?
initCmds examples?
Category: EtherCAT
Follow the last line here github.com/linuxcnc-ethercat/linuxcnc-et...uration-reference.md
Example of sdoconfig
    <slave idx="0" name="X" type="generic" vid="00000a88" pid="0a880002" configPdos="true">
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
      <sdoConfig idx="2000" subIdx="0"><sdoDataRaw data ="a0 0f"/></sdoConfig>  <!-- Max motor current (3.0A=b80b 4.0=a00f 5.0=8813) Rated=4.0A -->
      <sdoConfig idx="2003" subIdx="0"><sdoDataRaw data ="64 00"/></sdoConfig>  <!-- Standby current percentage (100%) -->
      <sdoConfig idx="2011" subIdx="0"><sdoDataRaw data ="01 00"/></sdoConfig>  <!-- Closed loop -->
      <sdoConfig idx="2023" subIdx="1"><sdoDataRaw data ="a0 0f"/></sdoConfig>  <!-- Kp=4000 (def=2000) -->
      <syncManager idx="2" dir="out">
What's tricky is the byte order of the data. LSB first, so "1" becomes "01 00" and so on.
  • Kieran
  • Kieran
15 Aug 2025 06:08
initCmds examples? was created by Kieran
initCmds examples?
Category: EtherCAT
Does anyone have examples of initCmds or sdoconfig? i want to try sending my drives SDOs to set some parameters but am struggling to figure out how exactly to create a proper XML to call using initCmds, or alternatively how to format/add some lines with sdoConfig in my main XML. the whole index/ sub index thing also confuses me (like how does one know what syncmanager idx it should be Ect...) . If anyone has a dummys guide to how all the ethercat address stuff works LMK. It seems linuxcnc uses its own special formatting compared to "normal" ethercat XML? anyway, I want to try setting my servos to absolute mode (i have batteries on the encoders) through the SDO.
  • Hakan
  • Hakan
15 Aug 2025 05:47
New EtherCAT Slave Devices REAL data to HAL
Category: EtherCAT
I would look at the datatypes in the MCU and make sure they are right there.
Linuxcnc reads out this info from the board/mcu.
Can't see from the video but looks like LAN9252 plus mcu.
Then this info comes from the mcu, not the eeprom or esi file.
  • meister
  • meister
15 Aug 2025 05:45
> Just wondering if the existing tang primer 20K plugin will work for the tang primer 20k Lite board?
works !
  • rhscdn
  • rhscdn
15 Aug 2025 03:15
Replied by rhscdn on topic AXYZ retrofit - Stepper driver settings
Category: CNC Machines
Thanks! I really appreciate all the advice. Will give it a try tomorrow and report back.
15 Aug 2025 03:01
Replied by tommylight on topic AXYZ retrofit - Stepper driver settings
Start with generic values, should be 5000/5000, direction is not important so leave it at 20000.
You can safely try Gecko settings, mark the motor pulley/shaft with a marker and set it to go back and forth several turns and several times, see if it returns exactly where you marked it, if it misses even by a very small bit, do not use those settings on a production machine.
  • epineh
  • epineh
15 Aug 2025 02:59 - 15 Aug 2025 03:01
Just wondering if the existing tang primer 20K plugin will work for the tang primer 20k Lite board? It is a simpler board than the dev board and has 117 available IO. It's not a great deal more expensive than the nano9k.
  • rhscdn
  • rhscdn
15 Aug 2025 02:47 - 15 Aug 2025 03:26
I have minimal documentation on the AXYZ stepper drives (AXI 2200 microstepper). I have a wiring diagram and some calibration data for the machine size, steps/mm, velocity and acceleration. However, I don’t have specs on the drive step timing (ie step time, step space, dir hold, dir setup) in nanoseconds.
Is it safe to just try a few of the pre-configured Geko drives and see what happens? Overall, how big of
an issue is this and what are my options to figure it out?
  • PCW
  • PCW's Avatar
15 Aug 2025 00:16 - 15 Aug 2025 00:19
System hangs repeatedly with certain combinations of operations
Yes, G1 moves are controlled by the feed rate but G0 moves are at full machine speed
Also multi-axis G1 are coordinated but G0 moves are not.
You  could use some logic (say not + or components) or the lut5 component
in conjunction with your external spindle-at-speed signal to force  spindle-at-speed
true either when the spindle is on and the external spindle-at-speed is true or
the spindle is off.
A lut5 example might look like this:
setp lut5.0.function 0x0d
net spindle-on lut5.0.in-0
net ext_spindle-at-speed lut5.0.in-1
net spindle-at-speed lut5.0.out
A lut5 function value of 0x0d means it's output will be true either when in-0
(spindle-on) is false or if both in-0 (spindle-on) is true and in-1 (ext-spindle-at-speed)
are true.
man lut5
  • Jonathan_H
  • Jonathan_H
14 Aug 2025 23:08
If I understand what I've just read correctly, G0 moves are full speed, whereas G1 are controlled?
This would explain why the tool change/probing code I used as the basis for mine uses G1 calls.
However if it is only the first feed move after the spindle start that matters then I may be able to work around it by making the first move a rapid one?
I'll have a look at whether there's a way to have a "true" value when it is stopped anyway.
Displaying 13666 - 13680 out of 14177 results.
Time to create page: 0.701 seconds
