  • rhscdn
  • rhscdn
14 Aug 2025 03:07 - 14 Aug 2025 03:13
Axyz retrofit - spindle wiring 7i96 was created by rhscdn
Category: CNC Machines
I think I have wrapped my head around my stepper motor and limit switch wiring. Regarding the spindle, I have a few questions:
The inverter is a woods eTrac x2c and the manual offers a nearly overwhelming number of options. I was never able to see the spindle working with the stock
AMC controller. I have attached the relevant table from the inverter manual and it seems like I should be able to use the analog spindle interface to provide 0-5vdc signal for speed control (vin). Do I simply use inputs on the 7i96 to conteol fwd/rev and a ground connected to the inverter common? Is that all there is to it?
The original wiring from the AMC controller to the inverter is somewhat different and it isn’t obvious that the AMC was actually able to control the spindle speed. It is connected to use 4 preset spindle speeds and the AMC has wires indicating an acceleration/deceleration signal, as well as some connections to NO and RCM.
  • KaveMan
  • KaveMan
14 Aug 2025 02:18
Replied by KaveMan on topic Raspbery pi5 pcie adapter to parport card
Thanks. I tried all three variants on both parport cards. Did not work.
Let's not spend any more time on this. appreciate everyone's time and effort.
I'll likely jump back in this fall when I have more time.
14 Aug 2025 01:35
System hangs repeatedly with certain combinations of operations
I deleted my previous post as i missed a crucial point, sorry for the confusion.
  • rodw
  • rodw's Avatar
14 Aug 2025 00:42
Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Category: Installing LinuxCNC
Possibly. I have not tried it but it will be up to the devs to increment the Python version. I thought that would have been done as linuxcnc 2.9.4 is in Debian 13 natively.
  • PCW
  • PCW's Avatar
14 Aug 2025 00:02
M3 S10000 ; works, spindle starts and spins up
M5 ; works, spindle stops
G53 G1 F4000 Z-10 ; Spindle does not move and GCode interpreter seems to be hung!
Is spindle-at-speed true? if not, pretty sure this will hang waiting for spindle-at-speed to be true.
  • PCW
  • PCW's Avatar
13 Aug 2025 23:34
Wiring encoder to LinuxCNC + Mesa vs motor controller
Category: Driver Boards
One advantage, If you have step/dir servos, returning the position information to LinuxCNC
allows LinuxCNC to monitor the actual following error during operation.
13 Aug 2025 23:28 - 14 Aug 2025 01:34
DELETED as i missed a crucial point so my reply was not correct.
See PCW's reply below
  • Jonathan_H
  • Jonathan_H
13 Aug 2025 23:11
OK, so an update on this issue.
Tonight I had some time to isolate where the problem is happening, and I can bring it down to just a couple of commands.
I start up Linux CNC, toggle the CNC on and home it, this is my start point.
Now in the MDI window I type the following
G53 G1 F4000 Z-10 ; This works, carriage moves down
G53 G1 F4000 Z0 ; This works, carriage moves up
I can repeat the above multiple times, the carriage moves up and down as expected.
BUT, if I type the following (either after typing the above or after a clean start)
On the console I see the following output
mdi_execute_hook: MDI command 'M5' done (remaining: 0)
Issuing EMC_TASK_PLAN_EXECUTE --      (  +509,+280,   +23,G53\032G1\032F4000\032Z-10,)
emcTaskPlanLevel() returned 0
NML_INTERP_LIST(0x55afd11daa60)::append(nml_msg_ptr{size=208,type=EMC_TRAJ_LINEAR_MOVE}) : list_size=1, line_number=0
emcTaskPlanExecute(G53 G1 F4000 Z-10) returned 0
NML_INTERP_LIST(0x55afd11daa60)::get(): {size=208, type=EMC_TRAJ_LINEAR_MOVE}, list_size=0
Issuing EMC_TRAJ_LINEAR_MOVE --      (  +220,+208,    +0,605.000000,400.000000,-10.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,    +2,25.000000,25.000000,750.000000,    +0,    -1,)
I've attached the full console output from the linuxcnc command
File Name: console_wh...8-13.txt
File Size:2 KB
13 Aug 2025 22:23
Replied by tommylight on topic PathPilot V2 source code
Category: PathPilot
Oh good, and oh .... i don't know....
13 Aug 2025 22:16
Replied by tommylight on topic Axyz retrofit - limits and homing
Yes that is it, and sorry forgot to mention, read until Host Interface section.
  • rhscdn
  • rhscdn
13 Aug 2025 20:57 - 13 Aug 2025 22:07
Replied by rhscdn on topic Axyz retrofit - limits and homing
Thanks for the reply. I have LinuxCNC installed on a computer now but I’m still waiting for the Mesa card to arrive (should be this week). When you wrote ‘Mesa manual’ do you mean the ‘7i96s Ethernet Step/Dir Motion control interface’ document? If so, I’ve read it but will admit to not fully understanding all of it (yet).
  • phino
  • phino
13 Aug 2025 20:44
Oh! I thought feedback would be required for coordinated motion.
What are the limitations or benefits without/with encoder feedback to LinuxCNC+Mesa?
  • Hakan
  • Hakan
13 Aug 2025 20:41
What difference between DC mode and free-run mode in motor control?
Category: EtherCAT
Yes, to have all servos/drives start acting on new data/position data at the same time.
For servos and drives you want distributed clock mode.
The following error in LinuxCNC with EtherCat is somewhat superficial.
If the drive offers a following error, use that, if possible.
  • scotta
  • scotta's Avatar
13 Aug 2025 20:30
Remora - Compile warnings when compiling spi linuxcnc component
Hi Mars,
Great to hear that you are giving Remora a try. Those are just warnings, and can be ignored.
  • Benb
  • Benb's Avatar
13 Aug 2025 20:28 - 13 Aug 2025 20:30
Replied by Benb on topic Switch relay in a defined x position
Let see if I grasp the concept. You have an existing reed switch that detects that the support is in extended position and you like stop all axis from moving when switch is active.
1) Wire the reed switch to your mesa digital input.
2) Load the new revised .comp file
3) You may need the change operations by changing the state of pins. for example, trigger=1; to trigger=0; same for halt and reedsw.
Attached is revised the revised spinport.comp
Displaying 13741 - 13755 out of 14177 results.
Time to create page: 0.521 seconds
