  • dogsop
  • dogsop
06 Jan 2025 23:33
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
Are the images you post here the same ones that are on the Linuxcnc download pages for the RPi's?
Thank you
  • sajurcaju
  • sajurcaju
06 Jan 2025 22:57
Replied by sajurcaju on topic Adding a linefeed to a gcode line
Category: AXIS
Weird. I tried it as you wrote, with just the G64/G4 on one line (other commands removed). I still get the error. I'm using Axis 2.8.4-76-g6082f1df7.
Aciera, I will try the subroutine and report back when I get a chance.
  • phillc54
  • phillc54's Avatar
06 Jan 2025 22:50
Replied by phillc54 on topic Adding a linefeed to a gcode line
Category: AXIS
It works for me in master branch on the axis_mm sim using f-engrave 1.75
  • gardenweazel
  • gardenweazel's Avatar
06 Jan 2025 22:09
Replied by gardenweazel on topic QTDesigner PATH issue
I get the same error as I initially reported.
It's also reporting:
WARNING: Recursive promotion of  "IndicatedPushButton"  to  "ActionButton" . A plugin is missing.
for each of the plugins used by qtvcp.
andy@file03:~/linuxcnc-dev/lib/python/qtvcp/plugins$ ls -la
total 244
drwxr-xr-x 3 andy andy  4096 Jan  6 15:57 .
drwxr-xr-x 7 andy andy  4096 Oct 19 14:09 ..
-rw-r--r-- 1 andy andy 52049 Oct 29  2023 actionbutton_plugin.py
-rw-r--r-- 1 andy andy  1193 Oct 29  2023 bar_plugin.py
-rw-r--r-- 1 andy andy  1249 Oct 29  2023 basic_probe_plugin.py
-rw-r--r-- 1 andy andy  1329 Oct 29  2023 camview_plugin.py
-rw-r--r-- 1 andy andy  2611 Oct 29  2023 container_plugin.py
-rw-r--r-- 1 andy andy  1319 Oct 29  2023 detach_tabs_plugin.py
-rw-r--r-- 1 andy andy 12231 Oct 29  2023 dialog_plugin.py
-rw-r--r-- 1 andy andy  1281 Oct 29  2023 graphics_plugin.py
-rw-r--r-- 1 andy andy  1234 Oct 29  2023 hal_label_plugin.py
-rw-r--r-- 1 andy andy   201 Oct 29  2023 __init__.py
-rw-r--r-- 1 andy andy  1377 Oct 29  2023 jogincrements_plugin.py
-rw-r--r-- 1 andy andy  2228 Oct 29  2023 joypad_plugin.py
-rw-r--r-- 1 andy andy  1289 Oct 29  2023 led_plugin.py
-rw-r--r-- 1 andy andy  1279 Oct 29  2023 nurbs_editor_plugin.py
-rw-r--r-- 1 andy andy  1368 Oct 29  2023 overlay_plugin.py
drwxr-xr-x 2 andy andy  4096 Jan  6 15:57 __pycache__
-rw-r--r-- 1 andy andy  2846 Sep 22 17:17 qtvcp_plugin.py
-rw-r--r-- 1 andy andy  1305 Oct 29  2023 round_gauge_plugin.py
-rw-r--r-- 1 andy andy  1495 Oct 29  2023 round_progress_bar_plugin.py
-rw-r--r-- 1 andy andy  6151 Oct 29  2023 screenoptions_plugin.py
-rw-r--r-- 1 andy andy 24049 Oct 29  2023 simplewidgets_plugin.py
-rw-r--r-- 1 andy andy  1359 Oct 29  2023 state_label_plugin.py
-rw-r--r-- 1 andy andy  1329 Oct 29  2023 state_led_plugin.py
-rw-r--r-- 1 andy andy  1490 Oct 29  2023 status_adjustment_bar_plugin.py
-rw-r--r-- 1 andy andy 19973 Oct 29  2023 status_label_plugin.py
-rw-r--r-- 1 andy andy  1379 Oct 29  2023 status_slider_plugin.py
-rw-r--r-- 1 andy andy  1746 Oct 29  2023 tab_widget_plugin.py
-rw-r--r-- 1 andy andy  2525 Oct 29  2023 toolbutton_plugin.py
-rw-r--r-- 1 andy andy  1249 Oct 29  2023 versa_probe_plugin.py
-rw-r--r-- 1 andy andy  1316 Oct 29  2023 virtualkeyboard_plugin.py
-rw-r--r-- 1 andy andy  1155 Oct 29  2023 web_widget_plugin.py
-rw-r--r-- 1 andy andy 13469 Oct 29  2023 widgets_plugin.py
  • Murphy
  • Murphy
06 Jan 2025 22:02
Thanks Cakeslob I entered some of your hal file in mine for the spindle rpm. The spindle seems to be working a lot smoother than before. I also have the rpm displaying now.
Iv ordered a Chinese clone differential line encoder. So I'll single end it with an AM26ls32 IC. Hopefully that will get rid of the noise
  • ihavenofish
  • ihavenofish
06 Jan 2025 21:39
Replied by ihavenofish on topic Resolution and speed with servo motor
gah. yes, i got those backwards.
"nevermind'
  • PCW
  • PCW's Avatar
06 Jan 2025 21:31
Replied by PCW on topic Resolution and speed with servo motor
Direction setup and hold timing should have no effect on maximum speed
as the direction is only changed at zero velocity. Step length and Step space
do affect the maximum step rate.
  • ihavenofish
  • ihavenofish
06 Jan 2025 21:13
dirhold and dirsetup are the restrictions i think
I have the same issue on mine. I had to increase them to 20000 which in turn restricted my top speed to 12m/m (with my screw and steps per turn of course)
I need to refine this. 5000 drops steps, but 20k is overkill.
60000 seems very extreme. is there a reason you have it set that high?
  • Martin.L
  • Martin.L
06 Jan 2025 21:12
Exercise: Turn on output led on EL2809 when machine is turned on
Category: EtherCAT
I have spent a lot of time reading the manual but unfortunately I could not put togheter all the pieces to come up with a solution, I'm pretty new to LCNC and I would like to learn by doing, had the idea to turn on an output led on EL2809 when machine is turned on. (have succesfully installed following Rodw guide)
In HalShow I can turn on and off the led my hand with SET CLR buttons, so it works manually.
I found this info : motion.motion-enabled - (bit, out) TRUE when in machine on state.
Also from the manual: 5.2.1.4 net
The command net creates a connection between a signal and one or more pins. If the signal does not
exist net creates the new signal. This replaces the need to use the command newsig. The optional
direction arrows <=, => and <=> make it easier to follow the logic when reading a net command line
and are not used by the net command. The direction arrows must be separated by a space from the
pin names.
Syntax and Examples of net
net signal-name pin-name <optional arrow> <optional second pin-name>
net home-x joint.0.home-sw-in <= parport.0.pin-11-in
So I guess I have to combine these two, but I have no Idea how to do it.
Please Help!
  • Aciera
  • Aciera's Avatar
06 Jan 2025 20:53
Replied by Aciera on topic 2.9.3 INI_VARS issue
Just went back to current master and I can confirm that the problem is the lowercase variable (or key) name 'z_tool'.
1. A lowercase variable (key) name in the ini file is ignored (eg 'z_tool = 1').
2. If you then want to read the lowercase variable (eg #<_ini[TOOLSETTER]z_tool>) the value is not found because it was never created
3. if you assign a value (eg: #<_ini[TOOLSETTER]z_tool> = 1.2) you actually create a global named parameter
So the key is to ALWAYS use uppercase variables (keys) in the ini file (which should probably be noted somewhere in the documentation)
  • Masiwood123
  • Masiwood123's Avatar
06 Jan 2025 20:35
Replied by Masiwood123 on topic Fehlmann Picomax 100 Retrofit
Category: Milling Machines
Hello, can you tell me if limit switches are NO or NC 24vdc...I have a similar machine and I am trying first of all to bring it to the factory control.. it throws out errors that one of the limit switch is on , control allows me to reference    to the z axis, xy will not reach the switches. linear scale on x is also filled with dirt and have to figure out how to clean it. thank you very much
  • blazini36
  • blazini36
06 Jan 2025 20:30
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Wow that was quick. I'll check that out soon
  • Aciera
  • Aciera's Avatar
06 Jan 2025 20:24
So it seems to me that it does not like the lowercase entry in the ini file:
z_tool = -1
If I change this to
Z_TOOL = -1
I get the expected behavior.
  • shipmodeller
  • shipmodeller's Avatar
06 Jan 2025 20:01
Replied by shipmodeller on topic 2.9.3 INI_VARS issue
Ok, thanks for verifying the issues I was having...
  • shipmodeller
06 Jan 2025 20:00
I followed your Debug patterns in attachment
Displaying 20491 - 20505 out of 21729 results.
Time to create page: 0.462 seconds
