Flexible GUI
06 Jan 2025 11:54 #318209 by blazini36
Replied by blazini36 on topic Flexible GUI
Oh and is there any way to use a progress bar for something like spindle speed feedback? I don't see progressbar in the docs
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
06 Jan 2025 12:16 #318211 by JT
Replied by JT on topic Flexible GUI
Is there any mechanism to use a qstackedwidget and some pushbuttons instead of the tab widget? I suppose you generally need to stuff some python in there to use the former.
So yes you can use a QStackedWidget now.
JT
  • JT
  • Administrator
  • Administrator
06 Jan 2025 12:52 #318212 by JT
Can stuff like "view_dro_cb" be a pushbutton that is set to checkable rather than a checkbox?
You can now and no need to set it checkable in the designer the code does that for you.
JT
  • JT
  • Administrator
  • Administrator
06 Jan 2025 12:53 #318213 by JT
I'll have to add a HAL QProgressBar... then you can connect it in your postgui.hal file.
JT
  • JT
  • Administrator
  • Administrator
06 Jan 2025 14:00 #318223 by JT
I've added a QProgressBar to monitor the HAL pin you give it.
gnipsel.com/linuxcnc/flexgui/hal.html#progress-bar
No time left this morning for a video...
JT
06 Jan 2025 20:30 #318259 by blazini36
Wow that was quick. I'll check that out soon
07 Jan 2025 00:50 #318275 by blazini36
I installed the new deb from releases but it doesn't seem to be adding anything new. I don't have qabstractproperties on the pushbutton whether I set it inside the stacked widget or not. Do I have to do anything special when upgrading flexgui?
  • JT
  • Administrator
  • Administrator
07 Jan 2025 11:20 #318288 by JT
I'm not sure what qabstractproperties is, what are you trying to do with that?
If you download the deb from the latest release and install it with gdebi or your favorite way you have the latest.
I'll add a screenshot to the docs.
JT
  • JT
  • Administrator
  • Administrator
07 Jan 2025 11:44 #318293 by JT
The first video really didn't show the steps to create a stacked widget page change buttons very well.
And I added a screen shot to the docs
gnipsel.com/linuxcnc/flexgui/controls.html#stacked-widget
JT
  • JT
  • Administrator
  • Administrator
07 Jan 2025 13:09 #318298 by JT
As an added bonus I just added Next Previous buttons for a stacked widget so you only need two buttons for unlimited number of pages.
JT
Moderators: JT
Time to create page: 0.167 seconds
