Flexible GUI
- blazini36
- Thank you received: 167
06 Jul 2024 13:51 #304541
by blazini36
Replied by blazini36 on topic Flexible GUI
lol it's one page back in this thread, you replied to it.
- tlightus
- Thank you received: 19
07 Jul 2024 03:08 - 07 Jul 2024 03:12 #304561
by tlightus
Replied by tlightus on topic Flexible GUI
Last edit: 07 Jul 2024 03:12 by tlightus. Reason: added where to find them
The following user(s) said Thank You: tommylight, stefan63
- MennilTossFlykune
- Thank you received: 30
28 Jul 2024 23:36 - 28 Jul 2024 23:42 #306293
by MennilTossFlykune
Replied by MennilTossFlykune on topic Flexible GUI
In the plot widget, to automatically reload a file when an offset has changed you could maybe use the fingerprint
For example:
files.catbox.moe/5km48d.mp4
For example:
fingerprint = (self.logger.npts,
self.soft_limits(),
s.actual_position,
s.motion_mode,
s.current_vel,
s.joint_actual_position,
s.homed,
s.limit,
s.tool_in_spindle,
s.g5x_offset,
s.g92_offset,
s.rotation_xy,
s.tool_offset)
if fingerprint[9:12] != self.fingerprint[9:12] or s.file != self._current_file:
if self.display_loaded:
self.load()
if fingerprint != self.fingerprint:
self.fingerprint = fingerprint
self.update()
Last edit: 28 Jul 2024 23:42 by MennilTossFlykune. Reason: couldn't embed video
The following user(s) said Thank You: blazini36, JT
- JT
- Thank you received: 593
29 Jul 2024 13:55 - 29 Jul 2024 14:21 #306330
by JT
JT
Replied by JT on topic Flexible GUI
Can you share the whole code for what I saw in the video? For some reason the plot is not moving when I set an offset. The xyz origin marker is the only thing that moves...In the plot widget, to automatically reload a file when an offset has changed you could maybe use the fingerprint
For example:
files.catbox.moe/5km48d.mp4fingerprint = (self.logger.npts, self.soft_limits(), s.actual_position, s.motion_mode, s.current_vel, s.joint_actual_position, s.homed, s.limit, s.tool_in_spindle, s.g5x_offset, s.g92_offset, s.rotation_xy, s.tool_offset) if fingerprint[9:12] != self.fingerprint[9:12] or s.file != self._current_file: if self.display_loaded: self.load() if fingerprint != self.fingerprint: self.fingerprint = fingerprint self.update()
JT
Last edit: 29 Jul 2024 14:21 by JT.
- blazini36
29 Jul 2024 19:40 #306356
by blazini36
Any chance you can share the whole configuration you have shown in your post a couple pages back? That looks pretty good. I've been pecking at a Flex UI for a bit but haven't gotten very far yet.In the plot widget, to automatically reload a file when an offset has changed you could maybe use the fingerprint
For example:
fingerprint = (self.logger.npts, self.soft_limits(), s.actual_position, s.motion_mode, s.current_vel, s.joint_actual_position, s.homed, s.limit, s.tool_in_spindle, s.g5x_offset, s.g92_offset, s.rotation_xy, s.tool_offset) if fingerprint[9:12] != self.fingerprint[9:12] or s.file != self._current_file: if self.display_loaded: self.load() if fingerprint != self.fingerprint: self.fingerprint = fingerprint self.update() https://files.catbox.moe/5km48d.mp4
- JT
29 Jul 2024 22:20 #306367
by JT
Ok, I did figure out that I can't test the plotter with a sim running. Everything works as it should when I run from installed.
I still would like to look at your code if possible.
JT
JT
- MennilTossFlykune
30 Jul 2024 00:00 - 30 Jul 2024 00:06 #306370
I wanted to be able to test it in qtdragon so it's PyQt5 instead
This one does work as a standalone window
Last edit: 30 Jul 2024 00:06 by MennilTossFlykune. Reason: attached wrong file
- MennilTossFlykune
30 Jul 2024 23:52 #306451
I don't think I have it anymore. It was based on Persei8's QtDragon version but when the plotter stuff is all working I'll modify the standard QtDragon UI instead.Any chance you can share the whole configuration you have shown in your post a couple pages back? That looks pretty good. I've been pecking at a Flex UI for a bit but haven't gotten very far yet.
- JT
31 Jul 2024 12:20 #306512
by JT
JT
JT
The following user(s) said Thank You: tommylight, MennilTossFlykune
- MennilTossFlykune
01 Aug 2024 04:24 #306581
This should all work:
view_controls = {
'view_rotate_up_pb': ('rotateView', 0, -10),
'view_rotate_down_pb': ('rotateView', 0, 10),
'view_rotate_left_pb': ('rotateView', 10, 0),
'view_rotate_right_pb': ('rotateView', -10, 0),
'view_pan_up_pb': ('panView', 0, 10),
'view_pan_down_pb': ('panView', 0, -10),
'view_pan_left_pb': ('panView', 10, 0),
'view_pan_right_pb': ('panView', -10, 0),
'view_zoom_in_pb': ('zoomin',),
'view_zoom_out_pb': ('zoomout',),
'view_clear_pb': ('clear_live_plotter',)
for key, value in view_controls.items():
if key in parent.children:
button = getattr(parent, key)
if len(value) == 3:
method, vertical, horizontal = value
button.clicked.connect(lambda _, m=method, v=vertical, h=horizontal: (
getattr(parent.plotter, m)(vertical=v, horizontal=h)
elif len(value) == 1:
method = value[0]
button.clicked.connect(lambda _, m=method: (
getattr(parent.plotter, m)()
views = {
'view_p_pb': 'p',
'view_x_pb': 'x',
'view_y_pb': 'y',
'view_y2_pb': 'y2',
'view_z_pb': 'z',
'view_z2_pb': 'z2'
for key, value in views.items():
button.clicked.connect(lambda _, v=value: (
parent.plotter.makeCurrent(),
setattr(parent.plotter, 'current_view', v),
parent.plotter.set_current_view()
Moderators: JT
Time to create page: 0.603 seconds
