Flexible GUI
- JT
- Thank you received: 593
25 Apr 2024 13:51 #299069
by JT
Replied by JT on topic Flexible GUI
That's pretty cool!
JT
JT
The following user(s) said Thank You: MennilTossFlykune
- MennilTossFlykune
- Thank you received: 30
26 Apr 2024 17:03 #299125
by MennilTossFlykune
Replied by MennilTossFlykune on topic Flexible GUI
The following user(s) said Thank You: Roguish, tommylight, besriworld, travis036, Grotius, blazini36, JT, rdtsc
- JT
26 Apr 2024 21:59 #299153
by JT
That's awesome!
How did you do the plotter?
JT
JT
- MennilTossFlykune
27 Apr 2024 15:48 - 27 Apr 2024 20:41 #299195
Last edit: 27 Apr 2024 20:41 by MennilTossFlykune.
The following user(s) said Thank You: tommylight, JT
- JT
07 May 2024 14:13 #300041
by JT
I've made a lot of improvements to Flex GUI in the last few weeks and with some help you can create a button, checkbutton, checkbox or radio button that controls a hal out pin. I've got almost all status labels that return a float have the precision set to 3 for metric and 4 for inch and if you specify the precision in a Dynamic Property then Flex uses that instead of the default.
JT
JT
- JT
14 Jun 2024 13:00 - 14 Jun 2024 13:14 #303006
by JT
Flex GUI is up to version 0.8.0 and includes MDI buttons now.
Flex GUI is for folks that want just what they want in a GUI, no more no less.
JT
JT
Last edit: 14 Jun 2024 13:14 by JT.
The following user(s) said Thank You: tommylight, Grotius, Aciera
- Grotius
- Thank you received: 2349
14 Jun 2024 18:58 #303018
by Grotius
Replied by Grotius on topic Flexible GUI
@JT,
In a few post earlyer you mentioned:
Qt Creator is for C++ and Qt Designer is for python.
The qt designer creates .ui files that can be used with qt creator.
The link is broken:
gnipsel.com/linuxcnc/flex/index.html
Made a new link for you:
gnipsel.com/linuxcnc/flexgui/index.html
github link
I want to say, i really like your work. A few years ago when i started linuxcnc,
i followed your gtk course gnipsel.com/glade/index.html.
I think you can also do widget overlay in the gremlin screen these days to show dro's.
The link is broken:
github link
- JT
14 Jun 2024 20:09 - 14 Jun 2024 20:10 #303023
by JT
I updated the links in the first posts.
Now if I can figure out how to code a plotter Flex GUI will be complete.
JT
JT
Last edit: 14 Jun 2024 20:10 by JT.
- Grotius
15 Jun 2024 09:33 #303042
by Grotius
@JT,
Do you want to code a new plotter or what are your ingredients?
- JT
15 Jun 2024 09:57 #303043
by JT
JT
I need to get a plotter to work with PyQt6. I would like to use OpenGL with the QOpenGLWidget. If possible use LinuxCNC libraries to parse the G code. How Flex GUI works is if a widget is found then the code is attached to it so in the case of a plotter if a container with an object name of plot_widget is found then the plotter is inserted into the plot_widget container. Any help is much appreciated.@JT,
JT
Moderators: JT
Time to create page: 0.277 seconds
