Flexible GUI
15 Jun 2024 11:41 #303045 by Grotius
Replied by Grotius on topic Flexible GUI
Ok, i will have a look coming time if i can help you a bit.
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
15 Jun 2024 21:48 #303083 by JT
Replied by JT on topic Flexible GUI
Thanks so much for looking at this.
This is the entry point for the plotter.
github.com/jethornton/flexgui/blob/maste...xgui/startup.py#L898
JT
17 Jun 2024 20:58 #303208 by Grotius
Hi Jt,
How to run the flexgui in a rip environment? qtvcp axis run's. qtvcp dependencies are installed.
I don't know where to copy the files to.
  • JT
  • Administrator
  • Administrator
17 Jun 2024 21:58 #303210 by JT
I've never tried to run flexgui in a RIP, let me experiment a bit. Heck I've not even built a RIP in years...
JT
  • JT
  • Administrator
  • Administrator
17 Jun 2024 22:18 #303211 by JT
The consistence on the IRC is just install flexgui and LinuxCNC should find it even if running a RIP.
JT
  • JT
  • Administrator
  • Administrator
18 Jun 2024 10:42 #303245 by JT
Hi Jt,
I just confirmed that when running a RIP if flexgui is installed using the deb then LinuxCNC will find it.
When I'm testing code I run sim_axis_xyzh.ini from the examples then launch flex from a terminal with ./flexgui
JT
02 Jul 2024 17:08 #304264 by tlightus
Replied by tlightus on topic Flexible GUI
FlexGUI is coming along nicely. Here are some screen shots of a UI I've included in the examples.
The following user(s) said Thank You: Grotius, JT
  • JT
  • Administrator
  • Administrator
04 Jul 2024 17:09 #304402 by JT
Started working on a Dark Side theme for keyboard use.
JT
04 Jul 2024 18:46 #304411 by blazini36
Replied by blazini36 on topic Flexible GUI
Has flex GUI officially integrated MennilTossFlykune's Gremlin approach? Might be a good idea until the other thing is working.
  • JT
  • Administrator
  • Administrator
05 Jul 2024 11:29 #304452 by JT
No, I'm not aware of it. Where is it?
JT
Moderators: JT
Time to create page: 0.405 seconds
