Flexible GUI
- JT
- Thank you received: 593
22 Jan 2025 13:58 #319638
by JT
JT
Replied by JT on topic Flexible GUI
Do you have an example of what you mean? I'm having a hard time visualizing that...The file browser is a little hard to navigate because it doesn't show the current directory, easy to get lost. Any chance you can add current directory at the top or something?
JT
- blazini36
- Thank you received: 167
22 Jan 2025 19:48 #319665
by blazini36
As for the file browser showing the current directory, just some bar at the top of the browser or maybe even a label that can display it above the file browser. Right now you see files in the directory that you are in....but you have no idea what directory you are in. I keep most of my NC files on a NAS so sometimes I move around a bit to get to the file. It's alot easier to navigate if you can see what directory you are currently browsing.
BTW, thanks for answering these questions. I can probably figure some of this out myself but that probably wouldn't help anyone else looking to work with Flex.
Replied by blazini36 on topic Flexible GUI
THEME = touch overrides my qss. I get the touch file browser back be it's using whatever qss the theme uses instead of the one I specified with QSS =. Can I add the touch style file browser to my qss?The ini entry INPUT is now THEME gnipsel.com/linuxcnc/flexgui/ini.html#themes
Which file browser, the keyboard or the touch screen?
Good point on the flood and mist and I see no reason to disable them at any time and that has been fixed.
JT
- JT
22 Jan 2025 21:48 #319679
by JT
I should be able to add the current directory to the touch file browser.
JT
From the manual gnipsel.com/linuxcnc/flexgui/ini.html THEME is checked first then QSS so the first entry found is used.
JT
As for the file browser showing the current directory, just some bar at the top of the browser or maybe even a label that can display it above the file browser. Right now you see files in the directory that you are in....but you have no idea what directory you are in. I keep most of my NC files on a NAS so sometimes I move around a bit to get to the file. It's a lot easier to navigate if you can see what directory you are currently browsing.
JT
- JT
22 Jan 2025 23:40 #319685
by JT
Sorry missed one of your questions and yes the touch screen file browser is here
gnipsel.com/linuxcnc/flexgui/touch.html#file-navigator
JT
JT
- blazini36
23 Jan 2025 09:24 #319700
by blazini36
The thing that is not really clear is that you can't use a qss file and still have any way to use the touch style widgets. It wasn't obvious until I looked in libflexgui and the python file that the THEME is just a premade qss file and the touch style widgets are just properties in the qss.
So I suppose the best way to have custom colors and the touch style stuff is just to copy the touch THEME qss out of libflexgui and stick it in the config directory, point at it with QSS and just modify it, otherwise it won't survive an update. I suppose this is probably where INPUT was going but that's probably a bit more difficult to impliment since it's written directly into the main qss.
Lol I think were moving past each other here. I see that "theme is checked first". I also have file_lw, I have the browser....that's not the issue.Sorry missed one of your questions and yes the touch screen file browser is here
JT
- blazini36
23 Jan 2025 10:58 #319703
by blazini36
I copied out the Qlistwidget from the touch theme to my qss and it works pretty much the same as the touch them but I noticed the same problem on both......
If you hit a directory with a file name that is too long it will resize the Qlistwidget horizonally and push the scroll bar out of view. Any idea how to fix this?
- JT
23 Jan 2025 11:55 #319708
by JT
You can only apply style to a widget once AFAIK the second time over writes the first time.
I added the themes to the examples so they are easier to find.
I've possibly improved the docs about themes.
JT
Yes, touch style widgets are defined in the qss file.
JT
So I suppose the best way to have custom colors and the touch style stuff is just to copy the touch THEME qss out of libflexgui and stick it in the config directory, point at it with QSS and just modify it, otherwise it won't survive an update. I suppose this is probably where INPUT was going but that's probably a bit more difficult to implement since it's written directly into the main qss.
JT
- JT
23 Jan 2025 12:26 #319709
by JT
JT
The width is set here based on the width of the longest item. I'm working on making that an ini selection to turn that feature on but I need to fix the touch style sheets sliders to work as expected.I copied out the Qlistwidget from the touch theme to my qss and it works pretty much the same as the touch them but I noticed the same problem on both......
JT
- JT
23 Jan 2025 13:56 #319715
by JT
- blazini36
24 Jan 2025 16:43 - 24 Jan 2025 18:14 #319767
by blazini36
Cool, that oughtta do it. I'll update my Flexgui as soon as I get done messing with HAL,
Having a little trouble with the GUI Estop. I have a hardware Estop as well, connected to halui. Both the GUI and the hard Estop work perfectly as long as I'm using one or the other. The hard Estop triggers the GUI just the same as the GUI Estop does.
The problem occurs when I have the hardware Estop set and push the GUI Estop button, the UI Estop will unset the Estop condition. Not quite sure how I stop that from happening.
Heres my HAL connections:
[/code]
Just noticed another issue. I have the UI Estop button colors set in the ini file. If I ignore the hardware Estop, the button colors change as expected with Estop and power. If I set the hardware Estop, the UI states work fine, and the button labels change, but the button colors don't change.
Also, just tried the multi-state label. I can't get the hal pin to show up, am I doing something wrong?
[code]##Estop Connections
net estop-NO-switch => halui.estop.activate
net estop-NO-switch => oneshot.estop.in #Oneshot triggers reset from hardware Estop release
net estop-out => iocontrol.0.emc-enable-in
#net estop-out => motion.enable
net estop-reset <= oneshot.estop.out
net estop-reset => halui.estop.reset
net estop-in <= halui.estop.is-activated
net estop-in => flash.estop.enable
net estop-led <= flash.estop.out
setp flash.estop.hold-prec false
setp flash.estop.hold-prec-inv false
setp flash.estop.hold false
setp flash.estop.flash-rate-ms 500
setp oneshot.estop.width 0.5
setp oneshot.estop.retriggerable false
setp oneshot.estop.rising false
setp oneshot.estop.falling trueJust noticed another issue. I have the UI Estop button colors set in the ini file. If I ignore the hardware Estop, the button colors change as expected with Estop and power. If I set the hardware Estop, the UI states work fine, and the button labels change, but the button colors don't change.
Last edit: 24 Jan 2025 18:14 by blazini36.
Moderators: JT
Time to create page: 0.412 seconds
