02 Jan 2025 00:50
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
I'm going to assume model boat building, other wise I'd imagine you would have researched the larger machines required for human scale boats. If all you want to do is profile cuts, eg bulkheads and the like and you aren't using timber over 3mm or so I would suggest a 10w - 20w laser cutter might be the better choice. No need for Linuxcnc as the supplied controllers do a fine job, I have one myself. Far easier to deal with the "fumes" from a laser cutter than the sawdust you would get with a router.....and far gentler on the thinner timber components as the cutting forces are reduced to practically zero on the material being cut.
At a recent exhibition of local model boat builders I met a Hungarian gentleman who did some amazing work with a hand held rotary tool, timber was carved so thin as to be almost see thru. When asked whether he be human or magician, he puffed out his chest and proudly stated "I am Hungarian".
Tho I would suggest a honeycomb type bed and air assist to reduce scorching and a build up of residue in the cut.
02 Jan 2025 00:38
Replied by Cant do this anymore bye all on topic raspberry pi5 requirements
Proper answer would involve asking what exactly you want to run.
Easier answer, as much as you can afford.
  • ccatlett1984
  • ccatlett1984
02 Jan 2025 00:27
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
Category: Driver Boards
If I'm going to do that, I'd prefer to send in my pi5, so the whole thing gets validated as a set.
  • PCW
  • PCW's Avatar
02 Jan 2025 00:25
So, unknown hardware issues...
One possibility is to send the 7C80 card/cable back to Mesa with an RMA
so it can be tested with a RPI5.
  • ccatlett1984
  • ccatlett1984
02 Jan 2025 00:21
CR56 off
CR57 off
CR58 is lit yellow
  • PCW
  • PCW's Avatar
02 Jan 2025 00:20
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
Looks like you used a 7I96S configuration file  for a 7I96
  • PCW
  • PCW's Avatar
02 Jan 2025 00:12
Does sound like a hardware issue.
Are there any red LEDs illuminated on the 7C80?
and is the 7C80 yellow power LED illuminated?
  • ccatlett1984
  • ccatlett1984
02 Jan 2025 00:06
pi@linuxcnc:/ $ uname -r
6.13.0-rc3-v8-16k+
pi@linuxcnc:/ $ uname -v
#1 SMP PREEMPT_RT Mon Dec 30 16:54:49 EST 2024
pi@linuxcnc:/ $ halcmd -kf
halcmd: loadrt hostmot2
Note: Using POSIX non-realtime
halcmd: loadrt hm2_spix
hm2_spix: SPI0/CE0: Invalid cookie, read: 00000000 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d followed by a value less than 0x10000
hm2_spix: SPI0/CE0: No drive seen on MISO line (kept at pull-down level). No board connected or bad connection?
hm2_spix: rtapi_app_main: No such device (-19)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_spix
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_spix failed, returned -1
halcmd:
  • ccatlett1984
  • ccatlett1984
02 Jan 2025 00:02
Waiting for component 'hm2_spix' to become ready.Waited 3 seconds for master.  giving up.
hm2_spix: dlopen: /usr/lib/linuxcnc/modules/hm2_spix.so: undefined symbol: hm2_register
<stdin>:1: waitpid failed /usr/bin/rtapi_app hm2_spix
<stdin>:1: /usr/bin/rtapi_app exited without becoming ready
<stdin>:1: insmod for hm2_spix failed, returned -1
halcmd:
  • PCW
  • PCW's Avatar
01 Jan 2025 23:58
So no idea, looks like maybe a hardware issue of some kind
You might try the hm2 driver in case its some kernel driver SPI setup issue:
halcmd -kf
  • ccatlett1984
  • ccatlett1984
01 Jan 2025 23:51
Pulled and reseated cable.
Linux linuxcnc 6.13.0-rc3-v8-16k+ #1 SMP PREEMPT_RT Mon Dec 30 16:54:49 EST 2024        aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Jan  1 18:38:07 2025
pi@linuxcnc:~ $ mesaflash --version
Mesaflash version 3.5.10
pi@linuxcnc:~ $ sudo mesaflash --device 7c80 --addr /dev/spidev0.0 --spi --readhmid
Unexpected cookie at 0100..0110:
No 7C80 board found
pi@linuxcnc:~ $
  • PCW
  • PCW's Avatar
01 Jan 2025 23:39
Did you verify the mesaflash version?
mesaflash --version
  • ccatlett1984
  • ccatlett1984
01 Jan 2025 23:34
using cable purchased from MESA
  • PCW
  • PCW's Avatar
01 Jan 2025 23:33 - 01 Jan 2025 23:34
OK, using mesaflash 3.5.10 or > is necessary on the RPI5  but there must be other issues.
Maybe cable related?
mesaflash --version
Displaying 20896 - 20910 out of 21770 results.
Time to create page: 0.672 seconds
