You coming at this arse about. Which makes me wonder if this is for academic purposes, a potential commercial endeavor or a tech blog.
First one decides on the type of cnc machine they want to build, then they choose the controller to suit.
The simplest entry point for one who has no plan for their actual "cnc machine" would be.
A Lenovo M73e tower, preferably with an i5, the appropriate MB to Parallel Port cable ( there's some trickery with the cable that enables the PP hardware) and a generic Parallel Port breakout board. I've recommended this combination as I know it works, I have tested it with a lathe for basic functionality. I actually found this machine on the side of road with a celeron processor, which I swapped out for an i5 (3470 I think) and an SSD from the "useful box".
What people want is something that will run their hardware (their cnc machine be it a plasma cutter, lathe, mill router, laser tube profiler, PnP machine, cnc soldering machine) at a price point they can afford. As you can guess this is quite an expansive list.
