LinuxCNC on Raspberry Pi 5
- TomAlborough
10 Jan 2025 02:38 #318603
by TomAlborough
Replied by TomAlborough on topic LinuxCNC on Raspberry Pi 5
I have made a mistake. I thought the kit I bought gave no *physical^ access to the SD card. But, it does.
My apologies for the trouble and misunderstanding.
Tom
Tom
- Thank you received: 426
10 Jan 2025 04:18 #318609
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
hahaha
These things happen.
We're making some headway towards getting a 6.12 kernel going with rod's image builder.
But despite what the recent skuttlebutt suggests for arm platforms it seems that some patches are still required for realtime.
- resmond
- Thank you received: 3
10 Jan 2025 18:57 #318654
by resmond
Replied by resmond on topic LinuxCNC on Raspberry Pi 5
Is there a GitHub tracking thread (or something else) for those patches?
I would be really interested in following that thread.
10 Jan 2025 21:47 #318663
These are Linux kernel patches, so I guess where the kernel devs hangout.
- Onat
20 Jan 2025 14:16 #319463
by Onat
Replied by Onat on topic LinuxCNC on Raspberry Pi 5
Hi all,
after swapping our Raspberry Pi4 with a 5 things didn't work anymore as they did before, and thanks to this forum, as far as I understood there is no SPI support yet, right?
I have also read that "rodw" you have created an image builder, and "Cornholio" you managed to patch it so it works right?
As we are trying to run the mesa 7c80 with a Raspberry Pi5, is there an image available currently that supports this combination? If not what would be the steps to "patch" it together?
Thanks a lot in advance
- Thank you received: 5330
20 Jan 2025 17:26 #319472
Replied by PCW on topic LinuxCNC on Raspberry Pi 5
The 7C80 will work with the RPI5 using the hm2_spix driver.
Note that some 7C80s were shipped with firmware that does
not work with the RPI5. These cards can be re-programmed
on a RPI4 if that's convenient. All the distributed bitfiles are OK.
The following user(s) said Thank You: Onat
20 Jan 2025 17:57 - 20 Jan 2025 18:03 #319475
The biggest issue is that Linuxcnc will require building from source as the RPi5 images don’t have Linuxcnc packages built from the most recent code base. Editing config.txt to turn on spi is a trivial matter.
Give me a day or 2 and I’ll generate an image with the most recent Linuxcnc & Mesaflash.
Last edit: 20 Jan 2025 18:03 by Cant do this anymore bye all.
- Onat
21 Jan 2025 09:41 - 21 Jan 2025 09:41 #319534
by Onat
Wow, thank you @cornholio! That will make it much easier for us
@PCW thank you as well for the info.
Last edit: 21 Jan 2025 09:41 by Onat.
21 Jan 2025 11:26 #319548
6.1.69 Fully preempt kernel
SPI enabled by default
Linuxcnc 2.9 built from git repo today just uspace & dev packages no docs
Mesaflash built from source today, version 3.5.10
Instead of xfce I built the image with Mate, std debian config looks different to std Mint install.
Tested mesaflash to just get the pins from my 7c81 clone tested ok
Test loading the hm2_spix driver for the rpi via a halrun session ok
Quick latency test ok
drive.google.com/file/d/1MEgxQ1IrdI2hnnw...ilQ/view?usp=sharing
- Onat
21 Jan 2025 20:16 #319587
by Onat
Thank you! Will try it out on friday.
Time to create page: 0.271 seconds
