LinuxCNC on Raspberry Pi 5
- unknown
- Thank you received: 323
05 Feb 2025 08:37 #320711
by unknown
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
The images provided are not generic Debian images, as generic Debian didn't support overlays.
The images we build are custom images based on Debian repo but with kernel sources from the RPi-Linux github.
The output I gave was showing that the hal_gpio driver does indeed work, the first line is loading the driver with the GPIO config as per the man page for the driver. Yes it was the current image, with the 6.12 series kernel & Linuxcnc 2.9.4.
The following user(s) said Thank You: rodw, KrisJ
- Thank you received: 4149
05 Feb 2025 09:12 #320714
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
hal_gpio uses a newer method that is meant to support other ARM hardware, not just the PI. Code changes at the kernel never stops!
The following user(s) said Thank You: KrisJ
05 Feb 2025 09:56 #320716
There is a commit pending with etherlab or the 6.11 kernel and up which also should let ethercat on 6.12 work for us.
Bjarne at etherlab is chasing it up for us internally. He has been so helpful for us along the way.
The following user(s) said Thank You: unknown
- unknown
05 Feb 2025 10:54 #320720
by unknown
Invalid parameter `help' <<<<< this is the error from the above, Linux is pretty verbose in telling you what is wrong.
But you really need to read the man page
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
halcmd loadrt hal_gpio helpHello everyone,
I started to work with linuxcnc only a few weeks ago, when I decided to upgrade my 3d printer with A and B axis.
Because my pi4 was starting to jitter I acquired a pi5.As one does..
I etched the image 2.94 for pi5 to an SD card. Running this image, GPIO is not working.
Note: Using POSIX realtime
<commandline>:0: waitpid failed /usr/bin/rtapi_app hal_gpio
<commandline>:0: /usr/bin/rtapi_app exited without becoming ready
<commandline>:0: insmod for hal_gpio failed, returned -1
cnc@raspberrypi:~$
I dont have the knowledge to troubleshoot this. Unfortunately. Maybe somebody here know how to solve this.
kind regards,
JAiro
- unknown
05 Feb 2025 11:01 #320721
by unknown
I had a look at the ethercat DKMS package (extracted the package in a temporary directory, no need to do an install), and what I saw is that the source of the modules have ending with 5.14 & 6.1 before the .c .h extension (I'm guessing these are the supported kernels). I'd get confirmation that the commit for 6.11 will work for 6.12.There is a commit pending with etherlab or the 6.11 kernel and up which also should let ethercat on 6.12 work for us.
05 Feb 2025 11:29 #320724
gitlab.com/etherlab.org/ethercat/-/merge_requests/151
It seems to be confirmed because the notes say it fixes issue #160 which is the issue I raised.
- unknown
05 Feb 2025 11:33 #320727
by unknown
I wonder about the drivers in the gnet folder for the RPi. Whether the drivers from 6.12.x kernel source need to be patched with the ethercat stuff and moved into the gnet folder.
05 Feb 2025 11:39 #320730
Don't overthink it.
The drivers in Ethercat refer to optimised RT Ethernet NIC drivers. There is a generic driver we use and then some hardware specific ones for install and broadcom, I assumed there would be generic driver support.
- zmrdko
- Thank you received: 49
05 Feb 2025 13:57 #320745
by zmrdko
Replied by zmrdko on topic LinuxCNC on Raspberry Pi 5
regarding EtherCAT driver for rpi5 ethernet:
gitlab.com/etherlab.org/ethercat/-/issues/104
RPi 5 uses the
driver (Cadence GEM) and notmacb. So I guess you have to use a Raspberry Pi 4 if you want a native driver.genet
- unknown
05 Feb 2025 14:34 #320750
by unknown
I'll have to leave this to Rod & others. It's not something I could really test other than the installation bit.
Time to create page: 0.236 seconds
