LinuxCNC on Raspberry Pi 5
- unknown
- Thank you received: 323
09 Feb 2025 04:56 #321042
by unknown
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
What is the actual command are you using for ping
- jairobbo
- Thank you received: 4
09 Feb 2025 10:13 #321052
by jairobbo
Replied by jairobbo on topic LinuxCNC on Raspberry Pi 5
After using two model of pi (4B and 5) I still get disappointing results. Even at slow printing speeds around 25mm/s there is layer shifting and unreliable motion throughout the operation. I believe now that pi + GPIO struggles to keep up with the pulse generation. Even though I am doing indexed printing (orienting the bed only between sections of printing, so no full 5 axis kinematics) My application is a 5 axis (3 + 2 tilting bed) 3d printer.
I think this was mentioned in the instructions that the PREEMT linux kernel was compatible only, but not recommended as 'industry standard'. Since I cant afford a Mesa FPGA card I am going for klipper on an Octopus board and try my best there. Thanks everyone for being super helpful. And if anyone is interested my 5 axis slicer is on Github, it is A Blender addon that works if you also have the Cura engine up and running. You would be able to slice more complicated models with overhang and printing it by rotating the bed (if you do have this kind of setup).
github.com/bbo-git/5AxisSlicerBlenderAddon
Cheers!
Jairo
Cheers!
Jairo
- unknown
09 Feb 2025 10:47 #321053
by unknown
""I think this was mentioned in the instructions that the PREEMT linux kernel was compatible only, but not recommended as 'industry standard'.""
What do you mean by this ?
I guess you haven't seen this:
github.com/ozzyrob/Linuxcnc-FPGA
- jairobbo
09 Feb 2025 10:52 #321054
by jairobbo
I mean by that you need additional hardware to get good results. The Pi alone even the 5 cannot handle it is my finding and conclusion.
- unknown
09 Feb 2025 11:01 #321055
by unknown
I fail how your last post explains what I questioned.
If you want to delve into industry standard, what ever that may mean, you'll have to realise that the RPi isn't certified for industrial applications.
Furthermore I'd like to see the reference to that quote. None of it makes sense. It would appear you chose the wrong hardware setup for for application. Did you realise max step rate was related to latency and therefore the base thread ?
- unknown
09 Feb 2025 11:11 #321056
by unknown
The thing is if you had of asked you would do have been advised on the limitations of software step generation. It's not a finding, it is something that is known. And I could have directed you on how run 7c81 firmware on a $40 spartan 6 dev board, or been directed to one of the other projects.
- jhandel
- Thank you received: 7
09 Feb 2025 18:07 #321079
by jhandel
Replied by jhandel on topic LinuxCNC on Raspberry Pi 5
sudo chrt 99 ping -i .001 10.10.10.10 -c [count I am testing]
- unknown
09 Feb 2025 23:24 #321129
by unknown
sudo ping -i 0.001 -c 1000000 -f 192.168.1.1
This was pinging my router, for about 15 minutes, and I did not get a failed packet, no lockups.
- jairobbo
11 Feb 2025 11:05 - 11 Feb 2025 11:39 #321225
by jairobbo
I'm sorry if my previous post was hard to understand or based on misread info.
I was under the assumption that the most affordable mesa card for 6 axis (5 move and 1 extr) was around 200 bucks. But you are totally right better to ask than assume... I'm sorry for sounding stupid.
I'm still very much open to guidance for hardware selection for my 5 axis printer
Have a great day!
Have a great day!
Last edit: 11 Feb 2025 11:39 by jairobbo.
- unknown
11 Feb 2025 11:57 #321227
by unknown
If you had of read the docs, the parts regarding using a parallel port and software step generation, you would have learnt that there is a limit to the stepper speed based on the latency of the base thread.
This is the problem, people don't fully research/read the docs and don't fully understand what they are doing. They also assume things that are not so.
Many times people blame Linuxcnc, 99% of the time it is a mistake they have made.
The recent rise in the availability of home CNC machines has led people to think it is easy thing to setup and use. It's not, there are many hats you have to wear. And to be fair the basis for a project for Linuxcnc, all those years ago, was for control of industrial machines. I don't think the original authors of the papers imagined the extent that small CNC machines would become available to the "average Joe".
Checkout the mesa website, see what they have available. Read the forums, see what other people are doing. Checkout the remora project, have a look at Linuxcnc-RIO, geesh I even gave a link to my own GitHub project.
Time to create page: 0.183 seconds
