LinuxCNC on Raspberry Pi 5
06 Feb 2025 21:05 #320851 by PCW
Replied by PCW on topic LinuxCNC on Raspberry Pi 5
What is the servo thread rate?
How are the ping times?
06 Feb 2025 22:40 - 06 Feb 2025 22:42 #320861 by jhandel
Replied by jhandel on topic LinuxCNC on Raspberry Pi 5
I was able to cause it to crash out without going into Linux CNC if i load it up too much with commands like
sudo chrt 99 ping -i .001
It handled running realtime at 1ms delay with averages of .101msĀ  for 10000, 20000 and 30000 pings, but when I jumped to 50000 pings it crashed out at about 40k pings..
So there is something that someone in the "chain" doesn't like under high network traffic..
and again, unplugging and plugging back in (just the network) fixes it... which is... wierd... (to me)..
Here is my Servo Period:
SERVO_PERIOD = 1000000
and here is my Servo Timeout
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
the whole config can be found here (its where I wrote it a while ago, but my old pc died so working on getting it up and running on this pi)
github.com/Skyfire-community/SVM2-LinuxCNC
Last edit: 06 Feb 2025 22:42 by jhandel.
06 Feb 2025 23:09 #320862 by PCW
Strange, others have used the RPI5 with Ethernet FPGA cards without issue.
What kernel are you using?
(uname -a)
I guess it could be a hardware issue.
Do lose link lights when you lose the network connection?
I can try and duplicate this when I get a chance.
07 Feb 2025 00:26 #320863 by skunkworks
Replied by skunkworks on topic LinuxCNC on Raspberry Pi 5
What image are you using for the rpi5? I was having read errors on my 7i97 very often with whatever image I was using (I don't remember when I got it) I downloaded the latest off of linuxcnc's site (2.9.4)
It has been rock solid. No issues running it for a week now.
sam
07 Feb 2025 01:02 #320865 by jhandel
this is an on and off project for me so I built it maybe 4 months ago before there was an official image... I'll pull down the 2.9.4 and reimage the pi with it and see if that makes it happy...
I'll report back if that doesn't fix it..
07 Feb 2025 02:27 #320874 by unknown
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
There's been official images for the RPi5 from about Dec 2023.
07 Feb 2025 09:58 #320900 by Grad
Replied by Grad on topic LinuxCNC on Raspberry Pi 5
Thank you for your help, please notice my linux knowledge is limited so my answers may sound stupid :-). Anyways
cat /proc/device-tree/compatible | tr '\0' '\n'
returned:
raspberrypi, 5-model-b
brcm, bcm2712
The checksum did not match, but the link you provided is for rpi-5-debian-bookworm - I used the linuxcnc_2.9.4-amd64.hybrid.iso
Anyways, I mounted Linuxcnc image under Ubuntu and all the checksums there matched when i used
sha256sum -c sha256sum.txt
07 Feb 2025 10:16 #320901 by unknown
What you were trying to boot a RPi5 with a amd64 image ?
Of course I provided the RPi5 checksum, why wouldn't I, this is a thread for the RPi5. The checksum will only work when used against a file, not a mounted file system, the checksum is for the compressed image file.
Am I missing something here ?
The following user(s) said Thank You: Grad
07 Feb 2025 11:20 #320904 by Grad
As you might have guessed already I just downloaded the wrong file. Now you can say that you pointed me on that with your last comment. But since my linux knowledge is limited (told you so) I just needed you to tell me again to realize my mistake :-)
Anyways it runs just fine now - thx for your help :-)
The following user(s) said Thank You: unknown
07 Feb 2025 12:17 #320905 by jhandel
I just remember lots of discussion around build your own last fall and went off some of the instructions in there... either which way, its a "home brew" and I'll give the official image a go.
Time to create page: 0.206 seconds
