  • Crimznn
  • Crimznn
23 Aug 2024 17:31
Replied by Crimznn on topic Download older version (2.5.1)
Category: Installing LinuxCNC
I need to downgrade new router pc to 2.5.0 which of the downloads will be best?
  • Crimznn
  • Crimznn
23 Aug 2024 17:27
I need 2.5.0 same download link? ubuntu/linux
  • rajsekhar
  • rajsekhar
23 Aug 2024 17:26
Replied by rajsekhar on topic 4 Axis CNC MIG welding, weavy stuff problem
Category: Show Your Stuff
I am thinking of making a similar machine..
What kinematics is used here?
  • Aciera
  • Aciera's Avatar
23 Aug 2024 17:24 - 23 Aug 2024 17:25
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
Looking at the screenshot of your ini file it seems that you are loading both panels ('testpanel' and 'testpanel1') to the same location 'ntb_preview', not sure what that does but you may want to load the 'testpanel' to a different location like.
EMBED_TAB_LOCATION = box_cooling
  • Crimznn
  • Crimznn
23 Aug 2024 17:18
I need to downgrade from 2.9.2 to 2.5.0 to run our old configs/ hal files
our old pc broke we sent it in to get fixed and overnighted a new one but it won't run I/O through the extra parport to the plc, I need to remove 2.9.2 and find the download for 2.5.0 or copy it from our other router pc I need some guidance mostly as far as the re-installation process and where I can find a repo or source to get 2.5.0
  • fsabbatini
  • fsabbatini
23 Aug 2024 16:38
  • fsabbatini
  • fsabbatini
23 Aug 2024 16:32 - 23 Aug 2024 16:34
Replied by fsabbatini on topic Cylindrical mapping
Cylindrical mapping
Thanks Bari! that looks awesome, lots of efforts in writing that software
Here is another video of Cylindrical mapping at real work
  • Moutomation
  • Moutomation
23 Aug 2024 16:22
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
I will do this first thing tomorrow morning.
  • Aciera
  • Aciera's Avatar
23 Aug 2024 16:14
İnstall glade
Category: Gmoccapy
Problem is your handler script does not load so start a terminal and type:
linuxcnc -l
note the minus and lowercase letter 'L' should load the last config.
  • Moutomation
  • Moutomation
23 Aug 2024 16:12
İnstall glade
Category: Gmoccapy
linuxcnc boots without any warning. I don't know how to get terminal output
  • Aciera
  • Aciera's Avatar
23 Aug 2024 16:06
İnstall glade
Category: Gmoccapy
Terminal output?
  • Moutomation
  • Moutomation
23 Aug 2024 15:57
İnstall glade
Category: Gmoccapy
  • Moutomation
  • Moutomation
23 Aug 2024 15:49
İnstall glade
Category: Gmoccapy
I change the value. When I open it again, I see the value as 10,000 again.
  • Aciera
  • Aciera's Avatar
23 Aug 2024 15:33
İnstall glade
Category: Gmoccapy
So what exactly is not working?
Notes:
1. forget the __pycache__ folder, that gets created whenever the script is run. You can even delete it, doesn't matter.
2. You don't need to create 'gladepanel_parameter.txt'. If it does not exist the panel will load the default value set in the .ui and it will be created on the first change.
Open the 'Halshow' tool and check if you see your custom panel and it pins. If so does it also show a pin named 'number':
Finally are you getting any output in the terminal?
  • Moutomation
  • Moutomation
23 Aug 2024 15:19 - 23 Aug 2024 15:20
İnstall glade
Category: Gmoccapy
I tried all the steps many times, I think I'm making a mistake somewhere.
A folder has been automatically created inside the Pythhon folder, its name is __pycache__ and it contains the gladevcp-handler.cpython-311.pyc file.
1-I created a new file in the folder where the configuration files are located. name: gladepanel_parameter.txt
I marked the code you sent me as executable and saved it in the python folder as gladevcp-handler.py.
I replaced the line in my 3-ini file with this code
EMBED_TAB_COMMAND= halcmd loadusr -Wn test panel gladevcp -c test panel -u python/gladevcp-handler.py -H ./gladevcp/testpanel.hal -x {XID} ./gladevcp/testpanel.ui
4-I wrote on_value_cahanged in the vlue_changed section in the glade panel.
5-id=hal_spinbutton1
Displaying 23416 - 23430 out of 24335 results.
Time to create page: 0.785 seconds
