  • M.adams9093
  • M.adams9093
03 Aug 2024 03:56
Replied by M.adams9093 on topic Error at startup
Error at startup
Category: Configuration Tools
Thank you all for the quick response.
The issue was that I assigned the wrong limit switch pin to the wrong joint number. I am using mesa CT to build my configuration I have version 2.1.4 I believe its the latest version. Now I have the motor synced successfully, when I click home, both motors shaft turn simultaneously but my limit switches are not responding when I click them. MESA 7i95T seems like a good card, but unfortunately, it doesn't have wiring schematics that I can refer to. Can someone guide me on how to connect limit switches the right way on Mesa 7i95T?
thank you
  • Moutomation
  • Moutomation
03 Aug 2024 03:54 - 03 Aug 2024 04:01
Replied by Moutomation on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
What we have done so far: (maybe simple things for you, but difficult things for me)
1-linux installation (not easy for someone who has not done this before)
2-Servo control is completed with ethercat.
3-Remote I/O modules completed with ethercat
4-Modbus Tcp comleted
5-Automatic file reading worked quickly because it is a feature of gmoccapy.
6-Linuxcnc can be controlled by Windows in a local network without internet.
7-A common folder was created between Linux and Windows so that g codes were automatically sent to Linuxcnc.
I shared the remaining few issues in the forum. If there is anyone who can provide paid support on these issues, you can contact me and I am ready to pay a fee.
  • scotta
  • scotta's Avatar
03 Aug 2024 03:52
It's very very early days, but I've managed to send SPI packets on a RPi 5 from LinuxCNC using the low level RP1 memory mapped peripheral. Hopefully we can get RPi 5 support for Remora up and going.
  • Moutomation
  • Moutomation
03 Aug 2024 03:41
Category: EtherCAT
5 days is not a very long time, but when I wrote to the forum yesterday, the problem was not solved. If the problem was solved, I wouldn't write these.
I've been working on this project for 1 month.
I have opened a few topics on the forum for a few days.
90% of my project is completed.
I don't want free support from anyone
I met and befriended the saints. I don't know his name on the forum, thanks to him the project is 90% completed.
I asked for help from him for a fee, but he devoted his hours to me free of charge and contacted me remotely many times.
Even if he does not ask for a wage, he will definitely be rewarded for his labor when the project is completed.
Evidence of my pursuit of paid support is the Instagram message I sent you in the past. If you check your Instagram message, you will understand that I do not want free support. As a last resort, I wrote to the forum for free support.
and I think some friends here don't know what the purpose of this forum is.
  • Moutomation
  • Moutomation
03 Aug 2024 03:30
Category: EtherCAT
If it weren't for you it wouldn't have been solved so quickly. Updating Ethercat may not be under Linuxcnc's control, but I think that such important files, versions and packages that were running in the past should be preserved or backed up. I appreciate your support and you serve the purpose of the Forum's existence.
03 Aug 2024 02:50
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
If you have a look at the figures on the wiz net wiki you’ll see as packet size drops so does the overall throughput.
All I could find is the implementation and proposed data integrity stuff. I know you're past your daylight but when you have a chance tomorrow, see if you can find that bit of info you ref'ed and we'll talk to their engineer about it. See if we can flip a Magic Register to disable that supposedly/suspected throttling thingy...
Impl. Ref: docs.wiznet.io/Product/iEthernet/W5500/Application/udp
docs.wiznet.io/Product/iEthernet/W5500/A...tion/spi-performance
  • onceloved
  • onceloved's Avatar
03 Aug 2024 01:10
Replied by onceloved on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
你不行不代表别人不行
03 Aug 2024 00:33
Hardware needed to switch from mach 3 6 axis to linuxcnc 9 axis
Mesa 7i96S can do 10 axis just by adding a simple BOB (it can do without BOB, but wiring must be careful).
If you do not need much input/output pins, go for that one, later you can add whatever you might need, like 7i85S or 7i84 or even analog servo drives with 7i83.
  • rodw
  • rodw's Avatar
03 Aug 2024 00:27
hm2/hm2_7i96s.0: watchdog has bit! (set the .has-bit pin to false to resume)
Category: Installing LinuxCNC
The 8168-dkms driver requires the installation of DKMS and linux-headers for your particular kernel
These should be installed by the Linux ISO
  • spumco
  • spumco
03 Aug 2024 00:25
There's always this:
forum.linuxcnc.org/27-driver-boards/5160...sa-card-should-i-buy
A Mesa 7i96S, plus a 7i85S, plus a 7i84 (or 7i84D) should cover just about everything you've described.
If you want a physical user control station with lots of buttons & handwheels, a 7i73 can be added.
What's got me interested is the 'auto' part of 'auto-lathe.'  Do you mean something with a parts loader or bar feeder?
I've got a 4-axis lathe with a subspindle and I still don't need 9 axes of positioning.
  • rodw
  • rodw's Avatar
03 Aug 2024 00:19
A strange 5 axis machine detailed build log with limited tools, on youtube
Category: Show Your Stuff
He’s made quite a few small machines. I like his channel.
After seeing this post, I wasted a lot of time watching all his 55 axis videos.....
  • rodw
  • rodw's Avatar
02 Aug 2024 23:08
Have a look at the mesa boards:
www.mesanet.com/index.html
store.mesanet.com/
It won't get more flexible and expandable then that.
Well, the OP could consider Ethercat which is flexible and expandable but adds some complexity, reduces wiring  and probably adds  more cost than mesa cards
  • rodw
  • rodw's Avatar
02 Aug 2024 23:04
Replied by rodw on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
I buy and use professional devices, I pay money for these devices. I only shared this to prevent anyone from getting hurt. Because I can't do something I did a week ago a week later. For example, who can guess that something that worked a week ago won't work a week later. And since I worked it before, I could start a new job thinking it would work again and I could be disappointed. My aim is to prevent others from falling into these situations.
You really have an unrealistic view of Open source.
This has been fixed today 5 days after I became aware of the issue, during that time,  a lot happened.
1. Issue tested by me.
2. Bug report filed by me with etherlabmaster (5 days ago)
3. Bug was marked as fixed  4 days ago  by etherlabmaster and they kindly pushed changes to the Linuxcnc git repo
4. I asked Linuxcnc devs to  accept the changes
5. Changes accepted into our git repo
6. I cloned and rebuilt ISO
7. New 1.6 Debs from etherlabmaster refused to install
8. I updated my earlier bug report
9. Bug marked resolved by etherlabmaster today
10 I tested the fix today, confirmed now working
11. I asked devs to deploy a new ISO to the downloads page.
Given what has happened to fix this, I think this is a very reasonable outage.
I pay for software that takes at least 2 weeks before they respond to a bug report so 5 days with open source is way faster than many commercial software services. You have to remember we are scattered all around the world so time zones become significant.
If you don't like the support you received, perhaps Linuxcnc is not for you.
  • rodw
  • rodw's Avatar
02 Aug 2024 22:46
Category: EtherCAT
Maybe I wasn't clear but my test was with the new Ethercat version 1.6 which now installs from repositories (if you have the new keys)
  • rodw
  • rodw's Avatar
02 Aug 2024 22:44
Category: EtherCAT
IIRC, the Ethercat people just did a major version upgrade after literally years of leading up to it. We should probably either pin LCEC to v 1.5.x or see what it takes to fix whatever upgrade problems are happening. I'll take a look at it later today if possible.
Several things happened at the Ethercat people's palace.
1. They rolled out the new 1.6 version of Ethercat
2. Their repository keys expired preventing us from installing Ethercat
3. They had a bug in their code that builds the DKMS (kernel part of) Ethercat
This is now all resolved. Their keys will expire in another 2 years.
rodw is very helpful to everyone regarding ethercat. Those who use ethercat should pray that nothing happens to him, otherwise you may not be able to install ethercat one day.
People were using Ethercat with Linuxcnc well before I got involved. I just made it easier by joining a few dots so they don't need to build from source and incorporating the great work by Scott Laird into one place.
Some bugs take time to resolve and in this instance they were not in Linuxcnc's control.
You can download a new ISO with the changes from my Google Drive
drive.google.com/file/d/1gEQzgHsj_LjHiGB...k1Z/view?usp=sharing
I have asked the devs to update the ISO on the downloads page with this.
I have tested this ISO and the installation process this morning and I can see my slaves :)
Displaying 24451 - 24465 out of 24640 results.
Time to create page: 0.451 seconds
