  • motionmasterupgrade
01 Apr 2026 02:37
Replied by motionmasterupgrade on topic MotionMaster Upgrade
As of now, I can easily send 60amps at 220 to it.
I was going to trace the power in the unit, but need to get set up. I'm just spending my time around the beast for now trying to understand it and familiarize myself. More than anything else, i'm trying to come up with a system to document what I am doing. Any idea for software, or perhaps, some sort of step by step thought process on replacing, identifying and tidying up wiring?
If you don't have many amps, can you stomach the cost & hassle of a service upgrade? >> Ideally, no, but if I really have to, I don't really have a choice. I'm dug in.
How many amps do the drives require, and what voltage? Please help me here. Is this information that I read off the faceplates (this would be maximum draws) or is this something I read off the drives? I know where the drives are, and can easily pull one out to check.
Also, before I start fingering the components, is there a component in here that can hold a charge despite being dormant for a while? I think this unit has been sleeping for about 12 to 15 months, but I've heard of folks getting a nasty shock from fingering old TVs.
Thank you
01 Apr 2026 02:31
Thank you!
-existing stuff
I don't see why I cannot use the existing drives for the existing servos. The intention was not to replace those at all. For the VFD, I very much want a water cooled VFD tho I have been told that it takes up a lot of extra vertical real estate. In the end, I'll be a one person outfit for a while anyway, so maybe I can just say screw you OSHA and just deal with the noise on that 16hp spindle. I will never use the full capacity, so as long as I can start it up, I think I should be alright. I imagine I can do some sort of a ramp up start with the VFD settings. That reminds me to check if it works.
-can I mix drives? the swivel head that I have will comes with yaskawa servos and no drives(or I can add drives). I cannot imagine there being as issue to mixing and matching. And concerns with mixing analog/digital?
-if you still want to replace the drives, you have two choices in general: EtherCAT or Mesa with normal step/dir or analog servos (do not bother to look at steppers and close loop steppers)
I'll have to research this. I do not know if the current servos are closed loop ones. The ones on the X and Y axis are mts30r4-42. They have 3 power leads (2 bigger wires, 1 thinner). I've confirmed that I can get a voltage if i turn the servos by hand. The resistance is above the plate, but still under 2ohms. 4 brushes in good condition. There are 4 other pairs of wires that I found out are A, B, Index and Power. Haven't wrapped my head aroud thinking about them from first principles yet. Would this existing hardware affect any of my choices?
-For the Mesa/new drives, i would look for "position and velocity" mode drives (analog +-10V and step/dir) and also with encoder outputs (all have encoder inputs or absolute encoders, usually serial ones) so the loop can be closed in LinuxCNC with both types of control, makes life easier during use. Given the choice between analog and step/dir, choose step/dir.
>>> I'm going to research this paragraph a little more first.
I was wondering if there are good software or schematics for recreating the wiring. I found the Fagor 8055 manual, but it seems more like how to use it rather than how to fix it.
Thank you!
  • PCW
  • PCW's Avatar
01 Apr 2026 02:16
Replied by PCW on topic Bitfile for rcservo - MESA 7i95t
Category: Driver Boards
OK all do that, probably tomorrow.
  • timo
  • timo
01 Apr 2026 02:09
Replied by timo on topic China Spindel Drehzahl passt nicht!
Category: Deutsch
Achtung Trollalarm :-) Die Beschreibung ist denke ich zu unspezifisch.
Wenn ich der KI "ausnahmsweise" glaube gibt es tausende (verschiedene) Umrichtermodelle; Made in China.
Ich denke die Kollegen, die sich damit auskennen brauchen wenigstens ein Foto, vom Apparat, vom Typenschild oder irgendsowas.
Gruß Timo
  • grandixximo
  • grandixximo's Avatar
01 Apr 2026 02:04
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
On my setup it takes about 6 seconds to get OP, it's always been like that on my setup I have about 6 servos and 6 IO cards, you should link OP with emergency, you should not let anything be operational till all-OP is on. Without my patches, old Ethernet release there is no delay in OP?
You have to catch the spikes in the scope, scope the servo thread and you joint 0 Ferror or pos-cmd pos-fb
Without a scope reading it's hard to tell what's the issue.
  • grandixximo
01 Apr 2026 01:43 - 01 Apr 2026 03:12
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
@ruediger123
I believe the jerk is not matained, because it is not possible to maintain it with your cycle time and your tolerance, you are purposely settings the machine up to spike, and it will because there is no choice if it follows your thread cycle, if it follows your tolerance, and it follows your set feed, how do you propose this should be fixed? One of these limits should be relaxed, which one?
I don't think I should hard code limits, it should be up to the integrator to setup the machine with proper cycle time and limits according to processing requirements
@endian @rodw
TP2 in a separate thread should be the medicine that fix our ailments, filtering, NURBS, all will be taken into consideration, it is an active development and testing on our end, not ready to share yet.
  • Donb9261
  • Donb9261's Avatar
01 Apr 2026 00:39 - 01 Apr 2026 00:41
Replied by Donb9261 on topic LinuxCNC python
LinuxCNC python
  • Donb9261
  • Donb9261's Avatar
01 Apr 2026 00:37
LinuxCNC python
Consider the following gcode lines:
197: G2 X[118.69393*#<scale>] Y[5.37699*#<scale>] I[5.36449*#<scale>] J[4.87005*#<scale>]
198: G2 X[118.27432*#<scale>] Y[8.23889*#<scale>] I[12.16539*#<scale>] J[3.2454*#<scale>]
199: G0 Z3.0
200: G55
201: M5
202: M30
LCNC reads/runs all the way down and stops at G0 Z3.0. And the program never resets. I stat.red_line, stat.motion_line, current_line, and see that motion_line is actually the line it is stuck on. In this case, it would be line 199. After 202: there is an EOF carraige return. I tried this using Axis, and all the others. I get the same result these do.
M30 should read and rewind to first line in the program which is RS-274 GCODE. But, no matter what I try, nope.
Any ideas?
Thanks,
Don
  • Unlogic
  • Unlogic
01 Apr 2026 00:31
Replied by Unlogic on topic Probe Active before non-probe move
I only get this error if I forget to plug in my probe cable before probing.
In my case the probe is wired in NC mode (normally connected) just as a safety precaution to avoid crashes.
  • andypugh
  • andypugh's Avatar
31 Mar 2026 21:04
Free Cincinatti Milacron - UK was created by andypugh
Category: User Exchange
A friend sent me this link, it's not my mill.
www.instagram.com/btr_fabrications/p/DWjx6bkDCgf/
  • spumco
  • spumco
31 Mar 2026 20:40
Replied by spumco on topic MotionMaster Upgrade
Before you make any decisions, you've got to sort out power.
How many amps of 220v single-phase do you have available for the machine?  This will narrow down your options considerably.
Even if you downgrade the VFD, you may not be able to run the existing drives on single-phase. You may not even have enough amps available with a rotary phase converter or Phase Perfect.
If you do have enough amps to run single-phase with no converter, you need to budget for significantly increase conductor sizes to (and maybe inside) the machine.
So...
How many amps do you have available?
I think these will help you determine if you're re-using anything or if this is gonna be a full-boogie replacement where everything electrical comes out and gets replaced with new.
  • susan-parker
  • susan-parker
31 Mar 2026 20:14
30 Second timeout before opening and E-Stop button not clicking...
Category: QtPyVCP
Used gdebi to install dependencies stuff, then dpkg worked... now have LinuxCNC installed.
I am trying to follow instructions as presented, but there is a lot of stuff to get up to speed on and it is difficult (for me) to remember all the various bit n' pieces and in shuffling things around I have probably confused myself - hence the clean install and going back from basics to walk though the installation process from scratch.
This restart is meant to simplify the process, rather than just spinning my wheels.
I will do the Probe-Basic stuff tomorrow... as it's getting later here in the UK and it's time to shut down for the night :)
Thanks for the time and help, it is appreciated. :)
  • grossm5000
  • grossm5000
31 Mar 2026 20:04
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
here are the pictures. the one with the white folding table background is the old one.
Thank you. I am starting to feel like I really must have missed something obvious here...
  • grossm5000
  • grossm5000
31 Mar 2026 19:54
PCW: no luck on the setpci option:
31 Mar 2026 19:51
Replied by tommylight on topic MotionMaster Upgrade
I might not be the best person to reply to this as i absolutely enjoy retrofitting and bringing back to life old machines, so i may be a bit on the "trigger happy" side, but:
-i would try to use the existing drives and motors and VFD/spindle
-seems like those are analog drives, so a Mesa 7i97T would do perfectly fine if you can find one, if not a 7i92T with 7i77 is the same thing, or if those are also scarce a 7i96S with 7i85 and 7i83 should do the same job.
-You will be bombarded by others to choose EtherCAT, i am still avoiding them due to some fuzzy communication issues, but i will test them for sure the fist chance i get.
Displaying 3496 - 3510 out of 14005 results.
Time to create page: 0.421 seconds
