  • scsmith1451
  • scsmith1451's Avatar
27 Mar 2026 21:48
Replied by scsmith1451 on topic Configuring and Homing dual Y Axes
Category: PnCConf Wizard
I understand your concern now. I only use probing to find my Z height. X/Y is handled by a crosshair laser. Once centered on the starting position of the cut, a button attached to g-code computes the actual position by applying offsets for both X and Y to the current location of the laser. Offsets are stored in my INI file and can be changed if needed without touching the code.
  • andrax
  • andrax's Avatar
27 Mar 2026 21:20
Replied by andrax on topic Ethercat Setup help needed for beginner
Category: EtherCAT
Er, no. It’s not that simple; LinuxCNC isn’t plug-and-play. If you don’t have any prior knowledge, you should put the A6 aside for now and start with simple stepper motors. You’ll first need to learn how the system works and what each component does. With EtherCAT, you’re moving beyond the hobbyist level, and even professionals sometimes find it frustrating.
27 Mar 2026 20:10
Replied by tommylight on topic Review Request for Arc Volt Sensor Schematic
Category: Plasma & Laser
In what way do you see 2x50k as a better way than 1x100k?
Keeps the high power stuff more isolated in case of wire break/short, making it much safer.
I always put those 3 resistors on the plasma source of in a box behind it.
  • grossm5000
  • grossm5000
27 Mar 2026 20:07
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
Category: Driver Boards
yes, mesaflash still says 5i25 not found
  • PCW
  • PCW's Avatar
27 Mar 2026 19:49
Did you try running mesaflash after running LinuxCNC?
  • djdelorie
  • djdelorie
27 Mar 2026 19:34
Replied by djdelorie on topic Configuring and Homing dual Y Axes
The problem isn't the 50ms, it's that during that time the machine is *moving*. I.e. where you home depends on the bouncing of the sensor, which means it's unpredictable, which means every other position is also unreliable.
If you "hit" on the first contact, instead of waiting for the physics to settle down, you get a more predictable "moment" when the machine is in the known state.
You'd think it wouldn't matter, but I've seen my probe go measurably past the right spot before it "hits", and my probing routines actually probe in both directions (G38.2 then G38.4, and take the average) to try to eliminate this overshoot.
With a "first hit" debouncer, you could set the debounce time to 3 seconds and still get the right value.
  • scsmith1451
27 Mar 2026 19:21
I don't see a problem with de-bouncing a signal when homing since the purpose of homing is to put the machine in a known state and stop before doing anything else. If that takes an extra 50ms to insure the starting position of all axes, it is a non sequitur since the result is the machine is stopped. It might be a minor issues when hitting a limit switch while machining, but I'd rather error on fact rather than bounce.
Just my two cents worth.
  • JT
  • JT's Avatar
27 Mar 2026 18:48
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Flex GUI has nothing to do with halui.
This is my code for my BP external Estop.
# E-Stop Chain
loadrt estop_latch count=1
addf estop-latch.0 servo-thread
# E-Stop Loop
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-loopout estop-latch.0.ok-out => iocontrol.0.emc-enable-in
# E-Stop Reset
net estop-reset iocontrol.0.user-request-enable
net estop-reset => estop-latch.0.reset
net remote-estop0 estop-latch.0.fault-in <= hm2_5i25.0.7i77.0.0.input-06-not
JT
  • JT
  • JT's Avatar
27 Mar 2026 18:43
Replied by JT on topic Flex GUI Keyboard Jogging
Category: Flex GUI
And you can now set the jog increments using the keyboard.
gnipsel.com/linuxcnc/flexgui/ini.html#keyboard-shortcuts
JT
  • JT
  • JT's Avatar
27 Mar 2026 18:42
Replied by JT on topic Jog troubles
Jog troubles
Category: Flex GUI
That's a LinuxCNC issue the joints are numbered 0-8 for xyzabcuvw so c is joint 5.
Maybe a jog axis button would work. I'd have to test.
JT
  • rodw
  • rodw's Avatar
27 Mar 2026 18:39
Replied by rodw on topic Updating Old GladeVCP Files?
Category: GladeVCP
This may not help but this 2017 post shows how to update a gmoccappy screen handler from gcode which sounds like your problem 1
forum.linuxcnc.org/plasma-laser/32691-settings-from-g-code-file
Here different values are set using an analog input which is decoded and used to modify screen elements. eg 900 and 999 change screen settings.
  • grossm5000
  • grossm5000
27 Mar 2026 18:28
kind of weird that i can see it talking to a 5i25 in the error file
  • grossm5000
  • grossm5000
27 Mar 2026 17:44
still cant seem to find the board
  • PCW
  • PCW's Avatar
27 Mar 2026 17:13
Yes, you need to install firmware that matches the 7I77
You first need to download the 5i25.zip from
 www.mesanet.com/software/parallel/5i25.zip
unzip and then change to the configs/hostmot2 directory and then
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit --reload
  • djdelorie
  • djdelorie
27 Mar 2026 17:02
Sigh, my brain couldn't help but try to fix this. My idea: change debounce() to act like this:
state in out action
neg 0 x state = -delay
neg 1 x state ++
zero 0 1 out=1 state = delay
zero 1 0 out=0 state = -delay
pos 1 x state = delay
pos 0 x state --
(if out isn't persistent, use state == +1 or -1 instead of zero)
Displaying 3661 - 3675 out of 14010 results.
Time to create page: 0.434 seconds
