  • NT4Boy
  • NT4Boy
22 Dec 2025 11:34 - 22 Dec 2025 11:42
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
I've been distracted by configuring a CAM post for this machine, and kind of blown away, that after months of learning, I can decide on a strategy, select tools speeds feed etc, and output the NC code from the CAM system and linuxcnc, parses it without comment. Not only that the machine runs the code and the the part is to drawing. Just excellent.
The orient.svg chart, while I get some of what it is telling me, i cannot understand how I need to convert it into hal statements. I thought by now I would get this stuff but I don't. which ones are loadrt, addf, setp and net ?
Sorry to be a dunce.
Could I ask for some pointers please?
  • DerKlotz
  • DerKlotz
22 Dec 2025 11:13
Replied by DerKlotz on topic SolidCAM 2021 circular pocket not generated
Category: CAD CAM
Thank you very much
  • MaHa
  • MaHa
22 Dec 2025 10:52
Category: CAD CAM
It's the xy allowance 0.25mm , using a 6mm tool machining 6.05
  • DerKlotz
  • DerKlotz
22 Dec 2025 10:38
Category: CAD CAM
Hello,
i just started with SolidCAM and try my first job -> attached photos..
All working toolpathes are blackish and one not working toolpath is blueish. Here i want a 6.05mm hole/4mm deep. Tool should be a 6mm end mill.
Tried many things but still don´t work.
Please help
  • jazzkramer
  • jazzkramer
22 Dec 2025 00:14 - 22 Dec 2025 00:26
Limit and home swithces with multiplexing with diodes and mux16 component?
Category: Basic Configuration
..AND, I see now, Mesa page says 7i84 is obsolite, there is the 7i84U now..
AND differences are:
1. Field outputs can be set to sourcing, sinking, or push pull modes on a per output basis.
2. Field outputs do not require flyback diodes for inductive loads regardless of load current.
3. 500 mA output current
So, nice! :)
Thanks! :)
  • jazzkramer
  • jazzkramer
22 Dec 2025 00:04 - 22 Dec 2025 00:12
Thank you Tommylight,
looking at the 7i84 specs pdf, it seams the easiest solution.
Inputs and outputs works from 5V to 28V so it's ok (and yes you're right about the half/half voltage, as stated in the pdf).
There are two version of this board:
sourcing outputs: (7I84)
or sinking outputs: (7I84D)
I will use inputs only for now, but... I have to decide which one is better for any possible future expansion...
Any ideas? Better sourcing or a sinking outputs?
(Post Scriptum: probably Sourcing is better?)
  • rodw
  • rodw's Avatar
21 Dec 2025 23:35
LinuxCNC latency and jitter improvements with PREEMPT_RT kernel parameter tuning
I also cover RT tuning in this video
What's not immediately clear that the servo thread and base thread are the only RT components used by Linuxcnc so that is why you only see one core in use.
  • jmelson
  • jmelson
21 Dec 2025 22:20
Pico Universal PWM Won't boot Random pins not working
Category: Driver Boards
The load fail red led does come on and stay on when I boot up linuxcnc and get the error messages. also the green estop ok led is lit as well. Prior to starting linuxcnc the light is off.
OH, didn't read closely enough!  If you are saying the Load Fail LED only stays on after LinuxCNC starts?  I know of NO WAY LinuxCNC can turn this light on, except by maybe causing a fluctuation of the 12 V supply.
Please give a bit more detail.
Jon
  • jmelson
  • jmelson
21 Dec 2025 22:17
Jon,
This is the killer problem!  The FPGA is not accepting the load of its program.  It is somewhat unlikely the EPROM has gone bad, but possible.  First, check that the +12V supply is operating properly, and does not have excessive ripple.  Without a valid program in the FPGA, nothing will ever work.  If the power supply is good, then it is possible the FPGA has been damaged, or one of the regulators on the board has gone bad or is overloaded.  You can check from the wide tab of U31 to one of the G terminals of P2.
That should read +3.3 V.  Then check the wide tab of U32, that should read +1.2V.  If either of these is out of range, something got popped.  You can also check for correct power up with the parallel port cable disconnected.  D4 (Load Fail) should blink once and then stay out.
Jon
21 Dec 2025 22:11
You can also use a simple BOB on the expansion header, adding 5 more inputs (limited by BOB, not by Mesa).
And for RS422 see Mesa 7i84, it has 32 inputs and 16 outputs that work with 24V, but also work with 5V, i am pretty sure you can have half of IO with 5V and the other half with 12V or 24V or any combination of voltages as half and half. You might want to wait for confirmation of the half/half thing from PCW as i did something like that several years ago and i am a bit fuzzy.
  • jazzkramer
  • jazzkramer
21 Dec 2025 21:40
Thanks PCW,
that's interesting... so maybe I better think about an expansion card to connect more inputs... I Know 7i96 has RS-422/RS485 and there are cards expansion with many I/Os...
I will think about. My limit switches works at 24V but I can think for a solution if this card works at a lower voltage...
  • PCW
  • PCW's Avatar
21 Dec 2025 21:21
A disadvantage of multiplexing is that the switch detection will be slower (by a factor of the servo thread period times the multiplex depth)
You could also use the parallel expansion port to add 17 more inputs (though 5V only and probable should have 220 Ohm or so
series resistors for protection)
  • jazzkramer
  • jazzkramer
21 Dec 2025 20:45
Thanks Tommylight,
I know I can connect more limits/homing to the same input, but in case of a wiring problem/fault I will have a generic "Limit switch triggered error" and I would have to check all the switches wiring...
Instead if is it possible to multiplex limit and home switches inside LinuxCNC, by adding diodes connections between switches, it will reducing the all problem to 4 inputs only. This way, in the case of triggering I have the exact error like for example "Y Limit swtich triggered", so I can check only the Y wiring (in this example).
21 Dec 2025 19:48
You do not need 12 switches for a simple machine, you need only 4 for a 4 axis machine, or for 3 axis with one of those having 2 motors/joints like gantry machines.
LinuxCNC can use the same switch for both limits and homing, it can also do all kinds of combinations to the point of using a single input for all limits and home on a 9 axis machine, granted none are tandem axis.
Here is some inspiration for DIY plasma cutting machines, certainly not the only one, but has more details about switches and reductions and overall building of such machines:
forum.linuxcnc.org/show-your-stuff/38547...-5m-cnc-plasma-build
  • jazzkramer
  • jazzkramer
21 Dec 2025 19:11
Hi all,
I have a diy Plasma with Linuxcnc (it has some mechanical problems and never got it to reliably work... due to modification of the original project due to not having the planned space in my previous location... I will solve...),
BUT I also had some wiring problems triggering limit switches...
AND, having all limit switches connected to one (or less than the total number) input in my 7i96,
I had to check every limit switch to find which wire was broken or had a loose connection (so triggering).
NOW, Hopefully in a few days, I'm going to be in another project (this NEEDS to work! :) ) adding Linuxcnc to a proper (not diy) milling machine by a Mesa 7i96S.
SO I WAS THINKING:
The Mesa 7i96S does not have enough inputs for 8 limits + 4 homing switches... SO
what if I make a diode schema to connect 8 limit switches (4 axis) + 4 homing switches to 4 7i96S inputs only and I multiplex these switches inside LinuxCNC?
I know there is a module called mux16 (or something similar, I have to check..), maybe I can connect it's output to the limit/home switches...
Has anyone tried that? Does it work?
This way if one limit or home switch get triggered when the machine is not there, I could already know the one to fix because the GUI would tell me which switch would be in error state...
Thanks for any reply,
Alberto.
Displaying 7876 - 7890 out of 14058 results.
Time to create page: 0.354 seconds
