  • Aciera
  • Aciera's Avatar
  • jaro_p
  • jaro_p's Avatar
15 Dec 2025 14:44
Changes in configuration files generated in pncconfig for 7i76 to 7i78
Category: PnCConf Wizard
Alternatively, could someone please create a bitfile for me for 7c81 with one 7i78 and port P2 entirely for encoders (i.e. at least 3)?
15 Dec 2025 14:22
  • aDm1N
  • aDm1N's Avatar
15 Dec 2025 14:15
  • cmorley
  • cmorley
15 Dec 2025 13:53
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
This should be moved to the Qtvcp section.
Looks promising! Keep is updated! If you get stumped with the programming i can try to help.
15 Dec 2025 13:44
Replied by tommylight on topic VOLATILE_HOME not unhoming on fault
Category: Basic Configuration
Does joint.N.amp-fault-in actually turn the machine off?
Yes, it does.
Not near a machine so i can not confirm this, but IIRC:
Yes it does Disable the machine.
No, it does not trigger e-stop.
  • Aciera
  • Aciera's Avatar
15 Dec 2025 13:41
Replied by Aciera on topic VOLATILE_HOME not unhoming on fault
Yes, it does.
  • Murphy
  • Murphy
15 Dec 2025 13:33 - 15 Dec 2025 13:33
I don't know about the file size @scotta ?
But scotta made the beta to try and solve my CSS problem. I still have no solution. If you have the RT1052 controller. Let me know if you can get the CSS working on your build.
  • aDm1N
  • aDm1N's Avatar
15 Dec 2025 12:19 - 01 Mar 2026 18:44
Category: Qtvcp
Repository:
github.com/peter-pan08/LatheEasyStep LatheEasyStep is an experimental QtVCP panel for LinuxCNC that enables step-by-step conversational lathe programming directly at the machine — without external CAM software.The goal is fast, safe, and practical programming for typical workshop jobs.PurposeLatheEasyStep is designed for:
  • Programming simple to medium turning operations directly at the machine
  • Repetitive standard jobs (facing, contouring, grooving, drilling, threading, roughing)
  • A workflow-focused approach:
    Enter parameters → Verify preview → Generate G-code
It aims to bring an industrial-style conversational workflow to LinuxCNC.Current Feature SetProgram Structure
  • Program header with stock/workpiece parameters
    (diameters, lengths, units, safety values)
  • Step-based program building with sortable operation list
  • Save/load for single steps and full programs
  • Bilingual UI (DE/EN)
Supported Operations
  • Facing
  • Contour
  • Groove / parting-style operations
  • Drilling
  • Threading
  • Roughing (material removal)
  • Keyway (macro-based)
Preview & Visualization
  • Live X/Z preview including reference geometry
  • Dedicated chuck safety zone visualization (color-coded with legend)
Safety & Motion Logic (Core Focus)
  • Context-aware retract/free-travel behavior per operation
  • Material-aware retract decisions
  • Extended chuck / no-go safety parameters:
    • Chuck size
    • Workpiece type
    • Clamping mode
    • Chuck profile
  • Machine/workshop profile presets for faster setup
Project Status
  • Experimental
  • Actively developed
  • Designed for real machine workflows
  • Iterative improvements based on practical use
Known Limitations
  • Not a full CAM replacement
  • Complex freeform geometry is intentionally limited
  • Machine-specific adaptation may be required
Target Direction
  • Fast conversational programming at the machine
  • Clear and understandable geometry visualization
  • Safer default behavior for common turning tasks
  • Continuous refinement driven by community feedback
Feedback WelcomeIf you test it, helpful reports include:
  • Brief machine/configuration info
  • Reproducible steps
  • Expected vs. actual behavior
  • Optional screenshots, preview images, or G-code snippets
  • zoeper
  • zoeper
15 Dec 2025 10:53 - 15 Dec 2025 11:10
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
Hi All,
At some point the S-code could be used to command the spindle speed. The control sends an analog voltage to the LARRIOZ speed control card. The card reads a sensor that counts spindle revolutions and compares it to the commanded speed. The card can then switch relays, that in turn switch the contactors driving the motorized CVT transmission between spindle and spindle motor to increase/ decrease the spindle speed as required.
This never worked since I got the mill. I did at the time try to get it to work, but due to lack of knowledge and/ or documentation, I could not get working. I would think that the lithium battery in the Dallas non-volatile SRAM would be long gone, but I am not sure what would be stored in SRAM. I assume (While I know not to assume anything) that the firmware would live on the EPROM and the SRAM might hold parameters relating to the specific installation. Other than JP 1(Jumper), and P1 (Potentiometer) there is no other configuration or programming port on the LARRIOZ HABIKON1 board.
Although slow, I prefer this system, as I would not sacrifice low speed torque, as would be the case with using only a VFD for speed control.
I suppose it would be fairly easy with modern microcontrollers to get the system going again, but I would be happy to hear from others as to their experience or suggestions as to how I should proceed.
Regards
P
15 Dec 2025 10:43
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Also, how can a person do roofing, plumbing, parquet flooring, and CNC?
Multi-talented! perhaps too multi-talented!
Stop offending people, i will not warn you again!
Instead, go read through this forum, watch pictures and videos, you might get some appreciation about what our members here are capable off.
  • rodw
  • rodw's Avatar
15 Dec 2025 10:22
Replied by rodw on topic Axis deflecting while jogging in G54
Category: QtPyVCP
It would probably be a good idea to add MaHa's G10 solution to your startup code..
  • rodw
  • rodw's Avatar
15 Dec 2025 10:19
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Did anybody get it to run with Rods guide??
E.
I don't think it works.  The master is meant to sense if of EoE is available but 2 things collide.
1. There is a bug affecting this drive in the ethercat master
2. the Linuxcnc  driver does not support EoE
I think without the bug it should fall back to supporting non-EoE mode but its a long time since I looked at this.
  • rodw
  • rodw's Avatar
15 Dec 2025 10:10
Replied by rodw on topic VOLATILE_HOME not unhoming on fault
Does joint.N.amp-fault-in actually turn the machine off? I'm not sure it does. I know it stops motion. My thinking is that conce you have the machine dialed in you will never get this error.
  • BoMadsen
  • BoMadsen
15 Dec 2025 10:04
Replied by BoMadsen on topic Issues with simple input on 7i76eu
Category: Driver Boards
Aahh shoot! I was hoping to avoid resoldering my DIY pullup resistor board. But thank you for the explanation.
Displaying 8101 - 8115 out of 14062 results.
Time to create page: 0.436 seconds
