  • Gautham
  • Gautham
25 Aug 2025 10:03 - 25 Aug 2025 10:11
Replied by Gautham on topic 5 axis milling machine with 7i96s
Category: Driver Boards
Hi again,So I finally got this BoB,  and I have wired up everything according to this video tutorial I found, but I don't know how to configure my B-axis to run through the BoB on LinuxCNC. I also managed to flash the 7i96s_5abobd.bin firmware to the mesa card but I'm not sure how to proceed on LinuxCNC
Thank you so much for your help.
  • andronick83
  • andronick83's Avatar
25 Aug 2025 09:35 - 25 Aug 2025 09:36
Replied by andronick83 on topic joywheel.comp - Joystick wheel processor
Category: Lathe Library
Added pins:
enable IN BIT - Enable joywheel
multiplier IN FLOAT - Output signal multiplier. For reverse: -1.0
  • karlhe
  • karlhe
25 Aug 2025 09:30
Replied by karlhe on topic in linuxcnc freecad 1.0 einbinden
Category: Configuration Tools
hallo Michael,
vielen Dank für Deine Hilfe. ich habe flatpak über das terminal installiert.
Wie binde ich jetzt freecad 1.0 ein?
karlhe
  • ts
  • ts
25 Aug 2025 08:37 - 25 Aug 2025 11:59
Replied by ts on topic Use of ODOT Ethercat coupler I/O?
Category: EtherCAT
Hi, Hakkan!
at this morning command PDOS -p0 give me only empty answer. After your command - lcec_configgen gives only <masters> string at all. But after manipulation - everything changed/I found information and solve this issue.So - our modules have to be flashed by configuration. Configuration generates with utility. This utility gives a bin file, which one have to be flashed into ODOT with command sii_write -p0 esi.bin .
sudo apt-get install libxml2-devgit
clone https://github.com/synapticon/siitool siitool
cd siitool
make
sudo make install
siitool -o esi.bin 'name of xml file ODOT'
ethercat sii_write -p 0 esi.bin
if needed i may send  file esi.bin (in attachment) and working xml for odot 8033 - only coupler and 222f module in config - in network ethercat only one slave - ODOT. Also - file XML from site ODOT dont work from the box when i try to compile bin file. It works in my case with XML ODOT version XML-ODOT-CN8033-V1.45-20241209.After procedure already lcec_configgen works fine. One point now - is how to automatic download sii_write to every starting of LinuxCNC because every power on, need to do sii_write procedure again...
  • Hakan
  • Hakan
25 Aug 2025 07:29
Debian tries to connect to the internet on EtherCAT network device?
Category: EtherCAT
Debian themselves say to use ifconfig in their wiki wiki.debian.org/NetworkConfiguration#Bri...ithout_an_IP_address. It's available just install it with "apt install net-tools".
There is no kernel variable to set/unset eee for the igc driver afaik. The only way is to use "ethtool --show-eee enps2s0" and "ethtool --set-eee enp2s0 eee off" or on. It was some five months since I played around with this so I might have forgotten things
forum.linuxcnc.org/18-computer/55782-adding-a-m-2-ethernet-port
  • becrazy
  • becrazy
25 Aug 2025 07:26 - 25 Aug 2025 07:34
RPi5 with LinuxCNC Image and Waveshare PCIe TO Gigabit ETH Board
Category: Installing LinuxCNC
Hello,thank you for your answer. Here are the outputs
cnc@linuxcnc1:~$ lspci -v
0000:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries BCM2712 PCIe Bridge (rev 21) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 38
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        Memory behind bridge: 80000000-800fffff =1M% [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Capabilities: <access denied>
        Kernel driver in use: pcieport
0000:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
        Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
        Flags: fast devsel, IRQ 38
        Memory at 1b80004000 (64-bit, non-prefetchable)
=4K%        Memory at 1b80000000 (64-bit, non-prefetchable)
=16K%        Capabilities: <access denied>
        Kernel driver in use: r8169
        Kernel modules: r8169
0001:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries BCM2712 PCIe Bridge (rev 21) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 39
        Memory behind bridge: 00000000-005fffff =6M% [32-bit]
0001:01:00.0 Ethernet controller: Raspberry Pi Ltd RP1 PCIe 2.0 South Bridge
        Memory at 1f00410000 (32-bit, non-prefetchable)
=16K%        Memory at 1f00000000 (32-bit, non-prefetchable) [virtual]
=4M%        Memory at 1f00400000 (32-bit, non-prefetchable)
=64K%        Capabilities: <access denied>
        Kernel driver in use: rp1
cnc@linuxcnc1:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 2c:cf:67:3a:15:bb brd ff:ff:ff:ff:ff:ff
    altname end0
    inet 192.168.0.153/24 brd 192.168.0.255 scope global dynamic eth0
       valid_lft 825164sec preferred_lft 825164sec
    inet6 fdce:a2be:2d61:0:2ecf:67ff:fe3a:15bb/64 scope global dynamic mngtmpaddr
       valid_lft 7188sec preferred_lft 3588sec
    inet6 2003:e4:9741:1e00:2ecf:67ff:fe3a:15bb/64 scope global dynamic mngtmpaddr
       valid_lft 7188sec preferred_lft 1313sec
    inet6 fe80::2ecf:67ff:fe3a:15bb/64 scope link
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether aa:57:f1:85:a9:88 brd ff:ff:ff:ff:ff:ff
    altname enp1s0
4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 2c:cf:67:3a:15:bc brd ff:ff:ff:ff:ff:ff
For
sudo dmesg | grep eth
there is no output on console.
  • Hakan
  • Hakan
25 Aug 2025 06:16
Replied by Hakan on topic Use of ODOT Ethercat coupler I/O?
Category: EtherCAT
Output of lcec_configgen?
  • ts
  • ts
25 Aug 2025 05:36 - 25 Aug 2025 06:05
Category: EtherCAT
dmesg says:
[ 42.224233] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 42.224475] EtherCAT ERROR 0-0: AL status message 0x001D: "Invalid output configuration".
[ 42.226186] EtherCAT 0-0: Acknowledged state PREOP.
additional information listing of sdos command - i have only coupler and ct222f module (16 do):
r@LCNC2:~$ ethercat sdos
SDO 0x1000, "Device type"
  0x1000:00, r-r-r-, uint32, 32 bit, "Device type"
SDO 0x1001, "Error register"
  0x1001:00, r-r-r-, uint8, 8 bit, "Error register"
SDO 0x1008, "Device name"
  0x1008:00, r-r-r-, string, 256 bit, "Device name"
SDO 0x1009, "Hardware version"
  0x1009:00, r-r-r-, string, 24 bit, "Hardware version"
SDO 0x100a, "Software version"
  0x100a:00, r-r-r-, string, 24 bit, "Software version"
SDO 0x1018, "Identity"
  0x1018:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1018:01, r-r-r-, uint32, 32 bit, "Vendor ID"
  0x1018:02, r-r-r-, uint32, 32 bit, "Product code"
  0x1018:03, r-r-r-, uint32, 32 bit, "Revision"
  0x1018:04, r-r-r-, uint32, 32 bit, "Serial number"
SDO 0x10f1, "Error Settings"
  0x10f1:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x10f1:01, rwrwrw, uint32, 32 bit, "Local Error Reaction"
  0x10f1:02, rwrwrw, uint16, 16 bit, "Sync Error Counter Limit"
SDO 0x10f8, "Timestamp Object"
  0x10f8:00, rwrwrw, uint64, 64 bit, "Timestamp Object"
SDO 0x1600, "CT-222F"
  0x1600:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1600:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
SDO 0x1c00, "Sync manager type"
  0x1c00:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c00:01, r-r-r-, uint8, 8 bit, "SubIndex 001"
  0x1c00:02, r-r-r-, uint8, 8 bit, "SubIndex 002"
  0x1c00:03, r-r-r-, uint8, 8 bit, "SubIndex 003"
  0x1c00:04, r-r-r-, uint8, 8 bit, "SubIndex 004"
SDO 0x1c12, "SyncManager 2 assignment"
  0x1c12:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c12:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
SDO 0x1c13, "SyncManager 3 assignment"
  0x1c13:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c13:01, r-r-r-, uint16, 16 bit, "SubIndex 001"
SDO 0x1c32, "SM output parameter"
  0x1c32:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c32:01, rwr-r-, uint16, 16 bit, "Synchronization Type"
  0x1c32:02, r-r-r-, uint32, 32 bit, "Cycle Time"
  0x1c32:03, ------, type 0000, 32 bit, "SubIndex 003"
  0x1c32:04, r-r-r-, uint16, 16 bit, "Synchronization Types supported"
  0x1c32:05, r-r-r-, uint32, 32 bit, "Minimum Cycle Time"
  0x1c32:06, r-r-r-, uint32, 32 bit, "Calc and Copy Time"
  0x1c32:07, ------, type 0000, 32 bit, "SubIndex 007"
  0x1c32:08, rwrwrw, uint16, 16 bit, "Get Cycle Time"
  0x1c32:09, r-r-r-, uint32, 32 bit, "Delay Time"
  0x1c32:0a, rwrwrw, uint32, 32 bit, "Sync0 Cycle Time"
  0x1c32:0b, r-r-r-, uint16, 16 bit, "SM-Event Missed"
  0x1c32:0c, r-r-r-, uint16, 16 bit, "Cycle Time Too Small"
  0x1c32:0d, ------, type 0000, 16 bit, "Shift Time Too Short"
  0x1c32:0e, ------, type 0000, 16 bit, "SubIndex 014"
  0x1c32:0f, ------, type 0000, 32 bit, "SubIndex 015"
  0x1c32:10, ------, type 0000, 32 bit, "SubIndex 016"
  0x1c32:11, ------, type 0000, 32 bit, "SubIndex 017"
  0x1c32:12, ------, type 0000, 32 bit, "SubIndex 018"
  0x1c32:13, ------, type 0000, 0 bit, "SubIndex 019"
  0x1c32:14, ------, type 0000, 0 bit, "SubIndex 020"
  0x1c32:15, ------, type 0000, 0 bit, "SubIndex 021"
  0x1c32:16, ------, type 0000, 0 bit, "SubIndex 022"
  0x1c32:17, ------, type 0000, 0 bit, "SubIndex 023"
  0x1c32:18, ------, type 0000, 0 bit, "SubIndex 024"
  0x1c32:19, ------, type 0000, 0 bit, "SubIndex 025"
  0x1c32:1a, ------, type 0000, 0 bit, "SubIndex 026"
  0x1c32:1b, ------, type 0000, 0 bit, "SubIndex 027"
  0x1c32:1c, ------, type 0000, 0 bit, "SubIndex 028"
  0x1c32:1d, ------, type 0000, 0 bit, "SubIndex 029"
  0x1c32:1e, ------, type 0000, 0 bit, "SubIndex 030"
  0x1c32:1f, ------, type 0000, 0 bit, "SubIndex 031"
  0x1c32:20, r-r-r-, bool, 1 bit, "Sync Error"
SDO 0x1c33, "SM input parameter"
  0x1c33:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x1c33:01, rwr-r-, uint16, 16 bit, "Synchronization Type"
  0x1c33:02, r-r-r-, uint32, 32 bit, "Cycle Time"
  0x1c33:03, ------, type 0000, 32 bit, "SubIndex 003"
  0x1c33:04, r-r-r-, uint16, 16 bit, "Synchronization Types supported"
  0x1c33:05, r-r-r-, uint32, 32 bit, "Minimum Cycle Time"
  0x1c33:06, r-r-r-, uint32, 32 bit, "Calc and Copy Time"
  0x1c33:07, ------, type 0000, 32 bit, "SubIndex 007"
  0x1c33:08, rwrwrw, uint16, 16 bit, "Get Cycle Time"
  0x1c33:09, r-r-r-, uint32, 32 bit, "Delay Time"
  0x1c33:0a, rwrwrw, uint32, 32 bit, "Sync0 Cycle Time"
  0x1c33:0b, r-r-r-, uint16, 16 bit, "SM-Event Missed"
  0x1c33:0c, r-r-r-, uint16, 16 bit, "Cycle Time Too Small"
  0x1c33:0d, ------, type 0000, 16 bit, "Shift Time Too Short"
  0x1c33:0e, ------, type 0000, 16 bit, "SubIndex 014"
  0x1c33:0f, ------, type 0000, 32 bit, "SubIndex 015"
  0x1c33:10, ------, type 0000, 32 bit, "SubIndex 016"
  0x1c33:11, ------, type 0000, 32 bit, "SubIndex 017"
  0x1c33:12, ------, type 0000, 32 bit, "SubIndex 018"
  0x1c33:13, ------, type 0000, 0 bit, "SubIndex 019"
  0x1c33:14, ------, type 0000, 0 bit, "SubIndex 020"
  0x1c33:15, ------, type 0000, 0 bit, "SubIndex 021"
  0x1c33:16, ------, type 0000, 0 bit, "SubIndex 022"
  0x1c33:17, ------, type 0000, 0 bit, "SubIndex 023"
  0x1c33:18, ------, type 0000, 0 bit, "SubIndex 024"
  0x1c33:19, ------, type 0000, 0 bit, "SubIndex 025"
  0x1c33:1a, ------, type 0000, 0 bit, "SubIndex 026"
  0x1c33:1b, ------, type 0000, 0 bit, "SubIndex 027"
  0x1c33:1c, ------, type 0000, 0 bit, "SubIndex 028"
  0x1c33:1d, ------, type 0000, 0 bit, "SubIndex 029"
  0x1c33:1e, ------, type 0000, 0 bit, "SubIndex 030"
  0x1c33:1f, ------, type 0000, 0 bit, "SubIndex 031"
  0x1c33:20, r-r-r-, bool, 1 bit, "Sync Error"
SDO 0x2000, "ConfigurationParameter"
  0x2000:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x2000:01, rwr-r-, type 0030, 1 bit, "SourceOfConfiguration"
  0x2000:02, rwr-r-, type 0030, 1 bit, "InputFaultAction"
  0x2000:03, rwr-r-, type 0030, 1 bit, "OutputFaultAction"
  0x2000:04, rwr-r-, type 0030, 1 bit, "DiagnosticFunctionEnable"
SDO 0x7000, ""
  0x7000:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0x7000:01, rwrwrw, uint32, 32 bit, "SubIndex 001"
SDO 0xf000, "Module device profile"
  0xf000:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0xf000:01, r-r-r-, uint16, 16 bit, "Index distance"
  0xf000:02, r-r-r-, uint16, 16 bit, "maximum number of modules"
SDO 0xf010, "Module Profile List"
  0xf010:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0xf010:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
  0xf010:02, r-r-r-, uint32, 32 bit, "SubIndex 002"
  0xf010:03, r-r-r-, uint32, 32 bit, "SubIndex 003"
  0xf010:04, r-r-r-, uint32, 32 bit, "SubIndex 004"
  0xf010:05, r-r-r-, uint32, 32 bit, "SubIndex 005"
  0xf010:06, r-r-r-, uint32, 32 bit, "SubIndex 006"
  0xf010:07, r-r-r-, uint32, 32 bit, "SubIndex 007"
  0xf010:08, r-r-r-, uint32, 32 bit, "SubIndex 008"
  0xf010:09, r-r-r-, uint32, 32 bit, "SubIndex 009"
  0xf010:0a, r-r-r-, uint32, 32 bit, "SubIndex 010"
  0xf010:0b, r-r-r-, uint32, 32 bit, "SubIndex 011"
  0xf010:0c, r-r-r-, uint32, 32 bit, "SubIndex 012"
  0xf010:0d, r-r-r-, uint32, 32 bit, "SubIndex 013"
  0xf010:0e, r-r-r-, uint32, 32 bit, "SubIndex 014"
  0xf010:0f, r-r-r-, uint32, 32 bit, "SubIndex 015"
  0xf010:10, r-r-r-, uint32, 32 bit, "SubIndex 016"
  0xf010:11, r-r-r-, uint32, 32 bit, "SubIndex 017"
  0xf010:12, r-r-r-, uint32, 32 bit, "SubIndex 018"
  0xf010:13, r-r-r-, uint32, 32 bit, "SubIndex 019"
  0xf010:14, r-r-r-, uint32, 32 bit, "SubIndex 020"
  0xf010:15, r-r-r-, uint32, 32 bit, "SubIndex 021"
  0xf010:16, r-r-r-, uint32, 32 bit, "SubIndex 022"
  0xf010:17, r-r-r-, uint32, 32 bit, "SubIndex 023"
  0xf010:18, r-r-r-, uint32, 32 bit, "SubIndex 024"
  0xf010:19, r-r-r-, uint32, 32 bit, "SubIndex 025"
  0xf010:1a, r-r-r-, uint32, 32 bit, "SubIndex 026"
  0xf010:1b, r-r-r-, uint32, 32 bit, "SubIndex 027"
  0xf010:1c, r-r-r-, uint32, 32 bit, "SubIndex 028"
  0xf010:1d, r-r-r-, uint32, 32 bit, "SubIndex 029"
  0xf010:1e, r-r-r-, uint32, 32 bit, "SubIndex 030"
  0xf010:1f, r-r-r-, uint32, 32 bit, "SubIndex 031"
  0xf010:20, r-r-r-, uint32, 32 bit, "SubIndex 032"
  0xf010:21, r-r-r-, uint32, 32 bit, "SubIndex 033"
  0xf010:22, r-r-r-, uint32, 32 bit, "SubIndex 034"
  0xf010:23, r-r-r-, uint32, 32 bit, "SubIndex 035"
  0xf010:24, r-r-r-, uint32, 32 bit, "SubIndex 036"
  0xf010:25, r-r-r-, uint32, 32 bit, "SubIndex 037"
  0xf010:26, r-r-r-, uint32, 32 bit, "SubIndex 038"
  0xf010:27, r-r-r-, uint32, 32 bit, "SubIndex 039"
  0xf010:28, r-r-r-, uint32, 32 bit, "SubIndex 040"
  0xf010:29, r-r-r-, uint32, 32 bit, "SubIndex 041"
  0xf010:2a, r-r-r-, uint32, 32 bit, "SubIndex 042"
  0xf010:2b, r-r-r-, uint32, 32 bit, "SubIndex 043"
  0xf010:2c, r-r-r-, uint32, 32 bit, "SubIndex 044"
  0xf010:2d, r-r-r-, uint32, 32 bit, "SubIndex 045"
  0xf010:2e, r-r-r-, uint32, 32 bit, "SubIndex 046"
  0xf010:2f, r-r-r-, uint32, 32 bit, "SubIndex 047"
  0xf010:30, r-r-r-, uint32, 32 bit, "SubIndex 048"
  0xf010:31, r-r-r-, uint32, 32 bit, "SubIndex 049"
  0xf010:32, r-r-r-, uint32, 32 bit, "SubIndex 050"
  0xf010:33, r-r-r-, uint32, 32 bit, "SubIndex 051"
  0xf010:34, r-r-r-, uint32, 32 bit, "SubIndex 052"
  0xf010:35, r-r-r-, uint32, 32 bit, "SubIndex 053"
  0xf010:36, r-r-r-, uint32, 32 bit, "SubIndex 054"
  0xf010:37, r-r-r-, uint32, 32 bit, "SubIndex 055"
  0xf010:38, r-r-r-, uint32, 32 bit, "SubIndex 056"
  0xf010:39, r-r-r-, uint32, 32 bit, "SubIndex 057"
  0xf010:3a, r-r-r-, uint32, 32 bit, "SubIndex 058"
  0xf010:3b, r-r-r-, uint32, 32 bit, "SubIndex 059"
  0xf010:3c, r-r-r-, uint32, 32 bit, "SubIndex 060"
  0xf010:3d, r-r-r-, uint32, 32 bit, "SubIndex 061"
  0xf010:3e, r-r-r-, uint32, 32 bit, "SubIndex 062"
  0xf010:3f, r-r-r-, uint32, 32 bit, "SubIndex 063"
  0xf010:40, r-r-r-, uint32, 32 bit, "SubIndex 064"
  0xf010:41, r-r-r-, uint32, 32 bit, "SubIndex 065"
SDO 0xf050, "Detected Module Ident List"
  0xf050:00, r-r-r-, uint8, 8 bit, "SubIndex 000"
  0xf050:01, r-r-r-, uint32, 32 bit, "SubIndex 001"
  0xf050:02, r-r-r-, uint32, 32 bit, "SubIndex 002"
  0xf050:03, r-r-r-, uint32, 32 bit, "SubIndex 003"
  0xf050:04, r-r-r-, uint32, 32 bit, "SubIndex 004"
  0xf050:05, r-r-r-, uint32, 32 bit, "SubIndex 005"
  0xf050:06, r-r-r-, uint32, 32 bit, "SubIndex 006"
  0xf050:07, r-r-r-, uint32, 32 bit, "SubIndex 007"
  0xf050:08, r-r-r-, uint32, 32 bit, "SubIndex 008"
  0xf050:09, r-r-r-, uint32, 32 bit, "SubIndex 009"
  0xf050:0a, r-r-r-, uint32, 32 bit, "SubIndex 010"
  0xf050:0b, r-r-r-, uint32, 32 bit, "SubIndex 011"
  0xf050:0c, r-r-r-, uint32, 32 bit, "SubIndex 012"
  0xf050:0d, r-r-r-, uint32, 32 bit, "SubIndex 013"
  0xf050:0e, r-r-r-, uint32, 32 bit, "SubIndex 014"
  0xf050:0f, r-r-r-, uint32, 32 bit, "SubIndex 015"
  0xf050:10, r-r-r-, uint32, 32 bit, "SubIndex 016"
  0xf050:11, r-r-r-, uint32, 32 bit, "SubIndex 017"
  0xf050:12, r-r-r-, uint32, 32 bit, "SubIndex 018"
  0xf050:13, r-r-r-, uint32, 32 bit, "SubIndex 019"
  0xf050:14, r-r-r-, uint32, 32 bit, "SubIndex 020"
  0xf050:15, r-r-r-, uint32, 32 bit, "SubIndex 021"
  0xf050:16, r-r-r-, uint32, 32 bit, "SubIndex 022"
  0xf050:17, r-r-r-, uint32, 32 bit, "SubIndex 023"
  0xf050:18, r-r-r-, uint32, 32 bit, "SubIndex 024"
  0xf050:19, r-r-r-, uint32, 32 bit, "SubIndex 025"
  0xf050:1a, r-r-r-, uint32, 32 bit, "SubIndex 026"
  0xf050:1b, r-r-r-, uint32, 32 bit, "SubIndex 027"
  0xf050:1c, r-r-r-, uint32, 32 bit, "SubIndex 028"
  0xf050:1d, r-r-r-, uint32, 32 bit, "SubIndex 029"
  0xf050:1e, r-r-r-, uint32, 32 bit, "SubIndex 030"
  0xf050:1f, r-r-r-, uint32, 32 bit, "SubIndex 031"
  0xf050:20, r-r-r-, uint32, 32 bit, "SubIndex 032"
  0xf050:21, r-r-r-, uint32, 32 bit, "SubIndex 033"
  0xf050:22, r-r-r-, uint32, 32 bit, "SubIndex 034"
  0xf050:23, r-r-r-, uint32, 32 bit, "SubIndex 035"
  0xf050:24, r-r-r-, uint32, 32 bit, "SubIndex 036"
  0xf050:25, r-r-r-, uint32, 32 bit, "SubIndex 037"
  0xf050:26, r-r-r-, uint32, 32 bit, "SubIndex 038"
  0xf050:27, r-r-r-, uint32, 32 bit, "SubIndex 039"
  0xf050:28, r-r-r-, uint32, 32 bit, "SubIndex 040"
  0xf050:29, r-r-r-, uint32, 32 bit, "SubIndex 041"
  0xf050:2a, r-r-r-, uint32, 32 bit, "SubIndex 042"
  0xf050:2b, r-r-r-, uint32, 32 bit, "SubIndex 043"
  0xf050:2c, r-r-r-, uint32, 32 bit, "SubIndex 044"
  0xf050:2d, r-r-r-, uint32, 32 bit, "SubIndex 045"
  0xf050:2e, r-r-r-, uint32, 32 bit, "SubIndex 046"
  0xf050:2f, r-r-r-, uint32, 32 bit, "SubIndex 047"
  0xf050:30, r-r-r-, uint32, 32 bit, "SubIndex 048"
  0xf050:31, r-r-r-, uint32, 32 bit, "SubIndex 049"
  0xf050:32, r-r-r-, uint32, 32 bit, "SubIndex 050"
  0xf050:33, r-r-r-, uint32, 32 bit, "SubIndex 051"
  0xf050:34, r-r-r-, uint32, 32 bit, "SubIndex 052"
  0xf050:35, r-r-r-, uint32, 32 bit, "SubIndex 053"
  0xf050:36, r-r-r-, uint32, 32 bit, "SubIndex 054"
  0xf050:37, r-r-r-, uint32, 32 bit, "SubIndex 055"
  0xf050:38, r-r-r-, uint32, 32 bit, "SubIndex 056"
  0xf050:39, r-r-r-, uint32, 32 bit, "SubIndex 057"
  0xf050:3a, r-r-r-, uint32, 32 bit, "SubIndex 058"
  0xf050:3b, r-r-r-, uint32, 32 bit, "SubIndex 059"
  0xf050:3c, r-r-r-, uint32, 32 bit, "SubIndex 060"
  0xf050:3d, r-r-r-, uint32, 32 bit, "SubIndex 061"
  0xf050:3e, r-r-r-, uint32, 32 bit, "SubIndex 062"
  0xf050:3f, r-r-r-, uint32, 32 bit, "SubIndex 063"
  0xf050:40, r-r-r-, uint32, 32 bit, "SubIndex 064"
  0xf050:41, r-r-r-, uint32, 32 bit, "SubIndex 065"
  • tcbmetalworks
  • tcbmetalworks
25 Aug 2025 04:48
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Here i have the saw. I pressure washed it like 20 times lots of wire brush on a angle grinder to all of the machined surfaces then painted it with thick oil based enamel paint. I also resurfaced all of the flat surfaces on the clamps/table on a large gorton milling machine with a shell mill. Soon I will start doing the assembly of the control box and wiring. I am going to keep a portion of the original electronic components and replacing most. Hopefully the system of controlling the hydraulic feed with a Encoder works well. If not I can scrap it for a ballscrew. slowly but surely it comes together.
  • jschulze
  • jschulze
25 Aug 2025 03:56
Looking for Stepgen Index Homing Firmware for Mesa 7i76eu & 7i85S
It worked! I don't have much time right now to play with it, but I was able to manually turn on the stepgen index-enable and it turned off and zeroed the stepgen count with the index signal. Thanks so much for your help with this, it's very much appreciated.
  • PCW
  • PCW's Avatar
25 Aug 2025 03:21 - 25 Aug 2025 03:34
Sorry,  I got the stepgen version wrong, will retry.
Try this:
File Name: 7i76eu_7i8...8-24.zip
File Size:302 KB
  • jschulze
  • jschulze
25 Aug 2025 03:12
I loaded it once and power cycled it, couldn't see anything, so I reuploaded the firmware and tried both power cycle and the --reload. I also enabled the additional encoders in my hal file.
  • PCW
  • PCW's Avatar
25 Aug 2025 02:59
Did you power cycle the 7I76EU (or use the --reload command)?
  • jschulze
  • jschulze
25 Aug 2025 02:49
Loaded up the firmware, but I'm not seeing the stepgen index-enable pins.  I looked in hal configuration and halcmd show pin in the terminal but I couldn't find them.  Would it make it easier if I picked up another 7i85S so I could have an encoder for each stepgen?  Thanks again for your help.
  • jschulze
  • jschulze
25 Aug 2025 01:50
Thanks so much. I really appreciate it. I'll load it up and give it a try.
Displaying 13681 - 13695 out of 13829 results.
Time to create page: 0.539 seconds
