  • Hakan
  • Hakan
20 Mar 2025 19:25
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
I have had the shared memory warning too. I don't think that's related to ethercat, it is something else. I ignored the warning and well it didn't go away but I can't see it causing a problem.
So the drives are in OP, good.
But you use that minimal hal file, the four lines hal file you attached?
You now need to have a hal file describing the movements and limit switches and so on. From a real linuxcnc system.
I guess you have a lathe in mind.
Your drives are cia402 drives, one way is to start from the cia402 example, link here. github.com/dbraun1981/hal-cia402/tree/main/example
You can have a look in the example ethercat-conf.xml for inspiration, but use your own.
The hal file you can use. It's for one axis, you extend it to a Z axis.
  • Tntmold
  • Tntmold
20 Mar 2025 18:52
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
I still get the shared memory buffers warnings (as before) but linuxcnc will start. The drives show to be in OP status and the linuxcnc shows the axis moving, but the steppers do not move
  • Henk
  • Henk
20 Mar 2025 18:26
Replied by Henk on topic Blown 7i84
Blown 7i84
Category: Driver Boards
Is it not possible that the blown 7i84 output resulted in a constantly on state, possibly causing the fwd and rev 3 phase contractors being active at the same time? That would cause the 3 phase CB to trip.
The relays should however be hard wire interlocked to prevent this from being possible
  • sajurcaju
  • sajurcaju
20 Mar 2025 18:18
Replied by sajurcaju on topic Missing one channel step/direction
Thanks PCW, that works fine.
  • PCW
  • PCW's Avatar
20 Mar 2025 17:57 - 20 Mar 2025 17:58
Replied by PCW on topic Missing one channel step/direction
Looks like StepConf did not connect parallel port 0 pins 8 and 9 (probably confused by the dual definition)
If you just want to drive the X and X2 outputs in parallel (not on separate joints),
you would need to add:
net xstep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net xdir => parport.0.pin-09-out
To your hal file.
  • RotarySMP
  • RotarySMP's Avatar
20 Mar 2025 17:57
Replied by RotarySMP on topic Blown 7i84
Blown 7i84
Thanks a lot.
I just rechecked. You are right. There is no single phase breaker on 3Ph power in this cabinet. It was Q2, a 3ph 16A breaker which tripped.
Downstream of this, the 24V rail of line 204 is powered through the 2A 6F2 breaker, which did not trip this time.
The field power of the 7i84 is powered off line 204 (incorrectly marked here as 200).
It is the output-03 (TB3-20) which appears to have blown, according to the damage trace on the housing of the IC.
In my search for root cause, I dont understand why a 16A 3Ph breaker would trip if there was a short in a downstream DC circuit protected by a 2A CB.
After dinner I will work back from the 24V control relay 11K6, moving back along the wiring until I get to Q2 looking for shorts. Any other trouble shooting recommendations are much appreciated.
Cheer,
Mark
  • sajurcaju
  • sajurcaju
20 Mar 2025 17:39
Here it is. I don't *know* of any changes I made.
One more thing I notice that wasn't there before, on opening Axis I get:
Unexpected realtime delay on task 0 with period 39370
before I actually do anything, like enable the motors.
  • ruediger123
  • ruediger123
20 Mar 2025 17:29 - 20 Mar 2025 17:54
Replied by ruediger123 on topic scurve trajectory planner
Hello,
attached is the hal file with the jerk pins.
Gruß Rüdiger
File Name: sim_lib.tcl.txt
File Size:16 KB
  • Hakan
  • Hakan
20 Mar 2025 17:09
Category: EtherCAT
Much better.
In the second line, the "<master idx="0">" line
add so it becomes <master idx="0" appTimePeriod="1000000">
that 1000000 number must match your SERVO_PERIOD setting in the ini file. It is normally 1000000 (= 1 millisecond)
Let's see if that is enough or if you also need to specify distributed clock settings.
  • richcolvin
  • richcolvin's Avatar
20 Mar 2025 16:54
C Axis as Second Spindle was created by richcolvin
I am looking for guidance on how to setup the C axis as a second spindle.  This is for a rose engine lathe (otbok.info/index.php?n=Main.RoseEngineLathe) where we need to use:
  1. the Spindle to rotate the piece, and
  2. the C axis to rotate the rosettes used to impart the design
We turn these quite slowly, certainly less than 10 RPM, and at times speeds approaching 3 or 4 minutes per revolution.  Thusly we are using stepper motors for both axes.
The end goal is to drive the spindle and the C axis simultaneously, but specifying a relationship percentage for their rotational speeds.  For example,
RPM of the C-axis = x% of RPM of the Spindle
Is there some documentation I can read which describes
  1. How to setup LinuxCNC to treat the C-axis as a secondary spindle, and
  2. The G-code I would use.
Apologies if this is already been asked and answered:  I searched the forum and could not find it.
  • Tntmold
  • Tntmold
20 Mar 2025 15:10 - 20 Mar 2025 15:55
Category: EtherCAT
Thanks for your help, I used the output from lcec_configgen and replaced all the BLANK halType entries as S32 or U32, but now I get other errors, am I missing information in the xml file?:
phil@SodickA:~/linuxcnc/configs/sim.axis$ linuxcnc lathe.ini
LINUXCNC - 2.9.3
Machine configuration directory is '/home/phil/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(LIB): /usr/share/linuxcnc/hallib/basic_sim.tcl
setup_kins: cmd=loadrt trivkins coordinates=xz
Found file(REL): ./ethercat.hal
LCEC: Invalid appTimePeriod of 0 for master 0 (should be 1000000).
link (updating variable file): No such file or directory
note: MAXV     max: 3.333 units/sec 200.000 units/min
note: LJOG     max: 3.333 units/sec 200.000 units/min
note: LJOG default: 1.000 units/sec 60.000 units/min
note: jog_order='ZX'
note: jog_invert={'X'}
task: main loop took 0.038776 seconds
task: main loop took 0.019003 seconds
task: 32479 cycles, min=0.000007, max=0.038776, avg=0.001059, 2 latency excursions (> 10x expected cycle time of 0.001000s)
  • Tntmold
  • Tntmold
20 Mar 2025 14:52
Category: EtherCAT
I am way to ignorant on linuxcnc to understand what to do next. They are cia402 drives (Lichuan OL3-E57H) as I have two of them I have started with a lathe config as shown on the first video of this thread. How is the ESI file different from what linuxcnc needs? Should I be using output from pdos as my xml file?
phil@SodickA:~/linuxcnc/configs/sim.axis$ ethercat pdos
=== Master 0, Slave 0 ===
SM0: PhysAddr 0x1000, DefaultSize 128, ControlRegister 0x26, Enable 1
RxPDO 0x1a01 "TxPDO 2"
PDO entry 0x603f:00, 16 bit, "ErrorCode"
PDO entry 0x6041:00, 16 bit, "StatusWord"
PDO entry 0x6064:00, 32 bit, "Position actual value"
PDO entry 0x60fd:00, 32 bit, "Digital inputs"
PDO entry 0x6061:00, 8 bit, "Modes of operation display"
RxPDO 0x1601 "RxPDO 2"
PDO entry 0x6040:00, 16 bit, "ControlWord"
PDO entry 0x6060:00, 8 bit, "Modes of operation"
PDO entry 0x607a:00, 32 bit, "Target position"
PDO entry 0x6081:00, 32 bit, "Profile velocity"
PDO entry 0x6099:01, 32 bit, "Search Switch"
PDO entry 0x6099:02, 32 bit, "Search Zero"
SM1: PhysAddr 0x1100, DefaultSize 128, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1200, DefaultSize 12, ControlRegister 0x64, Enable 1
RxPDO 0x1600 ""
PDO entry 0x6040:00, 16 bit, ""
PDO entry 0x607a:00, 32 bit, ""
PDO entry 0x60ff:00, 32 bit, ""
PDO entry 0x6060:00, 8 bit, ""
PDO entry 0x0000:00, 8 bit, "Gap"
SM3: PhysAddr 0x1300, DefaultSize 19, ControlRegister 0x20, Enable 1
TxPDO 0x1a00 ""
PDO entry 0x6041:00, 16 bit, ""
PDO entry 0x6064:00, 32 bit, ""
PDO entry 0x606c:00, 32 bit, ""
PDO entry 0x6061:00, 8 bit, ""
=== Master 0, Slave 1 ===
RxPDO 0x1600 ""
TxPDO 0x1a00 ""
phil@SodickA:~/linuxcnc/configs/sim.axis$ ethercat sdos
phil@SodickA:~/linuxcnc/configs/sim.axis$ ethercat -v slaves
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000a79
Product code: 0x00002000
Revision number: 0x00000001
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 1139426180 0 0
1 MII up open yes 1 1139427620 1440 720
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x1100/128
Supported protocols: CoE
General:
Group: EtherCAT Driver
Image name:
Order number:
Device name: OL3-E57H
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
DC system time transmission delay: 720 ns
0 MII down closed no 0 - - -
1 MII up open yes - 54668620 2396782160 0
Mailboxes:
General:
Image name:
Order number:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
phil@SodickA:~/linuxcnc/configs/sim.axis$ lcec_configgen
<masters>
<master idx="0">
<slave idx="0" type="generic" vid="0x00000a79" pid="0x00002000" name="D1">
<!--OL3-E57H-->
<syncManager idx="0" dir="out">
<pdo idx="1a01">
<!--TxPDO 2-->
<pdoEntry idx="603f" subIdx="00" bitLen="16" halPin="errorcode" halType="BLANK"/>
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="statusword" halType="BLANK"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="position-actual-value" halType="BLANK"/>
<pdoEntry idx="60fd" subIdx="00" bitLen="32" halPin="digital-inputs" halType="BLANK"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="modes-of-operation-display" halType="BLANK"/>
</pdo>
<pdo idx="1601">
<!--RxPDO 2-->
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="controlword" halType="BLANK"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="modes-of-operation" halType="BLANK"/>
<pdoEntry idx="607a" subIdx="00" bitLen="32" halPin="target-position" halType="BLANK"/>
<pdoEntry idx="6081" subIdx="00" bitLen="32" halPin="profile-velocity" halType="BLANK"/>
<pdoEntry idx="6099" subIdx="01" bitLen="32" halPin="search-switch" halType="BLANK"/>
<pdoEntry idx="6099" subIdx="02" bitLen="32" halPin="search-zero" halType="BLANK"/>
</pdo>
</syncManager>
<syncManager idx="1" dir="out"/>
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="pin-6040-00" halType="BLANK"/>
<pdoEntry idx="607a" subIdx="00" bitLen="32" halPin="pin-607a-00" halType="BLANK"/>
<pdoEntry idx="60ff" subIdx="00" bitLen="32" halPin="pin-60ff-00" halType="BLANK"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="pin-6060-00" halType="BLANK"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1a00">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="pin-6041-00" halType="BLANK"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="pin-6064-00" halType="BLANK"/>
<pdoEntry idx="606c" subIdx="00" bitLen="32" halPin="pin-606c-00" halType="BLANK"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="pin-6061-00" halType="BLANK"/>
</pdo>
</syncManager>
</slave>
<slave idx="1" type="generic" vid="0x00000a79" pid="0x00002000" name="D2">
<!--OL3-E57H-->
<pdo idx="1a01">
<!--TxPDO 2-->
</pdo>
<pdo idx="1601">
<!--RxPDO 2-->
</pdo>
</syncManager>
<pdo idx="1600">
</pdo>
</syncManager>
<pdo idx="1a00">
</pdo>
</syncManager>
</slave>
</master>
</masters>
  • Hakan
  • Hakan
20 Mar 2025 14:44
Category: EtherCAT
That xml file is an ESI file. It will not work. See my reply above.
Run "lcec_configgen" and put the output into ethercat-conf.xml.
  • PCW
  • PCW's Avatar
20 Mar 2025 14:41
Can you post your hal file?
  • Tntmold
  • Tntmold
20 Mar 2025 14:38
Category: EtherCAT
please see attached files
Displaying 17311 - 17325 out of 18505 results.
Time to create page: 1.185 seconds
