scurve trajectory planner
19 Mar 2025 14:11 #324297 by Aciera
Replied by Aciera on topic scurve trajectory planner
So when lines have no intersection, there is no extra torsion turn.
that's quite interesting.
19 Mar 2025 19:45 #324308 by ruediger123
Replied by ruediger123 on topic scurve trajectory planner
Hello,
I've been following this topic for a long time, great work.
I looked at the jerk with the Hal oscilloscope, there seemed to be outliers.
see image.
The following user(s) said Thank You: akb1212, Grotius
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Mar 2025 21:28 #324323 by Grotius
Replied by Grotius on topic scurve trajectory planner
@Arciera,
Yes. Interesting.
The clothoid takes as input the xy angle and the z angle. Derived from the 3d vector.
I personally should not design the abstract like this, where it uses xy & z angles.
I should prefer to design the abstract in pure 3d vector format. As this is cleaner in my view.
Now we need to transform xy & z angles into 3d vectors etc. I think this could be avoided.
If we should store extra info about a line vector self axis rotation 0 up to 2*M_PI. We could do a clothoid fit with multiple
torsion turns for example. The clothoid fit would then look like a helix fit.
There is still some kind of overfitting in some cases, where the clothoid fit is valid, but takes extra space into the workpiece.
This is inherent to the 4-clothoid-spline fit, as a 2-clothoid-spline can not fit like that, as it has less contrains.
I was considering to create a 2 clothoid spline library based on this 3d clothoid library. This is like downgrading the current
4-clothoid-spline. But will decide that later this year.
Hi Ruediger,
We are aware of spikes. Haha.
Even the most elegant curve seems to show acceleration spikes in halscope.
I dont have the J0 jerk pin here in my axis config.
One way to rule out spikes is to introduce back-end runners. They will filter out all spikes.
Good find btw. And nice you did some research on the codebase.
The following user(s) said Thank You: akb1212, Aciera
20 Mar 2025 17:29 - 20 Mar 2025 17:54 #324365 by ruediger123
Hello,
attached is the hal file with the jerk pins.
Gruß Rüdiger
File Name: sim_lib.tcl.txt
File Size:16 KB
Last edit: 20 Mar 2025 17:54 by ruediger123.
20 Mar 2025 20:53 #324376 by ruediger123
Hello,
I tested further and apparently the acceleration is not limited. In the ini it says 'MAX_ACCELERATION = 5000' in the halscope at approx. -10000.
Gruß Rüdiger
  • Grotius
  • Platinum Member
  • Platinum Member
20 Mar 2025 21:03 - 21 Mar 2025 20:20 #324377 by Grotius
@ Rüdiger,
Max acc scurve = 2 x acc.
at scurve inflection point the
Scurve acc = 2 x acc.
see  scurve lib abstract.
Last edit: 21 Mar 2025 20:20 by Grotius.
  • Grotius
  • Platinum Member
  • Platinum Member
21 Mar 2025 20:27 #324451 by Grotius
Hi all,
Today is activated the abc, uvw axis for the scurve planner.
It should work with look ahead.
git updated
The following user(s) said Thank You: akb1212, HalaszAttila, pommen, Aciera, Darium, hmnijp, nwallace
  • Grotius
  • Platinum Member
  • Platinum Member
22 Mar 2025 12:40 #324544 by Grotius
Hi all,
Today was a lucky day. We managed to fix acceleration spikes at the 4-clothoid-spline junctions.
The problem was solved by using a new gauss legendre and minor function updates to the clothoid3d lib.
The iteration for gaussian legendre is now set for a 16 for loop.
We can expand to 32 or 64 loops to even increase accuracy.
Now i changed the back color off halscope to plot a white background as this is nicer for websites and documents
to show pictures.
Below are some halscope results, where motion is passing trough 3d-clothoids. The acceleration spikes on
joint 0 & 1 are gone. This tells us the interpolation off the clothoid is now absolute. And without any numerical errors.
So now the clothoid interpolates just as a line or arc.
This was really a bad situation. Wich is now solved.
Git is updated.
The following user(s) said Thank You: robh, Todd Zuercher, akb1212, tommylight, jschulze, HalaszAttila, tivoi, rodw, roland, Aciera and 7 other people also said thanks.
22 Mar 2025 22:25 #324592 by ihavenofish
Replied by ihavenofish on topic scurve trajectory planner
/me feeds grotius and co more cookies and pizza
nice work
  • Grotius
  • Platinum Member
  • Platinum Member
23 Mar 2025 20:11 #324689 by Grotius
@IHaveNoFish,
Thanks!
Today i started investegating something new.  experimental code
The question is, can we use a clothoid curve for motion, just like the scurve is a curve used for motion?
The idea came up a while ago. Scurve motion uses derivates, the clothoid also uses derivates.
Somehow i used the clothoid curve for the velocity profile.
The theta start of the clothoid curve is a vector, this can be transformed to acceleration start and visa versa.
1. The x axis of the clothoid is then time.
2.  The y axis of the clothoid is then velocity.
During the curve's velocity profile, we printed the acceleration values along the curve. What i didn't know is,
the acceleration profile is not a straight line as like the trapezium or scurve motion profile.
Here is a plot of acceleration stage, mention the acceleration line. It's curved. This involves less Jerk?
Time to create page: 0.625 seconds
