scurve trajectory planner
18 Mar 2025 15:18 #324212 by Aciera
Replied by Aciera on topic linuxcnc scurve motion planner
I have seen cases where the clothoid fit result looks like overfitting.
What exactly do you mean by 'overfitting'?
19 Mar 2025 05:07 #324262 by ihavenofish
Replied by ihavenofish on topic linuxcnc scurve motion planner
i assume he means the overshooting on the lower right in the last image.
The following user(s) said Thank You: Grotius, Aciera
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Mar 2025 08:54 #324271 by Grotius
Replied by Grotius on topic linuxcnc scurve motion planner
Here is the so called overfit. To show it better i made a cube.ngc test file.
  • The problem is clearly visible.
  • Its a full torsion turn of 2*M_PI over the clothoid fit.
  • It looks for the clothoid lib the solution is valid but unwanted for us.
overview:
closup cube corner:
The following user(s) said Thank You: akb1212, Aciera
19 Mar 2025 09:24 - 19 Mar 2025 09:28 #324272 by Aciera
Ah yes I have noticed those. Seems to me that it does not occur for fillets in the XY plane.
[edit]
which makes me think, are you still transforming the space corner to the XY plane to fit the clothoid as in the paper or are you skipping that step (as I believe you wanted to at some point). If you are fitting directly in 3d than that may have something to do with it.
Last edit: 19 Mar 2025 09:28 by Aciera.
  • MennilTossFlykune
  • Senior Member
  • Senior Member
19 Mar 2025 09:53 #324274 by MennilTossFlykune
The following user(s) said Thank You: akb1212, Grotius
19 Mar 2025 10:24 #324275 by meister
Replied by meister on topic scurve trajectory planner
WTF
the installer script from the first post have removed all user writable files on my system
git clone https://codeberg.org/skynet/linuxcnc_scurve_compact
cd linuxcnc_scurve_compact/cmake
./installer
rm: cannot remove 'src/python3.11/Parser/Python.asdl': Permission denied
rm: cannot remove 'src/python3.11/Grammar/python.gram': Permission denied
rm: cannot remove 'src/kugel.scad': Permission denied
rm: cannot remove 'src/MXM': Permission denied
CMake Warning:
Ignoring extra path from command line:
CMake Error: The source directory "/" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
Current directory after build_cmake: /usr/src/MXM/linuxcnc_scurve_compact/cmake
./installer: line 9: cd: configs: No such file or directory
./installer: line 10: ./run_axis_9: No such file or directory
Current directory after run_lcnc: /usr/src/MXM/linuxcnc_scurve_compact/cmake
installer finished.
odippel@odippel:/usr/src/MXM/linuxcnc_scurve_compact/cmake$
odippel@odippel:/usr/src/MXM/linuxcnc_scurve_compact/cmake/../.$ cd /usr/src/MXM/
odippel@odippel:/usr/src/MXM$ ls -l
total 0
19 Mar 2025 10:28 #324277 by meister
my home directory is still there, puh, but
/usr/local/src/
/usr/src
and much much more other file are gone,
now i can re install my system and hope that nothing important is lost
WTF
  • Grotius
  • Platinum Member
  • Platinum Member
19 Mar 2025 10:31 #324280 by Grotius
Replied by Grotius on topic scurve trajectory planner
@Arciera,
The abstract proposes forward transformation (projection) to the xz plane.
Indeed the problem does not arise when there is no z value.
And yes we are directly fitting in 3d space.
The problem isn't there, when you do a plane fit. This is in fact a 2d fit solution in 3d space,
including forward & inverse transformation steps. We did this using the 2d clothoid lib in our
previous planners.
Maybe we can think about this problem and how to solve it using a 3d space fit.
You can state that this is a clothoid wich makes a full torsion turn, wich has no reason to do so.
  • I think the ceres is giving it a initial torsion value, and goes on with the torsion during fit iterations until a endpoint fit is found.
  • Why does it use this full torsion only in certain space corner directions? Is there a reason we don't know yet?
@Mennil,
The clothoid3d uses a non-linear solver to find the xyz endpos for the clothoid fit.
The solver will iterate to the desired endpoint in shortest way, naturally.
It's very unlikely for the ceres solver to give us a self intersecting result as shown in your picture,
unless we give incorrect input angles.
And it's unlikely we have infinite solutions regarding the 4-clothoid-spline fit.
The codebase ruled out self intersecting clohoids by making improvements to the abstract:  Abstract bug fixes
  1. In eq45, page 7, the Delta Theta is calculated by: Thetai4 - Thetai0.
    The clothoid Delta Theta produced by this substraction, is not alway's correct.
    When the incorrect value is used, it shows a self intersecting clothoid.
    Eq.45 input Angles are in the range [0,-2pi], [0,2pi]. Substraction can lead to a incorrect
    Delta Theta.
    To solve this issue, we convert back the thetai[x] into a xy vector.
    From here the signed angle between 2 vectors is calculated.
    This ensures a correct Delta Theta value.
    Problably this is also the reason why in the abstract forward & inverse transformations are used.
    In this codebase forward & inverse transformations are obsolet
  • Grotius
  • Platinum Member
  • Platinum Member
19 Mar 2025 10:37 #324281 by Grotius
Hi Meiser,
That could only done by ./build_cmake script
# flush build dir
rm -rf *
Hmm. That script is designed by Joco. But i take responsebility for it.
I know also from previous years, that this can indeed remove things you dont want to.
I experienced the same years ago, in a moment i lost my entire home dir content.
Will remove the rm in all scripts now. Sorry Meiser.
  • Grotius
  • Platinum Member
  • Platinum Member
19 Mar 2025 13:28 - 19 Mar 2025 13:32 #324293 by Grotius
@Arciera,
Attached a gcode sample. A cw and a ccw square. That contains the problem.
Extra torsion turn:
No extra torsion turn:
The investegation, i printed the clothoid result and take a look at the theta values, and compared them :
** where != means is not.
If clothoid output is like this, fit is ok:
  • theta10 Z != 0
  • theta 20 XY = 0
  • theta 14 Z = 0
  • theta 24 XY = 0
If clothoid output is like this, fit is not ok:
  • theta10 Z != 0
  • theta 20 XY = 0
  • theta 14 Z = 0
  • theta 24 XY != 0
This let me think about how to solve this. When you have the not ok situation,
you can introduce a tiny error to get the fit off-plane. A off plane fit seems to solves this issue.
So when you add 1e-6 (ultra tiny error) to one off the trimmed line's z-position, it goes off plane. Problem is solved.
So when lines have no intersection, there is no extra torsion turn.
Now i did not test any further. So i hope this is it.
Last edit: 19 Mar 2025 13:32 by Grotius.
Time to create page: 1.103 seconds
