scurve trajectory planner
20 Feb 2025 12:49 - 20 Feb 2025 13:06 #322057 by Aciera
Replied by Aciera on topic scurve trajectory planner
See my last post, looks like dogleg is not solving for gamma11 and gamma21.
[edit]
Just checked and it does seem to be adjusting gamma11 and gamma 21 but it always ends up being zero which does not quite look right to me.
Last edit: 20 Feb 2025 13:06 by Aciera.
20 Feb 2025 13:14 #322060 by Aciera
So the gamma11 and gamma21 depend on the start values, however there is another problem.
I'm running single_clothoid_fit and I changed kappa10 from 0 to 0.1 and now everything is off:
The following user(s) said Thank You: akb1212, Grotius
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Feb 2025 13:23 #322062 by Grotius
Replied by Grotius on topic scurve trajectory planner
@Arciera,
I found the buggybug. . Was not alien obstruction.
Glad in eq14 we can choose 2 interpolation models:
1. eq14_drift (archived)
2. eq14_gauss
It turns out nr. 1 works good and shows correct clothoid compound.
So nr.2 contains a buggybug. Will try to find it now.
The following user(s) said Thank You: akb1212, Aciera
  • Grotius
  • Platinum Member
  • Platinum Member
20 Feb 2025 13:30 #322063 by Grotius
@Arciera,
Yes, kappa10 is start curvature in z direction.
Gamma11 = y11, is the rigid property of the clothoid. if 0, then straight line. When 0.001 then clothoid begins to curve in a direction depending the sign off y11.
Keep also an eye on the GNU plot display max values. "set xrange [-20:80]\n"
20 Feb 2025 13:46 - 20 Feb 2025 14:01 #322065 by Aciera
We also might want to call it a fail if max_iterations have been reached:
Solution found after 1000000 iterations: gamma10 = -0.000148, gamma20 = 0.000011, s1 = 66.624893
Strange that it thinks it has succeeded when the residual is still way off (looks like its happy to have found a local minimum or something):
Last edit: 20 Feb 2025 14:01 by Aciera.
20 Feb 2025 14:22 #322070 by Aciera
Is there a particular reason for using 'Multidimensional Minimization' instead of 'Nonlinear Least-Squares Fitting' which would contain the dogleg method?
// Set up the Nelder-Mead solver
const gsl_multimin_fminimizer_type *T = gsl_multimin_fminimizer_nmsimplex2;
gsl_multimin_fminimizer *s = gsl_multimin_fminimizer_alloc(T, 3);
20 Feb 2025 14:25 #322071 by Aciera
reading this might explain why it is returning a local minimum:
www.gnu.org/software/gsl/doc/html/multimin.html
So in my opinion we are using the wrong solver.
20 Feb 2025 14:33 #322073 by Aciera
I'm way out of my depth here but this may help:
www.gnu.org/software/gsl/doc/html/nls.ht...east-squares-example
  • Grotius
  • Platinum Member
  • Platinum Member
20 Feb 2025 15:02 #322075 by Grotius
Hi Arciera,
Haha yes indeed we now use : Nelder-Mead simplex method
For now this solver prooved our codebase works ok.
Maybe we can switch solvers with a flag.
Then we can also measure different solvers performance time and choose the best one.
We will add a new dogleg solver soon, as libdogleg was kind of problematic. Github repository
also say's better to use seres solver.
The gauss now works without junction flaws, error solved in eq14_gauss.
It was kind off trickie error. It needed the theta, kappa, sharpness at the given distance.
This in combination with the gauss method, is tricky.
Result:
The drift vs gauss function in the example without fit method:
github updated
20 Feb 2025 15:17 #322076 by Aciera
Why not try the dogleg solver in the GSL library?
Playing around with one of the examples linked above, it looks like we could possibly run 'levenberg-marquard', 'dogleg' and 'double dogleg' and '2D subspace' methods with our function and the Jacobian:
  /* define function to be minimized */
  fdf.f = func_f;
  fdf.df = func_df;
  //fdf.fvv = func_fvv;
  fdf.n = n;
  fdf.p = p;
  fdf.params = &params;
  /* starting point */
  gsl_vector_set(x, 0, 6.0);
  gsl_vector_set(x, 1, 14.5);
  fprintf(stderr, "%-25s %-6s %-5s %-5s %-13s %-12s %-13s %-15s\n",
          "Method", "NITER", "NFEV", "NJEV", "Initial Cost",
          "Final cost", "Final cond(J)", "Final x");
  fdf_params.trs = gsl_multifit_nlinear_trs_lm;
  solve_system(x, &fdf, &fdf_params);
  //fdf_params.trs = gsl_multifit_nlinear_trs_lmaccel;
  //solve_system(x, &fdf, &fdf_params);
  fdf_params.trs = gsl_multifit_nlinear_trs_dogleg;
  fdf_params.trs = gsl_multifit_nlinear_trs_ddogleg;
  fdf_params.trs = gsl_multifit_nlinear_trs_subspace2D;
  gsl_vector_free(f);
  gsl_vector_free(x);
  return 0;
Time to create page: 0.447 seconds
