scurve trajectory planner
- Grotius
- Thank you received: 2349
18 Feb 2025 11:45 - 18 Feb 2025 12:06 #321911
by Grotius
Replied by Grotius on topic scurve trajectory planner
Hi Arciera,
Here is a basic powel example. It uses a equatation with 2 unknown's.
This example run's ok.
powel basic example
The residual = distance ( guess position result from first calculation up to final end position. )
I just found out why to use the gaus method....
gaus calculates clothoid length
I found it by accident, when computing the endpoint of the clothoid compound in a optimized function.
it turn's out that the Gauss method is used to get very high accuracy in a few iterations.
My current approach has the property to drift off. As values are incremented including nummerical errors.
So now finally i know why gauss is used.
Gaus vs Drift:
I guess we could simply calculate the length of our 3D residual vector and pass that back as the error value to be minimized.
Yes. Excact. That's going to be tested.
powel basic example
Gaus vs Drift:
Last edit: 18 Feb 2025 12:06 by Grotius.
The following user(s) said Thank You: tommylight, HalaszAttila, Beef
- Thank you received: 2176
18 Feb 2025 13:25 #321913
Replied by Aciera on topic scurve trajectory planner
20 iterations vs 1000
Nice.
Nice.
- Grotius
19 Feb 2025 10:26 #321971
by Grotius
19 Feb 2025 12:29 #321977
How would I add the dogleg dependencies to your cloned repo?
- Grotius
19 Feb 2025 13:01 #321980
by Grotius
@Arciera,
I think this : sudo apt-get install libdogleg-dev
In the mean time, i have seen the params[index], had a flaw. I repaired that. Git is updated.
Now still wrong results. I think the Jacobian setup is incorrect also.
19 Feb 2025 13:13 #321982
- Grotius
19 Feb 2025 13:39 - 19 Feb 2025 13:47 #321985
by Grotius
Hi Arciera,
I installed both off them in a hurry. I think this one :sudo apt-get install libdogleg2
apt-cache search libdogleg -> gives both : libdogleg-dev & libdogleg-dev
Ok,
I am a little further.
There is added a test : single_clothoid_fit();
This is a test, given a clothoid start point, end point.
It is a single clothoid, so no clothoid compound.
Ok,
Last edit: 19 Feb 2025 13:47 by Grotius.
19 Feb 2025 14:13 - 19 Feb 2025 14:14 #321990
Last edit: 19 Feb 2025 14:14 by Aciera.
19 Feb 2025 14:45 #321991
- Grotius
19 Feb 2025 17:13 - 19 Feb 2025 17:16 #322006
by Grotius
Hi Arciera,
Mr build? Huh. Wich dep is that?
I am able to let the single clothoid finish at target position ~ 50% off the cases.
using example : single_clothoid_fit();
Dogleg fails to find solution very often. Tarpos in the range x20 is ok. x200 is failing all the time.
The good news is, it works partially.
The bad new is, is fails a lot.
Here it does the job ok:
So now what to do?
Maybe try another library?
interpolation endpoint result : endpoint x: 11.000000 y: 5.000000 z: 2.000000
// Start point.
double xs = 0.0;
double ys = 0.0;
double zs = 0.0;
// Target point.
double xe = 11.00;
double ye = 5.00;
double ze = 2.2;
// Guess.
double s1 = 0.001;
double gamma10 = 0.0001; // Z
double gamma20 = 0.0001; // Xy.
double degrees_xy_start = 0.0;
double degrees_z_start = -20.0;So now what to do?
Last edit: 19 Feb 2025 17:16 by Grotius.
Time to create page: 1.081 seconds
