  • mediocre_chloride
  • mediocre_chloride's Avatar
02 Aug 2026 22:53
Replied by mediocre_chloride on topic Denford Orac ATC toolchanger component
Category: HAL Examples
Hi
i recently acquired a Denford lathe and am wondering if the comp is still around?
the wiki download is ending in a error 404.
The only other similar thing I found was this link:
www.machinekit.io/docs/developing/toolchangers/
But I am not sure it is the same thing.
Does anybody have access to the component from the original Wiki willing to share?
kind regards
02 Aug 2026 21:28
Replied by tommylight on topic LinuxCNC Version Question
Category: Installing LinuxCNC
2.9.10
Thank you for remind us to update the documentation.
02 Aug 2026 21:27
Replied by tommylight on topic DeskProto 8.1
DeskProto 8.1
Category: CAD CAM
I have a lot of questions for you, but no answer.
  • Logthor
  • Logthor
02 Aug 2026 21:14
LinuxCNC Version Question was created by Logthor
Hi all,
I just have a quick question regarding what version I should use for LinuxCNC. In your guide you say that version 2.9.8 should be used, but in the download section you say that 2.9.10 should be used. I just would like clarification on which ISO I should download and use.
  • deviltribs
  • deviltribs
02 Aug 2026 20:35
DeskProto 8.1 was created by deviltribs
DeskProto 8.1
Category: CAD CAM
Does anyone know where I can get a free license for DeskProto 8.1?
  • tuxcnc
  • tuxcnc
02 Aug 2026 20:34
Replied by tuxcnc on topic Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
hi,
with Pulse and direction top speed and precision calculus are clear  but
But how to calculate the bandwidth on a Ethercat servo drive and precision?
let say leadscrew pitch 0.100inch encoder servo 10000 ppr?
if bus cycle time is 1000000 and refClockSyncCycles=1
how to determine the top speed IPM and minimal resolution in  Inches (minimal cut).
In amateur machines, none of this matters.
You can count it for hours and buy a Chinese ball screw with a backlash  0.1 mm like me...
  • leexi
  • leexi
02 Aug 2026 20:20 - 02 Aug 2026 20:22
Replied by leexi on topic Chinise mesa clone vs Original vs Ethercat
hi,
  • hitchhiker
  • hitchhiker
02 Aug 2026 20:14
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
today.... get some stuff working...
i managed to eliminate the coupling of axis a to b axis a to c and axis b to c.
then i get it work to home on my edding marks with index signals from the encoders.
i think i am near to a working world mode?! but Z axis doesnt look ok... i upload some videos....
joint mode for handling stuff works perfect... but my world mode.. doesnt work correct... possible someone know the issue of my z axis? i double check all length and offsets for the DH parameters.... the angles are still the same (alpha).
right hand rule.. thumb as Z up.. i must doo the stuff i think... i will make some stuff from cradboard.. after this weekend..headache..
here some youtube shorts
www.youtube.com/shorts/QVSaIWWKXsQ
www.youtube.com/shorts/nbMT6QoQUbg
www.youtube.com/shorts/eSobhr9gZZ0
www.youtube.com/shorts/EBi62z3gkNc
possible i am on the wrong way with my DH parameters and rotations of each axis.. thats why i make a tool from cardboard to identify the issue
thanks
  • tuxcnc
  • tuxcnc
02 Aug 2026 19:09
interesting to know what are the step output card band with
Don't worry. In a real machine feed and acceleration are limited by mechanical parameters.
Whereas increase microstepping decreases effects. In other words there is big different for 1/2 and 1/4 and small different for 1/128 and 1/256...
  • PCW
  • PCW's Avatar
02 Aug 2026 19:05 - 02 Aug 2026 19:30
The maximum step rate will be limited by the step length and step space parameters.
In a working system, these parameters in turn are limited by the drives minimum timing values.
If the clone cards uses that same clock scheme as Mesa cards ( Stepgen base clock= 100 MHz ),
step rates to 10 MHz are possible.
  • leexi
  • leexi
02 Aug 2026 18:33 - 02 Aug 2026 19:21
Hi
test (open loop) non differential output, max step frequency output, perhaps the noise is coming from my testing probes, picture at 3Mhz this output frequency is way beyond my actual needs. and interesting to know what are the step output card band width
and At 5Mhz this is only for testing proposes my servos bandwidth are way below this output
02 Aug 2026 17:50
Replied by tommylight on topic Steuerung für Drehmaschine?
Category: Deutsch
"“linuxcnc-uspace” will also run on a standard Linux kernel for use as a simulator, but it should not be used to control hardware."
Das ist mit normaler "generic" kernel>
Mit RT kernel wir ales nutzen die LinuxCNC uspace fuhr machine steurung.
Fuhr Mesa karte, es ist besser die officiele ISO nutzen, nur wen etwas funkt nicht mit Trixie, dan nutz meine ISO.
  • Aciera
  • Aciera's Avatar
02 Aug 2026 17:35
Replied by Aciera on topic Steuerung für Drehmaschine?
Category: Deutsch
Du brauchst nur die 'Debian 13 Trixie PREEMPT-RT ISO ' runter zu laden, die hat alles was du für Mesa Karten brauchst.
  • Holzwurm56
  • Holzwurm56
02 Aug 2026 16:53 - 02 Aug 2026 17:03
Replied by Holzwurm56 on topic Steuerung für Drehmaschine?
Category: Deutsch
Es gibt wohl LinuxCNC und LinuxCNC-uspace. LCNC-uspace wäre nur zur Simulation aber nicht zur Maschinensteuerung. Die neueste Version
ist wohl Debian 13 mit LCNC 2.9.10, das ist aber mit uspace. Was soll ich jetzt am Anfang installieren? Es soll natürlich mit Mesa-Karten z. B.
7I96 zusammenarbeiten.
  • Aciera
  • Aciera's Avatar
02 Aug 2026 16:21
Category: Deutsch
habe mir aus dem Forum von Tommylight LM22.1 mit LCNC2.10 runtergeladen
Warum nicht die offizielle stabile Version 2.9.10 von hier linuxcnc.org/downloads/ statt irgend eine master version von vor einem Jahr?
Displaying 1876 - 1890 out of 12540 results.
Time to create page: 0.377 seconds
