PUMA 200 Robotarm and some Hal/INI issues
- hitchhiker
- Thank you received: 21
31 Jul 2026 13:48 #348287
by hitchhiker
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
Ok!
What me help:
If i jog in joint mode... what is correct?
J0 + turns it left
J0 - turns it right
J1 + lift up
J1 - lift down
J2 + lift up
J2 - lift down
J3 + turns right
J3 - turns left
J4 + lift up
J4 - lift down
J5 + turns right
J5 - turns left
I ask this because i am still wondering with my setup frlm the first ini i can move the z straight up and down x and y small dent or bend..
But on the end the inversekinematic fails.
Your idea is to bring the arm in a position where every joint is slightly + - 5 deg? To go out of the singularity?
Thank you!
What me help:
J0 + turns it left
J0 - turns it right
J1 + lift up
J1 - lift down
J2 + lift up
J2 - lift down
J3 + turns right
J3 - turns left
J4 + lift up
J4 - lift down
J5 + turns right
J5 - turns left
Thank you!
- Thank you received: 2177
31 Jul 2026 14:37 - 31 Jul 2026 14:40 #348292
Replied by Aciera on topic PUMA 200 Robotarm and some Hal/INI issues
Well, it depends on how you derive your DH parameters. You'll just have to go through the process I'm afraid, so please look at the linked tutorial regarding modified DH parameters, there is a graphical explanation of how the coordinate system is manipulated to build the kinematic chain from the base to the tool tip and how that will give you the correct DH-{D,A,ALPHA} values.
That process will also define the correct sense in the joint rotations by using the right hand rule with the thumb pointing in the Z-axis direction.
Again, please look at the linked explanation of wrist-singularity.
Also, I would just ignore the 'inverted Tool coordinate system' until you get things working like the 'puma560' sim.
Not 'every' joint, but joint 4 and joint 6 must not be close to being collinear.Your idea is to bring the arm in a position where every joint is slightly + - 5 deg? To go out of the singularity?
Last edit: 31 Jul 2026 14:40 by Aciera.
- hitchhiker
31 Jul 2026 19:10 #348304
by hitchhiker
youtube.com/shorts/PnO5MxeK1Xg?is=1G0Dy59B0bhhUQdd
I have a small success...old ini... home and homeoffset to zero.. jog to marked position (edding/sharpie on the joint..).. then homed to index.. bring all in a non singular position... start g code...
I think this was a step in the right direction... but z stays not on z on the table.. but on the linuxcnc dro
Heeeelp
thanks
Heeeelp
- NWE
- Thank you received: 84
31 Jul 2026 20:21 #348307
by NWE
Replied by NWE on topic PUMA 200 Robotarm and some Hal/INI issues
Are you saying Z does not operate correctly on the machine although it displays correctly in the DRO? If so then I would first suspect the problem would come from having some joint not zeroed at the exact true zero point. I think a slightly incorrect DH parameter would create the same symptom.I have a small success...old ini... home and homeoffset to zero.. jog to marked position (edding/sharpie on the joint..).. then homed to index.. bring all in a non singular position... start g code...
- hitchhiker
31 Jul 2026 20:27 #348308
by hitchhiker
I only had zero x y z in genser mode... not correct?!
I know that when i rotate A axis the B axis make moves.. because the mechanical stuff inside the hand goes over small gears.. but this should not be the problem or???
- NWE
31 Jul 2026 20:41 #348309
by NWE
disclaimer:
I have not yet had opportunity to run a LinuxCNC robot, except for playing with the sim. I have spent many hours programming/repairing Fanuc and ABB robots. Some day when I have enough projects completed to make more space in my shop I want to buy an old robot and put LinuxCNC on it.
First at powerup you have to zero every joint, did you do this?
disclaimer:
- hitchhiker
31 Jul 2026 21:14 #348312
by hitchhiker
Yes.. power up.. start linuxcnc... loose the brakes.. bring all joints to the sharpie marked position. Then reference/home to the index of every single encoder.
After this all joints at zero. B axis has offset 1 degree that there no failure message comes from linuxcnc because.. if all joints at 0 degree they are in singluarity... thats why its needed to brin as example a small offset to the B axis.
Thats how i understand it.
- NWE
31 Jul 2026 22:23 #348313
by NWE
That all sounds correct. I think I misunderstood your problem with Z position. Can you provide more details?
- hitchhiker
01 Aug 2026 03:05 #348321
by hitchhiker
Which infos you need?
I can upload actual hal and ini again.
I thinking about the issue with the moving b axis when turn a axis.
Issue is that the b axis encoder is not reading the moving because it comes from the mechanical buuld of a ans b axis. Should i make a video???
- hitchhiker
02 Aug 2026 20:14 #348392
by hitchhiker
today.... get some stuff working...
i managed to eliminate the coupling of axis a to b axis a to c and axis b to c.
then i get it work to home on my edding marks with index signals from the encoders.
i think i am near to a working world mode?! but Z axis doesnt look ok... i upload some videos....
joint mode for handling stuff works perfect... but my world mode.. doesnt work correct... possible someone know the issue of my z axis? i double check all length and offsets for the DH parameters.... the angles are still the same (alpha).
right hand rule.. thumb as Z up.. i must doo the stuff i think... i will make some stuff from cradboard.. after this weekend..headache..
here some youtube shorts
www.youtube.com/shorts/QVSaIWWKXsQ
www.youtube.com/shorts/nbMT6QoQUbg
www.youtube.com/shorts/eSobhr9gZZ0
www.youtube.com/shorts/EBi62z3gkNc
possible i am on the wrong way with my DH parameters and rotations of each axis.. thats why i make a tool from cardboard to identify the issue
thanks
thanks
The following user(s) said Thank You: NWE
Time to create page: 0.144 seconds
