  • Aciera
  • Aciera's Avatar
31 Jul 2026 05:08
Replied by Aciera on topic PUMA 200 Robotarm and some Hal/INI issues
Ah, I see what you mean, the A value being 180° because the tool coordinate frame is pointing away from the flange. You are rotating the tool frame in the kinematics. Ok that shouldn't be the problem then.
Can you post a screenshot of the situation when you start the example program?
  • GeckoWorks
  • GeckoWorks
31 Jul 2026 04:53
Replied by GeckoWorks on topic USB haas operator panel interface
Category: Other User Interfaces
I went a bit deeper into this rabbit hole and picked up some used panels. Still waiting for them to arrive. Not Haas though - I missed out on that deal.
But it turns out, sometimes (often?) these panels are a mix of both a raw matrix output and USB or PS/2. Like the Syntec and their clones as shown here . In the latter case, the "CNC'ish" buttons are all just a matrix but the keypad/numpad come out as a standard PS/2 protocol.
  • meister
  • meister
31 Jul 2026 04:49
I use ./bin/rio-flow riocore/configs/TangNano9K/config.json
The automatically generated ini and HAL files cannot output a 1kHz PWM spindle signal. Do I need to edit the HAL and ini files myself to output the spindle PWM signal?
What does your setup look like?
Which interface are you using, and where do you want the PWM output to be?
To use the spindle in LinuxCNC, you still need to configure it in the “Signals” tab.
  dty/net = spindle.0.speed-out
  enable/net = spindle.0.on
@all WARNING: Serial/USB does work, but it's really just for testing;
I wouldn't use it in a production environment.
  • GeckoWorks
  • GeckoWorks
31 Jul 2026 04:46
Replied by GeckoWorks on topic Control panel
Control panel
Category: Show Your Stuff
I was away for a bit but thanks so much Mass.
Thanks for elaborating on why you went with encoders. Syncing with display sliders and resetting to 100% on a press of the knob sounds like good ideas.
I think I read somewhere that the sliders can be made to move with the rotary switches and then if you go to make an adjustment on the slider, it overrides the physical knob. And then when you turn the knob again, that takes over and the slider follows along.
But I can imagine going back to the knob might make some abrupt speed changes. So, having full sync all the time and thus encoders sounds preferable unless one is OK with never/rarely using the sliders.
In the meantime, I picked up three used panels for a steal. They are not SKs but the arduino project and your info will still come in very handy when it's time for me to try to hook them up. If I give up on those, they were so cheap, I can grab an SK4 and make it happen faster thanks to this thread:)
  • meister
  • meister
31 Jul 2026 04:37
Hi Guys. I have used RIOcore on a Tang Nano 9k (TangBOB board) a couple of times. I am now wanting to try out Ethercat. I was wondering what my options are for doing this. I want to use a RP5 with the Tang connected via an SPI connection to the GPIO pins on the RP5. My first question is where do I connect my Ethercat Drives? from the RP5 or from the Wiznet module connected to the Tang. I would dearly love it if all my configurations for Ethercat can be done within RIOcore.
Cheers
Andrew
Hi Andrew,
EtherCAT must be connected directly to the RPi5. Rio runs independently of it; it can only adopt part of the configuration (and even then, only to a limited extent).
  • GeckoWorks
  • GeckoWorks
31 Jul 2026 04:20
RS485 + Absolute Encoder for Homing a 4th Axis?
I got my hands on a used 4th axis but need to put in a new servo which is fine. I have a Delta B3 750w servo and drive with absolute, multi turn encoders on the way (used, too).
The machine will have Mesa cards but given that the 4th axis supposedly has no homing sensor (still waiting for it to arrive), I was hoping to be able to home it to the absolute encoder of the servo.
Would it be possible and not too difficult to use the RS485 from the drive into the host PC (with a USB adapter) to do the homing? AI seems to think so but I don't know how well versed it actually is in LCNC. It did however say that latency shouldn't really be an issue given that this is homing routine done at the start and not something that happens during actual machining.
If this is not doable or takes a lot of trickery, I will try to put in a small hall effect sensor and home to that + Z-pulse. But would be nice if I didn't need to do that.
  • rodw
  • rodw's Avatar
31 Jul 2026 01:20
Replied by rodw on topic DIY CNC
DIY CNC
Category: Milling Machines
Cool, I will probably go with the parallel port in the meantime, then. I should have enough I/O with the parallel port to control my x, y, and z axes and my spindle, right? I'm just looking for a yes or no regarding the timing issue and whether it would be a problem or not in making that part (assuming I have 15000-20000 nanoseconds jitter).
Yes, I have started a video series on a parallel port control board from scratch. This is the first of 3
This is new for me as I've only used Mesa and Ethercat before.
Spindle is working fine with 0-10v control, There is enough inputs for estop, probe, home switches and outputs for coolant, mist etc so it will be complete.
The plan is to redo the spindle to use RS485 Modus and eventually migrate it to Mesa and even Ethercat. This is more of a training video than for a specific machine although I'll eventually build one for it.
  • viewsat
  • viewsat
31 Jul 2026 01:02
  • Logthor
  • Logthor
31 Jul 2026 00:47
Replied by Logthor on topic DIY CNC
DIY CNC
31 Jul 2026 00:25
Wire EDM 4 axis, seems to be open source and 3D printed
They just posted this, but 15000$ seems a bit far out, although the only thing close to it is BaxEDM and i do not know what that goes for, so might still be OK price.
I wonder if they implemented the "back off on short" functionality, i know someone on youtube did some 10 years ago.
And they use the open source nature to to their benefit with "no cloud, private, etc" , nice.
  • dbtayl
  • dbtayl
31 Jul 2026 00:18
Prvomajska G301 Milling machine converting to CNC
I've found having a spindle encoder really nice. Specifically, the spindle-stall detection. It's definitely saved breaking some tools. Depending on how the spindle is set up, you may be able to get that without an encoder (and it may be a non-issue anyway if you use your machine within its limits and don't have a dubiously-tuned servo as the spindle motor).
30 Jul 2026 23:53
Highlighted gcode doesn't follow current position.
Category: Gmoccapy
After posting that image of the g code I believe I see it now. The % symbol is on line 5. So that would explain everything being off set considering the line is starting at 1...
I knew it had to have been something silly.
Update: That was it....
Thank you for reporting back.
30 Jul 2026 23:52
Category: Gmoccapy
Upload a picture of the whole screen.
Also, please post the gcode
You did neither, seems you are hiding something...
Yet you ask us for help.
30 Jul 2026 23:46
Replied by tommylight on topic Prvomajska G301 Milling machine converting to CNC
Hello Tommy, haven't seen you for quite some time so definitely ill visit you!
You are welcomed, always.
Coffee's on me.
  • dbtayl
  • dbtayl
30 Jul 2026 23:45 - 31 Jul 2026 00:11
Replied by dbtayl on topic DIY CNC 2
DIY CNC 2
Is there a cheap way of acquiring tools for the mill (e.g., cylindrical edge finders, collets, drill bits, end mills, etc)?
Oops, it was in this thread...
I highly recommend NOT buying the cheapest of the cheap cheap no-name stuff. Cheap collets are prone to having high runout. The Sherline is a small machine, so you're probably using small tools. If you have 0.002" runout in your collet and are using a 1/8 2-flute end mill that's expecting a 0.001" chip load... you may well have one flute taking NO cut, and the other taking 0.003"- 3 times as much as you expect. Really easy to break tools "for no reason" like that. Even if you don't, tool life, surface finish, and dimensional accuracy will all suffer.
I don't know what collet types you need. For ER collets, I've found Techniks to work well for me. IIRC they're... $15ish each. I got mine on eBay. You probably only need a couple? 1/8, maybe 3/16 and 1/4"? You're not working with much power, so the larger tools aren't going to buy you too much (non-zero, though- larger tools for facing and/or more rigidity for deeper pockets is useful even if you can't put more power into them)For end mills, I don't use HSS, so can't speak to that. For carbide, any of the following places will get you good tools at reasonable prices:
onlinecarbide.com/
www.maritool.com/
www.carbidetoolsource.com/
routerburr.com/
Double-ended end mills can save you a bit on cost. For drills, I really like the PCB drills. At that last link, you can get them for cheap. The nice thing about them (in addition to being cheap) is they have a common 1/8" shank size, so you can use the same collet you use for end mills to hold them instead of a drill chuck (one less thing to buy, no drill chuck eating a mile of Z height).
For workholding, I've found the screwless "grinding vises" to be excellent. I've heard that even the cheapest of the cheap of these are actually pretty OK, but can't vouch for that. I got mine here: littlemachineshop.com/collections/screwless-vises Just make sure you get clamps that can hold it down.
I haven't tried these, but supposedly the Xin Dian self-centering vises are shockingly good for their price: xindianprecise.com/collections/manual-self-centering-vise If you're flipping parts over, you can avoid having to re-center in one axis at least... two if you also use a work stop.
Other assorted tools: IMO buy as you go and buy nice used stuff. eBay can be good for this, but also if there are industrial surplus auctions near you a lot of times you can get the common stuff dirt cheap, since a lot of that customer base already has the basics you're looking for. Searching "<name of big company around me> surplus" may turn up auctions that a lot of large companies regularly have to get rid of stuff.
Displaying 1996 - 2010 out of 12540 results.
Time to create page: 0.414 seconds
