  • royka
  • royka
12 Jan 2025 10:02
Real-time kerel not detected on patched 6.12
Yes but we were talking about 6.12 and up, of course for 6.1.x you still need patches.
  • nicton
  • nicton
12 Jan 2025 10:01 - 12 Jan 2025 10:08
How do I configure the connection of two mesa 7i92 via ethernet?
Я сделал конфигурацию через pcconf, но linux cnc на нем не загружается. Если я загружаю конфигурацию с одной платой, то запускается linux cnc. Должен ли мой компьютер иметь два порта LAN для подключения двух плат?
  • alangibson
  • alangibson
12 Jan 2025 09:36
RPi 5 with 6.12 PREEMPT_RT = Using POSIX non-realtime
Category: Installing LinuxCNC
 So is there a bug in the PREEMPT_RT support in the 6.12 kernel, or is it simply not implemented the way LinuxCNC has come to expect? Obviously LinuxCNC needs to support a working standard.
This conversation is a bit confusing because rodw and I are doing different things to get the same result.
I am starting with Raspberry Pi OS, switching to their 6.12 branch then building the kernel to enable PREEMPT_RT. I'm doing this because they don't have a kernel build of 6.12 with realtime enabled yet.
rodw is starring with plain Debian and using a build system to create an image for the Raspberry Pi.
Sidenote: all realtime code is merged in upstream 6.12 now, but you still have to enable it at build time with a configuration option. There's no way to turn realtime on and off after it's built.
  • cmorley
  • cmorley
12 Jan 2025 09:35
Replied by cmorley on topic Qtdragon_hd wrong preview
Category: Qtvcp
What version of linuxcnc are you using?
Can you post your config files?
How is the path displayed wrong?
  • vre
  • vre
12 Jan 2025 09:11
Qtdragon_hd wrong preview was created by vre
Category: Qtvcp
I have setup a knee mill with qtdragon_hd within these limits in mm
X 0min 950max
Y -380min 0max
Z -400min 0max
But does not display in preview correct the path.
How can config this?
also does not show me in manual mode
spindle set rpm slide bar and spindle override rpm
  • spumco
  • spumco
12 Jan 2025 08:39
4th axis build - Can I use Mitsubishi Servo Motor HF-SP102 (1kw) via SSCNET-III
I assume you posted some info on your 4th axis build so I'll do some reading up on the homing.
I can't remember if I did or not, but the homing wound up being pretty convoluted because I was out of HS encoder inputs and had zero room to stuff another Mesa board in the enclosure.
  • Solution - use the drive's internal home-to-encoder-index function (Copley XSL)
  • I wound up using some relays and HAL logic so that when I pushed the "Home-A" button
    • LCNC sets home (i.e. G53 A0) without commanding the drive to do anything
    • joint.3.homing sends an output to trigger the A-drive to home itself
    • When the drive finishes homing, it sets an output that's connected to joint.3.home-sw-in
It works, and is like a low-tech version of the absolute homing the Ethercat folks use to 'trick' LCNC in to behaving with hardware capable of external homing.
  • hmnijp
  • hmnijp
12 Jan 2025 08:27 - 12 Jan 2025 08:31
Replied by hmnijp on topic Installing ethercat repositories
Category: EtherCAT
If you are still having problems installing, I suggest you first uninstall all possible previously installed keys and repositories:
sudo rm -f /etc/apt/sources.list.d/ighvh.sources /etc/apt/sources.list.d/linuxcnc-ethercat.list /etc/apt/sources.list.d/science_EtherLab.list /etc/apt/trusted.gpg.d/linuxcnc-ethercat.gpg /etc/apt/trusted.gpg.d/science_EtherLab.gpg*
and then run the script from the first post.
wget -O ecat.sh https://forum.linuxcnc.org/media/kunena/attachments/20660/ecat.sh.txt
chmod +x ./ecat.sh
sudo ./ecat.sh
Or you can run the updated script, which will do this immediately. I've attached it.
wget -O ethercat-repos-update.sh https://forum.linuxcnc.org/media/kunena/attachments/34171/ethercat-repos-update.sh.txt
chmod +x ./ethercat-repos-update.sh
sudo ./ethercat-repos-update.sh
  • Aciera
  • Aciera's Avatar
12 Jan 2025 08:25
Replied by Aciera on topic G2
G2
What have you set as your tool diameter and how much is 'too small'?
12 Jan 2025 04:53
Replied by Cant do this anymore bye all on topic Real-time kerel not detected on patched 6.12
Like you assumed before I think those patches indeed didn't make it to the mainline kernel, but those are not needed to make a fully preemptible kernel.
The sysfs patch is only needed because LinuxCNC checks that indicator. Later I saw that the source of Raspberry also already has the arch_supports_rt in the kconfig.
Whilst it does have that it's not the correct value.....from the required patch I've used with 6.1.69
config ARCH_SUPPORTS_RT
-    bool
+    def_bool y
  • Lcvette
  • Lcvette's Avatar
12 Jan 2025 04:16
Replied by Lcvette on topic Probe basic Install errors
Category: QtPyVCP
If you have Facebook you can join the basic group, may be easier to troubleshoot in real-time
www.facebook.com/groups/probebasic/?ref=share&mibextid=NSMWBT
  • Lcvette
  • Lcvette's Avatar
12 Jan 2025 04:13
Category: QtPyVCP
How did you install probe basic?
12 Jan 2025 04:02
Used Laptops tested with LinuxCNC and Mesa Ethernet boards
-T470 = 380 Euro about 2-3 years back, 8GB RAM, 512GB NVME, touchscreen FHD
-Y370 = 200 Euro a few months back, 16GB RAM 512GB fast NVME, touchscreen FHD with VACOM pen, plus 30 Euro for the original docking station, ThunderBolt with 2 DP and many USB ports.
-Carbon X1 Gen1 = 120 Euro a few months back 8GB RAM 256GB NVME, touchscreen FHD with VACOM pen
-X240 = 50-70 Euro a few months back, 8GB RAM, 120GB M.2 SSD, both with 2 batteries included but both with 1 dead battery.
Considering very high quality parts and HD touchscreens, X1 and Y370 also with VACOM and pen, all the horspower, still cheaper than any combo of RPI5 here, last i checked the 4GB version was 140 Euro and a 7" cr@py touchscreen was 110, add some storage and...
The luck included to have them all usable for LinuxCNC with absolutely no fiddling is just an added bonus.
  • spumco
  • spumco
12 Jan 2025 03:19
Replied by spumco on topic pncconf Clearpath SDSK settings
Ok, we'll solve this in steps.
  • First...a little background and perhaps some context.
    • As @rodw pointed out, PNCconf is not able to cover every hardware configuration available.  I know Clearpaths are pretty common now, but they weren't when PNCconf was created.  And there aren't a ton of folks using Clearpaths with LCNC now - at least not those who have reported/described/posted plenty of helpful configs to copy.
    • This means the HLFB signal is not 'typical' - especially since Teknic has made a boatload of different options available through that single output.
    • What you're gonna have to do is some manual editing of the HAL file once you get a basic configuration working (i.e. motors move like you want, more or less).
    • Note that the HAL file (or files, you can have more than one) is simply a text file with a bunch of what looks like gibberish... but represents a configuration of what logical functions inside LCNC are connected to various hardware.
    • Once you get a really basic config you (we) will then edit the HAL file to include the HLFB function.
  • Can you get through PNCconf far enough to get the motors turning?
  • Have you decided what function you want the HLFB signal to accomplish?
    • Simple motor fault?
    • Something exotic, like PWM output of motor load?
  • Gantry homing/squaring
    • Clearpaths have home-to-hardstop and other features, but to keep everything simple you will disregard all the Teknic features and treat them like 'dumb' motors - albeit with encoders and fault outputs.
    • Clearpaths will be programmed to 'home in place' (I think that's the term/concept) - so they will never be internally homed.
    • At drive enable, they will just sit there until you tell LCNC to start the homing sequence.
      • LCNC will command both motors to move towards the limit switch(s), and LCNC will manage moving to the switch, then backing off until the switch just clears, then moving back until the switch just triggers.
    • The exact homing process is adjustable in LCNC, but be advised it can be annoying to wrap you head around the homing terminology.  This may be painful for you - it is for me, even now.
    • Two limit switches are require; one on each Y-axis side.
So far so good?  Lets get the motors turning (on the bench) and then proceed.
  • rodw
  • rodw's Avatar
12 Jan 2025 03:05
For Raspberry I think following this guide should help: github.com/by/RT-Kernel
Only after git clone, download this patch:
forum.linuxcnc.org/media/kunena/attachme...ernel-realtime.patch
Then enter the Linux folder and enter: git apply ../sys-kernel-realtime.patch
After make menuconfig make sure that these are also selected:
forum.linuxcnc.org/38-general-linuxcnc-q...6-12?start=10#315643
This does not work in all build environments. I think Cornholio is correct
12 Jan 2025 03:02
Replied by Cant do this anymore bye all on topic Used Laptops tested with LinuxCNC and Mesa Ethernet boards
Shh tommy, you're going to push up the price of T series Lenovos ;). Us poor sods on limited funds may not be able to afford the toughest laptops built, definitely better built than the discs in my spine . I've had my T530 pro-covid, maybe a year or 2 and it does everything I need it to do.
Displaying 20071 - 20085 out of 21712 results.
Time to create page: 0.361 seconds
