  • Aciera
  • Aciera's Avatar
25 Dec 2024 12:24 - 25 Dec 2024 12:27
Skew correction/perpendicularity correction (millkins or millkins_xyz)
Category: Basic Configuration
1. It's not a '.comp' file but '.c' (the 'comp' format is a more recently added way of creating kinematics files ) also you must not change the file name as the trt-kinematics consists of more than just 'trtfuncs.c'
2. if you want to try to compile it with halcompile just use my file to replace the standard 'trtfuncs.c' file and then do
sudo halcompile --install src/emc/kinematics/trtfuncs.c
3. If halcompile fails to compile it then you probably need to build linuxcnc locally from the repo first,  replace the 'trtfuncs.c' and recompile using 'make'
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
  • ihavenofish
  • ihavenofish
25 Dec 2024 11:58
Replied by ihavenofish on topic PathPilot V2 source code
Category: PathPilot
if its not the lastest one for the 1500mx, it is not the one we are talking about. keep that in mind. the older one is the same tp as is already in linuxcnc.
  • abdulasis12
  • abdulasis12
25 Dec 2024 11:51 - 25 Dec 2024 11:58
Hi , Aciera
I see in your sim and result  its so AWSOME ....
I want to try, I create file name
xyzbc-trt-kins.comp  and inside I put your code skew + xyzbc .
and compile it's.
but show error can't to unpack
what I'm wrong for compile file ?
FYI: I compile on new PC to test first , Because I fear this made my CNC PC broken and can't to working.
Thank you,
Asis
  • Hakan
  • Hakan
25 Dec 2024 11:41 - 25 Dec 2024 12:29
Replied by Hakan on topic PDO variable 64 bit
PDO variable 64 bit
Category: EtherCAT
No, it is your drive.
Sorry, I am not being very helpful.
But you got to start with what the drive delivers to linuxcnc.
I doubt that it is a 64-bit float. Maybe a 64-bit integer, but also unlikely.
Anyway, you need to know what datatype the drive delivers.
When that is known, it can be converted and taken care of.
Actually the "ethercat pdos" doesn't list the datatype.
You can try with "lcec-configgen", it is better at guessing the datatype.
Nothing beats the manual though.
  • papagno-source
  • papagno-source
25 Dec 2024 11:29
Replied by papagno-source on topic PDO variable 64 bit
PDO variable 64 bit
Category: EtherCAT
Sorry, but I can't understand why look at what the drive can handle.
The problem is related to linuxcnc.
The created pin of pos-command is declared as a 32-bit float.
The drive returns more than 8,000.000 revolution counts and so after the movement of 326 cm, the variable becomes negative.
My question is: can we declare the created pin pos-command as a 64-bit float, so that we can handle larger values?
how do we do it, declaring: halType="double"?
  • aikiaviator
  • aikiaviator
25 Dec 2024 11:29
Replied by aikiaviator on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Ahh... missed AXES = 3, now in. Tried GEOMETRY = xyzac (can you confirm this would be correct?)
And I put everything back into Post Gui, except still posts the following and wont let kickoff.
  • Hakan
  • Hakan
25 Dec 2024 11:16
PDO variable 64 bit
Category: EtherCAT
In the bash prompt, you type in the command "ethercat pdos". This will list all pdos of all ethercat slaves in your system.
You have to wade through that output and see what options the device give you.
  • papagno-source
  • papagno-source
25 Dec 2024 11:07
PDO variable 64 bit
Category: EtherCAT
i use debian 10 with linuxcnc 2.9.pre0 and ethercat 1.5.
for use Pdo at 64 bit write in xml :
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="poscommand" halType="double" scale="838860.7"/>
  • Sandro
  • Sandro
25 Dec 2024 10:17
Probe Basic M6G43 (m6_tool_call_tool_page) not working
Category: QtPyVCP
This works! Thank you very much! I totally overlooked it in the documentation and actually removed it from my old configuration.
Is there a way, that a tool touch off is automatically performed on every tool change?
  • Hakan
  • Hakan
25 Dec 2024 09:58
PDO variable 64 bit
Category: EtherCAT
You look at the drive's capabilities
ethercat pdos
  • papagno-source
  • papagno-source
25 Dec 2024 09:50
PDO variable 64 bit
Category: EtherCAT
i use debian 10 , with ethercat.
How can search path for this datatypehandler.ccp , for ceck if have support for 64 bit ?
If not have support , i can patch manually and recompile.
The sintax for use is :
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="poscommand" halType="float-double-ieee" scale="838860.7"/>
or
  • csurimilan
  • csurimilan
25 Dec 2024 09:48
Replied by csurimilan on topic Versaprobe
Versaprobe
Category: Qtvcp
so the versaprobe i can use only with the 3d probe correctly?
  • papagno-source
  • papagno-source
25 Dec 2024 09:41
PDO variable 64 bit
Category: EtherCAT
I use Mitsubishi MRj5 and it have encoder absolute value multiturn , without battery memory wirh resolution 26 bit.
With 26 bit you have much count for revolution and 32 bit pos-command hal pin, is full in 326 cm travel axis , with screew 10 mm pitch.
In drive parameter gear normally 1/1 , if you make a long machine with travel 10 meter , not can use 1/1 gear in drive , because after 326 cm moving , the pos-command return on -326 cm and linuxcnc return following error. For resolve now have increase gear in drive at 1/100 and can travel now 32600 cm. But normally is good have gear at 1/1 and use a 64 bit variable for command position and feedbak position.
  • bharath12
  • bharath12
25 Dec 2024 09:32
Retrofit Engraving machine was created by bharath12
Category: Milling Machines
I have bought this engraving machine to retrofit for my end use and want to learn from it. I want to know what size of steppers? I am thinking of attaching steppers using couplers, but is this type good?
  • bkt
  • bkt's Avatar
25 Dec 2024 09:29 - 25 Dec 2024 09:33
good day to all (in some gtp languages)
today is sunny ... cold ... there are snow in the ground .... is possible to skii .... I'm not at work ... at last the perfect day .... good Christmas day to all
Rumeno: Astăzi este însorit ... frig ... există zăpadă pe jos ... este posibil să schiezi ... nu sunt la muncă ... în sfârșit, ziua perfectă ... Crăciun fericit tuturor.
Albanese: Sot është me diell ... ftohtë ... ka borë në tokë ... është e mundur të skijosh ... nuk jam në punë ... më në fund dita perfekte ... Gëzuar Krishtlindjen të gjithëve.
Americano (Inglese Americano): Today is sunny ... cold ... there is snow on the ground ... it's possible to ski ... I'm not at work ... at last, the perfect day ... Merry Christmas to all.
Francese: Aujourd'hui, il fait ensoleillé ... froid ... il y a de la neige au sol ... il est possible de skier ... je ne suis pas au travail ... enfin, la journée parfaite ... Joyeux Noël à tous.
Tedesco: Heute ist es sonnig ... kalt ... es liegt Schnee auf dem Boden ... es ist möglich zu ski fahren ... ich bin nicht bei der Arbeit ... endlich der perfekte Tag ... Frohe Weihnachten an alle.
Kosovaro (Dialetto Albanese parlato in Kosovo): Sot është me diell ... ftohtë ... ka borë në tokë ... është e mundur të skijosh ... nuk jam në punë ... më në fund dita perfekte ... Gëzuar Krishtlindjet të gjithëve.
Russo: Сегодня солнечно ... холодно ... на земле лежит снег ... можно кататься на лыжах ... я не на работе ... наконец-то идеальный день ... Счастливого Рождества всем.
Italiano: Oggi è soleggiato ... freddo ... c'è neve a terra ... è possibile sciare ... non sono al lavoro ... finalmente la giornata perfetta ... Buon Natale a tutti.
Spagnolo:
Hoy está soleado ... frío ... hay nieve en el suelo ... es posible esquiar ... no estoy en el trabajo ... al fin el día perfecto ... Feliz Navidad a todos.
Cinese (Mandarino): 今天阳光明媚……很冷……地上有雪……可以滑雪……我没有上班……终于是完美的一天……祝大家圣诞快乐。
Ucraino:  Сьогодні сонячно ... холодно ... на землі лежить сніг ... можна кататися на лижах ... я не на роботі ... нарешті ідеальний день ... Щасливого Різдва всім.
Hindi (Indiano): आज धूप है ... ठंड है ... जमीन पर बर्फ है ... स्की करना संभव है ... मैं काम पर नहीं हूं ... आखिरकार, परफेक्ट दिन ... सभी को शुभ क्रिसमस।
Displaying 21136 - 21150 out of 21893 results.
Time to create page: 0.417 seconds
