  • RotarySMP
  • RotarySMP's Avatar
23 Jul 2026 19:43
Gmoccapy tool table not accepting lathe tool angles...
Category: Gmoccapy
Thanks a lot, that is now working as it should.
Cheers,
Mark
  • GFC
  • GFC
23 Jul 2026 19:02
Integrating ethercat with QTplasmaC and Beckhoff modules
Category: EtherCAT
in case anyone is curious, have some cad and pictures
ignore the messy home shop
  • Aciera
  • Aciera's Avatar
23 Jul 2026 19:00
Category: Gmoccapy
I did find those files in lib/python3/dist-packages/gladevcp
Yes, those are the files you need to edit.
  • GFC
  • GFC
23 Jul 2026 18:59
Category: EtherCAT
Over the last year I have been building a gantry plasma table with leadshine el8 servos and Beckhoff modules for I/O, I struggle a lot with software but have managed to get the motion going and calibrated in the axis interface following the guide below, the config files that worked are also below in a zip file.
The thing I need help with is how to integrate all of this into QtPlasmaC and how to map the I/O of the Beckhoff modules into the software.
I have a EK1100 coupler, an EL1008 digital input, an EL2008 digital output and EL3102 analog input to read the divided arc voltage.
Can anybody give any help, or tips on how to do this?
  • RotarySMP
23 Jul 2026 18:57
Category: Gmoccapy
 I was out on a business trip this week and only just got to try this. I don't have a lib/python/gladevcp folder.
I did find those files in lib/python3/dist-packages/gladevcp. Would it help to edit them there, or should I leave those versions alone and look for them somewhere else?
Cheers,
Mark
  • PCW
  • PCW's Avatar
23 Jul 2026 18:31
Replied by PCW on topic Precix Retrofit Project
Category: Driver Boards
To do a LinuxCNC retrofit (with existing servo drive and motors) you would need to know
the pinout of the 25 pin connector between the old controller and servo drive.
  • Kittifix
  • Kittifix
23 Jul 2026 15:55
Software für Stepperonline A6 / JSS Motors JSS715N / Synmatic AS 715N
Category: Deutsch
OK,das war bei mir aber nicht schwierig ,USB dran ,Com Port eingestellt und einmal gescannt - fertig ,klingt so als wären die Vorgängerversionen nicht so kommunikativ .
Nur bei dem Autotuning werd ich nicht schlau draus
  • RLA
  • RLA
23 Jul 2026 15:51
Replied by RLA on topic linuxcnc frequent freeze
Just went to run dmesg again....after it finished...stretched terminal window...went blank...opened new terminal fullof read only errors??
  • Aciera
  • Aciera's Avatar
23 Jul 2026 15:50 - 23 Jul 2026 16:23
If servo period is changed the coresponding P values for PID do not change
Category: PnCConf Wizard
I've had a look and we could generate a popup when the servo period has been changed in an existing config:
PR is here: github.com/LinuxCNC/linuxcnc/pull/4263
  • csec0128
  • csec0128
23 Jul 2026 15:44
Replied by csec0128 on topic Precix Retrofit Project
These are the nameplates on the drive motors, plus a list of documentation for what came with the machine. Plus, that is the first page of the amplifier, I believe. It's a 3-channel drive/amplifier from what I have gathered. I can send all other pages if needed.
  • RLA
  • RLA
23 Jul 2026 15:36
So this am I switched to another pc optiplex 9020...used same SSD...Got same error...
Ran smartctl...disc passed....just did fsck -f -y....got 4% noncontiguous as result
dmesg gave nothing in red
  • Lcvette
  • Lcvette's Avatar
23 Jul 2026 15:24
Replied by Lcvette on topic Some problems with probe basic lathe
Category: QtPyVCP
going forward you would need to use the usertabs for that. i am releasing a conversational plugin that will utilize that conversational tab so it is now no longer populating with the old bad conversational unfinished screens and macros.
  • PCW
  • PCW's Avatar
23 Jul 2026 15:14
Replied by PCW on topic linuxcnc frequent freeze
Seems to be getting worse...
Sounds like some hardware is failing,
Does dmesg show any hardware faults (disk errors etc?)
  • PCW
  • PCW's Avatar
23 Jul 2026 14:59
Looks like the servo drive is a Copley 800-468, and older 3 Axis drive.
I suspect it's an analog velocity mode drive but its old enough that is
hard to find data on the drive. Was any documentation included with the machine?
23 Jul 2026 14:45
Thank you Aciera, i do not use wizards as i am used to manually editing everything, but been forcing myself to use them lately.
Displaying 2236 - 2250 out of 12539 results.
Time to create page: 0.309 seconds
