Some problems with probe basic lathe
- Lcvette
- Thank you received: 782
12 Mar 2026 16:14 #344178
by Lcvette
Replied by Lcvette on topic Some problems with probe basic lathe
did you verify your paths for the subroutines were correct? those look to be correct names to be parsed. it appears you have hardcoded max rpm speed instead of using the ui entry. but other than that the names look to be correct. I would test by copying the subroutine and trying to run it as a program filling in the data as expected and see if you can make it run, may tell you if the subroutines is correctly formatted or not.
- Lcvette
12 Mar 2026 16:20 #344179
by Lcvette
i just tried using the facing one and it does do things, but i really am not a fan of the setup, i suspect it is incomplete compared to the original macros andy put out. it looked to have several missing inputs. and im not a fan of it running without having a chance to see the output plot for verification. i would say the subs need some work before i would use them personally.
- Ismacr63
- Thank you received: 11
21 Jul 2026 20:56 #347936
by Ismacr63
Replied by Ismacr63 on topic Some problems with probe basic lathe
I wanted to pick this up again to try to get the macros working, but I've noticed that the conversational tab in Probe Basic Lathe no longer appears. Would it be possible to get it back?
- Lcvette
23 Jul 2026 15:24 #347999
by Lcvette
going forward you would need to use the usertabs for that. i am releasing a conversational plugin that will utilize that conversational tab so it is now no longer populating with the old bad conversational unfinished screens and macros.
Moderators: KCJ, Lcvette
Time to create page: 0.251 seconds
