  • Muftijaja
  • Muftijaja
04 Aug 2024 13:26
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Hmm I tried both, changed priorities eno1 to 1 and auto/enp2 to 0 - no effect.
Then I changed the position of the lines in /etc/network/interfaces - no effect at all.
On what reason ever, the network definitions are faulty.
WTF is going on there?
  • Muftijaja
  • Muftijaja
04 Aug 2024 13:18
Category: Deutsch
And this is ip a with the 4 lines in /etc/network/
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0a:cd:00:00:56 brd ff:ff:ff:ff:ff:ff
inet 192.168.178.55/24 brd 192.168.178.255 scope global dynamic noprefixroute enp2s0
valid_lft 863931sec preferred_lft 863931sec
inet6 2003:ce:5f08:8600:6ae7:3d2d:fe1d:c940/64 scope global dynamic noprefixroute
valid_lft 7132sec preferred_lft 1118sec
inet6 fe80::d017:c5ae:2734:c531/64 scope link noprefixroute
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:23:24:5b:b4:ac brd ff:ff:ff:ff:ff:ff
altname enp0s25
inet 10.10.10.2/8 brd 10.255.255.255 scope global eno1
inet6 fe80::223:24ff:fe5b:b4ac/64 scope link
why does it change the altname to enp0s25? that is a conflict with 2. where can I change the altname manually to fix this?
Or should I change the priorities so that eno1 is launched before enp2?
  • Muftijaja
  • Muftijaja
04 Aug 2024 13:06
Category: Deutsch
This is the feedback of ip a without the suggested lines:
valid_lft 862758sec preferred_lft 862758sec
valid_lft 7101sec preferred_lft 1700sec
altname enp0s25
inet 10.10.10.2/24 brd 10.10.10.255 scope global noprefixroute eno1
  • MarkoPolo
  • MarkoPolo
04 Aug 2024 13:03
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
I tested it a bit, it works very well.
I like it.
It could be everything even in one menu, axis button, but if it is possible to customize the content of both menus, it is very good.
How to do it in the style sheet?
In qtdragon_hd, the ref buttons are probably no longer needed? If so, I can customize the layout..
Marek
  • Muftijaja
  • Muftijaja
04 Aug 2024 12:36 - 04 Aug 2024 12:42
Category: Deutsch
Hello PCW,
thank you for your answers! (sorry for delay, I was very busy the last days and couldn't do anything at my machine.)
I tried the lines in /etc/network/interfaces file and  after reboot my internal Intel network was disabled. Just  auto internet with RLT8111 is possible. The file is as follows:
Well, internet network is ok. What is the faulty setting here?
  • newbynobi
  • newbynobi's Avatar
04 Aug 2024 12:13 - 04 Aug 2024 12:13
Replied by newbynobi on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
I do recommend not to use halui pins, but the hardware button pins to control that stuff.
See:
Right and Botton Button Hal Pin
  • newbynobi
04 Aug 2024 12:09
Replied by newbynobi on topic Jog keys for A axis
Jog keys for A axis
Category: Gmoccapy
Can't you use the gmoccapy Jog hal pin?
  • gmoccapy.jog.jog-A-plus (bit IN)
  • gmoccapy.jog.jog-A-minus (bit IN)
    Norbert
  • anfänger
  • anfänger's Avatar
04 Aug 2024 11:21
Replied by anfänger on topic Mesa Analog Vs Step Dir
Category: Driver Boards
I'm kind of stuck I think there are some mistakes in my hal and ini setup.
I wonder if it would make sense to start new but its a relative complex machine an I've also done a lot to the GUI.
I attached my config files maybe some one sees what I can't see at the moment.
If not I'll restart new new
File Name: probe_basic.ini
File Size:8 KB
File Name: wully.hal
File Size:31 KB
these two files are for gui and hand wheel
File Name: handrad.hal
File Size:10 KB
File Name: time_2024-08-04.hal
File Size:7 KB
thanks Patrick
04 Aug 2024 09:55
Replied by Cant do this anymore bye all on topic Need Guidance for Retrigger (Falling Edge) GP14 by using RP 2040 PICO
Category: Show Your Stuff
You may have the wrong forum. This forum deals with the use & installation of Linuxcnc.
  • hashama
  • hashama
04 Aug 2024 09:11
I use 4 PICOs RP2040, a total of 16 ADC channels (4 ADC channels
per PICO) where the trigger signal (reference voltage) is connected to GP14. I’ve programmed the Picomite to set a trigger value for a falling edge, which means the trigger should activate when the signal reaches 0.8 V. However, I’m encountering an issue where the output voltages I’m getting are higher than expected—they should be lower or close to 0.8 V. The trigger signal frequency is set at 360 Hz, and the input voltage is a 1.2 V AC sine wave at the same frequency. Currently, the output voltages from all ADC channels are between 0.85 and 0.87 V. When I increase the frequency to 400 Hz, 450 Hz, or 500 Hz, the output voltages rise even higher, which is confusing. Could you please help me identify where I might be making a mistake?
I aim to capture the input signal precisely at the point where it crosses the trigger voltage of 0.8 V on a falling edge. To achieve this, I set the offset to zero (minimum). I connected an oscilloscope in DC coupling mode on the input side to monitor the amplitude and frequency of the input voltage. Since the trigger is set for the falling edge, which means the system should capture the signal as it transitions from rising to falling and reaches the trigger level, I expect the captured voltage to be less than 0.8 V.
Kind regardsHasham
  • ThyerHazard
  • ThyerHazard's Avatar
04 Aug 2024 07:46
Replied by ThyerHazard on topic Setting up 360 to post for LinuxCNC
Category: Fusion 360
Yuhp I found it -_- Sorry guys
Thanks mate I am an stupid
  • ThyerHazard
04 Aug 2024 07:44
Thanks Ill have a look. hopefully this is the case I have a habit of not finding things right in front of me
  • jjdege
  • jjdege's Avatar
04 Aug 2024 07:33 - 04 Aug 2024 07:36
Replied by jjdege on topic New LinuxCNC-Ethercat git tree
Category: EtherCAT
Hi Scott
Thanks!
I'm stupid,
it was the classic solution that you have in front of your eyes and you don't see.
The output must be enabled, of course, and the scale must also be set, of course,
but I didn't think of it, even though I had done the same thing for the FR4000
I'm speechless....
Everything works, I'd say the driver is ok
Thanks again for your time!
  • papagno-source
  • papagno-source
04 Aug 2024 06:55
Replied by papagno-source on topic Compensation Z axis respect at Y
Category: CNC Machines
Thanks for the reply.
I was wondering, after having obtained the map of the points, I thought of inserting them in a linuxcnc compensation file.
But the compensation file compensates errors related only to the axis involved and not to axes in mechanical relation between them, for example z with respect to y.
I thought of actually verifying the geometric displacement of y, in relation to the advancement of z and of relating them with trigonometry.
the result of the offset that varies in real time as Z moves, insert it with an offset component to the command position of the Y drives. It should work if the points taken are precise.
  • Mr. Mass
  • Mr. Mass's Avatar
04 Aug 2024 06:11
Replied by Mr. Mass on topic Control panel
Control panel
The keyboard is generally comfortable, only the spacebar button is fuzzy, you have to press it only in the middle. The track ball is unfamiliar to me, but it works well. I don't think it will be used often, the touch screen and keyboard covers 99% of all requests.
Displaying 24436 - 24450 out of 24520 results.
Time to create page: 0.448 seconds
