  • jg00163206
  • jg00163206's Avatar
29 May 2024 12:51
Replied by jg00163206 on topic Mesa Configuration Tool 2.0.0
Category: Driver Boards
thank you. at the time i was trying to get a working configuration. i ended up getting it working without installing the mesact, but i will keep that in mind if i need it in the future.
29 May 2024 12:31
Replied by Cant do this anymore bye all on topic linuxcnc_2.9.1-amd64.hybrid.iso Intallation fail
Category: Installing LinuxCNC
Another option is to use the text installer > expert mode and manually configure the network, post installation this can be changed to DHCP or left as a static address.
29 May 2024 12:21
Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
Haven't noticed the file copy issue but DHCP seems an issue. Currently installing 2.9.2 in a VBox Machine. Have noticed this on a couple of machines that previously had no issue. Using a DHCP server on a pfSense router. Previous Linuxcnc ISO didn't show this behaviour. Basically the install stall at configuring the network, tho there is no issue with running the live version, IP address is fine via DHCP
Have had to go through the "expert text installer" setup and config IP manually. Installation went ok, no issues copying files, one annoying thing is 3 of the 6 launchers of the lower panel are empty when booted to GUI.
All this has been done with the ISO being downloaded a few times, so just not operating on a single download. A mate of mine has also seen this behaviour.
Previously used the a net install image and did a manual install of Linuxcnc.
So I can confirm there has been no issues copying files the auto configuring of the network is an issue during install.
Post installation changing from a static address to one via DHCP works fine.
Seems strange, that's all I can say.
The boards I've tested have been a M73 ThinkStation and an Asrock J3355B-ITX. Haven't tried my Odroid as that has a stable setup, don't have a spare driver for it and it's a pain to access it in the enclosure.
  • Grotius
  • Grotius's Avatar
29 May 2024 11:56
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
I did a few presettings and it now starts ok.
This was a good practice. When i loaded lcevette's gcode file, it was loading about 150 lines. Not all the lines.
So the interpreter was waiting for "reset()", to dump more gcode lines. This now works.
And there was a tiny bug, related to no validation of gcode segments. So i added gcode validation that checks
if line has lenght, the circle is a circle and if it's an arc. Now i think less bug's may remain.
I need a volunteer !!!
Is someone willing to only make a gui with a designer? You don't have to have coding skills, only make the design.
It would be awesome if we can create high end controller gui's like fanuc, siemens, etc you name it.
But i need help. Eventually you may ask for public gifts yourself, In fact you did work.
So now the c++ app is running. We now can concentrate on the gui waypoints further on this day. To
look if we can do a point overlay test with some kind of curve.
  • zmrdko
  • zmrdko's Avatar
29 May 2024 11:22 - 29 May 2024 11:24
Calling tool_touch_off.ngc subroutine from another subroutine - Probe Basic
Category: QtPyVCP
Yes, I am aware of that. But question is more like where to put this expression, so that probe basic gets the value from INI to tool touch off parameters.
  • Aciera
  • Aciera's Avatar
29 May 2024 11:19
Category: QtPyVCP
Not sure if this is what you are looking for but by default you should be able to access values from the ini file in gcode using this format
#<_ini[section]name>
  • pmchetan
  • pmchetan
29 May 2024 10:40
Replied by pmchetan on topic Elumatec SBZ 130/01 retrofit
Category: CNC Machines
Your halfiles were very helpful, thank you :) I got my encoders spitting data.
Displaying 26296 - 26302 out of 26302 results.
Time to create page: 0.731 seconds
