  • Surmetall
  • Surmetall's Avatar
22 Apr 2026 17:56 - 22 Apr 2026 18:00
Replied by Surmetall on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Thank you for your help, and sorry for taking up your time. I hope to learn this myself as soon as possible so I won’t have to bother anyone.The exported file was called “.tnzip” for some reason I have no idea why. I renamed it to “.zip” so I can upload it here.
  • endian
  • endian's Avatar
22 Apr 2026 17:27
Replied by endian on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
both file missing startup IDNs
send me your active TC3 project archive I can translate it at my place...
  • Surmetall
22 Apr 2026 16:37
Category: EtherCAT
Hi Endian,sorry, but I still cannot get it working. I spent many hours on it yesterday evening, and I am obviously still doing something wrong.I am not sure whether I am missing an important step, whether I made a mistake in the configuration, or whether I am still missing a required driver or component.As you suggested, I redid the whole process from scratch using the current translator from the publish folder: fresh TwinCAT export, start the
.exe
, use
c -i
, and then convert the export again. This time the conversion itself seems to have worked properly.I am attaching:
  • the fresh
    ethercat-conf.xml
    generated by the current translator
  • my adapted machine
    ethercat-conf.xml
    with the other real bus slaves added back in
Current status on the real machine:
LinuxCNC 2.9.8
IgH EtherCAT master 1.6.8
all non-AX slaves go OP
only the AX5125-0000-0216 stays in
PREOP + ERROR
Current error:
AX5125 stays in PREOP + ERROR.
AL status message 0x0045: "MBX_SOE"
ethercat slaves
currently shows:ethercat slaves
0  0:0   OP     +  EK1100 EtherCAT Coupler (2A E-Bus)
1  0:1   OP     +  EL1008 8K. Dig. Eingang 24V, 3ms
2  0:2   OP     +  EL1008 8K. Dig. Eingang 24V, 3ms
3  0:3   OP     +  EL1008 8K. Dig. Eingang 24V, 3ms
4  0:4   OP     +  EL2008 8K. Dig. Ausgang 24V, 0.5A
5  0:5   OP     +  EL2008 8K. Dig. Ausgang 24V, 0.5A
6  0:6   OP     +  EL2008 8K. Dig. Ausgang 24V, 0.5A
7  0:7   PREOP  E  AX5125-0000-0216 EtherCAT Drive (SoE, 1 Ch.)
8  0:8   OP     +  EK1100 EtherCAT Coupler (2A E-Bus)
9  0:9   OP     +  EL2008 8K. Dig. Ausgang 24V, 0.5A
10 0:10  OP     +  EK1100 EtherCAT-Koppler (2A E-Bus)
11 0:11  OP     +  EL1008 8K. Dig. Eingang 24V, 3ms
12 0:12  OP     +  EL3255 5K. Potentiometerauswertung mit SensorversorgungCould you please compare:
  • the freshly generated translator XML
  • the adapted machine bus XML
My main question is:
Do you already see from these two XML files what is still wrong in the AX5125 startup / SoE configuration, or what the minimal correct AX5125
lcec
configuration should look like?If there is already a known working example config for an AX5125 with
lcec
, that would also help a lot, because at this point I am worried that I may still be missing something fundamental.ChatGPT helped me sort the files and compare the configs, but the machine is still not getting past
PREOP + ERROR
, so I would really appreciate your expert view on the actual AX5125 setup.Thanks a lot for your time.
greetings
Tom
  • RotarySMP
  • RotarySMP's Avatar
22 Apr 2026 14:56
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
I double checked our ini's, and we both have the encoder scaling set to 8000 pulses/rev. Not sure what would cause that drift you are seeing.
  • Steve303
  • Steve303
22 Apr 2026 13:51
Replied by Steve303 on topic lcnc-suite — web UI for LinuxCNC
Category: Other User Interfaces
I really like this. Are you running your router/mill on your web UI?
  • papagno-source
  • papagno-source
22 Apr 2026 13:23
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
The comparison I'm making is about latency between Debian 10 with Kernel 4.19-27-rt and Debian Trixie Kernel 6.12.74-RT. Although Trixie's Grub has different optimization strings and Debian 10 has no optimizations at all, Debian 10 has half the jitter of Trixie on the same PC. Debian 10 has a jitter of 40 microsec and Trixie 85 microsec. So, since I want to do a further test with a new PC, can you advise me on which motherboard and processor would have the lowest jitter?
  • papagno-source
  • papagno-source
22 Apr 2026 13:08 - 22 Apr 2026 13:26
Category: EtherCAT
  • JT
  • JT's Avatar
22 Apr 2026 12:12 - 23 Apr 2026 18:16
Replied by JT on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Just completed the multiple spindle update to Flex GUI. It now fully supports all 8 spindles.
JT
  • Dudelbert
  • Dudelbert
22 Apr 2026 10:06
Category: Turning
That is the exact type of “laser tachometer” I used. I agree that they are useful.
  • rodw
  • rodw's Avatar
22 Apr 2026 10:03
  • rodw
  • rodw's Avatar
22 Apr 2026 09:59
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
Sorry I don't buy the excessive latency with Trixie today vs Debian 10, which was in the  2016 to   2017  era back when I started. That's 10 years ago. There was no PREEMPT_RT kernel available at that time. In fact, you could have been running the RTAI kernel. Back in 2017, the path I followed that was subsequently documented by cncbasher was to Install Linux Mint 17.x or 18.x and compile the PREEMPT_RT kernel. Ref: forum.linuxcnc.org/9-installing-linuxcnc...linuxcnc-from-source. Not long after this somebody made an ISO on Debian (10) Stretch which included PREEMPT_RT. Eventually, there was an official stretch release.
Bullseye (Debian 11) was released and that obsoleted Python 2.7 which we depended on. That was such a big stumbling block we did not Release anything on Bullseye but I used it to get network drivers for my Odroid H2+ instead of compiling from source. I had to give up Mint at this time because their kernels were too dated to have my drivers. I will never use anything other than Debian now! There was some big changes to the linux kernel network drivers in the 5.9 kernel pending the release of Bullseye on Kernel 5.10. I had one Ethercat machine running Bullseye (11) and moved to Bookworm (12) and got stuck on all PC's I had with Error Finishing Read on Mesa hardware but never had issues  with Ethercat in my bench testing. This is when I started working on kernel tuning and I found that my Old 2017 PC (Celeron J1900) had significantly improved jitter on Bookworm then it did back in the day. (eg reduced from 130k to 40k or lower). I don't think Trixie would be any worse. In fact other PC's I've tuned are running at almost half the latency now before tuning. Here is an example from Mike after he applied my optimisations
This is way below minimum latency requirements for Ethercat. There is no doubt in my mind that any issues being discussed here is due to  misconfiguration or issues in the Ethercat environment. Please forget all about latency. It is not an issue if the correct drivers are deployed and the appropriate network tuning has been done (Which it is for papagno-source's PC's).
  • Dudelbert
  • Dudelbert
22 Apr 2026 09:50 - 22 Apr 2026 09:58
Category: Turning
I am still struggling with threading.I have tested it at very low speed (100 RPM) in the hope to see something that helps me find what is wrong. But I cannot really say what I am looking at. The result is repeatable, and at least to me it looks like a constant offset that makes it wrong. I have set the cross-slide angle to 0, so that is not the reason. It is supposed to be an M8.
I would have expected a more random result if the spindle index was jittery, so that is probably not it. And spindle.0.revs, I tested it by turning the spindle by hand 25 turns, and spindle.0.revs was almost exactly 25. The remaining very small error can easily be attributed to me doing it by hand.
Additionally, I set the spindle to 1200 RPM and let it run. After it settled, I made a video filming the HAL Show screen and watching spindle.0.revs so I could later check it, and I got 1206 RPM that way.
I tried to make sure that the spindle really had 1200 RPM with a laser tachometer and by watching the encoder velocity RPM. Both agree within a margin of under 10 RPM. I don’t have any RPM measurement tools that are more reliable or accurate.
All these tests point me in the direction of the spindle encoder being OK. Are these tests the wrong way of testing this? What else can it be?
  • papagno-source
  • papagno-source
22 Apr 2026 07:52
Category: EtherCAT
Good morning everyone, and sorry if I'm less present, but technical support won't let me go. I personally think we need to focus on functional solutions; it's pointless to use a LinuxCNC, which is very modern but doesn't work. So I agree with Grandixximo. In the next few days, I'll do the tests Grandixximo asked me to do and I'll update you. I'll ask the customer if he'll let me do further tests outside of business hours. The machine is working properly with Debian 10. I remind you that I tried overwriting the lcec_conf and lcec.so files from Debian 10 to Trixie, but I didn't see any improvements. That's why I believe the problem, aside from those found by Grandixximo and fixed, isn't Lcec, but rather Ethercat and the kernel, which has high jitter for a CNC machine. The solutions are to use a PC suitable for RT or design a Master Hw that has a dual Port RAM, capable of buffering information and letting the PC breathe.
  • grandixximo
  • grandixximo's Avatar
22 Apr 2026 06:18 - 22 Apr 2026 06:22
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
Fair point on the age of the base, but it is not as stale as the "1.5.2" label makes it look. YangYang's build sits on the 1.5.2 API boundary, but a lot has been grafted on top of it. Martin Ribalda's refactor moved the slave scan, slave config, SDO request, dictionary, and state-change FSMs into per-slave state machines running off externally supplied datagrams, which means every slave progresses through INIT to PREOP to SAFEOP to OP in parallel instead of the master FSM walking them one at a time. That is where the OP speedup comes from, not the age of the base. On top of that there is an SDO injection path, so CoE transfers ride on the realtime cycle alongside PDOs and startup list SDOs plus PDO mapping writes do not each cost a full master FSM round trip. The 1.6 era API surface is mostly backported too (ecrt_master_sync_reference_clock_to, mbox gateway, rescan, RT slave request hooks, full FoE request API, reboot FSM, bulk register read/write, SII from file, and so on).
On the kernel side, the native drivers have been updated for modern kernels. The devices/ tree ships 6.12 variants of igb, igc, r8169, genet, e1000, e1000e, and stmmac, and DKMS builds cleanly against Trixie's 6.12 headers.
I tried the obvious "just tune 1.6.9" route first. Applying the same constants YangYang's build uses (EC_WAIT_SDO_DICT=0 and EC_SKIP_SDO_DICT=1) on top of stock 1.6.9 drops OP from around 15 s to around 12 s. YangYang's build reaches OP in roughly 5 s on the same bus. The remaining gap is not a constant that anyone can tune; it is the per-slave FSM architecture, and 1.6.9 does not have it. 1.7 does not have it either, I checked, master/fsm_slave.c is still 685 lines in 1.7, the same as in 1.6.9, against 1339 lines in YangYang's build.
So "use the newer version" is the intuitive answer but it does not actually close the gap. Porting Ribalda's refactor cleanly onto 1.6.9 is weeks of work with a large regression surface. Shipping YangYang's build with modern Debian packaging gets working fast OP debs this week. Different tradeoff, not a rollback.
OP transition time is of course unrelated to grinding itself, this is about how long the user waits for the machine to come up, not motion behavior.
22 Apr 2026 03:33
Replied by tommylight on topic Ethercat random jitter fix
Category: EtherCAT
It makes no sense to roll back to a version built for  kernel 2.6 (Trixie's is 5.12) that's not been touched for 7 years...
You mean 6.12 for sure, 5.12 is also pretty old.
Displaying 4261 - 4275 out of 12541 results.
Time to create page: 0.362 seconds
