  • PCW
  • PCW's Avatar
04 Feb 2026 15:42
Mesa Firmware request - 7i92 - 7i77 - 7i89
Category: Driver Boards
File Name: 7i92_7i77_7i89d.zip
File Size:113 KB
File Name: 7i92t_7i77_7i89d.zip
File Size:291 KB
  • PCW
  • PCW's Avatar
04 Feb 2026 15:40 - 04 Feb 2026 15:40
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
7I97 analog outputs are generated from PWM
which requires some setup:
 ---PWM Generator signals/setup---
setp hm2_7i97.0.pwmgen.pwm_frequency 75000
setp  hm2_7i97.0.pwmgen.00.output-type 1 #PWM pin0
setp  hm2_7i97.0.pwmgen.00.offset-mode 1 # offset mode so 50% = 0
setp  hm2_7i97.0.pwmgen.00.scale  10
setp hm2_7i97.0.pwmgen.00.enable true
setp hm2_7i97.0.pwmgen.00.value 1.0
  • Dudelbert
  • Dudelbert
04 Feb 2026 15:35
Replied by Dudelbert on topic T3D-L20A-RABF configuration help
Category: Turning
I don’t know that specific driver, but what I would try is separating the drive from LinuxCNC first.
There is probably a manual mode to turn the drive by using the front panel on the drive itself.
After that, you can set the needed inputs directly (wired to your DC sources) and use a low voltage (AA battery or similar) to give the analog input directly.
Then, if that works but still not in CNC control, you at least know that LinuxCNC is actually the problem.
  • Lcvette
  • Lcvette's Avatar
04 Feb 2026 15:23
Replied by Lcvette on topic Missing Tool Cone
Missing Tool Cone
Category: QtPyVCP
you have no tool length to draw the tool stored in your tool table. vtk draws an actual tool to display not a cone. the cone represents a point when no tool is loaded when tool is loaded the stored diameter and length draws the tool. try adding a tool length and you will see the tool.
  • Ismacr63
  • Ismacr63
04 Feb 2026 15:12
T3D-L20A-RABF configuration help was created by Ismacr63
Category: Turning
I've been trying for several days to configure the T3D-L20A-RABF servo motor as a spindle in speed mode, but I can't get it to work.
I've set the parameters p004=1, p047 to auto-zero, p050=1 for 0-10V unipolar, and p103=9 to reverse the spindle. I've set p025=0 (default) to use the analog input AS+.
I'm using pin 17 to control the relay and connecting S0 or 0V/GND to the relay.
I'm using pin 16 to reverse the spindle direction.
And pin 1 is for PWM. I've connected AGND and AS+ to the bobbin's 0-10V pin.
The board is powered by 24V, and the servo driver is also powered by 24V.
When I input the command M3 S100, for example, the spindle energizes and has torque, but it doesn't rotate or respond to RPMs.
With my limited knowledge, I don't know what else to try. T_T
  • NWE
  • NWE's Avatar
04 Feb 2026 14:52
Replied by NWE on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
but did you try to go to op-enabled without the cia402 component?
That echos my thoughts, I considered throwing that idea out there but decided I'm too much of a newby in this ethercat business to be making too much noise here without trying stuff out on hardware first.
My drive and motors are expected to show up today. Not that that makes it a rush to get this figured out. I still need to decide what I'll build with it once it's working.
  • Nkbhvid
  • Nkbhvid
04 Feb 2026 14:33
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
I've finally managed to configure my 7i97t with the mesaCT.
In order to test my card I tried to put a small voltage on the output pin of the analog 0.
I would have expected to be able to use something like
setp hm2_7i97.0.analogout0 1.0
but it seems that the parameter for the analog drives doesnt exist at all?
My firmware is 7i97_d.bin
Where did i get lost this time?
  • andrax
  • andrax's Avatar
04 Feb 2026 13:26
Replied by andrax on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I am reading all the topics on EtherCAT and CIA402 carefully. Unfortunately, I am not a programmer and cannot contribute much.
But I found this page, maybe it will help?
EtherCAT Slave: CiA 402 example
Note: would it be possible to incorporate certain safety routines? For example, a watchdog if the servo receives the command for homing but does not start moving.
  • Muecke
  • Muecke's Avatar
04 Feb 2026 13:22
Proposal to improve forum stability and structure
Category: Forum Questions
Hello dear administrators,
I would like to raise a concern about the stability and structure of the forum, as it is becoming increasingly difficult to be active here. Often, the forum is unavailable or you can no longer reply to your own posts. Unfortunately, this is very frustrating and a shame, as the forum is an important point of contact for many of us.
Question for our administrator, BigJohnT:
You recently made some adjustments to the server structure. A question about this:
Would it be possible to share a new database, i.e., create a new table in the database?
Is it possible to create a new folder in the root directory where a new Joomla 6.x can be installed?
I would like to implement this suggestion in collaboration with other interested members of the forum.
Specific suggestion for improvement:
A) Installation of a new Joomla 6.x
B) Installation of the Kanuna forum for Joomla
C) Preparation so that other areas can also be migrated or integrated if desired, such as:
* Downloads
* Search
* Documents
* Archives
* Community
* Forum (this could then be given a new location)
* Wiki
* Source
This is, of course, only a suggestion and not a mandatory requirement! I am not very familiar with Joomla (I only have a small static page with it), but I am convinced that a fresh installation of Joomla and a new forum would improve stability and user-friendliness.
Important:
I am not aiming to migrate the existing forum! Users would have to re-register in the new forum. However, a transition process could be created in which existing members receive an email with a password that they can change when they log in for the first time.
Additional help:
If anyone in the forum is more familiar with Joomla or server structures and is willing to help, please respond with the words: “I offer my help!” Perhaps we can work together to come up with a stable solution.
I hope this suggestion is met with understanding and look forward to your feedback!
Best regards,
Mücke
Translated with DeepL.com (free version)
  • Dudelbert
  • Dudelbert
04 Feb 2026 12:47
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
so in the last weeks it is really hard to convince myself to even go to the shop — “badly isolated to small of a heater,” you know how it is. Anyway, I still have a bit of an update.
I worked mainly on the control cabinet and its mounting. In the attachments you can see the box made from laser-cut and pre-bent steel plate, and the arm to mount the cabinet.
I decided to take it in the front of the machine. I reused the foot of the holder that mounted the original one in the back. Because the cabinet now is in the way of the tailstock, it had to be articulated twice. Simple rotation would not have worked.
It’s not quite together yet, but you may still see how it is supposed to go together.
It will be some weeks until I will be able to paint it (again, it is too cold).
I think that’s it for now.
  • Hakan
  • Hakan
04 Feb 2026 12:43
Replied by Hakan on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
Can't you just forget about cia for the moment and only work with lcec, like I did.
And transition manually 6,7 15.
  • rodw
  • rodw's Avatar
04 Feb 2026 12:39
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I've attached my unfinished comp and hal for good luck. also had a look at Dominic's results and its the same
  • rodw
  • rodw's Avatar
04 Feb 2026 12:33
Category: EtherCAT
Well, that's disappointing! Thats exactly what I have done.
And all of my statuswords 1-3 are zero. :(
If you can see any obvious errors in the XML, let me know
  • rodw
  • rodw's Avatar
04 Feb 2026 12:26
Category: EtherCAT
Funny, I was just looking too. There is only one lcec slave showing
So if I go back and rework all the cia402 joints to point to the correct variable/pdo for that one slave, it might work!
File Name: pdos_2026-02-04.txt
File Size:2 KB
File Name: ethercat-c...2-04.xml
File Size:4 KB
XML and dump of PDO's is attached
  • Isleape
  • Isleape
04 Feb 2026 11:45 - 04 Feb 2026 11:48
Mesa 7i90HD no comunication/ update erprobte on 2nd mesa (Solved)
Hi, I am measuring on all pins (11 13 15 17) with no LPTR connected ~ 1.6V - When grounding CS (Pin 17) nothing changes....
LED CR3 is constantly on.
What can i che k in the FPGA configuration that may not be set to have SPI enabled?
Not sure if i used a spi cfg for my custom Bit file...
I created some for ethernet 7i80 and Epp sucessfull 7i90hd previously.... but then things went wrong....
Displaying 7531 - 7545 out of 12626 results.
Time to create page: 0.327 seconds
