  • PCW
  • PCW's Avatar
07 Jan 2026 00:19
Replied by PCW on topic Servos drives directly start turning
The hal file shows independent analog outputs and encoders
Are you sure you have the feedback correct for Y and Y2?
You not only have to get the right (matching) directions but the
proper feedback so you don't get a instant runaway at drive enable.
Might be best to test  this with the linear axis disconnected
  • ihavenofish
  • ihavenofish
06 Jan 2026 23:50
lemontart - a call for help with s curve, ui's, and all the cool toys
Ah, I didn't see anything on a real machine. Will have to look deeper.
First tart is here in 2 weeks or so, so ill try it on that.
  • rodw
  • rodw's Avatar
06 Jan 2026 23:36 - 06 Jan 2026 23:36
I think grandixxmo takes the prize already. A complete stable and finished scurve planner with a PR for inclusion in the linuxcnc core code. (new features go into 2.10 so that's where it is). Also tested by another user on real hardware (by endian) In the mean time, try the version in his github. It works!
06 Jan 2026 22:44
Replied by tommylight on topic Servos drives directly start turning
But now i got a problem with my gantry Y Axis. If both Y Axis connected to the TB5 and we press F2 the Motors jumps around and an following error occures. Do you have any idea why this happend?
Do you mean both servo drives are connected to the same analog output?
If yes, that does not work, analog drives can not be wired like that as it will mess with the feedback.
Each MUST use it's own output and it's own feedback.
  • ihavenofish
  • ihavenofish
06 Jan 2026 22:38
interesting. I'll be watching where this goes. There have been 100 false starts on this that never make it to the end. That's why I am going to be offering up a tart, to incentivise completion.
(completion mean running a machine bug free, solid, stable and finished)
  • grandixximo
  • grandixximo's Avatar
06 Jan 2026 22:01
Yes, you can see the other post in the forum
forum.linuxcnc.org/38-general-linuxcnc-q...-curve-accelerations
Endian posted a video in action.
It will be in 2.10 release, it's in my Linuxcnc fork now, and should be merged soon to master.
  • JanCNC
  • JanCNC
06 Jan 2026 21:52
Replied by JanCNC on topic Servos drives directly start turning
Now the wiring is correct and the enable is working. If i test every axis for its own it seems to work fine.
  • Murphy
  • Murphy
06 Jan 2026 21:21 - 06 Jan 2026 21:21
Anyone have any ideas what's wrong with my spindle. The video clip below shows the lathe in CSS mode. Everytime I'm moving the X axis you can see the display on the vfd dipping , when a lot of speed changes are there it newly stops the spindle it's so low. I noticed this in manual mode also. When changing to another speed it dips slightly before going to the commanded speed. I measured the 0-10v output on the Ec500 and can see the voltage dipping before going back up.
youtube.com/shorts/Mo1SoWhW5U4?si=6uqabWnk2D27JKpQ
  • Routercnc
  • Routercnc
06 Jan 2026 20:35 - 06 Jan 2026 20:38
Replied by Routercnc on topic EasyProbe
EasyProbe
Category: AXIS
The issue is resolved. The only missing part was adding USER_M_PATH = /home/cnc/linuxcnc/nc_files to the [RS274NGC] section of the .ini file. After adding this line and restarting LinuxCNC, the M130 user M-code was recognized correctly.
 Thanks to hmnijp for the help and guidance.
06 Jan 2026 20:04
The PINS ENA0- and ENA0+ on the TB5 connector should get power when I turn on the machine with F2 right???
No.
They just short internally as a normal switch.
  • JanCNC
  • JanCNC
06 Jan 2026 19:57
My wiring was a little bit different, I configured the enable signal to my normal Digital Outputs and connected the servo enable cable direct to the output signal.
I did some changes and tried to wired it properly but...
If I press F2 in LinuxCNC the analogena signal seem to work in the HALSHOW but there is no power on the TB5 Analog Drive Interface from the 7i77. The PINS ENA0- and ENA0+ on the TB5 connector should get power when I turn on the machine with F2 right???
  • kello711
  • kello711's Avatar
06 Jan 2026 19:15
Replied by kello711 on topic 7i96S card arrived what setup is recomended
Category: Driver Boards
Yeah, I was already doing that with the other NC contact from the estop to the Mesa input and tied into the estop-latch logic in hal.
  • RotarySMP
  • RotarySMP's Avatar
06 Jan 2026 18:52
Replied by RotarySMP on topic Please help - Endless loop
Category: O Codes (subroutines) and NGCGUI
Thanks a lot.
Cheers,
Mark
  • scsmith1451
  • scsmith1451's Avatar
06 Jan 2026 18:40
Replied by scsmith1451 on topic No configuration pages for Y2 Axis
Category: PnCConf Wizard
I don't need them, this post was a continuation of a previous post on the subject of adding a second Y axis to my machine. But PCW has answered my question so finding the previous post is a not necessary.
Thx,
  • MaHa
  • MaHa
06 Jan 2026 18:37
Replied by MaHa on topic Please help - Endless loop
#1 to #30 are used to send variables to a called subroutine, so them are not writeable in the sub. If names given from #31 up, it should work
Displaying 8746 - 8760 out of 12666 results.
Time to create page: 0.408 seconds
