  • lorenzing
  • lorenzing
20 Dec 2025 09:44 - 20 Dec 2025 09:47
Ethercat Motion Problem was created by lorenzing
Category: EtherCAT
Hi all,I'm experiencing an issue with my EtherCAT drive. When I try to move any axis through LinuxCNC, the motion is noticeably slower compared to using the drive's own software.I've attached two videos for comparison:
  • Hakan
  • Hakan
20 Dec 2025 09:37
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
I was able to find the manual and some info´about the alarm. Even if there were very few clues in the post
Then you can try
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000" syncToRefClock="true">
or if you have an old lcec version and syncToRefClock isn't recognized: refClockSyncCycles="-1000"
Check the lcec.0.pll-reset-count variable that it stays on single digit. Read at least one full page here github.com/linuxcnc-ethercat/linuxcnc-et...istributed-clocks.md
  • Hakan
  • Hakan
20 Dec 2025 09:21
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Good. Has happened before. A total reset after eeprom update is usually a good idea.
I normally upload firmware on the fly, even when connected to linuxcnc. Much less sensitive.
  • Hakan
  • Hakan
20 Dec 2025 09:18
Category: EtherCAT
And what does the last lines in "sudo dmesg" say?
It is the drive that is unhappy, but hopefully the ethercat master tells why it won't download data to an SDO.
Or give another clue.
  • tar_san
  • tar_san
20 Dec 2025 08:21 - 20 Dec 2025 08:21
Category: EtherCAT
Yes, 67108864 is Encoder count per round.
The problem is "Alarm A12 (EtherCAT Output Syncronization Error) "
A support person said,
"As long as A12 occurs, servo amp can't anser properly."
  • vibram
  • vibram
20 Dec 2025 07:48
Category: EtherCAT
strange, i unplug everything and replug and itw works in linuxcnc too :)
very happy about this
i will continue to see what can I achieve
thanks again !!!
I uploaded the github
  • unknown
  • unknown
20 Dec 2025 03:57
Replied by unknown on topic PicoBOB-DLX
PicoBOB-DLX
Category: Driver Boards
Stick with Mesa, loads of info, it works without issues, they've been around for ages. Support is fantastic. A 7i92T gives you 2 lpt like interfaces. So 34 io pins, can be expanded via SmartSerial cards to get even more io. Mesa drivers are part of the Linuxcnc source code, so you know they will always be supported.
Oh BTW chatgpt has given so much useless info regarding Linuxcnc it's gone past be a joke to a complete waste of time.
  • PCW
  • PCW's Avatar
20 Dec 2025 03:19
7i96S card arrived what setup is recomended
According to the manual section 6, it shows that I need to supply 5-24v DC to that circuit. Can I just use my 24v field power for this?
No, the output can switch 5V to 24V signals but should not be directly connected to a power source for sinking (NPN) operation
The ALM output would wire directly to a 7I96S input as shown in my table.
The drives 5V/24V switch only affects inputs (PUL,DIR,ENA)
Note that the ENA input is actually a  DISABLE input so not really of much use unless you change it's polarity.
(because the drive would be enabled if there is no controller power which is a bit crazy)
This likely requires the use of the (windows) software setup utility for the drive. Similarly, the ALM outputs cannot be
paralled unless re-programmed to be ON for alarm rather than the default OFF for alarm, They could possible be connected
in series instead using the default (OFF for alarm) setting
To use a step/dir pin for ENA, you set the number of stepgens to < 5, freeing up the GPIO pins that connect to say stepgen3 or 4
you then use the GPIO pins in hal to control the output state of these pins.
  • cmorley
  • cmorley
20 Dec 2025 02:56
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
I note you use the qtpy abstraction layer. This is not pulled in for our linuxcnc package, so could trip some people up. I would suggest adding a descriptive warning to the terminal if the module is not found.
  • PCW
  • PCW's Avatar
20 Dec 2025 02:12
Replied by PCW on topic Stepcraft M700 with 7i92TM
Category: PnCConf Wizard
7i92t_benezanx2d.bin firmware will at least have the first 4 stepgen pinouts correct
so that will get you a bit further.
To get the stepcraft configuration fully working may require a  new firmware configuration,
at least to get the PWMgen on the correct pin. Do you have a list of all DB25 pin functions?
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar
20 Dec 2025 01:34
Replied by LearningLinuxCNC on topic Pico Universal PWM Won't boot Random pins not working
John,
Yes it is the UPWM board. It is driving your pwm servo drives. The CMOS battery did die at one point but the parallel port is set up in epp mode. I am not sure why it is doing this. If you have any troubleshooting tips I would be glad to hear them. Could the eeprom be bad?
  • xkonni
  • xkonni
20 Dec 2025 00:23
Stepcraft M700 with 7i92TM was created by xkonni
Hello! After fiddling with uccnc on my Stepcraft M700 for a while I thought linuxcnc does look good.
Unfortunately I have lots of troubles to get things up and running.
The uccnc config does not look overly complicated:
Setting    X-Axis    Y-Axis    Z-Axis    A-Axis
Step Pin    Pin 3    Pin 5    Pin 7    Pin 9
Direction Pin    Pin 2    Pin 4    Pin 6    Pin 8
Steps per Unit    160    160    320    480
Or so I thought. Putting all this in pncconf does leave me with a non-working config, the axes just click when trying to move them. It seems that my machine has swapped dir and step pins but the firmware does not allow that.
After some trial and mostly error I found this:
- If DB25 Pin 2 is left disconnected ("open"), the spindle starts immediately
- The Y-axis Step signal is on Pin 6, not sure about the Dir
- The Z-axis Step signal is on Pin 8, not sure about the Dir
But I fail to make sense of it or get anything else to work. Did search through for forum for 7i92 or stepcraft machines, no luck so far. Wrong keywords maybe? Added my config, any help is appreciated!
  • unknown
  • unknown
20 Dec 2025 00:08
Installing on RPi with GPIO and software stepping
Category: Installing LinuxCNC
The hal_gpio driver will only work with the bookworm images and not with the recent Trixie images due to incompatibility issues with libgpiod2 supplied with bookworm and libgpiod3 supplied with Trixie.
I raised this issue on GitHub and it is on the to do list.
So what it means is that for gpios builds use the images dated around Jan 2025 or earlier.
  • Hakan
  • Hakan
19 Dec 2025 23:54
Category: EtherCAT
Preop is fine, preop E is not.
General debug tool is to look at the last 10-20 or so lines from "sudo dmesg". Ethercat master always says there what is the problem. Not always easy to decode, still it gives some clues.
Many many times the eeprom and firmware have come out of sync. Like added something with eeprom_generator and didn't upload eeprom.
Also, does the counter update in Twincat?
If you get stuck and it won't work, please push the updated code to github and I can have a look.
  • NWE
  • NWE's Avatar
19 Dec 2025 22:13 - 20 Dec 2025 06:41
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
Y1 and Y2 are not reading any index for me. I better bring my oscilloscope next time to check what, if anything, is coming in those z and /z wires from the linear scales. Latching hal logic connected to [HMOT](CARD0).encoder.04.input-index and [HMOT](CARD0).encoder.05.input-index does not catch any pulse.
Y1 and Y2 also has reference sensors near the bottom, it'll never reach that position after he installs the punch and the die. I see the book calls them Max Down Left, and Max Down Right. So they are bottom limits. Maybe to avoid overextending the cylinders when no tooling is installed.
edit:
Finally got R1 axis (joint 6) homing to index.
When all else fails, read the instructions! Here is the magic that makes home-to-index work:
net    j6-index-enable        [HMOT](CARD0).encoder.00.index-enable
net    j6-index-enable        joint.6.index-enable
Displaying 9481 - 9495 out of 12676 results.
Time to create page: 0.350 seconds
