- onceloved
03 Sep 2025 15:44
Replied by onceloved on topic Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
关闭eoe试试
- Artur_1617
03 Sep 2025 15:41
Replied by Artur_1617 on topic Mpg stop working
Mpg stop working
Category: AXIS
I made changes but still not working after homing.
- John15
- John15
03 Sep 2025 15:07
Replied by John15 on topic Install works but the password entered will not work to log on. Please Help
Category: Installing LinuxCNC
Thank's for your replies. It's the login screen thats not clear!
As you say it wants the user name in the top of the two rows but there is no indication that that is what it needs.
All sorted now
Thanks again
All sorted now
Thanks again
03 Sep 2025 14:59
Replied by andypugh on topic Mpg stop working
Mpg stop working
Category: AXIS
Yes.
Just add the axes too
net x-jog-select joint.0.jog-enable axis.x.jog-enable <= hm2_5i25.0.7i77.0.0.input-10
net y-jog-select joint.1.jog-enable axis.y.jog-enable <= hm2_5i25.0.7i77.0.0.input-11
... etc ...- andypugh
03 Sep 2025 14:52
Replied by andypugh on topic Program cnc linux
Program cnc linux
Category: Milling Machines
You need to "attach" the file with the "attachments" button then "include" it into the post.I tried to up load a jpg file but it kept saying didn't load.
03 Sep 2025 14:49
Replied by andypugh on topic Y axis A slave help request
Have you tried just importing the Mach3 configuration? That is an option.
("import mach file" on the first page)
That still might not properly configure a gantry, as I am not sure if LinuxCNC can tell the difference between a Y2 or a true A when parsing the Mach file.
Rather than configure it as an "A" configure it as a "Tandem Y" in the drop-downs.
- Artur_1617
03 Sep 2025 14:42
Mpg stop working
Category: AXIS
Yes Mpg working before homing.
I think must to change this
net x-jog-select joint.0.jog-enable <= hm2_5i25.0.7i77.0.0.input-10
net y-jog-select joint.1.jog-enable <= hm2_5i25.0.7i77.0.0.input-11
net z-jog-select joint.2.jog-enable <= hm2_5i25.0.7i77.0.0.input-12
net a-jog-select joint.3.jog-enable <= hm2_5i25.0.7i77.0.0.input-13
03 Sep 2025 14:42
Replied by andypugh on topic Gig Skillcut 60
Gig Skillcut 60
Yes, can you post the link that you found that brought you here? I may be able to find an "orphan" image file on the server, for example.
- Maho400P
- Maho400P
03 Sep 2025 14:28
Replied by Maho400P on topic Debian tries to connect to the internet on EtherCAT network device?
Category: EtherCAT
Linuxcnc 2.9.4, dual ethernet network realtek rtl,
When first start pc wired connection 1 is connected and 2 is not seen. Connecting slave to connection 2 is not seen but working.
When first start slave wire connection 1 is not connected and 2 is not seen, slave is working. There is no internet.
03 Sep 2025 14:17
Replied by PCW on topic Mpg stop working
Mpg stop working
Category: AXIS
Is this homing related?
Because before homing you need to jog joints and after homing you need to jog axis
- Artur_1617
03 Sep 2025 13:43
Mpg stop working
Category: AXIS
Not, I use MPG conected directly to one encoder input in 7i77.
- Maho400P
- Maho400P
03 Sep 2025 13:40
Category: EtherCAT
Hello i am very new to linuxcnc but dicovered that when you start the ethercat slave before the PC is loaded you will loss connection to internet. The work around for me is first start the pc and then the slave.
- bridges67
- bridges67
03 Sep 2025 13:39 - 03 Sep 2025 14:51
Replied by bridges67 on topic Program cnc linux
Program cnc linux
(5555)
(SHOP SIGN CEDAR)
(T1 D=0.0252 CR=0.015 TAPER=10DEG - ZMIN=-0.0394 - TAPERED MILL)
N10 G90 G94 G17 G91.1
N15 G20
N20 G53 G0 Z0.
(TRACE3)
N25 T1 M6
N30 S5000 M3
N35 G17 G90 G94
N40 G54
N45 G64 P0.0004 Q0.0004
N50 G0 X-6.0683 Y3.7453
N55 G43 Z0.6 H1
N60 G0 Z0.1606
N65 G1 Z-0.0394 F13.123
N70 Y4.6203 F39.37
N75 X-5.8039
N80 X-5.6452 Y4.0235
N85 X-5.4882 Y4.6203
N90 X-5.2232
N95 Y3.7453
N100 X-5.3873
N105 Y4.4341
N110 X-5.561 Y3.7453
N115 X-5.7311
N120 X-5.9042 Y4.4341
N125 Y3.7453
N130 X-6.0683
N135 Z0.1606
N140 G0 Z0.2
N145 X-5.1367
N150 Z0.1606
N155 G1 Z-0.0394 F13.123
N160 X-4.7958 Y4.6203 F39.37
N165 X-4.609
N170 X-4.2587 Y3.7453
N175 X-4.4509
N180 X-4.5272 Y3.9441
N185 X-4.877
N190 X-4.9493 Y3.7453
N195 X-5.1367
N200 Z0.1606
N205 G0 Z0.2
N210 X-4.0903 Y3.8586
N215 Z0.1606
N220 G1 Z-0.0394 F13.123
N225 X-4.1097 Y3.8859 F39.37
N230 X-4.1222 Y3.9043
N235 X-4.1341 Y3.9229
N240 X-4.1452 Y3.9418
N245 X-4.1552 Y3.961
N250 X-4.1641 Y3.9807
N255 X-4.1716 Y4.0009
N260 X-4.1777 Y4.0215
N265 X-4.1826 Y4.0426
N270 X-4.1865 Y4.0641
N275 X-4.1894 Y4.0859
N280 X-4.1917 Y4.108
N285 X-4.1934 Y4.1302
N290 X-4.196 Y4.175
N295 X-4.1936 Y4.2216
N300 X-4.192 Y4.2446
N305 X-4.1898 Y4.2676
N310 X-4.1869 Y4.2902
N315 X-4.1831 Y4.3126
N320 X-4.1783 Y4.3346
N325 X-4.1722 Y4.3561
N330 X-4.1647 Y4.3772
N335 X-4.1558 Y4.3977
N340 X-4.1456 Y4.4178
N345 X-4.1343 Y4.4376
N350 X-4.1223 Y4.457
N355 X-4.1096 Y4.4763
N360 X-4.0832 Y4.5144
N365 X-4.051 Y4.5414
N370 X-4.0348 Y4.5544
N375 X-4.0183 Y4.5668
N380 X-4.0014 Y4.5785
N385 X-3.9842 Y4.5891
N390 X-3.9665 Y4.5987
N395 X-3.9481 Y4.6069
N400 X-3.9293 Y4.6136
N405 X-3.9099 Y4.6191
N410 X-3.89 Y4.6234
N415 X-3.8698 Y4.6269
N420 X-3.8492 Y4.6296
N425 X-3.8285 Y4.6318
N430 X-3.7865 Y4.6352
N435 X-3.7505 Y4.6327
N440 X-3.7326 Y4.6311
N445 X-3.7148 Y4.629
N450 X-3.6973 Y4.6264
N455 X-3.68 Y4.623
N460 X-3.6631 Y4.6188
N465 X-3.6465 Y4.6135
N470 X-3.6304 Y4.6071
N475 X-3.6147 Y4.5996
N480 X-3.5993 Y4.5912
N485 X-3.5842 Y4.582
N490 X-3.5694 Y4.5721
N495 X-3.5547 Y4.5618
N500 X-3.5257 Y4.5403
N505 X-3.5104 Y4.5225
N510 X-3.4957 Y4.5044
N515 X-3.4821 Y4.4856
N520 X-3.4758 Y4.4759
N525 X-3.4701 Y4.4659
N530 X-3.4648 Y4.4557
N535 X-3.4599 Y4.4452
N540 X-3.4512 Y4.4236
N545 X-3.4435 Y4.4015
N550 X-3.4362 Y4.3792
N555 X-3.6111 Y4.3374
N560 X-3.6158 Y4.3529
N565 X-3.6209 Y4.3681
N570 X-3.6269 Y4.3829
N575 X-3.6303 Y4.3899
N580 X-3.6341 Y4.3968
N585 X-3.6384 Y4.4034
N590 X-3.643 Y4.4098
N595 X-3.6532 Y4.4219
N600 X-3.6643 Y4.4335
N605 X-3.6758 Y4.4448
N610 X-3.6895 Y4.4536
N615 X-3.7033 Y4.4619
N620 X-3.7175 Y4.4692
N625 X-3.7248 Y4.4723
N630 X-3.7322 Y4.475
N635 X-3.7397 Y4.4772
N640 X-3.7474 Y4.4789
N645 X-3.7632 Y4.4815
N650 X-3.7793 Y4.4831
N655 X-3.7955 Y4.4842
N660 X-3.8182 Y4.482
N665 X-3.8405 Y4.4791
N670 X-3.8514 Y4.477
N675 X-3.862 Y4.4744
N680 X-3.8724 Y4.4712
N685 X-3.8825 Y4.4673
N690 X-3.8922 Y4.4626
N695 X-3.9015 Y4.457
N700 X-3.9106 Y4.4509
N705 X-3.9194 Y4.4443
N710 X-3.9366 Y4.4298
N715 X-3.9534 Y4.4144
N720 X-3.9685 Y4.3883
N725 X-3.9758 Y4.3752
N730 X-3.9826 Y4.362
N735 X-3.9889 Y4.3486
N740 X-3.9945 Y4.335
N745 X-3.9994 Y4.3212
N750 X-4.0033 Y4.3071
N755 X-4.0064 Y4.2927
N760 X-4.0088 Y4.2782
N765 X-4.0106 Y4.2635
N770 X-4.0119 Y4.2486
N775 X-4.0133 Y4.2185
N780 X-4.0139 Y4.1882
N785 X-4.0135 Y4.1567
N790 X-4.0122 Y4.1254
N795 X-4.011 Y4.1099
N800 X-4.0093 Y4.0946
N805 X-4.007 Y4.0794
N810 X-4.0039 Y4.0644
N815 X-4.0001 Y4.0497
N820 X-3.9954 Y4.0352
N825 X-3.9898 Y4.0209
N830 X-3.9835 Y4.0069
N835 X-3.9767 Y3.993
N840 X-3.9694 Y3.9792
N845 X-3.9543 Y3.9518
N850 X-3.9379 Y3.9364
N855 X-3.9211 Y3.9218
N860 X-3.9125 Y3.9151
N865 X-3.9036 Y3.909
N870 X-3.8944 Y3.9034
N875 X-3.8849 Y3.8987
N880 X-3.875 Y3.8947
N885 X-3.8648 Y3.8914
N890 X-3.8542 Y3.8888
N895 X-3.8435 Y3.8867
N900 X-3.8215 Y3.8836
N905 X-3.7991 Y3.8814
N910 X-3.7824 Y3.8828
N915 X-3.7659 Y3.8847
N920 X-3.7498 Y3.8877
N925 X-3.7419 Y3.8898
N930 X-3.7342 Y3.8923
N935 X-3.7268 Y3.8954
N940 X-3.7195 Y3.8989
N945 X-3.7053 Y3.9071
N950 X-3.6915 Y3.9163
N955 X-3.6779 Y3.9262
N960 X-3.6647 Y3.9415
N965 X-3.652 Y3.9572
N970 X-3.6461 Y3.9653
N975 X-3.6405 Y3.9735
N980 X-3.6353 Y3.982
N985 X-3.6306 Y3.9907
N990 X-3.6264 Y3.9998
N995 X-3.6226 Y4.0089
N1000 X-3.616 Y4.0279
N1005 X-3.6103 Y4.0473
N1010 X-3.6051 Y4.067
N1015 X-3.4338 Y4.0127
N1020 X-3.4438 Y3.9821
N1025 X-3.4546 Y3.952
N1030 X-3.4606 Y3.9373
N1035 X-3.467 Y3.9229
N1040 X-3.474 Y3.9088
N1045 X-3.4817 Y3.8952
N1050 X-3.4901 Y3.8821
N1055 X-3.4994 Y3.8694
N1060 X-3.5093 Y3.8572
N1065 X-3.5197 Y3.8453
N1070 X-3.5418 Y3.8223
N1075 X-3.5648 Y3.7999
N1080 X-3.5916 Y3.784
N1085 X-3.6188 Y3.769
N1090 X-3.6325 Y3.7622
N1095 X-3.6465 Y3.756
N1100 X-3.6606 Y3.7505
N1105 X-3.6751 Y3.7458
N1110 X-3.6898 Y3.742
N1115 X-3.7047 Y3.739
N1120 X-3.7198 Y3.7366
N1125 X-3.7351 Y3.7347
N1130 X-3.7661 Y3.7321
N1135 X-3.7973 Y3.7304
N1140 X-3.8378 Y3.734
N1145 X-3.8579 Y3.7363
N1150 X-3.8778 Y3.7391
N1155 X-3.8973 Y3.7426
N1160 X-3.9165 Y3.7469
N1165 X-3.9353 Y3.7524
N1170 X-3.9535 Y3.7591
N1175 X-3.9711 Y3.7672
N1180 X-3.9882 Y3.7765
N1185 X-4.0049 Y3.787
N1190 X-4.0211 Y3.7984
N1195 X-4.037 Y3.8105
N1200 X-4.0528 Y3.8232
N1205 X-4.0838 Y3.8495
N1210 X-4.0903 Y3.8586
N1215 Z0.1606
N1220 G0 Z0.2
N1225 X-3.2816 Y4.0703
N1230 Z0.1606
N1235 G1 Z-0.0394 F13.123
N1240 Y4.6203 F39.37
N1245 X-3.1049
N1250 Y4.2759
N1255 X-2.7587
N1260 Y4.6203
N1265 X-2.5821
N1270 Y3.7453
N1275 X-2.7587
N1280 Y4.1279
N1285 X-3.1049
N1290 Y3.7453
N1295 X-3.2816
N1300 Y4.0703
N1305 Z0.1606
N1310 G0 Z0.2
N1315 X-2.4048 Y3.7453
N1320 Z0.1606
N1325 G1 Z-0.0394 F13.123
N1330 Y4.6203 F39.37
N1335 X-2.2281
N1340 Y3.7453
N1345 X-2.4048
N1350 Z0.1606
N1355 G0 Z0.2
N1360 X-2.058
N1365 Z0.1606
N1370 G1 Z-0.0394 F13.123
N1375 Y4.6203 F39.37
N1380 X-1.8861
N1385 X-1.528 Y4.036
N1390 Y4.6203
N1395 X-1.3639
N1400 Y3.7453
N1405 X-1.5411
N1410 X-1.8939 Y4.3159
N1415 Y3.7453
N1420 X-2.058
N1425 Z0.1606
N1430 G0 Z0.2
N1435 X-2.0691 Y3.2542
N1440 Z0.1606
N1445 G1 Z-0.0394 F13.123
N1450 X-2.0482 Y3.2533 F39.37
N1455 X-2.0273 Y3.2518
N1460 X-2.0065 Y3.2494
N1465 X-1.9858 Y3.2461
N1470 X-1.9446 Y3.238
N1475 X-1.9261 Y3.2312
N1480 X-1.9079 Y3.2239
N1485 X-1.8902 Y3.2159
N1490 X-1.8816 Y3.2114
N1495 X-1.8733 Y3.2066
N1500 X-1.8651 Y3.2013
N1505 X-1.8572 Y3.1957
N1510 X-1.842 Y3.1836
N1515 X-1.8272 Y3.1707
N1520 X-1.8127 Y3.1574
N1525 X-1.7994 Y3.1414
N1530 X-1.7865 Y3.1251
N1535 X-1.7743 Y3.1084
N1540 X-1.7632 Y3.0911
N1545 X-1.7535 Y3.073
N1550 X-1.7448 Y3.0542
N1555 X-1.7368 Y3.035
N1560 X-1.7292 Y3.0156
N1565 X-1.7224 Y2.9903
N1570 X-1.7161 Y2.9648
N1575 X-1.7106 Y2.9392
N1580 X-1.7065 Y2.9135
N1585 X-1.7037 Y2.8875
N1590 X-1.702 Y2.8614
N1595 X-1.7005 Y2.8088
N1600 X-1.7021 Y2.7615
N1605 X-1.7037 Y2.738
N1610 X-1.7063 Y2.7146
N1615 X-1.7102 Y2.6914
N1620 X-1.7153 Y2.6684
N1625 X-1.7274 Y2.6226
N1630 X-1.7358 Y2.6013
N1635 X-1.7446 Y2.5802
N1640 X-1.7542 Y2.5596
N1645 X-1.7595 Y2.5495
N1650 X-1.7651 Y2.5397
N1655 X-1.7711 Y2.5301
N1660 X-1.7775 Y2.5208
N1665 X-1.7913 Y2.5028
N1670 X-1.806 Y2.4853
N1675 X-1.8211 Y2.468
N1680 X-1.8351 Y2.4566
N1685 X-1.8492 Y2.4455
N1690 X-1.8638 Y2.4352
N1695 X-1.879 Y2.4259
N1700 X-1.895 Y2.4179
N1705 X-1.9114 Y2.4108
N1710 X-1.9452 Y2.3982
N1715 X-1.9838 Y2.3895
N1720 X-2.0032 Y2.3859
N1725 X-2.0227 Y2.3832
N1730 X-2.0423 Y2.3815
N1735 X-2.062 Y2.3805
N1740 X-2.1016 Y2.3797
N1745 X-2.4341
N1750 Y3.2547
N1755 X-2.1112
N1760 X-2.0691 Y3.2542
N1765 Z0.1606
N1770 G0 Z0.2
N1775 X-2.2574 Y3.1067
N1780 Z0.1606
N1785 G1 Z-0.0394 F13.123
N1790 Y2.5271 F39.37
N1795 X-2.1255
N1800 X-2.0986 Y2.5273
N1805 X-2.0718 Y2.5284
N1810 X-2.0585 Y2.5295
N1815 X-2.0452 Y2.5312
N1820 X-2.0186 Y2.5355
N1825 X-1.9992 Y2.5416
N1830 X-1.9898 Y2.5451
N1835 X-1.9807 Y2.5492
N1840 X-1.972 Y2.5541
N1845 X-1.9636 Y2.5597
N1850 X-1.9473 Y2.5719
N1855 X-1.9318 Y2.5908
N1860 X-1.9248 Y2.6006
N1865 X-1.9187 Y2.611
N1870 X-1.9135 Y2.6219
N1875 X-1.9089 Y2.6331
N1880 X-1.9011 Y2.6563
N1885 X-1.8925 Y2.6959
N1890 X-1.8891 Y2.7158
N1895 X-1.8865 Y2.7358
N1900 X-1.8848 Y2.7559
N1905 X-1.8839 Y2.7761
N1910 X-1.8832 Y2.8166
N1915 X-1.8838 Y2.856
N1920 X-1.8847 Y2.8757
N1925 X-1.8863 Y2.8952
N1930 X-1.8889 Y2.9146
N1935 X-1.8924 Y2.934
N1940 X-1.9011 Y2.9724
N1945 X-1.91 Y2.9957
N1950 X-1.9151 Y3.007
N1955 X-1.9209 Y3.0179
N1960 X-1.9275 Y3.0283
N1965 X-1.935 Y3.0382
N1970 X-1.9512 Y3.0571
N1975 X-1.9696 Y3.0714
N1980 X-1.9792 Y3.0778
N1985 X-1.9892 Y3.0834
N1990 X-1.9997 Y3.088
N1995 X-2.0106 Y3.0919
N2000 X-2.033 Y3.0983
N2005 X-2.0691 Y3.1028
N2010 X-2.0871 Y3.1045
N2015 X-2.1053 Y3.1057
N2020 X-2.1416 Y3.1067
N2025 X-2.178
N2030 X-2.2574
N2035 Z0.1606
N2040 G0 Z0.2
N2045 X-1.5507 Y3.1047
N2050 Z0.1606
N2055 G1 Z-0.0394 F13.123
N2060 Y3.2547 F39.37
N2065 X-0.9019
N2070 Y3.1067
N2075 X-1.374
N2080 Y2.9127
N2085 X-0.9347
N2090 Y2.7653
N2095 X-1.374
N2100 Y2.5271
N2105 X-0.8852
N2110 Y2.3797
N2115 X-1.5507
N2120 Y3.1047
N2125 Z0.1606
N2130 G0 Z0.2
N2135 X-1.9114 Y1.6789
N2140 Z0.1606
N2145 G1 Z-0.0394 F13.123
N2150 X-1.9008 Y1.6725 F39.37
N2155 X-1.8909 Y1.6651
N2160 X-1.8815 Y1.6568
N2165 X-1.8638 Y1.639
N2170 X-1.8512 Y1.6194
N2175 X-1.8458 Y1.6094
N2180 X-1.8414 Y1.5989
N2185 X-1.8384 Y1.588
N2190 X-1.8364 Y1.5767
N2195 X-1.8342 Y1.5536
N2200 X-1.8352 Y1.5387
N2205 X-1.8361 Y1.5314
N2210 X-1.8374 Y1.5242
N2215 X-1.8393 Y1.5171
N2220 X-1.8417 Y1.5101
N2225 X-1.8473 Y1.4963
N2230 X-1.8551 Y1.4833
N2235 X-1.8594 Y1.477
N2240 X-1.864 Y1.4711
N2245 X-1.8691 Y1.4656
N2250 X-1.8745 Y1.4605
N2255 X-1.8861 Y1.4506
N2260 X-1.9049 Y1.4393
N2265 X-1.9145 Y1.4342
N2270 X-1.9244 Y1.4297
N2275 X-1.9346 Y1.4258
N2280 X-1.945 Y1.4225
N2285 X-1.9661 Y1.4167
N2290 X-1.9924 Y1.412
N2295 X-2.0188 Y1.408
N2300 X-2.0098 Y1.4176
N2305 X-2.0009 Y1.4233
N2310 X-1.9777 Y1.4196
N2315 X-1.9548 Y1.415
N2320 X-1.9435 Y1.412
N2325 X-1.9323 Y1.4086
N2330 X-1.9101 Y1.401
N2335 X-1.8932 Y1.3937
N2340 X-1.8769 Y1.3855
N2345 X-1.869 Y1.3809
N2350 X-1.8614 Y1.3758
N2355 X-1.8465 Y1.3651
N2360 X-1.8348 Y1.3544
N2365 X-1.8293 Y1.3488
N2370 X-1.8242 Y1.3429
N2375 X-1.8195 Y1.3366
N2380 X-1.8153 Y1.33
N2385 X-1.8074 Y1.3163
N2390 X-1.8018 Y1.3022
N2395 X-1.7994 Y1.295
N2400 X-1.7974 Y1.2877
N2405 X-1.7961 Y1.2803
N2410 X-1.7952 Y1.2728
N2415 X-1.7941 Y1.2576
N2420 X-1.7954 Y1.2445
N2425 X-1.7971 Y1.2316
N2430 X-1.7996 Y1.219
N2435 X-1.8014 Y1.2128
N2440 X-1.8035 Y1.2068
N2445 X-1.8088 Y1.1953
N2450 X-1.8155 Y1.1843
N2455 X-1.8229 Y1.1736
N2460 X-1.8308 Y1.1631
N2465 X-1.8535 Y1.1427
N2470 X-1.8653 Y1.1333
N2475 X-1.8778 Y1.1249
N2480 X-1.891 Y1.1177
N2485 X-1.9047 Y1.1114
N2490 X-1.9331 Y1.1001
N2495 X-1.9694 Y1.0905
N2500 X-1.9877 Y1.0864
N2505 X-2.0061 Y1.0832
N2510 X-2.0247 Y1.081
N2515 X-2.0434 Y1.0796
N2520 X-2.0809 Y1.0782
N2525 X-2.1043 Y1.0789
N2530 X-2.1276 Y1.0806
N2535 X-2.1508 Y1.0837
N2540 X-2.1738 Y1.0877
N2545 X-2.1921 Y1.0919
N2550 X-2.2101 Y1.097
N2555 X-2.219 Y1.1001
N2560 X-2.2276 Y1.1036
N2565 X-2.2447 Y1.1113
N2570 X-2.2595 Y1.1213
N2575 X-2.2665 Y1.1267
N2580 X-2.2732 Y1.1324
N2585 X-2.2793 Y1.1387
N2590 X-2.2851 Y1.1454
N2595 X-2.2959 Y1.1595
N2600 X-2.3035 Y1.1733
N2605 X-2.3067 Y1.1803
N2610 X-2.3094 Y1.1876
N2615 X-2.3114 Y1.195
N2620 X-2.3127 Y1.2026
N2625 X-2.3144 Y1.2183
N2630 X-2.3127 Y1.2345
N2635 X-2.3112 Y1.2424
N2640 X-2.3088 Y1.2499
N2645 X-2.3055 Y1.2571
N2650 X-2.3012 Y1.2638
N2655 X-2.2914 Y1.2769
N2660 X-2.2788 Y1.2869
N2665 X-2.2722 Y1.2912
N2670 X-2.2652 Y1.2946
N2675 X-2.2578 Y1.2971
N2680 X-2.2501 Y1.2986
N2685 X-2.2341 Y1.3004
N2690 X-2.2186 Y1.2989
N2695 X-2.2111 Y1.2975
N2700 X-2.204 Y1.2953
N2705 X-2.1972 Y1.2921
N2710 X-2.1907 Y1.2881
N2715 X-2.1784 Y1.2787
N2720 X-2.1691 Y1.2669
N2725 X-2.1652 Y1.2607
N2730 X-2.162 Y1.2542
N2735 X-2.1598 Y1.2473
N2740 X-2.1584 Y1.24
N2745 X-2.1568 Y1.2251
N2750 X-2.1574 Y1.2157
N2755 X-2.159 Y1.2066
N2760 X-2.1621 Y1.1979
N2765 X-2.1663 Y1.1895
N2770 X-2.173 Y1.1808
N2775 X-2.1805 Y1.1727
N2780 X-2.1889 Y1.1657
N2785 X-2.1979 Y1.1593
N2790 X-2.202 Y1.1569
N2795 X-2.2057 Y1.1541
N2800 X-2.2086 Y1.1506
N2805 X-2.2109 Y1.1465
N2810 X-2.2053 Y1.1372
N2815 X-2.2019 Y1.1333
N2820 X-2.1979 Y1.1301
N2825 X-2.1933 Y1.1276
N2830 X-2.1883 Y1.1256
N2835 X-2.1775 Y1.1223
N2840 X-2.1559 Y1.1171
N2845 X-2.1451 Y1.115
N2850 X-2.1342 Y1.1134
N2855 X-2.1232 Y1.1123
N2860 X-2.1121 Y1.1117
N2865 X-2.0899 Y1.1112
N2870 X-2.0756 Y1.1115
N2875 X-2.0614 Y1.1122
N2880 X-2.0474 Y1.1137
N2885 X-2.0339 Y1.1165
N2890 X-2.0273 Y1.1184
N2895 X-2.0209 Y1.1208
N2900 X-2.0084 Y1.1268
N2905 X-1.9962 Y1.1339
N2910 X-1.9842 Y1.1416
N2915 X-1.9755 Y1.1541
N2920 X-1.9674 Y1.1669
N2925 X-1.9638 Y1.1734
N2930 X-1.9606 Y1.18
N2935 X-1.9578 Y1.1868
N2940 X-1.9556 Y1.1938
N2945 X-1.9538 Y1.2009
N2950 X-1.9526 Y1.2081
N2955 X-1.9512 Y1.223
N2960 X-1.9508 Y1.2382
N2965 X-1.951 Y1.2536
N2970 X-1.952 Y1.2689
N2975 X-1.9534 Y1.2841
N2980 X-1.9556 Y1.299
N2985 X-1.959 Y1.3135
N2990 X-1.9612 Y1.3205
N2995 X-1.964 Y1.3274
N3000 X-1.9706 Y1.3408
N3005 X-1.9784 Y1.3537
N3010 X-1.9868 Y1.3664
N3015 X-1.9971 Y1.3737
N3020 X-2.0076 Y1.3806
N3025 X-2.0185 Y1.3865
N3030 X-2.0241 Y1.3889
N3035 X-2.0298 Y1.391
N3040 X-2.0417 Y1.394
N3045 X-2.054 Y1.3958
N3050 X-2.0665 Y1.3968
N3055 X-2.0793 Y1.3974
N3060 X-2.1071 Y1.3962
N3065 X-2.1349 Y1.3941
N3070 X-2.1474 Y1.3928
N3075 X-2.1599 Y1.3923
N3080 X-2.1662 Y1.3926
N3085 X-2.1723 Y1.3932
N3090 X-2.1778 Y1.3944
N3095 X-2.1826 Y1.3966
N3100 X-2.1846 Y1.3981
N3105 X-2.1863 Y1.4
N3110 X-2.1891 Y1.4046
N3115 X-2.1912 Y1.41
N3120 X-2.1929 Y1.4159
N3125 X-2.1908 Y1.4219
N3130 X-2.1883 Y1.4274
N3135 X-2.1851 Y1.4321
N3140 X-2.1832 Y1.4339
N3145 X-2.181 Y1.4354
N3150 X-2.1758 Y1.4374
N3155 X-2.1699 Y1.4385
N3160 X-2.1635 Y1.4389
N3165 X-2.1569 Y1.4391
N3170 X-2.1422 Y1.4379
N3175 X-2.1274 Y1.4364
N3180 X-2.103 Y1.4341
N3185 X-2.0784 Y1.4331
N3190 X-2.0638 Y1.4336
N3195 X-2.0566 Y1.4342
N3200 X-2.0494 Y1.4352
N3205 X-2.0424 Y1.4367
N3210 X-2.0355 Y1.4388
N3215 X-2.0219 Y1.4439
N3220 X-2.0121 Y1.4507
N3225 X-2.0076 Y1.4545
N3230 X-2.0036 Y1.4586
N3235 X-2.0001 Y1.4633
N3240 X-1.997 Y1.4683
N3245 X-1.9917 Y1.479
N3250 X-1.9871 Y1.4958
N3255 X-1.9852 Y1.5042
N3260 X-1.9838 Y1.5128
N3265 X-1.9824 Y1.53
N3270 X-1.9821 Y1.5475
N3275 X-1.9824 Y1.5587
N3280 X-1.983 Y1.5698
N3285 X-1.9844 Y1.5809
N3290 X-1.9862 Y1.592
N3295 X-1.9908 Y1.6103
N3300 X-1.994 Y1.6192
N3305 X-1.9976 Y1.628
N3310 X-2.0012 Y1.6349
N3315 X-2.0052 Y1.6415
N3320 X-2.01 Y1.6476
N3325 X-2.0152 Y1.6534
N3330 X-2.0238 Y1.6596
N3335 X-2.0325 Y1.6655
N3340 X-2.0416 Y1.6706
N3345 X-2.051 Y1.6745
N3350 X-2.0609 Y1.6771
N3355 X-2.0712 Y1.6787
N3360 X-2.0924 Y1.6801
N3365 X-2.1071 Y1.6797
N3370 X-2.1217 Y1.6785
N3375 X-2.1362 Y1.6762
N3380 X-2.1506 Y1.6732
N3385 X-2.1614 Y1.6702
N3390 X-2.172 Y1.6666
N3395 X-2.1821 Y1.6619
N3400 X-2.192 Y1.6564
N3405 X-2.1971 Y1.6529
N3410 X-2.2015 Y1.6489
N3415 X-2.2032 Y1.6465
N3420 X-2.2046 Y1.6439
N3425 X-2.2066 Y1.6382
N3430 X-2.2059 Y1.6347
N3435 X-2.204 Y1.6319
N3440 X-2.1978 Y1.6271
N3445 X-2.1911 Y1.623
N3450 X-2.1819 Y1.6179
N3455 X-2.1733 Y1.6121
N3460 X-2.1694 Y1.6087
N3465 X-2.1658 Y1.6049
N3470 X-2.159 Y1.5969
N3475 X-2.1544 Y1.5879
N3480 X-2.1525 Y1.5833
N3485 X-2.151 Y1.5785
N3490 X-2.1493 Y1.5687
N3495 X-2.1487 Y1.5586
N3500 X-2.1502 Y1.544
N3505 X-2.1516 Y1.5369
N3510 X-2.1538 Y1.5302
N3515 X-2.1569 Y1.5239
N3520 X-2.1608 Y1.5178
N3525 X-2.1699 Y1.5063
N3530 X-2.1816 Y1.4975
N3535 X-2.1877 Y1.4937
N3540 X-2.1941 Y1.4906
N3545 X-2.2009 Y1.4885
N3550 X-2.208 Y1.4871
N3555 X-2.2226 Y1.4856
N3560 X-2.2381 Y1.4873
N3565 X-2.2456 Y1.4889
N3570 X-2.2527 Y1.4912
N3575 X-2.2594 Y1.4945
N3580 X-2.2658 Y1.4987
N3585 X-2.278 Y1.5084
N3590 X-2.2875 Y1.5208
N3595 X-2.2916 Y1.5273
N3600 X-2.2949 Y1.534
N3605 X-2.2971 Y1.5412
N3610 X-2.2986 Y1.5487
N3615 X-2.3003 Y1.5642
N3620 X-2.2979 Y1.5859
N3625 X-2.2958 Y1.5963
N3630 X-2.2927 Y1.6064
N3635 X-2.2883 Y1.616
N3640 X-2.2828 Y1.6252
N3645 X-2.2702 Y1.6429
N3650 X-2.2518 Y1.6599
N3655 X-2.2422 Y1.6678
N3660 X-2.232 Y1.6748
N3665 X-2.2212 Y1.6809
N3670 X-2.21 Y1.6862
N3675 X-2.1868 Y1.6957
N3680 X-2.1573 Y1.7037
N3685 X-2.1425 Y1.7072
N3690 X-2.1276 Y1.7099
N3695 X-2.1125 Y1.7117
N3700 X-2.0974 Y1.7129
N3705 X-2.0668 Y1.7141
N3710 X-2.0359 Y1.7129
N3715 X-2.0206 Y1.7117
N3720 X-2.0053 Y1.7098
N3725 X-1.9902 Y1.707
N3730 X-1.9753 Y1.7034
N3735 X-1.9455 Y1.6948
N3740 X-1.9225 Y1.6846
N3745 X-1.9114 Y1.6789
N3750 Z0.1606
N3755 G0 Z0.2
N3760 X-1.692 Y1.3613
N3765 Z0.1606
N3770 G1 Z-0.0394 F13.123
N3775 X-1.3819 F39.37
N3780 Y1.2356
N3785 X-1.692
N3790 Y1.3613
N3795 Z0.1606
N3800 G0 Z0.2
N3805 X-1.2737 Y1.3142
N3810 Z0.1606
N3815 G1 Z-0.0394 F13.123
N3820 X-0.9153 Y1.7132 F39.37
N3825 X-0.8691
N3830 Y1.3196
N3835 X-0.7399
N3840 Y1.2348
N3845 X-0.8691
N3850 Y1.2111
N3855 X-0.8677 Y1.1927
N3860 X-0.8662 Y1.1839
N3865 X-0.8639 Y1.1753
N3870 X-0.8603 Y1.1673
N3875 X-0.8556 Y1.1597
N3880 X-0.8446 Y1.1451
N3885 X-0.8289 Y1.1346
N3890 X-0.8207 Y1.1302
N3895 X-0.8121 Y1.1269
N3900 X-0.8032 Y1.1247
N3905 X-0.794 Y1.1233
N3910 X-0.775 Y1.1221
N3915 X-0.7459
N3920 Y1.0891
N3925 X-1.1364
N3930 Y1.1221
N3935 X-1.1094
N3940 X-1.093 Y1.1226
N3945 X-1.0848 Y1.1232
N3950 X-1.0767 Y1.1242
N3955 X-1.0687 Y1.1257
N3960 X-1.0608 Y1.1277
N3965 X-1.0451 Y1.1326
N3970 X-1.0342 Y1.1385
N3975 X-1.029 Y1.1418
N3980 X-1.0243 Y1.1456
N3985 X-1.02 Y1.1499
N3990 X-1.0162 Y1.1547
N3995 X-1.0092 Y1.1649
N4000 X-1.0039 Y1.179
N4005 X-1.0017 Y1.1862
N4010 X-1.0001 Y1.1935
N4015 X-0.999 Y1.2008
N4020 X-0.9984 Y1.2083
N4025 X-0.9978 Y1.2234
N4030 Y1.2348
N4035 X-1.2737
N4040 Y1.3142
N4045 Z0.1606
N4050 G0 Z0.2
N4055 X-0.9978 Y1.5866
N4060 Z0.1606
N4065 G1 Z-0.0394 F13.123
N4070 X-1.2359 Y1.3187 F39.37
N4075 X-0.9978
N4080 Y1.5866
N4085 Z0.1606
N4090 G0 Z0.2
N4095 X-0.6733 Y1.5604
N4100 Z0.1606
N4105 G1 Z-0.0394 F13.123
N4110 X-0.6714 Y1.5729 F39.37
N4115 X-0.6684 Y1.585
N4120 X-0.664 Y1.5966
N4125 X-0.6586 Y1.608
N4130 X-0.6459 Y1.6301
N4135 X-0.6279 Y1.6498
N4140 X-0.6184 Y1.6589
N4145 X-0.6082 Y1.6672
N4150 X-0.5972 Y1.6743
N4155 X-0.5855 Y1.6807
N4160 X-0.5613 Y1.6919
N4165 X-0.53 Y1.7014
N4170 X-0.5143 Y1.7053
N4175 X-0.4984 Y1.7084
N4180 X-0.4823 Y1.7105
N4185 X-0.4661 Y1.7119
N4190 X-0.4334 Y1.7132
N4195 X-0.4088 Y1.7121
N4200 X-0.3844 Y1.7103
N4205 X-0.3724 Y1.7089
N4210 X-0.3606 Y1.707
N4215 X-0.3489 Y1.7045
N4220 X-0.3375 Y1.7013
N4225 X-0.3264 Y1.6974
N4230 X-0.3156 Y1.6926
N4235 X-0.305 Y1.6872
N4240 X-0.2946 Y1.6812
N4245 X-0.2743 Y1.6679
N4250 X-0.2543 Y1.6536
N4255 X-0.2458 Y1.6443
N4260 X-0.2381 Y1.6344
N4265 X-0.2317 Y1.6236
N4270 X-0.2261 Y1.6122
N4275 X-0.2217 Y1.6001
N4280 X-0.2182 Y1.5877
N4285 X-0.2163 Y1.5751
N4290 X-0.2154 Y1.5622
N4295 X-0.2163 Y1.548
N4300 X-0.2171 Y1.541
N4305 X-0.2184 Y1.5341
N4310 X-0.2203 Y1.5273
N4315 X-0.2226 Y1.5207
N4320 X-0.228 Y1.5075
N4325 X-0.2363 Y1.4946
N4330 X-0.2407 Y1.4884
N4335 X-0.2455 Y1.4825
N4340 X-0.2508 Y1.477
N4345 X-0.2564 Y1.4719
N4350 X-0.2682 Y1.462
N4355 X-0.2836 Y1.452
N4360 X-0.2915 Y1.4473
N4365 X-0.2996 Y1.4431
N4370 X-0.308 Y1.4395
N4375 X-0.3165 Y1.4363
N4380 X-0.334 Y1.4305
N4385 X-0.3058 Y1.421
N4390 X-0.2919 Y1.4156
N4395 X-0.2785 Y1.4095
N4400 X-0.2655 Y1.4025
N4405 X-0.2529 Y1.3947
N4410 X-0.2284 Y1.3776
N4415 X-0.2161 Y1.3655
N4420 X-0.2044 Y1.3531
N4425 X-0.1989 Y1.3466
N4430 X-0.1939 Y1.34
N4435 X-0.1894 Y1.3331
N4440 X-0.1854 Y1.326
N4445 X-0.182 Y1.3186
N4450 X-0.1792 Y1.3108
N4455 X-0.177 Y1.3029
N4460 X-0.1751 Y1.2947
N4465 X-0.1723 Y1.2778
N4470 X-0.1702 Y1.2607
N4475 X-0.1712 Y1.2455
N4480 X-0.172 Y1.2379
N4485 X-0.1733 Y1.2305
N4490 X-0.1751 Y1.2231
N4495 X-0.1773 Y1.2158
N4500 X-0.1824 Y1.2014
N4505 X-0.1905 Y1.1864
N4510 X-0.1949 Y1.1792
N4515 X-0.1998 Y1.1723
N4520 X-0.2052 Y1.1659
N4525 X-0.2111 Y1.1597
N4530 X-0.2234 Y1.1479
N4535 X-0.2485 Y1.1307
N4540 X-0.2611 Y1.1224
N4545 X-0.2739 Y1.1146
N4550 X-0.2869 Y1.1073
N4555 X-0.3001 Y1.1008
N4560 X-0.3136 Y1.0952
N4565 X-0.3275 Y1.0906
N4570 X-0.3417 Y1.0869
N4575 X-0.3562 Y1.084
N4580 X-0.3709 Y1.0819
N4585 X-0.3858 Y1.0802
N4590 X-0.4161 Y1.0783
N4595 X-0.4467 Y1.0773
N4600 X-0.476 Y1.0782
N4605 X-0.4905 Y1.079
N4610 X-0.5051 Y1.0803
N4615 X-0.5195 Y1.0821
N4620 X-0.5339 Y1.0844
N4625 X-0.5627 Y1.0899
N4630 X-0.5859 Y1.0962
N4635 X-0.5973 Y1.0997
N4640 X-0.6085 Y1.1039
N4645 X-0.6194 Y1.1087
N4650 X-0.63 Y1.1141
N4655 X-0.6509 Y1.126
N4660 X-0.663 Y1.1361
N4665 X-0.6745 Y1.1465
N4670 X-0.6799 Y1.1519
N4675 X-0.6848 Y1.1576
N4680 X-0.6893 Y1.1635
N4685 X-0.6932 Y1.1697
N4690 X-0.6966 Y1.1762
N4695 X-0.6994 Y1.1831
N4700 X-0.7017 Y1.1902
N4705 X-0.7035 Y1.1975
N4710 X-0.7064 Y1.2127
N4715 X-0.7086 Y1.2283
N4720 X-0.7074 Y1.2451
N4725 X-0.7063 Y1.2534
N4730 X-0.7045 Y1.2616
N4735 X-0.702 Y1.2695
N4740 X-0.6988 Y1.2772
N4745 X-0.6913 Y1.2923
N4750 X-0.6797 Y1.3072
N4755 X-0.6735 Y1.3142
N4760 X-0.6668 Y1.3208
N4765 X-0.6596 Y1.3268
N4770 X-0.6521 Y1.3324
N4775 X-0.6363 Y1.3428
N4780 X-0.6144 Y1.3541
N4785 X-0.6032 Y1.3594
N4790 X-0.5919 Y1.3641
N4795 X-0.5803 Y1.3682
N4800 X-0.5685 Y1.3719
N4805 X-0.5447 Y1.3784
N4810 X-0.5723 Y1.3889
N4815 X-0.5856 Y1.3949
N4820 X-0.5983 Y1.4018
N4825 X-0.6104 Y1.4098
N4830 X-0.6217 Y1.4189
N4835 X-0.6326 Y1.4287
N4840 X-0.6433 Y1.4389
N4845 X-0.6506 Y1.4498
N4850 X-0.6573 Y1.4609
N4855 X-0.6633 Y1.4722
N4860 X-0.668 Y1.484
N4865 X-0.6712 Y1.4963
N4870 X-0.6733 Y1.509
N4875 X-0.6745 Y1.5219
N4880 X-0.6754 Y1.535
N4885 X-0.6733 Y1.5604
N4890 Z0.1606
N4895 G0 Z0.2
N4900 X-0.5279 Y1.3534
N4905 Z0.1606
N4910 G1 Z-0.0394 F13.123
N4915 X-0.539 Y1.3451 F39.37
N4920 X-0.5495 Y1.3361
N4925 X-0.5597 Y1.3266
N4930 X-0.5677 Y1.3172
N4935 X-0.575 Y1.3072
N4940 X-0.5808 Y1.2964
N4945 X-0.5858 Y1.2851
N4950 X-0.5894 Y1.272
N4955 X-0.592 Y1.2587
N4960 X-0.5933 Y1.2453
N4965 X-0.5938 Y1.2317
N4970 X-0.5863 Y1.2023
N4975 X-0.582 Y1.1882
N4980 X-0.5771 Y1.1748
N4985 X-0.5714 Y1.1624
N4990 X-0.5682 Y1.1566
N4995 X-0.5646 Y1.1512
N5000 X-0.5608 Y1.1461
N5005 X-0.5566 Y1.1414
N5010 X-0.5521 Y1.1372
N5015 X-0.5472 Y1.1333
N5020 X-0.542 Y1.1298
N5025 X-0.5364 Y1.1268
N5030 X-0.5306 Y1.124
N5035 X-0.5244 Y1.1216
N5040 X-0.5114 Y1.1176
N5045 X-0.4975 Y1.1146
N5050 X-0.483 Y1.1124
N5055 X-0.4679 Y1.1108
N5060 X-0.4369 Y1.1086
N5065 X-0.4155 Y1.1095
N5070 X-0.4049 Y1.1104
N5075 X-0.3943 Y1.1118
N5080 X-0.3839 Y1.1138
N5085 X-0.3735 Y1.1164
N5090 X-0.353 Y1.1226
N5095 X-0.3372 Y1.1296
N5100 X-0.3295 Y1.1335
N5105 X-0.3222 Y1.1379
N5110 X-0.3153 Y1.1429
N5115 X-0.3088 Y1.1484
N5120 X-0.2963 Y1.1603
N5125 X-0.288 Y1.1721
N5130 X-0.2844 Y1.1783
N5135 X-0.2815 Y1.1846
N5140 X-0.2794 Y1.1913
N5145 X-0.278 Y1.1982
N5150 X-0.2762 Y1.2125
N5155 X-0.2778 Y1.227
N5160 X-0.2793 Y1.2339
N5165 X-0.2815 Y1.2405
N5170 X-0.2847 Y1.2467
N5175 X-0.2887 Y1.2525
N5180 X-0.2981 Y1.2636
N5185 X-0.3099 Y1.273
N5190 X-0.3222 Y1.2816
N5195 X-0.3424 Y1.2916
N5200 X-0.3628 Y1.3013
N5205 X-0.4043 Y1.3191
N5210 X-0.4344 Y1.3309
N5215 X-0.4585 Y1.3403
N5220 X-0.4692 Y1.3443
N5225 X-0.48 Y1.3479
N5230 X-0.5019 Y1.3553
N5235 X-0.5164 Y1.3612
N5240 X-0.5279 Y1.3534
N5245 Z0.1606
N5250 G0 Z0.2
N5255 X-0.4686 Y1.4832
N5260 Z0.1606
N5265 G1 Z-0.0394 F13.123
N5270 X-0.4482 Y1.4753 F39.37
N5275 X-0.4173 Y1.4643
N5280 X-0.3918 Y1.4563
N5285 X-0.3666 Y1.4476
N5290 X-0.3552 Y1.4578
N5295 X-0.3498 Y1.4631
N5300 X-0.3448 Y1.4688
N5305 X-0.3403 Y1.4749
N5310 X-0.3362 Y1.4813
N5315 X-0.3287 Y1.4946
N5320 X-0.3231 Y1.5105
N5325 X-0.3208 Y1.5185
N5330 X-0.319 Y1.5266
N5335 X-0.3178 Y1.5349
N5340 X-0.317 Y1.5432
N5345 X-0.3163 Y1.5601
N5350 X-0.3169 Y1.5726
N5355 X-0.3179 Y1.585
N5360 X-0.3198 Y1.597
N5365 X-0.3228 Y1.6087
N5370 X-0.3249 Y1.6142
N5375 X-0.3275 Y1.6197
N5380 X-0.3336 Y1.6301
N5385 X-0.3407 Y1.6402
N5390 X-0.3483 Y1.6502
N5395 X-0.3591 Y1.6574
N5400 X-0.3701 Y1.6641
N5405 X-0.3814 Y1.6699
N5410 X-0.3872 Y1.6723
N5415 X-0.3932 Y1.6742
N5420 X-0.4055 Y1.6771
N5425 X-0.4181 Y1.6787
N5430 X-0.4311 Y1.6796
N5435 X-0.4442 Y1.6801
N5440 X-0.4636 Y1.6794
N5445 X-0.4732 Y1.6787
N5450 X-0.4828 Y1.6775
N5455 X-0.4923 Y1.6757
N5460 X-0.5017 Y1.6735
N5465 X-0.5203 Y1.6681
N5470 X-0.534 Y1.6621
N5475 X-0.5407 Y1.6587
N5480 X-0.547 Y1.655
N5485 X-0.553 Y1.6506
N5490 X-0.5586 Y1.6458
N5495 X-0.5693 Y1.6354
N5500 X-0.5765 Y1.6242
N5505 X-0.5796 Y1.6184
N5510 X-0.582 Y1.6124
N5515 X-0.5837 Y1.6062
N5520 X-0.5849 Y1.5997
N5525 X-0.5861 Y1.5865
N5530 X-0.5856 Y1.5785
N5535 X-0.5845 Y1.5706
N5540 X-0.5824 Y1.5629
N5545 X-0.5796 Y1.5554
N5550 X-0.576 Y1.5487
N5555 X-0.572 Y1.5423
N5560 X-0.5672 Y1.5365
N5565 X-0.5619 Y1.5311
N5570 X-0.5506 Y1.5222
N5575 X-0.5386 Y1.5143
N5580 X-0.5089 Y1.5003
N5585 X-0.4788 Y1.4871
N5590 X-0.4686 Y1.4832
N5595 Z0.1606
N5600 G0 Z0.2
N5605 X-0.1129 Y1.4258
N5610 Z0.1606
N5615 G1 Z-0.0394 F13.123
N5620 X-0.1114 Y1.4423 F39.37
N5625 X-0.1091 Y1.4587
N5630 X-0.1058 Y1.4749
N5635 X-0.1017 Y1.4909
N5640 X-0.092 Y1.5228
N5645 X-0.0799 Y1.5498
N5650 X-0.0732 Y1.5629
N5655 X-0.0656 Y1.5754
N5660 X-0.057 Y1.5873
N5665 X-0.0476 Y1.5985
N5670 X-0.0272 Y1.62
N5675 X-0.0053 Y1.6414
N5680 X0.0061 Y1.6515
N5685 X0.018 Y1.6608
N5690 X0.0306 Y1.6691
N5695 X0.0438 Y1.6767
N5700 X0.0711 Y1.6905
N5705 X0.0986 Y1.7
N5710 X0.1125 Y1.7041
N5715 X0.1265 Y1.7074
N5720 X0.1408 Y1.7098
N5725 X0.1551 Y1.7114
N5730 X0.1842 Y1.7132
N5735 X0.2076 Y1.7119
N5740 X0.2192 Y1.7107
N5745 X0.2307 Y1.7088
N5750 X0.242 Y1.7061
N5755 X0.2531 Y1.7027
N5760 X0.2752 Y1.6948
N5765 X0.2941 Y1.6849
N5770 X0.3031 Y1.6795
N5775 X0.3117 Y1.6735
N5780 X0.3197 Y1.6668
N5785 X0.3273 Y1.6594
N5790 X0.3416 Y1.6438
N5795 X0.352 Y1.6274
N5800 X0.3564 Y1.619
N5805 X0.3601 Y1.6103
N5810 X0.3627 Y1.6013
N5815 X0.3645 Y1.5919
N5820 X0.3666 Y1.5727
N5825 X0.3649 Y1.5575
N5830 X0.3634 Y1.5501
N5835 X0.3612 Y1.543
N5840 X0.358 Y1.5363
N5845 X0.3541 Y1.5299
N5850 X0.3448 Y1.5176
N5855 X0.3328 Y1.5079
N5860 X0.3265 Y1.5038
N5865 X0.3198 Y1.5005
N5870 X0.3128 Y1.4981
N5875 X0.3054 Y1.4966
N5880 X0.29 Y1.495
N5885 X0.2747 Y1.4964
N5890 X0.2673 Y1.4978
N5895 X0.2601 Y1.4999
N5900 X0.2533 Y1.5029
N5905 X0.2469 Y1.5067
N5910 X0.2344 Y1.5157
N5915 X0.2249 Y1.5272
N5920 X0.2208 Y1.5332
N5925 X0.2176 Y1.5396
N5930 X0.2153 Y1.5464
N5935 X0.2138 Y1.5535
N5940 X0.2121 Y1.5683
N5945 X0.2129 Y1.5788
N5950 X0.2136 Y1.5839
N5955 X0.2147 Y1.5889
N5960 X0.2164 Y1.5937
N5965 X0.2185 Y1.5984
N5970 X0.2235 Y1.6076
N5975 X0.2308 Y1.6158
N5980 X0.2387 Y1.6233
N5985 X0.2477 Y1.6295
N5990 X0.2573 Y1.635
N5995 X0.2623 Y1.6375
N6000 X0.267 Y1.6404
N6005 X0.2711 Y1.644
N6010 X0.2746 Y1.6484
N6015 X0.2729 Y1.6525
N6020 X0.2705 Y1.6561
N6025 X0.2673 Y1.659
N6030 X0.2635 Y1.6616
N6035 X0.256 Y1.6659
N6040 X0.2482 Y1.6695
N6045 X0.2401 Y1.6723
N6050 X0.2318 Y1.6747
N6055 X0.2207 Y1.6771
N6060 X0.2095 Y1.6789
N6065 X0.1981 Y1.6798
N6070 X0.1868 Y1.6801
N6075 X0.171 Y1.6788
N6080 X0.1556 Y1.6769
N6085 X0.148 Y1.6756
N6090 X0.1407 Y1.6738
N6095 X0.1336 Y1.6716
N6100 X0.1267 Y1.6688
N6105 X0.1202 Y1.6655
N6110 X0.1139 Y1.6615
N6115 X0.1079 Y1.6571
N6120 X0.102 Y1.6522
N6125 X0.0908 Y1.6415
N6130 X0.0799 Y1.6302
N6135 X0.0711 Y1.6117
N6140 X0.0628 Y1.593
N6145 X0.0592 Y1.5836
N6150 X0.0559 Y1.574
N6155 X0.0531 Y1.5644
N6160 X0.0508 Y1.5546
N6165 X0.049 Y1.5447
N6170 X0.0476 Y1.5347
N6175 X0.0459 Y1.5145
N6180 X0.045 Y1.494
N6185 X0.0447 Y1.4734
N6190 Y1.393
N6195 X0.0325
N6200 X0.0479 Y1.411
N6205 X0.0557 Y1.4197
N6210 X0.0638 Y1.428
N6215 X0.0721 Y1.4358
N6220 X0.0808 Y1.4429
N6225 X0.0898 Y1.4493
N6230 X0.0994 Y1.4548
N6235 X0.1094 Y1.4593
N6240 X0.1199 Y1.463
N6245 X0.1308 Y1.4659
N6250 X0.142 Y1.4683
N6255 X0.1535 Y1.4701
N6260 X0.1651 Y1.4716
N6265 X0.1887 Y1.474
N6270 X0.2166 Y1.4721
N6275 X0.2303 Y1.4705
N6280 X0.2438 Y1.4679
N6285 X0.2571 Y1.4643
N6290 X0.2702 Y1.4597
N6295 X0.2959 Y1.449
N6300 X0.3185 Y1.4353
N6305 X0.3292 Y1.4278
N6310 X0.3393 Y1.4196
N6315 X0.3486 Y1.4106
N6320 X0.3573 Y1.4008
N6325 X0.3735 Y1.38
N6330 X0.3856 Y1.3574
N6335 X0.3908 Y1.3458
N6340 X0.395 Y1.3339
N6345 X0.398 Y1.3217
N6350 X0.4 Y1.3091
N6355 X0.4022 Y1.2835
N6360 X0.3997 Y1.2555
N6365 X0.3976 Y1.2418
N6370 X0.3943 Y1.2285
N6375 X0.3896 Y1.2155
N6380 X0.3838 Y1.2029
N6385 X0.3703 Y1.1782
N6390 X0.352 Y1.1555
N6395 X0.3422 Y1.1449
N6400 X0.3317 Y1.1351
N6405 X0.3203 Y1.1263
N6410 X0.3082 Y1.1184
N6415 X0.2828 Y1.1039
N6420 X0.2531 Y1.0925
N6425 X0.2381 Y1.0876
N6430 X0.2228 Y1.0837
N6435 X0.2073 Y1.081
N6440 X0.1916 Y1.0792
N6445 X0.1598 Y1.0773
N6450 X0.1338 Y1.0786
N6455 X0.121 Y1.0798
N6460 X0.1082 Y1.0816
N6465 X0.0956 Y1.0843
N6470 X0.0832 Y1.0877
N6475 X0.0584 Y1.0956
N6480 X0.0361 Y1.1061
N6485 X0.0252 Y1.1118
N6490 X0.0148 Y1.1181
N6495 X0.0047 Y1.125
N6500 X-0.005 Y1.1326
N6505 X-0.0237 Y1.1486
N6510 X-0.0377 Y1.1641
N6515 X-0.0444 Y1.1721
N6520 X-0.0508 Y1.1804
N6525 X-0.0567 Y1.1889
N6530 X-0.0622 Y1.1977
N6535 X-0.0728 Y1.2158
N6540 X-0.0824 Y1.2359
N6545 X-0.0869 Y1.2461
N6550 X-0.091 Y1.2564
N6555 X-0.0979 Y1.2776
N6560 X-0.1039 Y1.2991
N6565 X-0.1084 Y1.3222
N6570 X-0.1119 Y1.3455
N6575 X-0.1137 Y1.369
N6580 X-0.1145 Y1.3925
N6585 X-0.1129 Y1.4258
N6590 Z0.1606
N6595 G0 Z0.2
N6600 X0.0937 Y1.414
N6605 Z0.1606
N6610 G1 Z-0.0394 F13.123
N6615 X0.0875 Y1.4093 F39.37
N6620 X0.0817 Y1.4043
N6625 X0.0763 Y1.3988
N6630 X0.0716 Y1.3929
N6635 X0.0672 Y1.3866
N6640 X0.0593 Y1.3732
N6645 X0.0529 Y1.3568
N6650 X0.0502 Y1.3485
N6655 X0.048 Y1.3401
N6660 X0.0466 Y1.3315
N6665 X0.0457 Y1.3228
N6670 X0.0447 Y1.3052
N6675 Y1.251
N6680 X0.0453 Y1.2308
N6685 X0.0461 Y1.2208
N6690 X0.0472 Y1.2108
N6695 X0.049 Y1.201
N6700 X0.0514 Y1.1912
N6705 X0.0571 Y1.1719
N6710 X0.0637 Y1.1582
N6715 X0.0673 Y1.1516
N6720 X0.0715 Y1.1455
N6725 X0.0763 Y1.1399
N6730 X0.0817 Y1.1347
N6735 X0.0933 Y1.125
N6740 X0.107 Y1.1181
N6745 X0.114 Y1.1152
N6750 X0.1211 Y1.113
N6755 X0.1285 Y1.1114
N6760 X0.136 Y1.1105
N6765 X0.1513 Y1.1095
N6770 X0.1627 Y1.1105
N6775 X0.1738 Y1.112
N6780 X0.1845 Y1.1145
N6785 X0.1895 Y1.1162
N6790 X0.1943 Y1.1184
N6795 X0.1989 Y1.121
N6800 X0.2032 Y1.1241
N6805 X0.2113 Y1.1314
N6810 X0.2187 Y1.1398
N6815 X0.2259 Y1.1486
N6820 X0.2304 Y1.1568
N6825 X0.2342 Y1.1653
N6830 X0.2369 Y1.1742
N6835 X0.2391 Y1.1833
N6840 X0.2426 Y1.2106
N6845 X0.244 Y1.2244
N6850 X0.2449 Y1.2381
N6855 X0.2456 Y1.2657
N6860 Y1.2933
N6865 X0.2454 Y1.3128
N6870 X0.2444 Y1.3321
N6875 X0.242 Y1.3514
N6880 X0.2387 Y1.3706
N6885 X0.2342 Y1.3842
N6890 X0.2316 Y1.3909
N6895 X0.2286 Y1.3974
N6900 X0.2252 Y1.4036
N6905 X0.2213 Y1.4097
N6910 X0.213 Y1.4214
N6915 X0.2006 Y1.4279
N6920 X0.1942 Y1.4305
N6925 X0.1876 Y1.4324
N6930 X0.1808 Y1.4337
N6935 X0.1739 Y1.4344
N6940 X0.1598 Y1.4348
N6945 X0.144 Y1.4337
N6950 X0.1363 Y1.4327
N6955 X0.1287 Y1.431
N6960 X0.1213 Y1.4287
N6965 X0.114 Y1.4257
N6970 X0.0998 Y1.4187
N6975 X0.0937 Y1.414
N6980 Z0.1606
N6985 G0 Z0.2
N6990 X0.5088 Y1.311
N6995 Z0.1606
N7000 G1 Z-0.0394 F13.123
N7005 Y1.3613 F39.37
N7010 X0.8189
N7015 Y1.2356
N7020 X0.5088
N7025 Y1.311
N7030 Z0.1606
N7035 G0 Z0.2
N7040 X0.9386 Y1.2424
N7045 Z0.1606
N7050 G1 Z-0.0394 F13.123
N7055 X0.941 Y1.2499 F39.37
N7060 X0.9444 Y1.2571
N7065 X0.9486 Y1.2638
N7070 X0.9585 Y1.2769
N7075 X0.9711 Y1.2869
N7080 X0.9777 Y1.2912
N7085 X0.9846 Y1.2946
N7090 X0.992 Y1.2971
N7095 X0.9997 Y1.2986
N7100 X1.0157 Y1.3004
N7105 X1.0312 Y1.2989
N7110 X1.0387 Y1.2975
N7115 X1.0459 Y1.2953
N7120 X1.0526 Y1.2921
N7125 X1.0591 Y1.2881
N7130 X1.0715 Y1.2787
N7135 X1.0807 Y1.2669
N7140 X1.0846 Y1.2607
N7145 X1.0878 Y1.2542
N7150 X1.09 Y1.2473
N7155 X1.0915 Y1.24
N7160 X1.0931 Y1.2251
N7165 X1.0924 Y1.2157
N7170 X1.0908 Y1.2066
N7175 X1.0877 Y1.1979
N7180 X1.0836 Y1.1895
N7185 X1.0768 Y1.1808
N7190 X1.0694 Y1.1727
N7195 X1.0609 Y1.1657
N7200 X1.0519 Y1.1593
N7205 X1.0478 Y1.1569
N7210 X1.0441 Y1.1541
N7215 X1.0412 Y1.1506
N7220 X1.0389 Y1.1465
N7225 X1.0445 Y1.1372
N7230 X1.0479 Y1.1333
N7235 X1.0519 Y1.1301
N7240 X1.0566 Y1.1276
N7245 X1.0616 Y1.1256
N7250 X1.0723 Y1.1223
N7255 X1.0939 Y1.1171
N7260 X1.1047 Y1.115
N7265 X1.1157 Y1.1134
N7270 X1.1267 Y1.1123
N7275 X1.1377 Y1.1117
N7280 X1.1599 Y1.1112
N7285 X1.1743 Y1.1115
N7290 X1.1885 Y1.1122
N7295 X1.2024 Y1.1137
N7300 X1.2159 Y1.1165
N7305 X1.2225 Y1.1184
N7310 X1.229 Y1.1208
N7315 X1.2415 Y1.1268
N7320 X1.2536 Y1.1339
N7325 X1.2656 Y1.1416
N7330 X1.2743 Y1.1541
N7335 X1.2824 Y1.1669
N7340 X1.286 Y1.1734
N7345 X1.2893 Y1.18
N7350 X1.292 Y1.1868
N7355 X1.2943 Y1.1938
N7360 X1.296 Y1.2009
N7365 X1.2972 Y1.2081
N7370 X1.2987 Y1.223
N7375 X1.299 Y1.2382
N7380 X1.2989 Y1.2536
N7385 X1.2979 Y1.2689
N7390 X1.2964 Y1.2841
N7395 X1.2942 Y1.299
N7400 X1.2909 Y1.3135
N7405 X1.2886 Y1.3205
N7410 X1.2859 Y1.3274
N7415 X1.2792 Y1.3408
N7420 X1.2714 Y1.3537
N7425 X1.2631 Y1.3664
N7430 X1.2527 Y1.3737
N7435 X1.2422 Y1.3806
N7440 X1.2314 Y1.3865
N7445 X1.2258 Y1.3889
N7450 X1.22 Y1.391
N7455 X1.2081 Y1.394
N7460 X1.1959 Y1.3958
N7465 X1.1833 Y1.3968
N7470 X1.1706 Y1.3974
N7475 X1.1427 Y1.3962
N7480 X1.1149 Y1.3941
N7485 X1.1025 Y1.3928
N7490 X1.0899 Y1.3923
N7495 X1.0836 Y1.3926
N7500 X1.0776 Y1.3932
N7505 X1.072 Y1.3944
N7510 X1.0673 Y1.3966
N7515 X1.0653 Y1.3981
N7520 X1.0635 Y1.4
N7525 X1.0608 Y1.4046
N7530 X1.0587 Y1.41
N7535 X1.0569 Y1.4159
N7540 X1.059 Y1.4219
N7545 X1.0615 Y1.4274
N7550 X1.0647 Y1.4321
N7555 X1.0666 Y1.4339
N7560 X1.0689 Y1.4354
N7565 X1.074 Y1.4374
N7570 X1.0799 Y1.4385
N7575 X1.0863 Y1.4389
N7580 X1.0929 Y1.4391
N7585 X1.1077 Y1.4379
N7590 X1.1224 Y1.4364
N7595 X1.1469 Y1.4341
N7600 X1.1714 Y1.4331
N7605 X1.186 Y1.4336
N7610 X1.1932 Y1.4342
N7615 X1.2004 Y1.4352
N7620 X1.2074 Y1.4367
N7625 X1.2143 Y1.4388
N7630 X1.228 Y1.4439
N7635 X1.2377 Y1.4507
N7640 X1.2422 Y1.4545
N7645 X1.2463 Y1.4586
N7650 X1.2497 Y1.4633
N7655 X1.2528 Y1.4683
N7660 X1.2581 Y1.479
N7665 X1.2627 Y1.4958
N7670 X1.2646 Y1.5042
N7675 X1.266 Y1.5128
N7680 X1.2674 Y1.53
N7685 X1.2677 Y1.5475
N7690 X1.2668 Y1.5698
N7695 X1.2655 Y1.5809
N7700 X1.2637 Y1.592
N7705 X1.259 Y1.6103
N7710 X1.2558 Y1.6192
N7715 X1.2522 Y1.628
N7720 X1.2487 Y1.6349
N7725 X1.2447 Y1.6415
N7730 X1.2399 Y1.6476
N7735 X1.2346 Y1.6534
N7740 X1.226 Y1.6596
N7745 X1.2173 Y1.6655
N7750 X1.2083 Y1.6706
N7755 X1.1988 Y1.6745
N7760 X1.1889 Y1.6771
N7765 X1.1786 Y1.6787
N7770 X1.1574 Y1.6801
N7775 X1.1427 Y1.6797
N7780 X1.1281 Y1.6785
N7785 X1.1136 Y1.6762
N7790 X1.0992 Y1.6732
N7795 X1.0884 Y1.6702
N7800 X1.0778 Y1.6666
N7805 X1.0677 Y1.6619
N7810 X1.0578 Y1.6564
N7815 X1.0527 Y1.6529
N7820 X1.0483 Y1.6489
N7825 X1.0466 Y1.6465
N7830 X1.0452 Y1.6439
N7835 X1.0432 Y1.6382
N7840 X1.0439 Y1.6347
N7845 X1.0458 Y1.6319
N7850 X1.052 Y1.6271
N7855 X1.0587 Y1.623
N7860 X1.0679 Y1.6179
N7865 X1.0765 Y1.6121
N7870 X1.0804 Y1.6087
N7875 X1.084 Y1.6049
N7880 X1.0908 Y1.5969
N7885 X1.0954 Y1.5879
N7890 X1.0973 Y1.5833
N7895 X1.0989 Y1.5785
N7900 X1.1005 Y1.5687
N7905 X1.1012 Y1.5586
N7910 X1.0996 Y1.544
N7915 X1.0982 Y1.5369
N7920 X1.096 Y1.5302
N7925 X1.0929 Y1.5239
N7930 X1.089 Y1.5178
N7935 X1.0799 Y1.5063
N7940 X1.0682 Y1.4975
N7945 X1.0621 Y1.4937
N7950 X1.0557 Y1.4906
N7955 X1.0489 Y1.4885
N7960 X1.0419 Y1.4871
N7965 X1.0272 Y1.4856
N7970 X1.0117 Y1.4873
N7975 X1.0043 Y1.4889
N7980 X0.9971 Y1.4912
N7985 X0.9904 Y1.4945
N7990 X0.984 Y1.4987
N7995 X0.9718 Y1.5084
N8000 X0.9623 Y1.5208
N8005 X0.9582 Y1.5273
N8010 X0.955 Y1.534
N8015 X0.9527 Y1.5412
N8020 X0.9512 Y1.5487
N8025 X0.9495 Y1.5642
N8030 X0.9519 Y1.5859
N8035 X0.954 Y1.5963
N8040 X0.9572 Y1.6064
N8045 X0.9616 Y1.616
N8050 X0.967 Y1.6252
N8055 X0.9796 Y1.6429
N8060 X0.998 Y1.6599
N8065 X1.0076 Y1.6678
N8070 X1.0178 Y1.6748
N8075 X1.0286 Y1.6809
N8080 X1.0398 Y1.6862
N8085 X1.0631 Y1.6957
N8090 X1.0925 Y1.7037
N8095 X1.1073 Y1.7072
N8100 X1.1222 Y1.7099
N8105 X1.1373 Y1.7117
N8110 X1.1525 Y1.7129
N8115 X1.183 Y1.7141
N8120 X1.2139 Y1.7129
N8125 X1.2293 Y1.7117
N8130 X1.2445 Y1.7098
N8135 X1.2596 Y1.707
N8140 X1.2746 Y1.7034
N8145 X1.3043 Y1.6948
N8150 X1.3274 Y1.6846
N8155 X1.3385 Y1.6789
N8160 X1.349 Y1.6725
N8165 X1.359 Y1.6651
N8170 X1.3683 Y1.6568
N8175 X1.3861 Y1.639
N8180 X1.3987 Y1.6194
N8185 X1.4041 Y1.6094
N8190 X1.4084 Y1.5989
N8195 X1.4114 Y1.588
N8200 X1.4134 Y1.5767
N8205 X1.4156 Y1.5536
N8210 X1.4146 Y1.5387
N8215 X1.4138 Y1.5314
N8220 X1.4124 Y1.5242
N8225 X1.4105 Y1.5171
N8230 X1.4081 Y1.5101
N8235 X1.4025 Y1.4963
N8240 X1.3947 Y1.4833
N8245 X1.3905 Y1.477
N8250 X1.3858 Y1.4711
N8255 X1.3807 Y1.4656
N8260 X1.3753 Y1.4605
N8265 X1.3637 Y1.4506
N8270 X1.3449 Y1.4393
N8275 X1.3353 Y1.4342
N8280 X1.3254 Y1.4297
N8285 X1.3153 Y1.4258
N8290 X1.3049 Y1.4225
N8295 X1.2837 Y1.4167
N8300 X1.2574 Y1.412
N8305 X1.2311 Y1.408
N8310 X1.24 Y1.4176
N8315 X1.2489 Y1.4233
N8320 X1.2721 Y1.4196
N8325 X1.295 Y1.415
N8330 X1.3063 Y1.412
N8335 X1.3175 Y1.4086
N8340 X1.3397 Y1.401
N8345 X1.3566 Y1.3937
N8350 X1.373 Y1.3855
N8355 X1.3808 Y1.3809
N8360 X1.3884 Y1.3758
N8365 X1.4034 Y1.3651
N8370 X1.415 Y1.3544
N8375 X1.4205 Y1.3488
N8380 X1.4256 Y1.3429
N8385 X1.4303 Y1.3366
N8390 X1.4345 Y1.33
N8395 X1.4424 Y1.3163
N8400 X1.448 Y1.3022
N8405 X1.4505 Y1.295
N8410 X1.4524 Y1.2877
N8415 X1.4538 Y1.2803
N8420 X1.4547 Y1.2728
N8425 X1.4557 Y1.2576
N8430 X1.4544 Y1.2445
N8435 X1.4527 Y1.2316
N8440 X1.4502 Y1.219
N8445 X1.4485 Y1.2128
N8450 X1.4464 Y1.2068
N8455 X1.441 Y1.1953
N8460 X1.4344 Y1.1843
N8465 X1.4269 Y1.1736
N8470 X1.419 Y1.1631
N8475 X1.3963 Y1.1427
N8480 X1.3845 Y1.1333
N8485 X1.372 Y1.1249
N8490 X1.3588 Y1.1177
N8495 X1.3451 Y1.1114
N8500 X1.3167 Y1.1001
N8505 X1.2804 Y1.0905
N8510 X1.2621 Y1.0864
N8515 X1.2437 Y1.0832
N8520 X1.2251 Y1.081
N8525 X1.2065 Y1.0796
N8530 X1.1689 Y1.0782
N8535 X1.1455 Y1.0789
N8540 X1.1222 Y1.0806
N8545 X1.099 Y1.0837
N8550 X1.076 Y1.0877
N8555 X1.0577 Y1.0919
N8560 X1.0397 Y1.097
N8565 X1.0309 Y1.1001
N8570 X1.0222 Y1.1036
N8575 X1.0051 Y1.1113
N8580 X0.9904 Y1.1213
N8585 X0.9833 Y1.1267
N8590 X0.9766 Y1.1324
N8595 X0.9705 Y1.1387
N8600 X0.9647 Y1.1454
N8605 X0.9539 Y1.1595
N8610 X0.9464 Y1.1733
N8615 X0.9431 Y1.1803
N8620 X0.9404 Y1.1876
N8625 X0.9384 Y1.195
N8630 X0.9371 Y1.2026
N8635 X0.9354 Y1.2183
N8640 X0.9371 Y1.2345
N8645 X0.9386 Y1.2424
N8650 Z0.1606
N8655 G0 Z0.2
N8660 X1.4993 Y1.4705
N8665 Z0.1606
N8670 G1 Z-0.0394 F13.123
N8675 X1.4976 Y1.4798 F39.37
N8680 X1.4965 Y1.4893
N8685 X1.4952 Y1.5085
N8690 X1.4976 Y1.5364
N8695 X1.4997 Y1.55
N8700 X1.503 Y1.5633
N8705 X1.5076 Y1.5762
N8710 X1.5134 Y1.5888
N8715 X1.5268 Y1.6133
N8720 X1.5453 Y1.6358
N8725 X1.5551 Y1.6463
N8730 X1.5657 Y1.656
N8735 X1.5772 Y1.6646
N8740 X1.5893 Y1.6724
N8745 X1.6147 Y1.6866
N8750 X1.6446 Y1.6981
N8755 X1.6597 Y1.7029
N8760 X1.6751 Y1.7068
N8765 X1.6907 Y1.7095
N8770 X1.7065 Y1.7113
N8775 X1.7384 Y1.7132
N8780 X1.7572 Y1.7119
N8785 X1.7759 Y1.7102
N8790 X1.7943 Y1.7075
N8795 X1.8034 Y1.7057
N8800 X1.8123 Y1.7034
N8805 X1.8211 Y1.7007
N8810 X1.8298 Y1.6975
N8815 X1.8469 Y1.6901
N8820 X1.8637 Y1.6818
N8825 X1.8803 Y1.6729
N8830 X1.8954 Y1.6615
N8835 X1.9102 Y1.6497
N8840 X1.9242 Y1.6373
N8845 X1.9308 Y1.6307
N8850 X1.937 Y1.6239
N8855 X1.9429 Y1.6167
N8860 X1.9485 Y1.6093
N8865 X1.9589 Y1.5937
N8870 X1.9686 Y1.5775
N8875 X1.9779 Y1.561
N8880 X1.9856 Y1.5415
N8885 X1.9929 Y1.5219
N8890 X1.9993 Y1.5021
N8895 X2.0043 Y1.4821
N8900 X2.0078 Y1.4616
N8905 X2.01 Y1.4409
N8910 X2.0114 Y1.4201
N8915 X2.0123 Y1.3991
N8920 X2.0096 Y1.3659
N8925 X2.0079 Y1.3494
N8930 X2.0058 Y1.3331
N8935 X2.0031 Y1.317
N8940 X1.9998 Y1.3012
N8945 X1.9956 Y1.2857
N8950 X1.9904 Y1.2706
N8955 X1.9841 Y1.256
N8960 X1.9768 Y1.2417
N8965 X1.9687 Y1.2278
N8970 X1.9598 Y1.2142
N8975 X1.9503 Y1.2008
N8980 X1.9404 Y1.1875
N8985 X1.9198 Y1.1614
N8990 X1.8991 Y1.1426
N8995 X1.8884 Y1.1338
N9000 X1.8772 Y1.1257
N9005 X1.8655 Y1.1184
N9010 X1.8533 Y1.1118
N9015 X1.8281 Y1.0997
N9020 X1.8006 Y1.0903
N9025 X1.7867 Y1.0862
N9030 X1.7726 Y1.0829
N9035 X1.7584 Y1.0806
N9040 X1.744 Y1.0791
N9045 X1.7149 Y1.0773
N9050 X1.6949 Y1.0786
N9055 X1.6751 Y1.0805
N9060 X1.6653 Y1.0819
N9065 X1.6557 Y1.0837
N9070 X1.6463 Y1.086
N9075 X1.6371 Y1.0889
N9080 X1.6281 Y1.0924
N9085 X1.6194 Y1.0965
N9090 X1.6109 Y1.1012
N9095 X1.6025 Y1.1064
N9100 X1.5862 Y1.1176
N9105 X1.5702 Y1.1296
N9110 X1.562 Y1.1388
N9115 X1.5543 Y1.1481
N9120 X1.5473 Y1.1578
N9125 X1.5416 Y1.1681
N9130 X1.5393 Y1.1735
N9135 X1.5374 Y1.179
N9140 X1.5345 Y1.1905
N9145 X1.5325 Y1.2025
N9150 X1.5309 Y1.2146
N9155 X1.5324 Y1.2306
N9160 X1.5338 Y1.2384
N9165 X1.5361 Y1.2459
N9170 X1.5393 Y1.253
N9175 X1.5433 Y1.2598
N9180 X1.5528 Y1.2728
N9185 X1.5647 Y1.2827
N9190 X1.571 Y1.2869
N9195 X1.5776 Y1.2903
N9200 X1.5847 Y1.2927
N9205 X1.5921 Y1.2942
N9210 X1.6074 Y1.296
N9215 X1.623 Y1.2945
N9220 X1.6305 Y1.2931
N9225 X1.6378 Y1.291
N9230 X1.6446 Y1.2879
N9235 X1.6512 Y1.2841
N9240 X1.6639 Y1.275
N9245 X1.6736 Y1.2632
N9250 X1.6778 Y1.257
N9255 X1.6811 Y1.2505
N9260 X1.6834 Y1.2435
N9265 X1.6849 Y1.2362
N9270 X1.6866 Y1.221
N9275 X1.6858 Y1.2107
N9280 X1.6851 Y1.2057
N9285 X1.684 Y1.2008
N9290 X1.6824 Y1.196
N9295 X1.6804 Y1.1914
N9300 X1.6755 Y1.1823
N9305 X1.6673 Y1.1734
N9310 X1.6629 Y1.1692
N9315 X1.6582 Y1.1655
N9320 X1.648 Y1.1592
N9325 X1.6371 Y1.1537
N9330 X1.633 Y1.1514
N9335 X1.6294 Y1.1487
N9340 X1.6266 Y1.1452
N9345 X1.6247 Y1.141
N9350 X1.629 Y1.1337
N9355 X1.6316 Y1.1306
N9360 X1.6347 Y1.1279
N9365 X1.6382 Y1.1258
N9370 X1.6421 Y1.1239
N9375 X1.6502 Y1.1208
N9380 X1.6652 Y1.1161
N9385 X1.6728 Y1.1142
N9390 X1.6804 Y1.1126
N9395 X1.6959 Y1.111
N9400 X1.7116 Y1.1104
N9405 X1.7271 Y1.1118
N9410 X1.7422 Y1.1138
N9415 X1.7496 Y1.1152
N9420 X1.7568 Y1.117
N9425 X1.7638 Y1.1193
N9430 X1.7705 Y1.1221
N9435 X1.7769 Y1.1255
N9440 X1.7831 Y1.1294
N9445 X1.789 Y1.1339
N9450 X1.7947 Y1.1387
N9455 X1.8057 Y1.1493
N9460 X1.8164 Y1.1605
N9465 X1.8252 Y1.1781
N9470 X1.8335 Y1.1958
N9475 X1.8405 Y1.2139
N9480 X1.8433 Y1.2231
N9485 X1.8457 Y1.2324
N9490 X1.8475 Y1.2419
N9495 X1.849 Y1.2515
N9500 X1.8509 Y1.2709
N9505 X1.8518 Y1.2905
N9510 X1.8523 Y1.3103
N9515 Y1.3975
N9520 X1.8643
N9525 X1.8512 Y1.3799
N9530 X1.8443 Y1.3716
N9535 X1.8367 Y1.3638
N9540 X1.8285 Y1.3567
N9545 X1.8198 Y1.3503
N9550 X1.8014 Y1.3383
N9555 X1.7794 Y1.3294
N9560 X1.7683 Y1.3256
N9565 X1.7569 Y1.3227
N9570 X1.7454 Y1.3207
N9575 X1.7337 Y1.3195
N9580 X1.71 Y1.3183
N9585 X1.6888 Y1.3193
N9590 X1.6782 Y1.3203
N9595 X1.6678 Y1.3218
N9600 X1.6575 Y1.3239
N9605 X1.6473 Y1.3266
N9610 X1.627 Y1.3328
N9615 X1.6084 Y1.3408
N9620 X1.5994 Y1.3451
N9625 X1.5906 Y1.35
N9630 X1.5822 Y1.3553
N9635 X1.574 Y1.3612
N9640 X1.5581 Y1.3736
N9645 X1.5444 Y1.3872
N9650 X1.5379 Y1.3943
N9655 X1.5319 Y1.4017
N9660 X1.5263 Y1.4095
N9665 X1.5212 Y1.4176
N9670 X1.5118 Y1.4344
N9675 X1.5047 Y1.4523
N9680 X1.5017 Y1.4613
N9685 X1.4993 Y1.4705
N9690 Z0.1606
N9695 G0 Z0.2
N9700 X1.7995 Y1.3739
N9705 Z0.1606
N9710 G1 Z-0.0394 F13.123
N9715 X1.8082 Y1.3805 F39.37
N9720 X1.8167 Y1.3875
N9725 X1.8258 Y1.3984
N9730 X1.8299 Y1.4041
N9735 X1.8336 Y1.41
N9740 X1.8367 Y1.4163
N9745 X1.8394 Y1.4228
N9750 X1.844 Y1.4362
N9755 X1.8483 Y1.4561
N9760 X1.85 Y1.4662
N9765 X1.8513 Y1.4762
N9770 X1.8527 Y1.4965
N9775 X1.8531 Y1.5169
N9780 X1.8526 Y1.5407
N9785 X1.852 Y1.5526
N9790 X1.8509 Y1.5644
N9795 X1.8492 Y1.5762
N9800 X1.847 Y1.5879
N9805 X1.8416 Y1.6111
N9810 X1.8358 Y1.6262
N9815 X1.8325 Y1.6335
N9820 X1.8286 Y1.6403
N9825 X1.824 Y1.6468
N9830 X1.8188 Y1.6528
N9835 X1.8073 Y1.6641
N9840 X1.7937 Y1.6716
N9845 X1.7868 Y1.6748
N9850 X1.7796 Y1.6773
N9855 X1.7722 Y1.6789
N9860 X1.7646 Y1.68
N9865 X1.7491 Y1.681
N9870 X1.7377 Y1.6802
N9875 X1.7264 Y1.6789
N9880 X1.7156 Y1.6766
N9885 X1.7105 Y1.675
N9890 X1.7055 Y1.673
N9895 X1.7008 Y1.6706
N9900 X1.6964 Y1.6676
N9905 X1.688 Y1.6607
N9910 X1.6801 Y1.6526
N9915 X1.6726 Y1.644
N9920 X1.6682 Y1.635
N9925 X1.6643 Y1.6258
N9930 X1.6613 Y1.6163
N9935 X1.6589 Y1.6066
N9940 X1.6568 Y1.5945
N9945 X1.6555 Y1.5823
N9950 X1.6542 Y1.5621
N9955 X1.6534 Y1.5419
N9960 X1.6526 Y1.4934
N9965 X1.6528 Y1.4767
N9970 X1.6536 Y1.4599
N9975 X1.6552 Y1.4433
N9980 X1.6576 Y1.4267
N9985 X1.6619 Y1.408
N9990 X1.6678 Y1.3897
N9995 X1.675 Y1.3822
N10000 X1.6825 Y1.3751
N10005 X1.6903 Y1.3688
N10010 X1.6945 Y1.3661
N10015 X1.6988 Y1.3638
N10020 X1.708 Y1.3604
N10025 X1.7179 Y1.3581
N10030 X1.7281 Y1.3567
N10035 X1.7385 Y1.3557
N10040 X1.7495 Y1.3566
N10045 X1.7604 Y1.358
N10050 X1.7709 Y1.3601
N10055 X1.781 Y1.3634
N10060 X1.7905 Y1.368
N10065 X1.7995 Y1.3739
N10070 Z0.1606
N10075 G0 Z0.2
N10080 X2.1121 Y1.3513
N10085 Z0.1606
N10090 G1 Z-0.0394 F13.123
N10095 X2.4371 Y1.7132 F39.37
N10100 X2.4834
N10105 Y1.3196
N10110 X2.6126
N10115 Y1.2348
N10120 X2.4834
N10125 Y1.2111
N10130 X2.4848 Y1.1927
N10135 X2.4862 Y1.1839
N10140 X2.4886 Y1.1753
N10145 X2.4922 Y1.1673
N10150 X2.4968 Y1.1597
N10155 X2.5079 Y1.1451
N10160 X2.5236 Y1.1346
N10165 X2.5318 Y1.1302
N10170 X2.5403 Y1.1269
N10175 X2.5492 Y1.1247
N10180 X2.5585 Y1.1233
N10185 X2.5774 Y1.1221
N10190 X2.6066
N10195 Y1.0891
N10200 X2.216
N10205 Y1.1221
N10210 X2.2431
N10215 X2.2595 Y1.1226
N10220 X2.2677 Y1.1232
N10225 X2.2758 Y1.1242
N10230 X2.2838 Y1.1257
N10235 X2.2917 Y1.1277
N10240 X2.3073 Y1.1326
N10245 X2.3183 Y1.1385
N10250 X2.3234 Y1.1418
N10255 X2.3282 Y1.1456
N10260 X2.3324 Y1.1499
N10265 X2.3363 Y1.1547
N10270 X2.3432 Y1.1649
N10275 X2.3485 Y1.179
N10280 X2.3507 Y1.1862
N10285 X2.3524 Y1.1935
N10290 X2.3535 Y1.2008
N10295 X2.3541 Y1.2083
N10300 X2.3546 Y1.2234
N10305 Y1.2348
N10310 X2.0787
N10315 Y1.3142
N10320 X2.1121 Y1.3513
N10325 Z0.1606
N10330 G0 Z0.2
N10335 X2.3546 Y1.5866
N10340 Z0.1606
N10345 G1 Z-0.0394 F13.123
N10350 X2.1166 Y1.3187 F39.37
N10355 X2.3546
N10360 Y1.5866
N10365 Z0.1606
N10370 G0 Z0.2
N10375 X2.6792 Y1.5604
N10380 Z0.1606
N10385 G1 Z-0.0394 F13.123
N10390 X2.6811 Y1.5729 F39.37
N10395 X2.6841 Y1.585
N10400 X2.6884 Y1.5966
N10405 X2.6939 Y1.608
N10410 X2.7066 Y1.6301
N10415 X2.7245 Y1.6498
N10420 X2.7341 Y1.6589
N10425 X2.7443 Y1.6672
N10430 X2.7553 Y1.6743
N10435 X2.7669 Y1.6807
N10440 X2.7912 Y1.6919
N10445 X2.8224 Y1.7014
N10450 X2.8382 Y1.7053
N10455 X2.8541 Y1.7084
N10460 X2.8702 Y1.7105
N10465 X2.8864 Y1.7119
N10470 X2.919 Y1.7132
N10475 X2.9437 Y1.7121
N10480 X2.9681 Y1.7103
N10485 X2.9801 Y1.7089
N10490 X2.9919 Y1.707
N10495 X3.0036 Y1.7045
N10500 X3.0149 Y1.7013
N10505 X3.0261 Y1.6974
N10510 X3.0369 Y1.6926
N10515 X3.0475 Y1.6872
N10520 X3.0579 Y1.6812
N10525 X3.0782 Y1.6679
N10530 X3.0981 Y1.6536
N10535 X3.1067 Y1.6443
N10540 X3.1144 Y1.6344
N10545 X3.1208 Y1.6236
N10550 X3.1263 Y1.6122
N10555 X3.1308 Y1.6001
N10560 X3.1343 Y1.5877
N10565 X3.1362 Y1.5751
N10570 X3.1371 Y1.5622
N10575 X3.1362 Y1.548
N10580 X3.1353 Y1.541
N10585 X3.134 Y1.5341
N10590 X3.1322 Y1.5273
N10595 X3.1299 Y1.5207
N10600 X3.1244 Y1.5075
N10605 X3.1162 Y1.4946
N10610 X3.1118 Y1.4884
N10615 X3.1069 Y1.4825
N10620 X3.1017 Y1.477
N10625 X3.0961 Y1.4719
N10630 X3.0843 Y1.462
N10635 X3.0689 Y1.452
N10640 X3.061 Y1.4473
N10645 X3.0529 Y1.4431
N10650 X3.0445 Y1.4395
N10655 X3.0359 Y1.4363
N10660 X3.0184 Y1.4305
N10665 X3.0467 Y1.421
N10670 X3.0605 Y1.4156
N10675 X3.074 Y1.4095
N10680 X3.087 Y1.4025
N10685 X3.0996 Y1.3947
N10690 X3.124 Y1.3776
N10695 X3.1364 Y1.3655
N10700 X3.1481 Y1.3531
N10705 X3.1535 Y1.3466
N10710 X3.1586 Y1.34
N10715 X3.1631 Y1.3331
N10720 X3.1671 Y1.326
N10725 X3.1704 Y1.3186
N10730 X3.1732 Y1.3108
N10735 X3.1755 Y1.3029
N10740 X3.1774 Y1.2947
N10745 X3.1802 Y1.2778
N10750 X3.1823 Y1.2607
N10755 X3.1813 Y1.2455
N10760 X3.1805 Y1.2379
N10765 X3.1792 Y1.2305
N10770 X3.1774 Y1.2231
N10775 X3.1752 Y1.2158
N10780 X3.1701 Y1.2014
N10785 X3.162 Y1.1864
N10790 X3.1575 Y1.1792
N10795 X3.1527 Y1.1723
N10800 X3.1472 Y1.1659
N10805 X3.1414 Y1.1597
N10810 X3.129 Y1.1479
N10815 X3.104 Y1.1307
N10820 X3.0914 Y1.1224
N10825 X3.0786 Y1.1146
N10830 X3.0656 Y1.1073
N10835 X3.0524 Y1.1008
N10840 X3.0388 Y1.0952
N10845 X3.0249 Y1.0906
N10850 X3.0107 Y1.0869
N10855 X2.9963 Y1.084
N10860 X2.9815 Y1.0819
N10865 X2.9666 Y1.0802
N10870 X2.9363 Y1.0783
N10875 X2.9058 Y1.0773
N10880 X2.8765 Y1.0782
N10885 X2.8619 Y1.079
N10890 X2.8474 Y1.0803
N10895 X2.8329 Y1.0821
N10900 X2.8185 Y1.0844
N10905 X2.7898 Y1.0899
N10910 X2.7666 Y1.0962
N10915 X2.7552 Y1.0997
N10920 X2.744 Y1.1039
N10925 X2.7331 Y1.1087
N10930 X2.7224 Y1.1141
N10935 X2.7016 Y1.126
N10940 X2.6894 Y1.1361
N10945 X2.6779 Y1.1465
N10950 X2.6726 Y1.1519
N10955 X2.6677 Y1.1576
N10960 X2.6632 Y1.1635
N10965 X2.6592 Y1.1697
N10970 X2.6559 Y1.1762
N10975 X2.6531 Y1.1831
N10980 X2.6508 Y1.1902
N10985 X2.6489 Y1.1975
N10990 X2.6461 Y1.2127
N10995 X2.6439 Y1.2283
N11000 X2.6451 Y1.2451
N11005 X2.6462 Y1.2534
N11010 X2.648 Y1.2616
N11015 X2.6505 Y1.2695
N11020 X2.6537 Y1.2772
N11025 X2.6612 Y1.2923
N11030 X2.6728 Y1.3072
N11035 X2.679 Y1.3142
N11040 X2.6857 Y1.3208
N11045 X2.6928 Y1.3268
N11050 X2.7004 Y1.3324
N11055 X2.7162 Y1.3428
N11060 X2.7381 Y1.3541
N11065 X2.7493 Y1.3594
N11070 X2.7606 Y1.3641
N11075 X2.7722 Y1.3682
N11080 X2.784 Y1.3719
N11085 X2.8078 Y1.3784
N11090 X2.7802 Y1.3889
N11095 X2.7669 Y1.3949
N11100 X2.7541 Y1.4018
N11105 X2.7421 Y1.4098
N11110 X2.7307 Y1.4189
N11115 X2.7198 Y1.4287
N11120 X2.7091 Y1.4389
N11125 X2.7019 Y1.4498
N11130 X2.6951 Y1.4609
N11135 X2.6892 Y1.4722
N11140 X2.6845 Y1.484
N11145 X2.6813 Y1.4963
N11150 X2.6792 Y1.509
N11155 X2.6779 Y1.5219
N11160 X2.677 Y1.535
N11165 X2.6792 Y1.5604
N11170 Z0.1606
N11175 G0 Z0.2
N11180 X2.8246 Y1.3534
N11185 Z0.1606
N11190 G1 Z-0.0394 F13.123
N11195 X2.8134 Y1.3451 F39.37
N11200 X2.8029 Y1.3361
N11205 X2.7928 Y1.3266
N11210 X2.7847 Y1.3172
N11215 X2.7775 Y1.3072
N11220 X2.7716 Y1.2964
N11225 X2.7667 Y1.2851
N11230 X2.7631 Y1.272
N11235 X2.7604 Y1.2587
N11240 X2.7592 Y1.2453
N11245 X2.7587 Y1.2317
N11250 X2.7662 Y1.2023
N11255 X2.7705 Y1.1882
N11260 X2.7754 Y1.1748
N11265 X2.7811 Y1.1624
N11270 X2.7843 Y1.1566
N11275 X2.7878 Y1.1512
N11280 X2.7917 Y1.1461
N11285 X2.7958 Y1.1414
N11290 X2.8004 Y1.1372
N11295 X2.8053 Y1.1333
N11300 X2.8105 Y1.1298
N11305 X2.8161 Y1.1268
N11310 X2.8219 Y1.124
N11315 X2.828 Y1.1216
N11320 X2.8411 Y1.1176
N11325 X2.8549 Y1.1146
N11330 X2.8695 Y1.1124
N11335 X2.8845 Y1.1108
N11340 X2.9155 Y1.1086
N11345 X2.937 Y1.1095
N11350 X2.9476 Y1.1104
N11355 X2.9581 Y1.1118
N11360 X2.9686 Y1.1138
N11365 X2.9789 Y1.1164
N11370 X2.9995 Y1.1226
N11375 X3.0153 Y1.1296
N11380 X3.0229 Y1.1335
N11385 X3.0303 Y1.1379
N11390 X3.0372 Y1.1429
N11395 X3.0437 Y1.1484
N11400 X3.0562 Y1.1603
N11405 X3.0644 Y1.1721
N11410 X3.068 Y1.1783
N11415 X3.071 Y1.1846
N11420 X3.0731 Y1.1913
N11425 X3.0745 Y1.1982
N11430 X3.0762 Y1.2125
N11435 X3.0746 Y1.227
N11440 X3.0732 Y1.2339
N11445 X3.071 Y1.2405
N11450 X3.0678 Y1.2467
N11455 X3.0638 Y1.2525
N11460 X3.0544 Y1.2636
N11465 X3.0426 Y1.273
N11470 X3.0303 Y1.2816
N11475 X3.01 Y1.2916
N11480 X2.9896 Y1.3012
N11485 X2.9482 Y1.3191
N11490 X2.918 Y1.3309
N11495 X2.8939 Y1.3403
N11500 X2.8833 Y1.3443
N11505 X2.8725 Y1.3479
N11510 X2.8506 Y1.3553
N11515 X2.8361 Y1.3612
N11520 X2.8246 Y1.3534
N11525 Z0.1606
N11530 G0 Z0.2
N11535 X2.8838 Y1.4832
N11540 Z0.1606
N11545 G1 Z-0.0394 F13.123
N11550 X2.9043 Y1.4753 F39.37
N11555 X2.9352 Y1.4643
N11560 X2.9606 Y1.4563
N11565 X2.9859 Y1.4476
N11570 X2.9973 Y1.4578
N11575 X3.0027 Y1.4631
N11580 X3.0077 Y1.4688
N11585 X3.0122 Y1.4749
N11590 X3.0163 Y1.4813
N11595 X3.0238 Y1.4946
N11600 X3.0294 Y1.5105
N11605 X3.0317 Y1.5185
N11610 X3.0335 Y1.5266
N11615 X3.0347 Y1.5349
N11620 X3.0355 Y1.5432
N11625 X3.0362 Y1.5601
N11630 X3.0356 Y1.5726
N11635 X3.0345 Y1.585
N11640 X3.0327 Y1.597
N11645 X3.0296 Y1.6087
N11650 X3.0275 Y1.6142
N11655 X3.025 Y1.6197
N11660 X3.0189 Y1.6301
N11665 X3.0118 Y1.6402
N11670 X3.0042 Y1.6502
N11675 X2.9934 Y1.6574
N11680 X2.9824 Y1.6641
N11685 X2.9711 Y1.6699
N11690 X2.9653 Y1.6723
N11695 X2.9593 Y1.6742
N11700 X2.947 Y1.6771
N11705 X2.9343 Y1.6787
N11710 X2.9214 Y1.6796
N11715 X2.9083 Y1.6801
N11720 X2.8889 Y1.6794
N11725 X2.8793 Y1.6787
N11730 X2.8697 Y1.6775
N11735 X2.8602 Y1.6757
N11740 X2.8508 Y1.6735
N11745 X2.8322 Y1.6681
N11750 X2.8184 Y1.6621
N11755 X2.8118 Y1.6587
N11760 X2.8055 Y1.655
N11765 X2.7995 Y1.6506
N11770 X2.7939 Y1.6458
N11775 X2.7832 Y1.6354
N11780 X2.776 Y1.6242
N11785 X2.7729 Y1.6184
N11790 X2.7704 Y1.6124
N11795 X2.7687 Y1.6062
N11800 X2.7676 Y1.5997
N11805 X2.7664 Y1.5865
N11810 X2.7668 Y1.5785
N11815 X2.7679 Y1.5706
N11820 X2.7701 Y1.5629
N11825 X2.7729 Y1.5554
N11830 X2.7764 Y1.5487
N11835 X2.7804 Y1.5423
N11840 X2.7853 Y1.5365
N11845 X2.7906 Y1.5311
N11850 X2.8019 Y1.5222
N11855 X2.8139 Y1.5143
N11860 X2.8436 Y1.5003
N11865 X2.8736 Y1.4871
N11870 X2.8838 Y1.4832
N11875 Z0.1606
N11880 G0 Z0.2
N11885 X2.9044 Y0.423
N11890 Z0.1606
N11895 G1 Z-0.0394 F13.123
N11900 X2.9182 Y0.4217 F39.37
N11905 X2.9318 Y0.4197
N11910 X2.9452 Y0.4168
N11915 X2.9585 Y0.413
N11920 X2.9848 Y0.4043
N11925 X3.0069 Y0.3931
N11930 X3.0174 Y0.3869
N11935 X3.0274 Y0.38
N11940 X3.0367 Y0.3721
N11945 X3.0453 Y0.3635
N11950 X3.0617 Y0.3449
N11955 X3.0742 Y0.325
N11960 X3.0798 Y0.3148
N11965 X3.0846 Y0.3043
N11970 X3.0884 Y0.2934
N11975 X3.0914 Y0.2821
N11980 X3.0961 Y0.2591
N11985 X3.0988 Y0.2186
N11990 X3.1006 Y0.1781
N11995 X3.1011 Y0.1375
N12000 X3.101 Y0.0969
N12005 X3.1004 Y-0.0314
N12010 X3.1002 Y-0.0714
N12015 X3.0994 Y-0.1115
N12020 X3.0974 Y-0.1515
N12025 X3.0945 Y-0.1914
N12030 X3.0899 Y-0.2144
N12035 X3.0869 Y-0.2256
N12040 X3.0832 Y-0.2365
N12045 X3.0785 Y-0.247
N12050 X3.073 Y-0.2573
N12055 X3.0607 Y-0.2772
N12060 X3.0446 Y-0.2956
N12065 X3.036 Y-0.3042
N12070 X3.0268 Y-0.3121
N12075 X3.017 Y-0.3191
N12080 X3.0065 Y-0.3253
N12085 X2.9848 Y-0.3366
N12090 X2.9577 Y-0.3458
N12095 X2.944 Y-0.3496
N12100 X2.9302 Y-0.3526
N12105 X2.9162 Y-0.3546
N12110 X2.9021 Y-0.3558
N12115 X2.8735 Y-0.357
N12120 X2.8458 Y-0.3556
N12125 X2.832 Y-0.3543
N12130 X2.8184 Y-0.3523
N12135 X2.805 Y-0.3493
N12140 X2.7917 Y-0.3456
N12145 X2.7654 Y-0.3369
N12150 X2.7434 Y-0.3257
N12155 X2.7328 Y-0.3195
N12160 X2.7228 Y-0.3125
N12165 X2.7136 Y-0.3047
N12170 X2.7049 Y-0.296
N12175 X2.6885 Y-0.2775
N12180 X2.676 Y-0.2576
N12185 X2.6704 Y-0.2474
N12190 X2.6656 Y-0.2369
N12195 X2.6618 Y-0.2259
N12200 X2.6588 Y-0.2147
N12205 X2.6541 Y-0.1917
N12210 X2.6514 Y-0.1512
N12215 X2.6496 Y-0.1107
N12220 X2.6491 Y-0.0701
N12225 X2.6492 Y-0.0295
N12230 X2.6498 Y0.0988
N12235 X2.65 Y0.1389
N12240 X2.6508 Y0.1789
N12245 X2.6529 Y0.2189
N12250 X2.6558 Y0.2588
N12255 X2.6603 Y0.2818
N12260 X2.6633 Y0.293
N12265 X2.667 Y0.3039
N12270 X2.6717 Y0.3145
N12275 X2.6772 Y0.3247
N12280 X2.6895 Y0.3446
N12285 X2.7056 Y0.3631
N12290 X2.7142 Y0.3717
N12295 X2.7234 Y0.3795
N12300 X2.7332 Y0.3865
N12305 X2.7437 Y0.3928
N12310 X2.7655 Y0.4041
N12315 X2.7925 Y0.4132
N12320 X2.8062 Y0.417
N12325 X2.82 Y0.42
N12330 X2.834 Y0.422
N12335 X2.8482 Y0.4233
N12340 X2.8767 Y0.4245
N12345 X2.9044 Y0.423
N12350 Z0.1606
N12355 G0 Z0.2
N12360 X3.2864 Y-0.0305
N12365 Z0.1606
N12370 G1 Z-0.0394 F13.123
N12375 X3.2882 Y0.407 F39.37
N12380 X3.4263 Y0.4064
N12385 X3.4732 Y0.4062
N12390 X3.4966 Y0.4058
N12395 X3.52 Y0.4048
N12400 X3.5433 Y0.4032
N12405 X3.5666 Y0.4009
N12410 X3.6131 Y0.395
N12415 X3.625 Y0.391
N12420 X3.6367 Y0.3867
N12425 X3.6478 Y0.3816
N12430 X3.6582 Y0.3754
N12435 X3.6676 Y0.3679
N12440 X3.6763 Y0.3592
N12445 X3.6846 Y0.3499
N12450 X3.6926 Y0.3403
N12455 X3.7003 Y0.3237
N12460 X3.7075 Y0.3071
N12465 X3.7135 Y0.2901
N12470 X3.7159 Y0.2815
N12475 X3.7179 Y0.2728
N12480 X3.7206 Y0.2551
N12485 X3.722 Y0.237
N12490 X3.7226 Y0.2188
N12495 X3.7228 Y0.2005
N12500 X3.7225 Y0.1699
N12505 X3.7216 Y0.1548
N12510 X3.7197 Y0.1399
N12515 X3.7165 Y0.1253
N12520 X3.712 Y0.111
N12525 X3.7065 Y0.0969
N12530 X3.7006 Y0.0829
N12535 X3.6914 Y0.075
N12540 X3.682 Y0.0675
N12545 X3.6722 Y0.0611
N12550 X3.667 Y0.0584
N12555 X3.6617 Y0.0561
N12560 X3.6505 Y0.0526
N12565 X3.6389 Y0.0501
N12570 X3.6269 Y0.0484
N12575 X3.6147 Y0.0471
N12580 X3.6361 Y0.0412
N12585 X3.6465 Y0.0377
N12590 X3.6566 Y0.0335
N12595 X3.6661 Y0.0283
N12600 X3.6752 Y0.0222
N12605 X3.6924 Y0.0083
N12610 X3.7002 Y-0.0018
N12615 X3.7072 Y-0.0125
N12620 X3.7101 Y-0.0181
N12625 X3.7126 Y-0.024
N12630 X3.717 Y-0.036
N12635 X3.7197 Y-0.0637
N12640 X3.7213 Y-0.0914
N12645 X3.7216 Y-0.1192
N12650 X3.7214 Y-0.147
N12655 X3.7206 Y-0.3448
N12660 X3.5394 Y-0.344
N12665 X3.5405 Y-0.0948
N12670 X3.5407 Y-0.0757
N12675 X3.5405 Y-0.0663
N12680 X3.5398 Y-0.0569
N12685 X3.5386 Y-0.0476
N12690 X3.5366 Y-0.0384
N12695 X3.5313 Y-0.0202
N12700 X3.5203 Y-0.0125
N12705 X3.5145 Y-0.0095
N12710 X3.5083 Y-0.0074
N12715 X3.5019 Y-0.0062
N12720 X3.4952 Y-0.0057
N12725 X3.4815 Y-0.0056
N12730 X3.4801 Y-0.3438
N12735 X3.2851 Y-0.343
N12740 X3.2864 Y-0.0305
N12745 Z0.1606
N12750 G0 Z0.2
N12755 X3.4827 Y0.2779
N12760 Z0.1606
N12765 G1 Z-0.0394 F13.123
N12770 X3.482 Y0.1111 F39.37
N12775 X3.494 Y0.1113
N12780 X3.5058 Y0.1124
N12785 X3.5115 Y0.1137
N12790 X3.5171 Y0.1155
N12795 X3.5281 Y0.12
N12800 X3.5357 Y0.1334
N12805 X3.5386 Y0.1404
N12810 X3.5404 Y0.1476
N12815 X3.5414 Y0.1551
N12820 X3.5418 Y0.1628
N12825 X3.5416 Y0.1785
N12830 X3.5418 Y0.2197
N12835 X3.5416 Y0.2324
N12840 X3.5411 Y0.2386
N12845 X3.5401 Y0.2446
N12850 X3.5383 Y0.2504
N12855 X3.5357 Y0.2559
N12860 X3.5292 Y0.2666
N12865 X3.5184 Y0.2722
N12870 X3.5128 Y0.2745
N12875 X3.507 Y0.2761
N12880 X3.5011 Y0.2771
N12885 X3.495 Y0.2776
N12890 X3.4827 Y0.2779
N12895 Z0.1606
N12900 G0 Z0.2
N12905 X3.9119 Y0.2794
N12910 Z0.1606
N12915 G1 Z-0.0394 F13.123
N12920 X3.9124 Y0.4044 F39.37
N12925 X4.1074 Y0.4036
N12930 X4.1062 Y0.1123
N12935 X4.1943 Y0.4033
N12940 X4.3772 Y0.4025
N12945 X4.264 Y0.0643
N12950 X4.3848 Y-0.3475
N12955 X4.1833 Y-0.3467
N12960 X4.1056 Y-0.0249
N12965 X4.1043 Y-0.3464
N12970 X3.9093 Y-0.3456
N12975 X3.9119 Y0.2794
N12980 Z0.1606
N12985 G0 Z0.2
N12990 X2.9053 Y0.258
N12995 Z0.1606
N13000 G1 Z-0.0394 F13.123
N13005 X2.9041 Y0.2663 F39.37
N13010 X2.9009 Y0.2828
N13015 X2.8967 Y0.2893
N13020 X2.8943 Y0.292
N13025 X2.8916 Y0.2942
N13030 X2.8884 Y0.2956
N13035 X2.8848 Y0.2966
N13040 X2.8771 Y0.2975
N13045 X2.8702 Y0.2967
N13050 X2.8669 Y0.2959
N13055 X2.8638 Y0.2947
N13060 X2.861 Y0.293
N13065 X2.8585 Y0.2909
N13070 X2.8537 Y0.2858
N13075 X2.8489 Y0.2688
N13080 X2.8471 Y0.2602
N13085 X2.846 Y0.2515
N13090 X2.8451 Y0.2339
N13095 X2.8453 Y0.2161
N13100 X2.8438 Y-0.1341
N13105 X2.8436 Y-0.1544
N13110 X2.8441 Y-0.1746
N13115 X2.8447 Y-0.1847
N13120 X2.8458 Y-0.1947
N13125 X2.8488 Y-0.2147
N13130 X2.8531 Y-0.2216
N13135 X2.8555 Y-0.2244
N13140 X2.8584 Y-0.2267
N13145 X2.8618 Y-0.2282
N13150 X2.8655 Y-0.2292
N13155 X2.8736 Y-0.2301
N13160 X2.8822 Y-0.2289
N13165 X2.8861 Y-0.2278
N13170 X2.8896 Y-0.226
N13175 X2.8925 Y-0.2234
N13180 X2.895 Y-0.2202
N13185 X2.8991 Y-0.2126
N13190 X2.9023 Y-0.1918
N13195 X2.9036 Y-0.1814
N13200 X2.9044 Y-0.1709
N13205 X2.905 Y-0.1499
N13210 Y-0.1288
N13215 X2.9064 Y0.2159
N13220 X2.9066 Y0.2328
N13225 X2.906 Y0.2496
N13230 X2.9053 Y0.258
N13235 Z0.1606
N13240 G0 Z0.2
N13245 X2.487 Y0.2603
N13250 Z0.1606
N13255 G1 Z-0.0394 F13.123
N13260 X2.415 Y-0.3394 F39.37
N13265 X2.1715 Y-0.3384
N13270 X2.1546 Y-0.2404
N13275 X2.1466 Y-0.1913
N13280 X2.1391 Y-0.1422
N13285 X2.1323 Y-0.0929
N13290 X2.126 Y-0.0436
N13295 X2.1141 Y0.0552
N13300 X2.0868 Y-0.1415
N13305 X2.0581 Y-0.3379
N13310 X1.816 Y-0.3369
N13315 X1.7318 Y0.4134
N13320 X1.9213 Y0.4127
N13325 X1.9597 Y-0.1022
N13330 X1.9702 Y0.0268
N13335 X1.9761 Y0.0912
N13340 X1.9828 Y0.1556
N13345 X1.9903 Y0.2198
N13350 X1.9984 Y0.284
N13355 X2.0157 Y0.4123
N13360 X2.2182 Y0.4114
N13365 X2.229 Y0.2878
N13370 X2.2385 Y0.164
N13375 X2.2589 Y-0.1215
N13380 X2.2692 Y0.0121
N13385 X2.275 Y0.0788
N13390 X2.2816 Y0.1454
N13395 X2.2892 Y0.2119
N13400 X2.2975 Y0.2783
N13405 X2.3155 Y0.411
N13410 X2.5049 Y0.4102
N13415 X2.487 Y0.2603
N13420 Z0.1606
N13425 G0 Z0.2
N13430 X2.4976 Y-0.7469
N13435 Z0.1606
N13440 G1 Z-0.0394 F13.123
N13445 X2.5478 Y-0.7471 F39.37
N13450 X2.5447 Y-1.4971
N13455 X2.3738 Y-1.4964
N13460 X2.2737 Y-1.1551
N13465 X2.2723 Y-1.496
N13470 X2.1092 Y-1.4953
N13475 X2.1123 Y-0.7453
N13480 X2.2754 Y-0.746
N13485 X2.3833 Y-1.0842
N13490 X2.3847 Y-0.7465
N13495 X2.4976 Y-0.7469
N13500 Z0.1606
N13505 G0 Z0.2
N13510 X1.9142 Y-0.8822
N13515 Z0.1606
N13520 G1 Z-0.0394 F13.123
N13525 X1.9175 Y-0.8996 F39.37
N13530 X1.9199 Y-0.9172
N13535 X1.9214 Y-0.9348
N13540 X1.9222 Y-0.9526
N13545 X1.9226 Y-0.9882
N13550 X1.9225 Y-1.0206
N13555 X1.7275 Y-1.0198
N13560 X1.7277 Y-0.9517
N13565 X1.7279 Y-0.9315
N13570 X1.7275 Y-0.9112
N13575 X1.7267 Y-0.9012
N13580 X1.7256 Y-0.8911
N13585 X1.7225 Y-0.8711
N13590 X1.718 Y-0.8638
N13595 X1.7154 Y-0.8608
N13600 X1.7123 Y-0.8584
N13605 X1.7087 Y-0.8568
N13610 X1.7048 Y-0.8558
N13615 X1.6962 Y-0.8548
N13620 X1.6885 Y-0.8556
N13625 X1.6849 Y-0.8565
N13630 X1.6816 Y-0.8578
N13635 X1.6787 Y-0.8599
N13640 X1.6761 Y-0.8625
N13645 X1.6716 Y-0.8686
N13650 X1.6678 Y-0.8862
N13655 X1.6664 Y-0.895
N13660 X1.6654 Y-0.9039
N13665 X1.6647 Y-0.9219
N13670 X1.6648 Y-0.9399
N13675 X1.6633 Y-1.2999
N13680 X1.6632 Y-1.3167
N13685 X1.6639 Y-1.3334
N13690 X1.6647 Y-1.3417
N13695 X1.6661 Y-1.3499
N13700 X1.6695 Y-1.3664
N13705 X1.6741 Y-1.3734
N13710 X1.6767 Y-1.3763
N13715 X1.6797 Y-1.3787
N13720 X1.6832 Y-1.3803
N13725 X1.687 Y-1.3813
N13730 X1.6954 Y-1.3824
N13735 X1.7047 Y-1.3812
N13740 X1.709 Y-1.3801
N13745 X1.7129 Y-1.3782
N13750 X1.7163 Y-1.3756
N13755 X1.7192 Y-1.3723
N13760 X1.7244 Y-1.3645
N13765 X1.7285 Y-1.3472
N13770 X1.7302 Y-1.3385
N13775 X1.7313 Y-1.3297
N13780 X1.7323 Y-1.312
N13785 Y-1.2941
N13790 X1.7327 Y-1.2052
N13795 X1.6933 Y-1.205
N13800 X1.6938 Y-1.091
N13805 X1.9222 Y-1.092
N13810 X1.9205 Y-1.4946
N13815 X1.798 Y-1.494
N13820 X1.7801 Y-1.4402
N13825 X1.7699 Y-1.4555
N13830 X1.7644 Y-1.4628
N13835 X1.7584 Y-1.4696
N13840 X1.7518 Y-1.4758
N13845 X1.7447 Y-1.4815
N13850 X1.7296 Y-1.4921
N13855 X1.7125 Y-1.4997
N13860 X1.7038 Y-1.5029
N13865 X1.6949 Y-1.5054
N13870 X1.6859 Y-1.5071
N13875 X1.6766 Y-1.5082
N13880 X1.6579 Y-1.5092
N13885 X1.6339 Y-1.5073
N13890 X1.622 Y-1.5056
N13895 X1.6104 Y-1.5031
N13900 X1.5991 Y-1.4995
N13905 X1.5879 Y-1.4951
N13910 X1.566 Y-1.485
N13915 X1.5472 Y-1.4729
N13920 X1.5382 Y-1.4664
N13925 X1.5298 Y-1.4594
N13930 X1.522 Y-1.4517
N13935 X1.5147 Y-1.4433
N13940 X1.5011 Y-1.4256
N13945 X1.4915 Y-1.4081
N13950 X1.4872 Y-1.3992
N13955 X1.4834 Y-1.3901
N13960 X1.4803 Y-1.3807
N13965 X1.4778 Y-1.3712
N13970 X1.4736 Y-1.3516
N13975 X1.471 Y-1.3227
N13980 X1.4692 Y-1.2937
N13985 X1.4686 Y-1.2647
N13990 X1.4685 Y-1.2356
N13995 X1.4694 Y-1.0128
N14000 X1.4698 Y-0.9735
N14005 X1.4704 Y-0.9539
N14010 X1.4715 Y-0.9344
N14015 X1.4733 Y-0.9149
N14020 X1.4757 Y-0.8954
N14025 X1.4817 Y-0.8567
N14030 X1.487 Y-0.8434
N14035 X1.4927 Y-0.8303
N14040 X1.4993 Y-0.8179
N14045 X1.503 Y-0.812
N14050 X1.5071 Y-0.8064
N14055 X1.5162 Y-0.7959
N14060 X1.5264 Y-0.7861
N14065 X1.5373 Y-0.7768
N14070 X1.5485 Y-0.7678
N14075 X1.565 Y-0.7585
N14080 X1.5817 Y-0.7497
N14085 X1.5987 Y-0.7422
N14090 X1.6074 Y-0.739
N14095 X1.6162 Y-0.7363
N14100 X1.6252 Y-0.7341
N14105 X1.6343 Y-0.7324
N14110 X1.6529 Y-0.7301
N14115 X1.6717 Y-0.7287
N14120 X1.6907 Y-0.7278
N14125 X1.7094 Y-0.7287
N14130 X1.728 Y-0.73
N14135 X1.7463 Y-0.7322
N14140 X1.7643 Y-0.7358
N14145 X1.7732 Y-0.7381
N14150 X1.7819 Y-0.741
N14155 X1.7991 Y-0.7477
N14160 X1.816 Y-0.7554
N14165 X1.8327 Y-0.7636
N14170 X1.8445 Y-0.7719
N14175 X1.856 Y-0.7804
N14180 X1.8668 Y-0.7895
N14185 X1.8767 Y-0.7994
N14190 X1.8812 Y-0.8047
N14195 X1.8853 Y-0.8103
N14200 X1.8929 Y-0.8222
N14205 X1.8996 Y-0.8347
N14210 X1.9061 Y-0.8476
N14215 X1.9142 Y-0.8822
N14220 Z0.1606
N14225 G0 Z0.2
N14230 X1.2835 Y-1.0169
N14235 Z0.1606
N14240 G1 Z-0.0394 F13.123
N14245 X1.2815 Y-1.4919 F39.37
N14250 X1.0865 Y-1.4911
N14255 X1.0896 Y-0.7411
N14260 X1.2846 Y-0.7419
N14265 X1.2835 Y-1.0169
N14270 Z0.1606
N14275 G0 Z0.2
N14280 X0.8901 Y-0.8419
N14285 Z0.1606
N14290 G1 Z-0.0394 F13.123
N14295 X0.8935 Y-0.8576 F39.37
N14300 X0.8959 Y-0.8734
N14305 X0.8973 Y-0.8893
N14310 X0.898 Y-0.9054
N14315 X0.8982 Y-0.9377
N14320 X0.8981 Y-0.9673
N14325 X0.7169 Y-0.9666
N14330 X0.7172 Y-0.911
N14335 X0.7173 Y-0.8983
N14340 X0.7166 Y-0.8857
N14345 X0.7156 Y-0.8795
N14350 X0.7142 Y-0.8734
N14355 X0.7104 Y-0.8614
N14360 X0.7057 Y-0.8566
N14365 X0.7031 Y-0.8545
N14370 X0.7004 Y-0.853
N14375 X0.6973 Y-0.8519
N14380 X0.6941 Y-0.8513
N14385 X0.6873 Y-0.8506
N14390 X0.6793 Y-0.8517
N14395 X0.6755 Y-0.8526
N14400 X0.672 Y-0.8541
N14405 X0.6688 Y-0.8562
N14410 X0.6659 Y-0.8588
N14415 X0.6606 Y-0.8649
N14420 X0.6562 Y-0.8753
N14425 X0.6544 Y-0.8806
N14430 X0.6531 Y-0.886
N14435 X0.6518 Y-0.8971
N14440 X0.6514 Y-0.9084
N14445 X0.6517 Y-0.923
N14450 X0.6522 Y-0.9302
N14455 X0.6531 Y-0.9374
N14460 X0.6545 Y-0.9444
N14465 X0.6565 Y-0.9513
N14470 X0.6613 Y-0.965
N14475 X0.6729 Y-0.979
N14480 X0.6792 Y-0.9854
N14485 X0.6859 Y-0.9913
N14490 X0.6931 Y-0.9967
N14495 X0.7006 Y-1.0017
N14500 X0.7162 Y-1.0111
N14505 X0.7611 Y-1.0381
N14510 X0.7829 Y-1.0524
N14515 X0.804 Y-1.0675
N14520 X0.8143 Y-1.0754
N14525 X0.8242 Y-1.0837
N14530 X0.8434 Y-1.1013
N14535 X0.8617 Y-1.1197
N14540 X0.8798 Y-1.1386
N14545 X0.8883 Y-1.1576
N14550 X0.8962 Y-1.1768
N14555 X0.8997 Y-1.1864
N14560 X0.9028 Y-1.1962
N14565 X0.9055 Y-1.206
N14570 X0.9076 Y-1.216
N14575 X0.9093 Y-1.2261
N14580 X0.9106 Y-1.2363
N14585 X0.9121 Y-1.2569
N14590 X0.9128 Y-1.2777
N14595 X0.9129 Y-1.2986
N14600 X0.9123 Y-1.3289
N14605 X0.9113 Y-1.3439
N14610 X0.9096 Y-1.3588
N14615 X0.9068 Y-1.3735
N14620 X0.903 Y-1.388
N14625 X0.8937 Y-1.4167
N14630 X0.8866 Y-1.4269
N14635 X0.8793 Y-1.4368
N14640 X0.8714 Y-1.446
N14645 X0.8627 Y-1.4544
N14650 X0.8531 Y-1.4617
N14655 X0.8428 Y-1.4683
N14660 X0.8209 Y-1.4801
N14665 X0.7906 Y-1.4913
N14670 X0.7753 Y-1.496
N14675 X0.7598 Y-1.4997
N14680 X0.744 Y-1.5022
N14685 X0.728 Y-1.5037
N14690 X0.6957 Y-1.5052
N14695 X0.661 Y-1.5033
N14700 X0.6439 Y-1.5014
N14705 X0.627 Y-1.4984
N14710 X0.6105 Y-1.494
N14715 X0.5942 Y-1.4884
N14720 X0.5782 Y-1.4819
N14725 X0.5622 Y-1.475
N14730 X0.5506 Y-1.468
N14735 X0.5393 Y-1.4606
N14740 X0.5287 Y-1.4526
N14745 X0.519 Y-1.4438
N14750 X0.5146 Y-1.4389
N14755 X0.5105 Y-1.4338
N14760 X0.5031 Y-1.4228
N14765 X0.4964 Y-1.4112
N14770 X0.49 Y-1.3992
N14775 X0.4819 Y-1.3672
N14780 X0.4786 Y-1.3511
N14785 X0.4762 Y-1.3349
N14790 X0.4747 Y-1.3185
N14795 X0.4739 Y-1.3021
N14800 X0.4734 Y-1.269
N14805 X0.4736 Y-1.2199
N14810 X0.6547 Y-1.2206
N14815 X0.6544 Y-1.3119
N14820 X0.6542 Y-1.3258
N14825 X0.6551 Y-1.3395
N14830 X0.6561 Y-1.3463
N14835 X0.6577 Y-1.353
N14840 X0.6618 Y-1.3661
N14845 X0.6673 Y-1.3717
N14850 X0.6703 Y-1.374
N14855 X0.6736 Y-1.3758
N14860 X0.6771 Y-1.377
N14865 X0.6809 Y-1.3777
N14870 X0.6888 Y-1.3783
N14875 X0.6976 Y-1.3772
N14880 X0.7017 Y-1.3763
N14885 X0.7055 Y-1.3747
N14890 X0.7089 Y-1.3725
N14895 X0.7121 Y-1.3697
N14900 X0.7179 Y-1.3631
N14905 X0.7225 Y-1.3523
N14910 X0.7243 Y-1.3468
N14915 X0.7257 Y-1.3411
N14920 X0.7271 Y-1.3296
N14925 X0.7275 Y-1.3178
N14930 X0.7276 Y-1.295
N14935 X0.7269 Y-1.2838
N14940 X0.7255 Y-1.2728
N14945 X0.723 Y-1.262
N14950 X0.7193 Y-1.2515
N14955 X0.7148 Y-1.2412
N14960 X0.7098 Y-1.2311
N14965 X0.6884 Y-1.2123
N14970 X0.6773 Y-1.2033
N14975 X0.666 Y-1.1946
N14980 X0.6427 Y-1.1783
N14985 X0.6189 Y-1.1626
N14990 X0.5941 Y-1.146
N14995 X0.5697 Y-1.129
N15000 X0.5459 Y-1.111
N15005 X0.5228 Y-1.0922
N15010 X0.5107 Y-1.0787
N15015 X0.5051 Y-1.0716
N15020 X0.5 Y-1.0642
N15025 X0.4955 Y-1.0565
N15030 X0.4914 Y-1.0484
N15035 X0.4839 Y-1.0319
N15040 X0.4768 Y-1.0078
N15045 X0.4739 Y-0.9957
N15050 X0.4717 Y-0.9835
N15055 X0.4703 Y-0.9711
N15060 X0.4694 Y-0.9587
N15065 X0.4688 Y-0.9336
N15070 X0.4695 Y-0.9011
N15075 X0.4706 Y-0.8851
N15080 X0.4727 Y-0.8692
N15085 X0.4759 Y-0.8535
N15090 X0.4803 Y-0.8381
N15095 X0.4856 Y-0.8228
N15100 X0.4913 Y-0.8077
N15105 X0.5056 Y-0.7881
N15110 X0.5133 Y-0.7791
N15115 X0.5219 Y-0.7709
N15120 X0.5313 Y-0.7636
N15125 X0.5414 Y-0.7572
N15130 X0.5627 Y-0.7457
N15135 X0.5915 Y-0.7357
N15140 X0.606 Y-0.7315
N15145 X0.6208 Y-0.7283
N15150 X0.6357 Y-0.7262
N15155 X0.6509 Y-0.7249
N15160 X0.6814 Y-0.7237
N15165 X0.7146 Y-0.7252
N15170 X0.7311 Y-0.7268
N15175 X0.7474 Y-0.7293
N15180 X0.7635 Y-0.7329
N15185 X0.7794 Y-0.7376
N15190 X0.8107 Y-0.7488
N15195 X0.8322 Y-0.7601
N15200 X0.8423 Y-0.7665
N15205 X0.8517 Y-0.7736
N15210 X0.8601 Y-0.7818
N15215 X0.8677 Y-0.791
N15220 X0.8747 Y-0.8008
N15225 X0.8814 Y-0.8109
N15230 X0.8901 Y-0.8419
N15235 Z0.1606
N15240 G0 Z0.2
N15245 X0.3029 Y-0.888
N15250 Z0.1606
N15255 G1 Z-0.0394 F13.123
N15260 X0.1728 Y-0.8874 F39.37
N15265 X0.1722 Y-1.0296
N15270 X0.294 Y-1.0301
N15275 X0.2934 Y-1.1728
N15280 X0.1716 Y-1.1723
N15285 X0.1709 Y-1.3372
N15290 X0.3141 Y-1.3378
N15295 X0.3134 Y-1.4879
N15300 X-0.0247 Y-1.4865
N15305 X-0.0216 Y-0.7365
N15310 X0.3036 Y-0.7379
N15315 X0.3029 Y-0.888
N15320 Z0.1606
N15325 G0 Z0.2
N15330 X-0.2261 Y-0.822
N15335 Z0.1606
N15340 G1 Z-0.0394 F13.123
N15345 X-0.2224 Y-0.8305 F39.37
N15350 X-0.2194 Y-0.8393
N15355 X-0.2146 Y-0.8573
N15360 X-0.2112 Y-0.893
N15365 X-0.21 Y-0.9108
N15370 X-0.2091 Y-0.9287
N15375 X-0.2085 Y-0.9645
N15380 X-0.2087 Y-1.0003
N15385 X-0.2098 Y-1.2629
N15390 X-0.2099 Y-1.2969
N15395 X-0.2103 Y-1.3138
N15400 X-0.2111 Y-1.3308
N15405 X-0.2125 Y-1.3476
N15410 X-0.2146 Y-1.3644
N15415 X-0.2198 Y-1.3979
N15420 X-0.2253 Y-1.413
N15425 X-0.2285 Y-1.4203
N15430 X-0.2323 Y-1.4272
N15435 X-0.2368 Y-1.4336
N15440 X-0.2419 Y-1.4396
N15445 X-0.2532 Y-1.4511
N15450 X-0.2667 Y-1.4601
N15455 X-0.2736 Y-1.4642
N15460 X-0.2808 Y-1.4678
N15465 X-0.2883 Y-1.4708
N15470 X-0.2959 Y-1.4734
N15475 X-0.3116 Y-1.4777
N15480 X-0.3377 Y-1.4814
N15485 X-0.3507 Y-1.4828
N15490 X-0.3638 Y-1.4839
N15495 X-0.3901 Y-1.4848
N15500 X-0.4164 Y-1.4849
N15505 X-0.6623 Y-1.4839
N15510 X-0.6593 Y-0.7339
N15515 X-0.5133 Y-0.7345
N15520 X-0.4653 Y-0.7347
N15525 X-0.4413 Y-0.7353
N15530 X-0.4174 Y-0.7364
N15535 X-0.3935 Y-0.7384
N15540 X-0.3697 Y-0.7411
N15545 X-0.3223 Y-0.7483
N15550 X-0.3012 Y-0.7551
N15555 X-0.291 Y-0.7592
N15560 X-0.2812 Y-0.764
N15565 X-0.272 Y-0.7698
N15570 X-0.2633 Y-0.7765
N15575 X-0.2467 Y-0.7912
N15580 X-0.2355 Y-0.8062
N15585 X-0.2305 Y-0.814
N15590 X-0.2261 Y-0.822
N15595 Z0.1606
N15600 G0 Z0.2
N15605 X-0.4648 Y-0.863
N15610 Z0.1606
N15615 G1 Z-0.0394 F13.123
N15620 X-0.4668 Y-1.3564 F39.37
N15625 X-0.4522 Y-1.3563
N15630 X-0.4452 Y-1.3557
N15635 X-0.4384 Y-1.3543
N15640 X-0.432 Y-1.352
N15645 X-0.426 Y-1.3485
N15650 X-0.4204 Y-1.3443
N15655 X-0.4148 Y-1.3397
N15660 X-0.4091 Y-1.3171
N15665 X-0.407 Y-1.3058
N15670 X-0.4056 Y-1.2943
N15675 X-0.4049 Y-1.2827
N15680 X-0.4046 Y-1.2711
N15685 X-0.4047 Y-1.2478
N15690 X-0.4035 Y-0.9564
N15695 X-0.4034 Y-0.94
N15700 X-0.4037 Y-0.9236
N15705 X-0.4048 Y-0.9073
N15710 X-0.4065 Y-0.8911
N15715 X-0.4086 Y-0.8847
N15720 X-0.4116 Y-0.8789
N15725 X-0.4136 Y-0.8764
N15730 X-0.416 Y-0.8741
N15735 X-0.4212 Y-0.8699
N15740 X-0.4318 Y-0.8664
N15745 X-0.4371 Y-0.865
N15750 X-0.4425 Y-0.864
N15755 X-0.4536 Y-0.8631
N15760 X-0.4648 Y-0.863
N15765 Z0.1606
N15770 G0 Z0.2
N15775 X-0.4667 Y-0.3275
N15780 Z0.1606
N15785 G1 Z-0.0394 F13.123
N15790 X-0.504 Y-0.3273 F39.37
N15795 X-0.5139 Y-0.1925
N15800 X-0.5837 Y-0.1922
N15805 X-0.596 Y-0.327
N15810 X-0.7976 Y-0.3261
N15815 X-0.695 Y0.4235
N15820 X-0.4131 Y0.4223
N15825 X-0.3047 Y-0.3282
N15830 X-0.4667 Y-0.3275
N15835 Z0.1606
N15840 G0 Z0.2
N15845 X-0.241 Y0.4216
N15850 Z0.1606
N15855 G1 Z-0.0394 F13.123
N15860 X0.1852 Y0.4198 F39.37
N15865 X0.1846 Y0.2697
N15870 X0.0688 Y0.2702
N15875 X0.0663 Y-0.3297
N15880 X-0.1287 Y-0.3289
N15885 X-0.1263 Y0.271
N15890 X-0.2416 Y0.2715
N15895 X-0.241 Y0.4216
N15900 Z0.1606
N15905 G0 Z0.2
N15910 X0.3429 Y0.4192
N15915 Z0.1606
N15920 G1 Z-0.0394 F13.123
N15925 X0.5379 Y0.4184 F39.37
N15930 X0.5368 Y0.1502
N15935 X0.5952 Y0.1499
N15940 X0.5963 Y0.4181
N15945 X0.7913 Y0.4173
N15950 X0.7882 Y-0.3327
N15955 X0.5932 Y-0.3319
N15960 X0.5945 Y-0.0169
N15965 X0.5361 Y-0.0166
N15970 X0.5348 Y-0.3316
N15975 X0.3398 Y-0.3308
N15980 X0.3429 Y0.4192
N15985 Z0.1606
N15990 G0 Z0.2
N15995 X0.9828 Y0.4165
N16000 Z0.1606
N16005 G1 Z-0.0394 F13.123
N16010 X1.308 Y0.4152 F39.37
N16015 X1.3074 Y0.2651
N16020 X1.1772 Y0.2656
N16025 X1.1766 Y0.1234
N16030 X1.2985 Y0.1229
N16035 X1.2979 Y-0.0198
N16040 X1.1761 Y-0.0193
N16045 X1.1754 Y-0.1842
N16050 X1.3185 Y-0.1848
N16055 X1.3179 Y-0.3349
N16060 X0.9797 Y-0.3335
N16065 X0.9828 Y0.4165
N16070 Z0.1606
N16075 G0 Z0.2
N16080 X-0.5469 Y0.2556
N16085 Z0.1606
N16090 G1 Z-0.0394 F13.123
N16095 X-0.558 Y0.1771 F39.37
N16100 X-0.5684 Y0.0984
N16105 X-0.5775 Y0.0197
N16110 X-0.5856 Y-0.0592
N16115 X-0.5185 Y-0.0595
N16120 X-0.5266 Y0.0192
N16125 X-0.5341 Y0.0979
N16130 X-0.5407 Y0.1767
N16135 X-0.5469 Y0.2556
N16140 Z0.1606
N16145 G0 Z0.2
N16150 X-0.9368 Y-0.1755
N16155 Z0.1606
N16160 G1 Z-0.0394 F13.123
N16165 X-0.9375 Y-0.3255 F39.37
N16170 X-1.2511 Y-0.3243
N16175 X-1.248 Y0.4257
N16180 X-1.053 Y0.4249
N16185 X-1.0554 Y-0.175
N16190 X-0.9368 Y-0.1755
N16195 Z0.1606
N16200 G0 Z0.2
N16205 X-1.813 Y0.2086
N16210 Z0.1606
N16215 G1 Z-0.0394 F13.123
N16220 X-1.8109 Y0.2008 F39.37
N16225 X-1.8078 Y0.1847
N16230 X-1.8058 Y0.1682
N16235 X-1.8045 Y0.1515
N16240 X-1.8067 Y0.1324
N16245 X-1.8096 Y0.1137
N16250 X-1.8115 Y0.1045
N16255 X-1.8138 Y0.0955
N16260 X-1.8167 Y0.0867
N16265 X-1.8201 Y0.0782
N16270 X-1.8241 Y0.0699
N16275 X-1.8287 Y0.0619
N16280 X-1.8337 Y0.0541
N16285 X-1.8392 Y0.0465
N16290 X-1.851 Y0.0316
N16295 X-1.8634 Y0.0169
N16300 X-1.7978 Y-0.1027
N16305 X-1.6955 Y-0.0375
N16310 X-1.696 Y-0.164
N16315 X-1.7483 Y-0.1971
N16320 X-1.6834 Y-0.3225
N16325 X-1.8567 Y-0.3218
N16330 X-1.879 Y-0.28
N16335 X-1.8982 Y-0.2915
N16340 X-1.9176 Y-0.3024
N16345 X-1.9373 Y-0.3123
N16350 X-1.9474 Y-0.3166
N16355 X-1.9576 Y-0.3206
N16360 X-1.9679 Y-0.3239
N16365 X-1.9785 Y-0.3268
N16370 X-1.9892 Y-0.3291
N16375 X-2. Y-0.3311
N16380 X-2.022 Y-0.3342
N16385 X-2.0442 Y-0.3367
N16390 X-2.0622 Y-0.3352
N16395 X-2.08 Y-0.3331
N16400 X-2.0887 Y-0.3315
N16405 X-2.0972 Y-0.3296
N16410 X-2.1054 Y-0.3271
N16415 X-2.1134 Y-0.3241
N16420 X-2.1211 Y-0.3204
N16425 X-2.1286 Y-0.3161
N16430 X-2.1358 Y-0.3113
N16435 X-2.1427 Y-0.306
N16440 X-2.1563 Y-0.2944
N16445 X-2.1694 Y-0.282
N16450 X-2.1792 Y-0.2671
N16455 X-2.1883 Y-0.252
N16460 X-2.1964 Y-0.2365
N16465 X-2.1998 Y-0.2286
N16470 X-2.2027 Y-0.2205
N16475 X-2.2052 Y-0.2122
N16480 X-2.2071 Y-0.2038
N16485 X-2.2099 Y-0.1866
N16490 X-2.2117 Y-0.169
N16495 X-2.2129 Y-0.1512
N16500 X-2.2115 Y-0.1257
N16505 X-2.21 Y-0.1133
N16510 X-2.2074 Y-0.1011
N16515 X-2.2036 Y-0.0892
N16520 X-2.1986 Y-0.0778
N16525 X-2.1928 Y-0.0665
N16530 X-2.1866 Y-0.0554
N16535 X-2.1697 Y-0.0377
N16540 X-2.1608 Y-0.0295
N16545 X-2.1514 Y-0.0221
N16550 X-2.1412 Y-0.0156
N16555 X-2.1306 Y-0.0097
N16560 X-2.1085 Y0.0008
N16565 X-2.1245 Y0.0154
N16570 X-2.1396 Y0.0304
N16575 X-2.1466 Y0.0382
N16580 X-2.153 Y0.0463
N16585 X-2.1588 Y0.0547
N16590 X-2.1638 Y0.0636
N16595 X-2.168 Y0.0728
N16600 X-2.1714 Y0.0824
N16605 X-2.1742 Y0.0924
N16610 X-2.1764 Y0.1026
N16615 X-2.1796 Y0.1237
N16620 X-2.182 Y0.1452
N16625 X-2.1804 Y0.1631
N16630 X-2.1782 Y0.1807
N16635 X-2.1766 Y0.1893
N16640 X-2.1747 Y0.1978
N16645 X-2.1723 Y0.206
N16650 X-2.1693 Y0.214
N16655 X-2.1657 Y0.2218
N16660 X-2.1615 Y0.2293
N16665 X-2.1568 Y0.2366
N16670 X-2.1517 Y0.2437
N16675 X-2.1405 Y0.2574
N16680 X-2.1287 Y0.2709
N16685 X-2.1123 Y0.282
N16690 X-2.0956 Y0.2924
N16695 X-2.0871 Y0.2971
N16700 X-2.0784 Y0.3013
N16705 X-2.0696 Y0.3051
N16710 X-2.0605 Y0.3082
N16715 X-2.0513 Y0.3108
N16720 X-2.0419 Y0.3128
N16725 X-2.0226 Y0.3155
N16730 X-2.0029 Y0.3171
N16735 X-1.9831 Y0.3181
N16740 X-1.9649 Y0.3169
N16745 X-1.9469 Y0.3151
N16750 X-1.9294 Y0.3122
N16755 X-1.9209 Y0.3101
N16760 X-1.9126 Y0.3075
N16765 X-1.9044 Y0.3044
N16770 X-1.8965 Y0.3006
N16775 X-1.8888 Y0.2964
N16780 X-1.8813 Y0.2917
N16785 X-1.8665 Y0.2816
N16790 X-1.8519 Y0.2707
N16795 X-1.8414 Y0.2577
N16800 X-1.8314 Y0.2444
N16805 X-1.8268 Y0.2376
N16810 X-1.8226 Y0.2306
N16815 X-1.8189 Y0.2235
N16820 X-1.8157 Y0.2162
N16825 X-1.813 Y0.2086
N16830 Z0.1606
N16835 G0 Z0.2
N16840 X-1.9488 Y-0.1849
N16845 Z0.1606
N16850 G1 Z-0.0394 F13.123
N16855 X-2.0028 Y-0.0937 F39.37
N16860 X-2.0166 Y-0.1082
N16865 X-2.0227 Y-0.1158
N16870 X-2.0278 Y-0.124
N16875 X-2.0316 Y-0.1327
N16880 X-2.0343 Y-0.1421
N16885 X-2.0363 Y-0.1518
N16890 X-2.0378 Y-0.1616
N16895 X-2.0374 Y-0.1722
N16900 X-2.0369 Y-0.1774
N16905 X-2.0359 Y-0.1825
N16910 X-2.0343 Y-0.1873
N16915 X-2.0322 Y-0.1921
N16920 X-2.0271 Y-0.2013
N16925 X-2.0203 Y-0.2072
N16930 X-2.0166 Y-0.2097
N16935 X-2.0127 Y-0.2117
N16940 X-2.0086 Y-0.213
N16945 X-2.0042 Y-0.2138
N16950 X-1.9951 Y-0.2146
N16955 X-1.9811 Y-0.2125
N16960 X-1.9742 Y-0.2109
N16965 X-1.9676 Y-0.2087
N16970 X-1.9612 Y-0.2058
N16975 X-1.955 Y-0.2025
N16980 X-1.9428 Y-0.1951
N16985 X-1.9488 Y-0.1849
N16990 Z0.1606
N16995 G0 Z0.2
N17000 X-1.984 Y0.0952
N17005 Z0.1606
N17010 G1 Z-0.0394 F13.123
N17015 X-1.9715 Y0.1131 F39.37
N17020 X-1.9659 Y0.1224
N17025 X-1.9612 Y0.132
N17030 X-1.9577 Y0.142
N17035 X-1.9551 Y0.1524
N17040 X-1.9517 Y0.1739
N17045 X-1.9524 Y0.1818
N17050 X-1.9539 Y0.1894
N17055 X-1.957 Y0.1966
N17060 X-1.9608 Y0.2035
N17065 X-1.9661 Y0.2093
N17070 X-1.9689 Y0.2117
N17075 X-1.972 Y0.2137
N17080 X-1.9754 Y0.2151
N17085 X-1.979 Y0.216
N17090 X-1.9867 Y0.2171
N17095 X-1.9934 Y0.2165
N17100 X-1.9966 Y0.2158
N17105 X-1.9996 Y0.2148
N17110 X-2.0024 Y0.2134
N17115 X-2.005 Y0.2115
N17120 X-2.0099 Y0.207
N17125 X-2.0137 Y0.1997
N17130 X-2.0153 Y0.196
N17135 X-2.0164 Y0.1922
N17140 X-2.0176 Y0.1842
N17145 X-2.0179 Y0.176
N17150 X-2.0166 Y0.1647
N17155 X-2.0149 Y0.1535
N17160 X-2.0125 Y0.1427
N17165 X-2.0088 Y0.1324
N17170 X-2.0039 Y0.1226
N17175 X-1.9978 Y0.1132
N17180 X-1.984 Y0.0952
N17185 Z0.1606
N17190 G0 Z0.2
N17195 X-2.6317 Y-0.1685
N17200 Z0.1606
N17205 G1 Z-0.0394 F13.123
N17210 X-2.6323 Y-0.3186 F39.37
N17215 X-2.9459 Y-0.3173
N17220 X-2.9428 Y0.4327
N17225 X-2.7478 Y0.4319
N17230 X-2.7503 Y-0.168
N17235 X-2.6317 Y-0.1685
N17240 Z0.1606
N17245 G0 Z0.2
N17250 X-3.2219 Y0.4339
N17255 Z0.1606
N17260 G1 Z-0.0394 F13.123
N17265 X-3.2243 Y-0.166 F39.37
N17270 X-3.1058 Y-0.1665
N17275 X-3.1064 Y-0.3166
N17280 X-3.42 Y-0.3153
N17285 X-3.4169 Y0.4347
N17290 X-3.2219 Y0.4339
N17295 Z0.1606
N17300 G0 Z0.2
N17305 X-3.6084 Y0.4355
N17310 Z0.1606
N17315 G1 Z-0.0394 F13.123
N17320 X-3.6115 Y-0.3145 F39.37
N17325 X-3.8065 Y-0.3137
N17330 X-3.8034 Y0.4363
N17335 X-3.6084 Y0.4355
N17340 Z0.1606
N17345 G0 Z0.2
N17350 X-3.9949 Y0.4371
N17355 Z0.1606
N17360 G1 Z-0.0394 F13.123
N17365 X-3.998 Y-0.3129 F39.37
N17370 X-4.1685 Y-0.3122
N17375 X-4.1667 Y0.1941
N17380 X-4.2366 Y-0.3119
N17385 X-4.3575 Y-0.3114
N17390 X-4.427 Y0.1836
N17395 X-4.4293 Y-0.3111
N17400 X-4.5998 Y-0.3104
N17405 X-4.5967 Y0.4396
N17410 X-4.3443 Y0.4385
N17415 X-4.3324 Y0.3589
N17420 X-4.3219 Y0.279
N17425 X-4.2949 Y0.0881
N17430 X-4.2487 Y0.4381
N17435 X-3.9949 Y0.4371
N17440 Z0.1606
N17445 G0 Z0.2
N17450 X-3.4072 Y1.1296
N17455 Z0.1606
N17460 G1 Z-0.0394 F13.123
N17465 X-3.4154 Y1.1388 F39.37
N17470 X-3.4231 Y1.1481
N17475 X-3.43 Y1.1578
N17480 X-3.4358 Y1.1681
N17485 X-3.4381 Y1.1735
N17490 X-3.44 Y1.179
N17495 X-3.4429 Y1.1905
N17500 X-3.4449 Y1.2025
N17505 X-3.4465 Y1.2146
N17510 X-3.445 Y1.2306
N17515 X-3.4435 Y1.2384
N17520 X-3.4413 Y1.2459
N17525 X-3.4381 Y1.253
N17530 X-3.4341 Y1.2598
N17535 X-3.4246 Y1.2728
N17540 X-3.4127 Y1.2827
N17545 X-3.4064 Y1.2869
N17550 X-3.3998 Y1.2903
N17555 X-3.3927 Y1.2927
N17560 X-3.3853 Y1.2942
N17565 X-3.3699 Y1.296
N17570 X-3.3544 Y1.2945
N17575 X-3.3469 Y1.2931
N17580 X-3.3396 Y1.291
N17585 X-3.3327 Y1.2879
N17590 X-3.3261 Y1.2841
N17595 X-3.3135 Y1.275
N17600 X-3.3037 Y1.2632
N17605 X-3.2996 Y1.257
N17610 X-3.2963 Y1.2505
N17615 X-3.294 Y1.2435
N17620 X-3.2925 Y1.2362
N17625 X-3.2908 Y1.221
N17630 X-3.2915 Y1.2107
N17635 X-3.2922 Y1.2057
N17640 X-3.2934 Y1.2008
N17645 X-3.295 Y1.196
N17650 X-3.297 Y1.1914
N17655 X-3.3019 Y1.1823
N17660 X-3.3101 Y1.1734
N17665 X-3.3145 Y1.1692
N17670 X-3.3192 Y1.1655
N17675 X-3.3294 Y1.1592
N17680 X-3.3403 Y1.1537
N17685 X-3.3444 Y1.1514
N17690 X-3.348 Y1.1487
N17695 X-3.3507 Y1.1452
N17700 X-3.3527 Y1.141
N17705 X-3.3484 Y1.1337
N17710 X-3.3458 Y1.1306
N17715 X-3.3427 Y1.1279
N17720 X-3.3392 Y1.1258
N17725 X-3.3353 Y1.1239
N17730 X-3.3272 Y1.1208
N17735 X-3.3122 Y1.1161
N17740 X-3.3046 Y1.1142
N17745 X-3.297 Y1.1126
N17750 X-3.2815 Y1.111
N17755 X-3.2658 Y1.1104
N17760 X-3.2503 Y1.1118
N17765 X-3.2352 Y1.1138
N17770 X-3.2278 Y1.1152
N17775 X-3.2206 Y1.117
N17780 X-3.2136 Y1.1193
N17785 X-3.2069 Y1.1221
N17790 X-3.2005 Y1.1255
N17795 X-3.1943 Y1.1294
N17800 X-3.1884 Y1.1339
N17805 X-3.1827 Y1.1387
N17810 X-3.1717 Y1.1493
N17815 X-3.161 Y1.1605
N17820 X-3.1522 Y1.1781
N17825 X-3.1439 Y1.1958
N17830 X-3.1369 Y1.2139
N17835 X-3.1341 Y1.2231
N17840 X-3.1317 Y1.2324
N17845 X-3.1298 Y1.2419
N17850 X-3.1284 Y1.2515
N17855 X-3.1265 Y1.2709
N17860 X-3.1256 Y1.2905
N17865 X-3.1251 Y1.3103
N17870 Y1.3975
N17875 X-3.1131
N17880 X-3.1261 Y1.3799
N17885 X-3.1331 Y1.3716
N17890 X-3.1407 Y1.3638
N17895 X-3.1488 Y1.3567
N17900 X-3.1576 Y1.3503
N17905 X-3.176 Y1.3383
N17910 X-3.198 Y1.3294
N17915 X-3.2091 Y1.3256
N17920 X-3.2204 Y1.3227
N17925 X-3.232 Y1.3207
N17930 X-3.2437 Y1.3195
N17935 X-3.2674 Y1.3183
N17940 X-3.2886 Y1.3193
N17945 X-3.2991 Y1.3203
N17950 X-3.3096 Y1.3218
N17955 X-3.3199 Y1.3239
N17960 X-3.3301 Y1.3266
N17965 X-3.3504 Y1.3328
N17970 X-3.3689 Y1.3408
N17975 X-3.378 Y1.3451
N17980 X-3.3868 Y1.35
N17985 X-3.3952 Y1.3553
N17990 X-3.4034 Y1.3612
N17995 X-3.4193 Y1.3736
N18000 X-3.433 Y1.3872
N18005 X-3.4395 Y1.3943
N18010 X-3.4455 Y1.4017
N18015 X-3.451 Y1.4095
N18020 X-3.4561 Y1.4176
N18025 X-3.4656 Y1.4344
N18030 X-3.4727 Y1.4523
N18035 X-3.4757 Y1.4613
N18040 X-3.4781 Y1.4705
N18045 X-3.4798 Y1.4798
N18050 X-3.4809 Y1.4893
N18055 X-3.4822 Y1.5085
N18060 X-3.4798 Y1.5364
N18065 X-3.4777 Y1.55
N18070 X-3.4744 Y1.5633
N18075 X-3.4698 Y1.5762
N18080 X-3.464 Y1.5888
N18085 X-3.4506 Y1.6133
N18090 X-3.4321 Y1.6358
N18095 X-3.4222 Y1.6463
N18100 X-3.4117 Y1.656
N18105 X-3.4002 Y1.6646
N18110 X-3.3881 Y1.6724
N18115 X-3.3627 Y1.6866
N18120 X-3.3328 Y1.6981
N18125 X-3.3177 Y1.7029
N18130 X-3.3023 Y1.7068
N18135 X-3.2867 Y1.7095
N18140 X-3.2709 Y1.7113
N18145 X-3.239 Y1.7132
N18150 X-3.2201 Y1.7119
N18155 X-3.2015 Y1.7102
N18160 X-3.183 Y1.7075
N18165 X-3.174 Y1.7057
N18170 X-3.165 Y1.7034
N18175 X-3.1562 Y1.7007
N18180 X-3.1476 Y1.6975
N18185 X-3.1305 Y1.6901
N18190 X-3.1137 Y1.6818
N18195 X-3.0971 Y1.6729
N18200 X-3.0819 Y1.6615
N18205 X-3.0672 Y1.6497
N18210 X-3.0532 Y1.6373
N18215 X-3.0466 Y1.6307
N18220 X-3.0404 Y1.6239
N18225 X-3.0345 Y1.6167
N18230 X-3.0289 Y1.6093
N18235 X-3.0185 Y1.5937
N18240 X-3.0088 Y1.5775
N18245 X-2.9995 Y1.561
N18250 X-2.9918 Y1.5415
N18255 X-2.9845 Y1.5219
N18260 X-2.9781 Y1.5021
N18265 X-2.9731 Y1.4821
N18270 X-2.9696 Y1.4616
N18275 X-2.9674 Y1.4409
N18280 X-2.966 Y1.4201
N18285 X-2.965 Y1.3991
N18290 X-2.9678 Y1.3659
N18295 X-2.9695 Y1.3494
N18300 X-2.9716 Y1.3331
N18305 X-2.9743 Y1.317
N18310 X-2.9776 Y1.3012
N18315 X-2.9818 Y1.2857
N18320 X-2.987 Y1.2706
N18325 X-2.9933 Y1.256
N18330 X-3.0006 Y1.2417
N18335 X-3.0087 Y1.2278
N18340 X-3.0176 Y1.2142
N18345 X-3.0271 Y1.2008
N18350 X-3.037 Y1.1875
N18355 X-3.0576 Y1.1614
N18360 X-3.0782 Y1.1426
N18365 X-3.089 Y1.1338
N18370 X-3.1002 Y1.1257
N18375 X-3.1119 Y1.1184
N18380 X-3.1241 Y1.1118
N18385 X-3.1493 Y1.0997
N18390 X-3.1768 Y1.0903
N18395 X-3.1907 Y1.0862
N18400 X-3.2048 Y1.0829
N18405 X-3.219 Y1.0806
N18410 X-3.2334 Y1.0791
N18415 X-3.2624 Y1.0773
N18420 X-3.2825 Y1.0786
N18425 X-3.3023 Y1.0805
N18430 X-3.3121 Y1.0819
N18435 X-3.3217 Y1.0837
N18440 X-3.3311 Y1.086
N18445 X-3.3403 Y1.0889
N18450 X-3.3492 Y1.0924
N18455 X-3.358 Y1.0965
N18460 X-3.3665 Y1.1012
N18465 X-3.3748 Y1.1063
N18470 X-3.3912 Y1.1176
N18475 X-3.4072 Y1.1296
N18480 Z0.1606
N18485 G0 Z0.2
N18490 X-3.1779 Y1.3739
N18495 Z0.1606
N18500 G1 Z-0.0394 F13.123
N18505 X-3.1692 Y1.3805 F39.37
N18510 X-3.1606 Y1.3875
N18515 X-3.1516 Y1.3984
N18520 X-3.1474 Y1.4041
N18525 X-3.1438 Y1.41
N18530 X-3.1407 Y1.4163
N18535 X-3.138 Y1.4228
N18540 X-3.1334 Y1.4362
N18545 X-3.1291 Y1.4561
N18550 X-3.1274 Y1.4662
N18555 X-3.126 Y1.4762
N18560 X-3.1247 Y1.4965
N18565 X-3.1242 Y1.5169
N18570 X-3.1248 Y1.5407
N18575 X-3.1254 Y1.5526
N18580 X-3.1265 Y1.5644
N18585 X-3.1282 Y1.5762
N18590 X-3.1304 Y1.5879
N18595 X-3.1358 Y1.6111
N18600 X-3.1415 Y1.6262
N18605 X-3.1449 Y1.6335
N18610 X-3.1488 Y1.6403
N18615 X-3.1534 Y1.6468
N18620 X-3.1586 Y1.6528
N18625 X-3.1701 Y1.6641
N18630 X-3.1836 Y1.6716
N18635 X-3.1906 Y1.6748
N18640 X-3.1977 Y1.6773
N18645 X-3.2051 Y1.6789
N18650 X-3.2127 Y1.68
N18655 X-3.2282 Y1.681
N18660 X-3.2397 Y1.6802
N18665 X-3.251 Y1.6789
N18670 X-3.2618 Y1.6766
N18675 X-3.2669 Y1.675
N18680 X-3.2718 Y1.673
N18685 X-3.2765 Y1.6706
N18690 X-3.281 Y1.6676
N18695 X-3.2894 Y1.6607
N18700 X-3.2972 Y1.6526
N18705 X-3.3048 Y1.644
N18710 X-3.3092 Y1.635
N18715 X-3.3131 Y1.6258
N18720 X-3.3161 Y1.6163
N18725 X-3.3185 Y1.6066
N18730 X-3.3206 Y1.5945
N18735 X-3.3218 Y1.5823
N18740 X-3.3232 Y1.5621
N18745 X-3.324 Y1.5419
N18750 X-3.3247 Y1.4934
N18755 X-3.3245 Y1.4767
N18760 X-3.3238 Y1.4599
N18765 X-3.3221 Y1.4433
N18770 X-3.3198 Y1.4267
N18775 X-3.3155 Y1.408
N18780 X-3.3096 Y1.3897
N18785 X-3.3023 Y1.3822
N18790 X-3.2949 Y1.3751
N18795 X-3.287 Y1.3688
N18800 X-3.2829 Y1.3661
N18805 X-3.2786 Y1.3638
N18810 X-3.2693 Y1.3604
N18815 X-3.2595 Y1.3581
N18820 X-3.2493 Y1.3567
N18825 X-3.2389 Y1.3557
N18830 X-3.2279 Y1.3566
N18835 X-3.217 Y1.358
N18840 X-3.2065 Y1.3601
N18845 X-3.1964 Y1.3634
N18850 X-3.1869 Y1.368
N18855 X-3.1779 Y1.3739
N18860 Z0.1606
N18865 G0 Z0.2
N18870 X-2.8606 Y1.6425
N18875 Z0.1606
N18880 G1 Z-0.0394 F13.123
N18885 X-2.8355 Y1.644 F39.37
N18890 X-2.8104 Y1.6459
N18895 X-2.7855 Y1.6487
N18900 X-2.7606 Y1.652
N18905 X-2.7416 Y1.6554
N18910 X-2.7227 Y1.6594
N18915 X-2.7041 Y1.6644
N18920 X-2.6856 Y1.6701
N18925 X-2.6666 Y1.6774
N18930 X-2.6478 Y1.6852
N18935 X-2.6294 Y1.694
N18940 X-2.6112 Y1.7032
N18945 X-2.571
N18950 Y1.2158
N18955 X-2.5672 Y1.1947
N18960 X-2.5649 Y1.1845
N18965 X-2.5622 Y1.1748
N18970 X-2.5589 Y1.1657
N18975 X-2.5549 Y1.1573
N18980 X-2.55 Y1.1499
N18985 X-2.5441 Y1.1435
N18990 X-2.5371 Y1.1382
N18995 X-2.5292 Y1.1339
N19000 X-2.5205 Y1.1305
N19005 X-2.511 Y1.1278
N19010 X-2.5011 Y1.1257
N19015 X-2.4907 Y1.124
N19020 X-2.4693 Y1.1212
N19025 X-2.4034
N19030 Y1.0882
N19035 X-2.8772
N19040 Y1.1212
N19045 X-2.8071
N19050 X-2.7854 Y1.1222
N19055 X-2.7748 Y1.1235
N19060 X-2.7646 Y1.1259
N19065 X-2.7548 Y1.1295
N19070 X-2.7455 Y1.1344
N19075 X-2.7364 Y1.1402
N19080 X-2.7275 Y1.1464
N19085 X-2.7214 Y1.1559
N19090 X-2.7158 Y1.1655
N19095 X-2.711 Y1.1755
N19100 X-2.7075 Y1.1858
N19105 X-2.7053 Y1.1966
N19110 X-2.704 Y1.2076
N19115 X-2.7032 Y1.2303
N19120 Y1.4961
N19125 X-2.7033 Y1.5109
N19130 X-2.7039 Y1.5257
N19135 X-2.7054 Y1.5404
N19140 X-2.7077 Y1.555
N19145 X-2.7105 Y1.5633
N19150 X-2.7142 Y1.5711
N19155 X-2.7192 Y1.578
N19160 X-2.725 Y1.5845
N19165 X-2.7342 Y1.5908
N19170 X-2.7434 Y1.5966
N19175 X-2.753 Y1.6017
N19180 X-2.7629 Y1.6055
N19185 X-2.7734 Y1.608
N19190 X-2.7841 Y1.6094
N19195 X-2.8062 Y1.6107
N19200 X-2.8606
N19205 Y1.6425
N19210 Z0.1606
N19215 G0 Z0.2
N19220 X-2.6321 Y-0.7128
N19225 Z0.1606
N19230 G1 Z-0.0394 F13.123
N19235 X-2.6178 Y-0.7115 F39.37
N19240 X-2.5889 Y-0.7102
N19245 X-2.5703 Y-0.711
N19250 X-2.5518 Y-0.7122
N19255 X-2.5334 Y-0.7143
N19260 X-2.5155 Y-0.7176
N19265 X-2.5066 Y-0.7198
N19270 X-2.4979 Y-0.7225
N19275 X-2.4806 Y-0.7289
N19280 X-2.4637 Y-0.7362
N19285 X-2.4468 Y-0.7441
N19290 X-2.4349 Y-0.7522
N19295 X-2.4234 Y-0.7605
N19300 X-2.4125 Y-0.7695
N19305 X-2.4026 Y-0.7793
N19310 X-2.3982 Y-0.7846
N19315 X-2.394 Y-0.7902
N19320 X-2.3866 Y-0.8021
N19325 X-2.3798 Y-0.8146
N19330 X-2.3735 Y-0.8274
N19335 X-2.3649 Y-0.8656
N19340 X-2.3615 Y-0.8848
N19345 X-2.359 Y-0.9041
N19350 X-2.3575 Y-0.9235
N19355 X-2.3568 Y-0.943
N19360 X-2.3565 Y-0.9822
N19365 X-2.3568 Y-1.0535
N19370 X-2.5518 Y-1.0527
N19375 X-2.5513 Y-0.9223
N19380 X-2.5511 Y-0.9044
N19385 X-2.5517 Y-0.8866
N19390 X-2.5525 Y-0.8777
N19395 X-2.5538 Y-0.8689
N19400 X-2.5573 Y-0.8513
N19405 X-2.5625 Y-0.8448
N19410 X-2.5654 Y-0.842
N19415 X-2.5686 Y-0.84
N19420 X-2.5723 Y-0.8386
N19425 X-2.5763 Y-0.8378
N19430 X-2.5848 Y-0.8371
N19435 X-2.5945 Y-0.838
N19440 X-2.599 Y-0.8389
N19445 X-2.6031 Y-0.8405
N19450 X-2.6067 Y-0.843
N19455 X-2.6099 Y-0.8463
N19460 X-2.6154 Y-0.8541
N19465 X-2.6191 Y-0.8724
N19470 X-2.6204 Y-0.8816
N19475 X-2.6214 Y-0.8909
N19480 X-2.6222 Y-0.9095
N19485 Y-0.9282
N19490 X-2.6236 Y-1.2766
N19495 X-2.6238 Y-1.2946
N19500 X-2.6231 Y-1.3125
N19505 X-2.6222 Y-1.3215
N19510 X-2.6209 Y-1.3303
N19515 X-2.6175 Y-1.348
N19520 X-2.6123 Y-1.3556
N19525 X-2.6093 Y-1.3587
N19530 X-2.6058 Y-1.3612
N19535 X-2.6019 Y-1.3628
N19540 X-2.5976 Y-1.3638
N19545 X-2.5883 Y-1.3648
N19550 X-2.5793 Y-1.3638
N19555 X-2.575 Y-1.3628
N19560 X-2.5712 Y-1.3612
N19565 X-2.5678 Y-1.3587
N19570 X-2.5649 Y-1.3556
N19575 X-2.5598 Y-1.3482
N19580 X-2.5559 Y-1.3288
N19585 X-2.5545 Y-1.319
N19590 X-2.5535 Y-1.3092
N19595 X-2.5527 Y-1.2895
N19600 Y-1.2697
N19605 X-2.5524 Y-1.1754
N19610 X-2.3573 Y-1.1762
N19615 X-2.3574 Y-1.2055
N19620 X-2.3579 Y-1.2472
N19625 X-2.3586 Y-1.268
N19630 X-2.3601 Y-1.2887
N19635 X-2.3626 Y-1.3093
N19640 X-2.366 Y-1.3298
N19645 X-2.3746 Y-1.3706
N19650 X-2.3809 Y-1.3835
N19655 X-2.3877 Y-1.3961
N19660 X-2.3952 Y-1.4081
N19665 X-2.3993 Y-1.4138
N19670 X-2.4038 Y-1.4192
N19675 X-2.4136 Y-1.4293
N19680 X-2.4244 Y-1.4385
N19685 X-2.4359 Y-1.4472
N19690 X-2.4477 Y-1.4556
N19695 X-2.464 Y-1.4639
N19700 X-2.4805 Y-1.4718
N19705 X-2.4972 Y-1.4786
N19710 X-2.5057 Y-1.4814
N19715 X-2.5144 Y-1.4838
N19720 X-2.5231 Y-1.4858
N19725 X-2.532 Y-1.4874
N19730 X-2.55 Y-1.4896
N19735 X-2.5682 Y-1.4909
N19740 X-2.5865 Y-1.4917
N19745 X-2.6049 Y-1.491
N19750 X-2.6233 Y-1.4898
N19755 X-2.6414 Y-1.4879
N19760 X-2.6592 Y-1.4849
N19765 X-2.668 Y-1.4828
N19770 X-2.6767 Y-1.4803
N19775 X-2.6939 Y-1.4743
N19780 X-2.7109 Y-1.4674
N19785 X-2.7277 Y-1.4601
N19790 X-2.7399 Y-1.4519
N19795 X-2.7518 Y-1.4434
N19800 X-2.7629 Y-1.4342
N19805 X-2.768 Y-1.4293
N19810 X-2.7728 Y-1.424
N19815 X-2.7772 Y-1.4185
N19820 X-2.7813 Y-1.4127
N19825 X-2.7885 Y-1.4003
N19830 X-2.795 Y-1.3872
N19835 X-2.801 Y-1.3738
N19840 X-2.8097 Y-1.333
N19845 X-2.8132 Y-1.3125
N19850 X-2.8157 Y-1.2919
N19855 X-2.8173 Y-1.2712
N19860 X-2.8181 Y-1.2504
N19865 X-2.8184 Y-1.2086
N19870 X-2.8175 Y-0.9895
N19875 X-2.8172 Y-0.959
N19880 X-2.8163 Y-0.9286
N19885 X-2.8143 Y-0.8982
N19890 X-2.8114 Y-0.8679
N19895 X-2.8065 Y-0.847
N19900 X-2.8034 Y-0.8368
N19905 X-2.7996 Y-0.8269
N19910 X-2.795 Y-0.8173
N19915 X-2.7897 Y-0.8081
N19920 X-2.778 Y-0.79
N19925 X-2.7615 Y-0.7718
N19930 X-2.7528 Y-0.7633
N19935 X-2.7436 Y-0.7555
N19940 X-2.7336 Y-0.7487
N19945 X-2.7231 Y-0.7425
N19950 X-2.7013 Y-0.7313
N19955 X-2.674 Y-0.7219
N19960 X-2.6602 Y-0.7179
N19965 X-2.6462 Y-0.7148
N19970 X-2.6321 Y-0.7128
N19975 Z0.1606
N19980 G0 Z0.2
N19985 X-2.1658 Y-1.0842
N19990 Z0.1606
N19995 G1 Z-0.0394 F13.123
N20000 X-2.1171 Y-0.7279 F39.37
N20005 X-1.8352 Y-0.729
N20010 X-1.7267 Y-1.4795
N20015 X-1.9261 Y-1.4787
N20020 X-1.936 Y-1.3438
N20025 X-2.0057 Y-1.3435
N20030 X-2.018 Y-1.4783
N20035 X-2.2196 Y-1.4775
N20040 X-2.1658 Y-1.0842
N20045 Z0.1606
N20050 G0 Z0.2
N20055 X-1.9689 Y-0.8957
N20060 Z0.1606
N20065 G1 Z-0.0394 F13.123
N20070 X-1.98 Y-0.9743 F39.37
N20075 X-1.9904 Y-1.0529
N20080 X-1.9995 Y-1.1317
N20085 X-2.0077 Y-1.2106
N20090 X-1.9405 Y-1.2109
N20095 X-1.9486 Y-1.1322
N20100 X-1.9561 Y-1.0534
N20105 X-1.9628 Y-0.9746
N20110 X-1.9689 Y-0.8957
N20115 Z0.1606
N20120 G0 Z0.2
N20125 X-1.5793 Y-1.2176
N20130 Z0.1606
N20135 G1 Z-0.0394 F13.123
N20140 X-1.5773 Y-0.7301 F39.37
N20145 X-1.4314 Y-0.7307
N20150 X-1.3834 Y-0.7309
N20155 X-1.3594 Y-0.7315
N20160 X-1.3355 Y-0.7327
N20165 X-1.3116 Y-0.7346
N20170 X-1.2878 Y-0.7374
N20175 X-1.2404 Y-0.7445
N20180 X-1.2192 Y-0.7514
N20185 X-1.209 Y-0.7554
N20190 X-1.1993 Y-0.7602
N20195 X-1.1901 Y-0.766
N20200 X-1.1814 Y-0.7727
N20205 X-1.1648 Y-0.7874
N20210 X-1.1536 Y-0.8024
N20215 X-1.1485 Y-0.8102
N20220 X-1.1441 Y-0.8182
N20225 X-1.1405 Y-0.8267
N20230 X-1.1375 Y-0.8355
N20235 X-1.1326 Y-0.8535
N20240 X-1.1293 Y-0.8892
N20245 X-1.128 Y-0.907
N20250 X-1.1272 Y-0.9249
N20255 X-1.1266 Y-0.9607
N20260 X-1.1267 Y-0.9965
N20265 X-1.1278 Y-1.2591
N20270 X-1.1279 Y-1.2931
N20275 X-1.1284 Y-1.3101
N20280 X-1.1292 Y-1.327
N20285 X-1.1306 Y-1.3438
N20290 X-1.1326 Y-1.3606
N20295 X-1.1379 Y-1.3941
N20300 X-1.1434 Y-1.4092
N20305 X-1.1466 Y-1.4165
N20310 X-1.1504 Y-1.4234
N20315 X-1.1549 Y-1.4298
N20320 X-1.16 Y-1.4358
N20325 X-1.1712 Y-1.4473
N20330 X-1.1847 Y-1.4563
N20335 X-1.1917 Y-1.4604
N20340 X-1.1989 Y-1.464
N20345 X-1.2063 Y-1.467
N20350 X-1.214 Y-1.4696
N20355 X-1.2297 Y-1.4739
N20360 X-1.2557 Y-1.4776
N20365 X-1.2688 Y-1.479
N20370 X-1.2819 Y-1.4801
N20375 X-1.3081 Y-1.481
N20380 X-1.3344 Y-1.4811
N20385 X-1.5804 Y-1.4801
N20390 X-1.5793 Y-1.2176
N20395 Z0.1606
N20400 G0 Z0.2
N20405 X-1.3828 Y-0.8592
N20410 Z0.1606
N20415 G1 Z-0.0394 F13.123
N20420 X-1.3849 Y-1.3526 F39.37
N20425 X-1.3703 Y-1.3525
N20430 X-1.3632 Y-1.3519
N20435 X-1.3565 Y-1.3505
N20440 X-1.3501 Y-1.3482
N20445 X-1.3441 Y-1.3447
N20450 X-1.3384 Y-1.3405
N20455 X-1.3329 Y-1.3359
N20460 X-1.3272 Y-1.3134
N20465 X-1.3251 Y-1.302
N20470 X-1.3237 Y-1.2905
N20475 X-1.3229 Y-1.279
N20480 X-1.3226 Y-1.2673
N20485 X-1.3228 Y-1.244
N20490 X-1.3216 Y-0.9526
N20495 X-1.3215 Y-0.9362
N20500 X-1.3217 Y-0.9199
N20505 X-1.3228 Y-0.9035
N20510 X-1.3246 Y-0.8873
N20515 X-1.3267 Y-0.8809
N20520 X-1.3296 Y-0.8751
N20525 X-1.3317 Y-0.8726
N20530 X-1.334 Y-0.8703
N20535 X-1.3393 Y-0.8661
N20540 X-1.3498 Y-0.8626
N20545 X-1.3552 Y-0.8612
N20550 X-1.3606 Y-0.8602
N20555 X-1.3716 Y-0.8593
N20560 X-1.3828 Y-0.8592
N20565 Z0.1606
N20570 G0 Z0.2
N20575 X-1.4286 Y-2.0457
N20580 Z0.1606
N20585 G1 Z-0.0394 F13.123
N20590 X-1.4356 Y-2.0663 F39.37
N20595 X-1.4469
N20600 X-1.4674 Y-2.0714
N20605 X-1.4877 Y-2.077
N20610 X-1.5075 Y-2.0837
N20615 X-1.5171 Y-2.0876
N20620 X-1.5267 Y-2.0919
N20625 X-1.5453 Y-2.1015
N20630 X-1.5634 Y-2.1121
N20635 X-1.5991 Y-2.1349
N20640 X-1.6897 Y-2.1906
N20645 X-1.6342 Y-2.3631
N20650 X-1.6301 Y-2.3746
N20655 X-1.6278 Y-2.3802
N20660 X-1.625 Y-2.3855
N20665 X-1.6218 Y-2.3905
N20670 X-1.6181 Y-2.3952
N20675 X-1.6098 Y-2.4041
N20680 X-1.6001 Y-2.4097
N20685 X-1.595 Y-2.4121
N20690 X-1.5899 Y-2.4139
N20695 X-1.5845 Y-2.4151
N20700 X-1.579 Y-2.4158
N20705 X-1.5677 Y-2.4165
N20710 X-1.5547
N20715 X-1.5621 Y-2.4382
N20720 X-1.8088
N20725 X-1.8014 Y-2.4165
N20730 X-1.7836
N20735 X-1.7681 Y-2.4167
N20740 X-1.7607 Y-2.416
N20745 X-1.7537 Y-2.4145
N20750 X-1.7472 Y-2.4119
N20755 X-1.7413 Y-2.4079
N20760 X-1.7358 Y-2.4029
N20765 X-1.7305 Y-2.3975
N20770 X-1.7299 Y-2.3939
N20775 X-1.73 Y-2.3902
N20780 X-1.7324 Y-2.3685
N20785 X-1.7726 Y-2.2425
N20790 X-1.879 Y-2.3115
N20795 X-1.893 Y-2.3527
N20800 X-1.8968 Y-2.3649
N20805 X-1.8981 Y-2.371
N20810 X-1.8988 Y-2.377
N20815 X-1.8986 Y-2.383
N20820 X-1.8975 Y-2.3891
N20825 X-1.8937 Y-2.401
N20830 X-1.8846 Y-2.4086
N20835 X-1.8798 Y-2.4117
N20840 X-1.8746 Y-2.4139
N20845 X-1.8691 Y-2.4153
N20850 X-1.8633 Y-2.4161
N20855 X-1.8512 Y-2.4165
N20860 X-1.8342
N20865 X-1.8416 Y-2.4382
N20870 X-2.0939
N20875 X-2.0865 Y-2.4165
N20880 X-2.0703
N20885 X-2.056 Y-2.4156
N20890 X-2.0489 Y-2.4146
N20895 X-2.0421 Y-2.4131
N20900 X-2.0354 Y-2.4108
N20905 X-2.029 Y-2.4079
N20910 X-2.0164 Y-2.4009
N20915 X-2.0058 Y-2.3906
N20920 X-2.001 Y-2.3852
N20925 X-1.9967 Y-2.3793
N20930 X-1.9931 Y-2.373
N20935 X-1.9899 Y-2.3665
N20940 X-1.9843 Y-2.3527
N20945 X-1.9088 Y-2.1307
N20950 X-1.905 Y-2.1185
N20955 X-1.9037 Y-2.1124
N20960 X-1.903 Y-2.1063
N20965 X-1.9032 Y-2.1002
N20970 X-1.9043 Y-2.0942
N20975 X-1.9081 Y-2.0821
N20980 X-1.9173 Y-2.0744
N20985 X-1.9222 Y-2.0712
N20990 X-1.9275 Y-2.0689
N20995 X-1.9331 Y-2.0675
N21000 X-1.939 Y-2.0668
N21005 X-1.9512 Y-2.0663
N21010 X-1.968
N21015 X-1.961 Y-2.0457
N21020 X-1.7081
N21025 X-1.7151 Y-2.0663
N21030 X-1.7321
N21035 X-1.7463 Y-2.0673
N21040 X-1.7532 Y-2.0683
N21045 X-1.76 Y-2.0699
N21050 X-1.7665 Y-2.0722
N21055 X-1.7728 Y-2.0751
N21060 X-1.7851 Y-2.082
N21065 X-1.7958 Y-2.0924
N21070 X-1.8007 Y-2.0979
N21075 X-1.805 Y-2.1038
N21080 X-1.8087 Y-2.1102
N21085 X-1.8119 Y-2.1168
N21090 X-1.8175 Y-2.1307
N21095 X-1.8721 Y-2.2912
N21100 X-1.652 Y-2.1477
N21105 X-1.6362 Y-2.137
N21110 X-1.6287 Y-2.1311
N21115 X-1.6214 Y-2.1249
N21120 X-1.6176 Y-2.1205
N21125 X-1.6143 Y-2.1159
N21130 X-1.6116 Y-2.1109
N21135 X-1.6094 Y-2.1056
N21140 X-1.6078 Y-2.0978
N21145 X-1.6075 Y-2.094
N21150 X-1.6078 Y-2.0903
N21155 X-1.6089 Y-2.0869
N21160 X-1.6107 Y-2.0836
N21165 X-1.6154 Y-2.0772
N21170 X-1.6246 Y-2.0719
N21175 X-1.6294 Y-2.0698
N21180 X-1.6343 Y-2.0682
N21185 X-1.6395 Y-2.0672
N21190 X-1.6447 Y-2.0667
N21195 X-1.6555 Y-2.0663
N21200 X-1.67
N21205 X-1.663 Y-2.0457
N21210 X-1.4286
N21215 Z0.1606
N21220 G0 Z0.2
N21225 X-2.0839 Y-2.1018
N21230 Z0.1606
N21235 G1 Z-0.0394 F13.123
N21240 X-2.0824 Y-2.1061 F39.37
N21245 X-2.08 Y-2.1153
N21250 X-2.0798 Y-2.1239
N21255 X-2.0802 Y-2.1325
N21260 X-2.0818 Y-2.1409
N21265 X-2.0841 Y-2.1493
N21270 X-2.0903 Y-2.1613
N21275 X-2.0968 Y-2.1729
N21280 X-2.1042 Y-2.1838
N21285 X-2.1083 Y-2.1889
N21290 X-2.1127 Y-2.1936
N21295 X-2.1174 Y-2.198
N21300 X-2.1225 Y-2.2022
N21305 X-2.1333 Y-2.2098
N21310 X-2.1448 Y-2.2167
N21315 X-2.1566 Y-2.2234
N21320 X-2.1694 Y-2.2285
N21325 X-2.1824 Y-2.2331
N21330 X-2.1957 Y-2.2368
N21335 X-2.2091 Y-2.2401
N21340 X-2.2394 Y-2.246
N21345 X-2.2546 Y-2.2481
N21350 X-2.27 Y-2.2498
N21355 X-2.3008 Y-2.2511
N21360 X-2.3317 Y-2.2514
N21365 X-2.3292 Y-2.2441
N21370 X-2.3151 Y-2.2553
N21375 X-2.3002 Y-2.2655
N21380 X-2.2856 Y-2.2739
N21385 X-2.2703 Y-2.281
N21390 X-2.2512 Y-2.2876
N21395 X-2.2316 Y-2.2929
N21400 X-2.2263 Y-2.3097
N21405 X-2.2198 Y-2.3288
N21410 X-2.2151 Y-2.3431
N21415 X-2.2081 Y-2.3633
N21420 X-2.1999 Y-2.3831
N21425 X-2.1941 Y-2.3947
N21430 X-2.1906 Y-2.4002
N21435 X-2.1866 Y-2.4054
N21440 X-2.1763 Y-2.4109
N21445 X-2.171 Y-2.4131
N21450 X-2.1655 Y-2.4147
N21455 X-2.1599 Y-2.4157
N21460 X-2.1541 Y-2.4162
N21465 X-2.1423 Y-2.4165
N21470 X-2.1259
N21475 X-2.1332 Y-2.4382
N21480 X-2.2849
N21485 X-2.3533 Y-2.2514
N21490 X-2.4303
N21495 X-2.4648 Y-2.3527
N21500 X-2.4685 Y-2.3648
N21505 X-2.4699 Y-2.3709
N21510 X-2.4706 Y-2.377
N21515 X-2.4704 Y-2.383
N21520 X-2.4694 Y-2.389
N21525 X-2.4657 Y-2.401
N21530 X-2.4565 Y-2.4087
N21535 X-2.4517 Y-2.4117
N21540 X-2.4464 Y-2.414
N21545 X-2.4409 Y-2.4154
N21550 X-2.435 Y-2.4161
N21555 X-2.4229 Y-2.4165
N21560 X-2.4059
N21565 X-2.4133 Y-2.4382
N21570 X-2.6654
N21575 X-2.658 Y-2.4165
N21580 X-2.6421
N21585 X-2.6278 Y-2.4156
N21590 X-2.6208 Y-2.4147
N21595 X-2.614 Y-2.4132
N21600 X-2.6074 Y-2.4109
N21605 X-2.601 Y-2.408
N21610 X-2.5885 Y-2.4011
N21615 X-2.578 Y-2.3907
N21620 X-2.5732 Y-2.3852
N21625 X-2.5689 Y-2.3794
N21630 X-2.5653 Y-2.3731
N21635 X-2.5621 Y-2.3665
N21640 X-2.5566 Y-2.3527
N21645 X-2.4811 Y-2.1307
N21650 X-2.4773 Y-2.1185
N21655 X-2.4759 Y-2.1125
N21660 X-2.4752 Y-2.1064
N21665 X-2.4754 Y-2.1003
N21670 X-2.4764 Y-2.0943
N21675 X-2.48 Y-2.0823
N21680 X-2.4893 Y-2.0746
N21685 X-2.4942 Y-2.0716
N21690 X-2.4995 Y-2.0694
N21695 X-2.5051 Y-2.068
N21700 X-2.511 Y-2.0673
N21705 X-2.5232 Y-2.0669
N21710 X-2.5391
N21715 X-2.5319 Y-2.0457
N21720 X-2.2307
N21725 X-2.2071 Y-2.0461
N21730 X-2.1836 Y-2.0473
N21735 X-2.1719 Y-2.0486
N21740 X-2.1602 Y-2.0504
N21745 X-2.137 Y-2.0547
N21750 X-2.1247 Y-2.0587
N21755 X-2.1189 Y-2.0612
N21760 X-2.1137 Y-2.0643
N21765 X-2.1091 Y-2.0683
N21770 X-2.1052 Y-2.073
N21775 X-2.0986 Y-2.0839
N21780 X-2.0917 Y-2.0905
N21785 X-2.0887 Y-2.094
N21790 X-2.086 Y-2.0977
N21795 X-2.0839 Y-2.1018
N21800 Z0.1606
N21805 G0 Z0.2
N21810 X-2.3545 Y-2.2303
N21815 Z0.1606
N21820 G1 Z-0.0394 F13.123
N21825 X-2.3202 F39.37
N21830 X-2.304 Y-2.2298
N21835 X-2.2879 Y-2.2284
N21840 X-2.2721 Y-2.2255
N21845 X-2.2564 Y-2.2214
N21850 X-2.2443 Y-2.2165
N21855 X-2.2385 Y-2.2138
N21860 X-2.2329 Y-2.2107
N21865 X-2.2276 Y-2.2071
N21870 X-2.2225 Y-2.2032
N21875 X-2.2127 Y-2.1947
N21880 X-2.2041 Y-2.1841
N21885 X-2.2002 Y-2.1787
N21890 X-2.1966 Y-2.173
N21895 X-2.1934 Y-2.167
N21900 X-2.1906 Y-2.1609
N21905 X-2.1856 Y-2.1482
N21910 X-2.1841 Y-2.1287
N21915 X-2.1838 Y-2.1194
N21920 X-2.1841 Y-2.1105
N21925 X-2.1851 Y-2.1023
N21930 X-2.1871 Y-2.0949
N21935 X-2.1886 Y-2.0915
N21940 X-2.1903 Y-2.0884
N21945 X-2.1924 Y-2.0856
N21950 X-2.1948 Y-2.0831
N21955 X-2.2006 Y-2.0787
N21960 X-2.2074 Y-2.0753
N21965 X-2.2153 Y-2.0727
N21970 X-2.2239 Y-2.0708
N21975 X-2.2331 Y-2.0694
N21980 X-2.2428 Y-2.0683
N21985 X-2.263 Y-2.0669
N21990 X-2.3676
N21995 X-2.4231 Y-2.2303
N22000 X-2.3545
N22005 Z0.1606
N22010 G0 Z0.2
N22015 X-2.6567 Y-2.2073
N22020 Z0.1606
N22025 G1 Z-0.0394 F13.123
N22030 X-2.6582 Y-2.2162 F39.37
N22035 X-2.6602 Y-2.2251
N22040 X-2.6651 Y-2.2428
N22045 X-2.6774 Y-2.2709
N22050 X-2.6843 Y-2.2845
N22055 X-2.6921 Y-2.2976
N22060 X-2.7009 Y-2.31
N22065 X-2.7105 Y-2.3219
N22070 X-2.7311 Y-2.3447
N22075 X-2.7562 Y-2.3667
N22080 X-2.7691 Y-2.3771
N22085 X-2.7826 Y-2.3867
N22090 X-2.7966 Y-2.3955
N22095 X-2.8111 Y-2.4035
N22100 X-2.841 Y-2.4184
N22105 X-2.8717 Y-2.4296
N22110 X-2.8872 Y-2.4345
N22115 X-2.9028 Y-2.4385
N22120 X-2.9188 Y-2.4413
N22125 X-2.9349 Y-2.4432
N22130 X-2.9675 Y-2.4455
N22135 X-2.9895 Y-2.4445
N22140 X-3.0005 Y-2.4435
N22145 X-3.0113 Y-2.442
N22150 X-3.022 Y-2.4398
N22155 X-3.0326 Y-2.4369
N22160 X-3.0536 Y-2.4302
N22165 X-3.0707 Y-2.4219
N22170 X-3.0789 Y-2.4173
N22175 X-3.0868 Y-2.4122
N22180 X-3.0941 Y-2.4065
N22185 X-3.1011 Y-2.4002
N22190 X-3.1144 Y-2.3867
N22195 X-3.1247 Y-2.3716
N22200 X-3.1294 Y-2.3639
N22205 X-3.1333 Y-2.3558
N22210 X-3.1365 Y-2.3474
N22215 X-3.1391 Y-2.3388
N22220 X-3.1432 Y-2.321
N22225 X-3.1444 Y-2.3009
N22230 Y-2.2909
N22235 X-3.1437 Y-2.2811
N22240 X-3.1422 Y-2.2712
N22245 X-3.1401 Y-2.2615
N22250 X-3.1347 Y-2.2421
N22255 X-3.1223 Y-2.214
N22260 X-3.1154 Y-2.2004
N22265 X-3.1076 Y-2.1874
N22270 X-3.0988 Y-2.175
N22275 X-3.0891 Y-2.1632
N22280 X-3.0685 Y-2.1404
N22285 X-3.0433 Y-2.1183
N22290 X-3.0303 Y-2.1078
N22295 X-3.0168 Y-2.098
N22300 X-3.0027 Y-2.0891
N22305 X-2.9882 Y-2.081
N22310 X-2.9583 Y-2.0658
N22315 X-2.9281 Y-2.0544
N22320 X-2.9129 Y-2.0495
N22325 X-2.8975 Y-2.0455
N22330 X-2.8818 Y-2.0426
N22335 X-2.8659 Y-2.0406
N22340 X-2.8339 Y-2.0382
N22345 X-2.8097 Y-2.0393
N22350 X-2.7977 Y-2.0404
N22355 X-2.7859 Y-2.0421
N22360 X-2.7742 Y-2.0447
N22365 X-2.7627 Y-2.048
N22370 X-2.7398 Y-2.0558
N22375 X-2.7218 Y-2.0655
N22380 X-2.7133 Y-2.0708
N22385 X-2.7052 Y-2.0768
N22390 X-2.6978 Y-2.0836
N22395 X-2.691 Y-2.091
N22400 X-2.6782 Y-2.1069
N22405 X-2.67 Y-2.1219
N22410 X-2.6663 Y-2.1296
N22415 X-2.6633 Y-2.1375
N22420 X-2.6608 Y-2.1456
N22425 X-2.659 Y-2.1539
N22430 X-2.6561 Y-2.1708
N22435 X-2.6557 Y-2.1891
N22440 X-2.6559 Y-2.1982
N22445 X-2.6567 Y-2.2073
N22450 Z0.1606
N22455 G0 Z0.2
N22460 X-2.834 Y-2.0594
N22465 Z0.1606
N22470 G1 Z-0.0394 F13.123
N22475 X-2.846 Y-2.0601 F39.37
N22480 X-2.8579 Y-2.0615
N22485 X-2.8696 Y-2.0641
N22490 X-2.8812 Y-2.0675
N22495 X-2.8926 Y-2.0721
N22500 X-2.9036 Y-2.0774
N22505 X-2.9141 Y-2.0837
N22510 X-2.9242 Y-2.0907
N22515 X-2.935 Y-2.0998
N22520 X-2.9455 Y-2.1093
N22525 X-2.9552 Y-2.1195
N22530 X-2.9646 Y-2.1301
N22535 X-2.9741 Y-2.1423
N22540 X-2.983 Y-2.1549
N22545 X-2.9912 Y-2.1679
N22550 X-2.999 Y-2.1813
N22555 X-3.0065 Y-2.1963
N22560 X-3.0136 Y-2.2115
N22565 X-3.0198 Y-2.227
N22570 X-3.0256 Y-2.2428
N22575 X-3.0313 Y-2.2612
N22580 X-3.0362 Y-2.2799
N22585 X-3.0397 Y-2.2988
N22590 X-3.0421 Y-2.318
N22595 X-3.0426 Y-2.3326
N22600 X-3.042 Y-2.3471
N22605 X-3.041 Y-2.3542
N22610 X-3.0395 Y-2.3614
N22615 X-3.0359 Y-2.3755
N22620 X-3.0311 Y-2.3862
N22625 X-3.0283 Y-2.3912
N22630 X-3.0252 Y-2.396
N22635 X-3.0215 Y-2.4004
N22640 X-3.0174 Y-2.4044
N22645 X-3.0084 Y-2.4119
N22650 X-2.9973 Y-2.4174
N22655 X-2.9917 Y-2.4198
N22660 X-2.9858 Y-2.4216
N22665 X-2.9799 Y-2.4228
N22670 X-2.9738 Y-2.4236
N22675 X-2.9614 Y-2.4243
N22680 X-2.9417 Y-2.4224
N22685 X-2.932 Y-2.4209
N22690 X-2.9226 Y-2.4186
N22695 X-2.9134 Y-2.4153
N22700 X-2.9045 Y-2.4114
N22705 X-2.8869 Y-2.4023
N22710 X-2.8682 Y-2.3888
N22715 X-2.8593 Y-2.3816
N22720 X-2.8509 Y-2.3739
N22725 X-2.843 Y-2.3656
N22730 X-2.8355 Y-2.3569
N22735 X-2.8212 Y-2.3388
N22740 X-2.8064 Y-2.3151
N22745 X-2.7994 Y-2.3031
N22750 X-2.793 Y-2.2908
N22755 X-2.7871 Y-2.2782
N22760 X-2.7818 Y-2.2654
N22765 X-2.7719 Y-2.2393
N22770 X-2.7666 Y-2.2221
N22775 X-2.7621 Y-2.2048
N22780 X-2.759 Y-2.1872
N22785 X-2.7567 Y-2.1695
N22790 X-2.7561 Y-2.1552
N22795 X-2.7565 Y-2.141
N22800 X-2.7574 Y-2.134
N22805 X-2.7586 Y-2.127
N22810 X-2.7619 Y-2.1131
N22815 X-2.7663 Y-2.1023
N22820 X-2.7689 Y-2.0971
N22825 X-2.7718 Y-2.0922
N22830 X-2.7753 Y-2.0876
N22835 X-2.7791 Y-2.0832
N22840 X-2.7875 Y-2.0751
N22845 X-2.7924 Y-2.0716
N22850 X-2.7974 Y-2.0685
N22855 X-2.8083 Y-2.0638
N22860 X-2.8146 Y-2.062
N22865 X-2.8209 Y-2.0605
N22870 X-2.8274 Y-2.0597
N22875 X-2.834 Y-2.0594
N22880 Z0.1606
N22885 G0 Z0.2
N22890 X-3.1172 Y-2.0457
N22895 Z0.1606
N22900 G1 Z-0.0394 F13.123
N22905 X-3.1243 Y-2.0665 F39.37
N22910 X-3.1394 Y-2.068
N22915 X-3.1469 Y-2.0694
N22920 X-3.1542 Y-2.0713
N22925 X-3.1665 Y-2.0766
N22930 X-3.1781 Y-2.0832
N22935 X-3.1938 Y-2.0952
N22940 X-3.2012 Y-2.1015
N22945 X-3.2083 Y-2.1083
N22950 X-3.215 Y-2.1154
N22955 X-3.2214 Y-2.1229
N22960 X-3.2335 Y-2.1385
N22965 X-3.4595 Y-2.4466
N22970 X-3.4776
N22975 X-3.4815 Y-2.1627
N22980 X-3.6874 Y-2.4466
N22985 X-3.706
N22990 X-3.7136 Y-2.141
N22995 X-3.7141 Y-2.1262
N23000 X-3.7146 Y-2.1189
N23005 X-3.7157 Y-2.1116
N23010 X-3.7173 Y-2.1045
N23015 X-3.7195 Y-2.0976
N23020 X-3.725 Y-2.0839
N23025 X-3.732 Y-2.0764
N23030 X-3.7358 Y-2.0732
N23035 X-3.7399 Y-2.0707
N23040 X-3.7445 Y-2.0691
N23045 X-3.7493 Y-2.068
N23050 X-3.7595 Y-2.0669
N23055 X-3.7747
N23060 X-3.7675 Y-2.0457
N23065 X-3.558
N23070 X-3.5643 Y-2.0668
N23075 X-3.5744 Y-2.067
N23080 X-3.5844 Y-2.0677
N23085 X-3.5942 Y-2.0696
N23090 X-3.6039 Y-2.0723
N23095 X-3.6086 Y-2.0751
N23100 X-3.6127 Y-2.0784
N23105 X-3.6158 Y-2.0827
N23110 X-3.6183 Y-2.0876
N23115 X-3.6214 Y-2.0996
N23120 X-3.6225 Y-2.1119
N23125 X-3.6217 Y-2.3327
N23130 X-3.4859 Y-2.1445
N23135 X-3.4866 Y-2.1255
N23140 X-3.489 Y-2.1067
N23145 X-3.4906 Y-2.1008
N23150 X-3.4925 Y-2.0952
N23155 X-3.4952 Y-2.0899
N23160 X-3.4983 Y-2.0847
N23165 X-3.5012 Y-2.0804
N23170 X-3.5045 Y-2.0765
N23175 X-3.5085 Y-2.0733
N23180 X-3.5129 Y-2.0706
N23185 X-3.5196 Y-2.0687
N23190 X-3.5265 Y-2.0675
N23195 X-3.5335 Y-2.067
N23200 X-3.5405 Y-2.0669
N23205 X-3.5333 Y-2.0457
N23210 X-3.3151
N23215 X-3.3223 Y-2.0669
N23220 X-3.3382
N23225 X-3.3477 Y-2.0672
N23230 X-3.357 Y-2.0683
N23235 X-3.3661 Y-2.0707
N23240 X-3.375 Y-2.074
N23245 X-3.381 Y-2.0777
N23250 X-3.3862 Y-2.0821
N23255 X-3.3884 Y-2.0847
N23260 X-3.3902 Y-2.0876
N23265 X-3.3934 Y-2.0938
N23270 X-3.3958 Y-2.1037
N23275 X-3.3963 Y-2.1138
N23280 X-3.3942 Y-2.3327
N23285 X-3.2511 Y-2.1316
N23290 X-3.2423 Y-2.1178
N23295 X-3.2386 Y-2.1104
N23300 X-3.2354 Y-2.1029
N23305 X-3.2337 Y-2.0956
N23310 X-3.2333 Y-2.0921
N23315 X-3.2335 Y-2.0887
N23320 X-3.2345 Y-2.0855
N23325 X-3.2361 Y-2.0825
N23330 X-3.2406 Y-2.0766
N23335 X-3.2519 Y-2.0717
N23340 X-3.2576 Y-2.0698
N23345 X-3.2635 Y-2.0684
N23350 X-3.2757 Y-2.0671
N23355 X-3.288 Y-2.0668
N23360 X-3.2817 Y-2.0457
N23365 X-3.1172
N23370 Z0.1606
N23375 G0 Z0.2
N23380 X-3.9978
N23385 Z0.1606
N23390 G1 Z-0.0394 F13.123
N23395 X-4.0518 Y-2.2044 F39.37
N23400 X-4.0701
N23405 X-4.069 Y-2.1739
N23410 X-4.0693 Y-2.1587
N23415 X-4.0702 Y-2.1434
N23420 X-4.0718 Y-2.1341
N23425 X-4.074 Y-2.1249
N23430 X-4.0772 Y-2.116
N23435 X-4.0809 Y-2.1072
N23440 X-4.0853 Y-2.0995
N23445 X-4.0904 Y-2.0923
N23450 X-4.0967 Y-2.0862
N23455 X-4.1038 Y-2.0808
N23460 X-4.1226 Y-2.0745
N23465 X-4.1321 Y-2.0718
N23470 X-4.1417 Y-2.0698
N23475 X-4.1515 Y-2.0684
N23480 X-4.1613 Y-2.0676
N23485 X-4.1811 Y-2.0669
N23490 X-4.2504
N23495 X-4.3082 Y-2.237
N23500 X-4.2939
N23505 X-4.2826 Y-2.2354
N23510 X-4.2716 Y-2.2335
N23515 X-4.2609 Y-2.2308
N23520 X-4.2507 Y-2.2268
N23525 X-4.2411 Y-2.2215
N23530 X-4.232 Y-2.2152
N23535 X-4.2146 Y-2.2007
N23540 X-4.2049 Y-2.1902
N23545 X-4.1957 Y-2.1793
N23550 X-4.1876 Y-2.1676
N23555 X-4.18 Y-2.1555
N23560 X-4.1695 Y-2.136
N23565 X-4.16 Y-2.1161
N23570 X-4.1396
N23575 X-4.2285 Y-2.3774
N23580 X-4.2487
N23585 X-4.2454 Y-2.3565
N23590 X-4.2428 Y-2.3353
N23595 X-4.2421 Y-2.3212
N23600 X-4.243 Y-2.3072
N23605 X-4.2456 Y-2.296
N23610 X-4.2496 Y-2.2853
N23615 X-4.2548 Y-2.2786
N23620 X-4.2603 Y-2.2724
N23625 X-4.2662 Y-2.2671
N23630 X-4.2694 Y-2.2649
N23635 X-4.2729 Y-2.263
N23640 X-4.2803 Y-2.2604
N23645 X-4.2883 Y-2.2589
N23650 X-4.2967 Y-2.258
N23655 X-4.3052 Y-2.2576
N23660 X-4.3152
N23665 X-4.3695 Y-2.4171
N23670 X-4.3126
N23675 X-4.2873 Y-2.4162
N23680 X-4.2747 Y-2.4149
N23685 X-4.2622 Y-2.4132
N23690 X-4.2513 Y-2.411
N23695 X-4.2405 Y-2.4085
N23700 X-4.2299 Y-2.4051
N23705 X-4.2194 Y-2.4014
N23710 X-4.2093 Y-2.3968
N23715 X-4.1994 Y-2.3919
N23720 X-4.1898 Y-2.3864
N23725 X-4.1804 Y-2.3805
N23730 X-4.1642 Y-2.3686
N23735 X-4.1564 Y-2.3623
N23740 X-4.1489 Y-2.3557
N23745 X-4.1417 Y-2.3487
N23750 X-4.1349 Y-2.3413
N23755 X-4.1219 Y-2.326
N23760 X-4.1024 Y-2.2986
N23765 X-4.0843 Y-2.2702
N23770 X-4.0641
N23775 X-4.1212 Y-2.4382
N23780 X-4.5474
N23785 X-4.541 Y-2.4171
N23790 X-4.5251
N23795 X-4.5102 Y-2.4147
N23800 X-4.4958 Y-2.4116
N23805 X-4.489 Y-2.4096
N23810 X-4.4825 Y-2.4071
N23815 X-4.4765 Y-2.404
N23820 X-4.4709 Y-2.4003
N23825 X-4.4658 Y-2.3959
N23830 X-4.4612 Y-2.3909
N23835 X-4.457 Y-2.3853
N23840 X-4.4531 Y-2.3793
N23845 X-4.446 Y-2.3664
N23850 X-4.4394 Y-2.3527
N23855 X-4.3639 Y-2.1307
N23860 X-4.3601 Y-2.1185
N23865 X-4.3587 Y-2.1125
N23870 X-4.358 Y-2.1064
N23875 X-4.3581 Y-2.1003
N23880 X-4.3592 Y-2.0943
N23885 X-4.3628 Y-2.0823
N23890 X-4.3721 Y-2.0746
N23895 X-4.377 Y-2.0716
N23900 X-4.3823 Y-2.0694
N23905 X-4.3879 Y-2.068
N23910 X-4.3938 Y-2.0673
N23915 X-4.406 Y-2.0669
N23920 X-4.4219
N23925 X-4.4147 Y-2.0457
N23930 X-3.9978
N23935 Z0.1606
N23940 G0 Z0.2
N23945 X-4.4405
N23950 Z0.1606
N23955 G1 Z-0.0394 F13.123
N23960 X-4.4477 Y-2.0669 F39.37
N23965 X-4.4574
N23970 X-4.4756 Y-2.0688
N23975 X-4.4844 Y-2.0704
N23980 X-4.493 Y-2.0729
N23985 X-4.5011 Y-2.0765
N23990 X-4.5089 Y-2.0809
N23995 X-4.524 Y-2.0913
N24000 X-4.5385 Y-2.1073
N24005 X-4.5452 Y-2.1156
N24010 X-4.5511 Y-2.1245
N24015 X-4.5562 Y-2.1338
N24020 X-4.5607 Y-2.1436
N24025 X-4.5686 Y-2.1637
N24030 X-4.6633 Y-2.4421
N24035 X-4.6805
N24040 X-4.8864 Y-2.1037
N24045 X-4.9616 Y-2.3248
N24050 X-4.9656 Y-2.3372
N24055 X-4.9688 Y-2.3497
N24060 X-4.9707 Y-2.3624
N24065 X-4.9715 Y-2.3754
N24070 X-4.9698 Y-2.3842
N24075 X-4.9687 Y-2.3884
N24080 X-4.967 Y-2.3924
N24085 X-4.9647 Y-2.3961
N24090 X-4.962 Y-2.3996
N24095 X-4.9559 Y-2.4061
N24100 X-4.9492 Y-2.4094
N24105 X-4.9422 Y-2.4119
N24110 X-4.935 Y-2.4134
N24115 X-4.9276 Y-2.4145
N24120 X-4.9097 Y-2.4164
N24125 X-4.8917 Y-2.4173
N24130 X-4.8988 Y-2.4382
N24135 X-5.1092
N24140 X-5.1021 Y-2.4174
N24145 X-5.0878 Y-2.4163
N24150 X-5.0735 Y-2.4145
N24155 X-5.0596 Y-2.4112
N24160 X-5.0459 Y-2.407
N24165 X-5.0361 Y-2.4022
N24170 X-5.0269 Y-2.3966
N24175 X-5.0186 Y-2.3896
N24180 X-5.0109 Y-2.3818
N24185 X-5.0039 Y-2.3721
N24190 X-4.9976 Y-2.3619
N24195 X-4.9925 Y-2.3511
N24200 X-4.9881 Y-2.3398
N24205 X-4.9148 Y-2.1241
N24210 X-4.9126 Y-2.1165
N24215 X-4.9112 Y-2.1089
N24220 X-4.9113 Y-2.1011
N24225 X-4.9123 Y-2.0933
N24230 X-4.9152 Y-2.0872
N24235 X-4.9188 Y-2.0818
N24240 X-4.9237 Y-2.0775
N24245 X-4.9294 Y-2.0739
N24250 X-4.9381 Y-2.0706
N24255 X-4.947 Y-2.0683
N24260 X-4.9562 Y-2.0672
N24265 X-4.9656 Y-2.0669
N24270 X-4.9761
N24275 X-4.9689 Y-2.0457
N24280 X-4.8077
N24285 X-4.6439 Y-2.3205
N24290 X-4.5899 Y-2.1616
N24295 X-4.5862 Y-2.1494
N24300 X-4.5835 Y-2.137
N24305 X-4.5828 Y-2.1307
N24310 X-4.5825 Y-2.1244
N24315 X-4.5826 Y-2.1116
N24320 X-4.5848 Y-2.102
N24325 X-4.5862 Y-2.0974
N24330 X-4.5882 Y-2.0931
N24335 X-4.5908 Y-2.0891
N24340 X-4.5939 Y-2.0853
N24345 X-4.6009 Y-2.0784
N24350 X-4.608 Y-2.0738
N24355 X-4.616 Y-2.0708
N24360 X-4.6318 Y-2.068
N24365 X-4.6477 Y-2.0665
N24370 X-4.6407 Y-2.0457
N24375 X-4.4405
N24380 Z0.1606
N24385 G0 Z0.2
N24390 X-5.0111
N24395 Z0.1606
N24400 G1 Z-0.0394 F13.123
N24405 X-5.0183 Y-2.0669 F39.37
N24410 X-5.0348
N24415 X-5.0489 Y-2.0678
N24420 X-5.0559 Y-2.0687
N24425 X-5.0626 Y-2.0702
N24430 X-5.0692 Y-2.0724
N24435 X-5.0755 Y-2.0753
N24440 X-5.0879 Y-2.0822
N24445 X-5.0984 Y-2.0926
N24450 X-5.1032 Y-2.0981
N24455 X-5.1074 Y-2.104
N24460 X-5.111 Y-2.1103
N24465 X-5.1142 Y-2.1169
N24470 X-5.1197 Y-2.1307
N24475 X-5.1952 Y-2.3527
N24480 X-5.199 Y-2.3649
N24485 X-5.2004 Y-2.371
N24490 X-5.2011 Y-2.377
N24495 X-5.2009 Y-2.3831
N24500 X-5.1999 Y-2.3891
N24505 X-5.1963 Y-2.4011
N24510 X-5.1872 Y-2.4087
N24515 X-5.1823 Y-2.4118
N24520 X-5.1771 Y-2.414
N24525 X-5.1715 Y-2.4154
N24530 X-5.1657 Y-2.4161
N24535 X-5.1537 Y-2.4165
N24540 X-5.1372
N24545 X-5.1446 Y-2.4382
N24550 X-5.3961
N24555 X-5.3887 Y-2.4165
N24560 X-5.3725
N24565 X-5.3582 Y-2.4156
N24570 X-5.3512 Y-2.4147
N24575 X-5.3444 Y-2.4132
N24580 X-5.3378 Y-2.4109
N24585 X-5.3314 Y-2.408
N24590 X-5.3189 Y-2.4011
N24595 X-5.3084 Y-2.3907
N24600 X-5.3036 Y-2.3852
N24605 X-5.2993 Y-2.3794
N24610 X-5.2957 Y-2.3731
N24615 X-5.2926 Y-2.3665
N24620 X-5.287 Y-2.3527
N24625 X-5.2772 Y-2.3238
N24630 X-5.2688 Y-2.2992
N24635 X-5.2569 Y-2.264
N24640 X-5.2089 Y-2.1229
N24645 X-5.2065 Y-2.1096
N24650 X-5.2059 Y-2.1028
N24655 Y-2.096
N24660 X-5.2065 Y-2.0918
N24665 X-5.2077 Y-2.0877
N24670 X-5.2097 Y-2.084
N24675 X-5.2122 Y-2.0805
N24680 X-5.2213 Y-2.0738
N24685 X-5.2261 Y-2.0711
N24690 X-5.2312 Y-2.0691
N24695 X-5.2366 Y-2.0679
N24700 X-5.2421 Y-2.0673
N24705 X-5.2536 Y-2.0669
N24710 X-5.2698
N24715 X-5.2626 Y-2.0457
N24720 X-5.0111
N24725 Z0.1606
N24730 G0 Z0.2
N24735 X-5.4334 Y-2.4165
N24740 Z0.1606
N24745 G1 Z-0.0394 F13.123
N24750 X-5.4407 Y-2.4382 F39.37
N24755 X-5.6904
N24760 X-5.6831 Y-2.4165
N24765 X-5.6696
N24770 X-5.6553 Y-2.4156
N24775 X-5.6483 Y-2.4147
N24780 X-5.6415 Y-2.4132
N24785 X-5.6348 Y-2.4109
N24790 X-5.6284 Y-2.408
N24795 X-5.6159 Y-2.401
N24800 X-5.6054 Y-2.3907
N24805 X-5.6006 Y-2.3852
N24810 X-5.5963 Y-2.3793
N24815 X-5.5927 Y-2.3731
N24820 X-5.5896 Y-2.3664
N24825 X-5.5841 Y-2.3527
N24830 X-5.5491 Y-2.2498
N24835 X-5.7431
N24840 X-5.7781 Y-2.3527
N24845 X-5.7819 Y-2.3649
N24850 X-5.7832 Y-2.3709
N24855 X-5.7839 Y-2.377
N24860 X-5.7837 Y-2.383
N24865 X-5.7826 Y-2.389
N24870 X-5.7788 Y-2.401
N24875 X-5.7696 Y-2.4086
N24880 X-5.7648 Y-2.4117
N24885 X-5.7596 Y-2.4139
N24890 X-5.7541 Y-2.4153
N24895 X-5.7483 Y-2.4161
N24900 X-5.7362 Y-2.4165
N24905 X-5.7219
N24910 X-5.7293 Y-2.4382
N24915 X-5.9806
N24920 X-5.9732 Y-2.4165
N24925 X-5.9554
N24930 X-5.9411 Y-2.4156
N24935 X-5.9341 Y-2.4147
N24940 X-5.9273 Y-2.4132
N24945 X-5.9207 Y-2.4109
N24950 X-5.9143 Y-2.408
N24955 X-5.9018 Y-2.4011
N24960 X-5.8913 Y-2.3907
N24965 X-5.8865 Y-2.3852
N24970 X-5.8822 Y-2.3793
N24975 X-5.8786 Y-2.373
N24980 X-5.8754 Y-2.3664
N24985 X-5.8699 Y-2.3527
N24990 X-5.8575 Y-2.3161
N24995 X-5.8387 Y-2.2609
N25000 X-5.8112 Y-2.18
N25005 X-5.7913 Y-2.1216
N25010 X-5.7892 Y-2.1087
N25015 X-5.7888 Y-2.0957
N25020 X-5.7895 Y-2.0915
N25025 X-5.7906 Y-2.0875
N25030 X-5.7926 Y-2.0839
N25035 X-5.7951 Y-2.0805
N25040 X-5.8043 Y-2.0738
N25045 X-5.809 Y-2.0711
N25050 X-5.8141 Y-2.0691
N25055 X-5.8194 Y-2.0679
N25060 X-5.825 Y-2.0673
N25065 X-5.8365 Y-2.0669
N25070 X-5.8551
N25075 X-5.848 Y-2.0457
N25080 X-5.5958
N25085 X-5.603 Y-2.0669
N25090 X-5.6173
N25095 X-5.6315 Y-2.0678
N25100 X-5.6385 Y-2.0687
N25105 X-5.6453 Y-2.0703
N25110 X-5.6519 Y-2.0725
N25115 X-5.6582 Y-2.0754
N25120 X-5.6707 Y-2.0823
N25125 X-5.6812 Y-2.0927
N25130 X-5.686 Y-2.0982
N25135 X-5.6902 Y-2.104
N25140 X-5.6939 Y-2.1103
N25145 X-5.697 Y-2.1169
N25150 X-5.7026 Y-2.1307
N25155 X-5.7355 Y-2.2275
N25160 X-5.5415
N25165 X-5.5085 Y-2.1307
N25170 X-5.5047 Y-2.1185
N25175 X-5.5033 Y-2.1124
N25180 X-5.5026 Y-2.1064
N25185 X-5.5028 Y-2.1003
N25190 X-5.5038 Y-2.0943
N25195 X-5.5074 Y-2.0823
N25200 X-5.5167 Y-2.0746
N25205 X-5.5217 Y-2.0716
N25210 X-5.5269 Y-2.0694
N25215 X-5.5326 Y-2.068
N25220 X-5.5385 Y-2.0673
N25225 X-5.5507 Y-2.0669
N25230 X-5.5641
N25235 X-5.5569 Y-2.0457
N25240 X-5.3073
N25245 X-5.3144 Y-2.0669
N25250 X-5.3315
N25255 X-5.3457 Y-2.0678
N25260 X-5.3526 Y-2.0688
N25265 X-5.3594 Y-2.0703
N25270 X-5.3659 Y-2.0725
N25275 X-5.3723 Y-2.0754
N25280 X-5.3847 Y-2.0823
N25285 X-5.3953 Y-2.0927
N25290 X-5.4001 Y-2.0982
N25295 X-5.4043 Y-2.104
N25300 X-5.408 Y-2.1103
N25305 X-5.4111 Y-2.1169
N25310 X-5.4167 Y-2.1307
N25315 X-5.4922 Y-2.3527
N25320 X-5.496 Y-2.3649
N25325 X-5.4973 Y-2.371
N25330 X-5.498 Y-2.377
N25335 X-5.4978 Y-2.383
N25340 X-5.4967 Y-2.3891
N25345 X-5.4929 Y-2.401
N25350 X-5.4838 Y-2.4086
N25355 X-5.479 Y-2.4117
N25360 X-5.4738 Y-2.4139
N25365 X-5.4682 Y-2.4153
N25370 X-5.4624 Y-2.4161
N25375 X-5.4504 Y-2.4165
N25380 X-5.4334
N25385 Z0.1606
N25390 G0 Z0.2
N25395 X-6.0276 Y-2.3586
N25400 Z0.1606
N25405 G1 Z-0.0394 F13.123
N25410 X-6.0446 Y-2.3746 F39.37
N25415 X-6.0645 Y-2.3895
N25420 X-6.0847 Y-2.4037
N25425 X-6.095 Y-2.4103
N25430 X-6.1055 Y-2.4164
N25435 X-6.1162 Y-2.422
N25440 X-6.1272 Y-2.4269
N25445 X-6.1385 Y-2.431
N25450 X-6.15 Y-2.4345
N25455 X-6.1617 Y-2.4373
N25460 X-6.1737 Y-2.4397
N25465 X-6.1981 Y-2.4433
N25470 X-6.2228 Y-2.446
N25475 X-6.2498 Y-2.4442
N25480 X-6.263 Y-2.4425
N25485 X-6.276 Y-2.4397
N25490 X-6.2886 Y-2.4357
N25495 X-6.3009 Y-2.4305
N25500 X-6.325 Y-2.4183
N25505 X-6.3438 Y-2.403
N25510 X-6.3524 Y-2.3948
N25515 X-6.3601 Y-2.3859
N25520 X-6.3666 Y-2.3761
N25525 X-6.3722 Y-2.3655
N25530 X-6.3817 Y-2.3433
N25535 X-6.3843 Y-2.3304
N25540 X-6.3864 Y-2.3175
N25545 X-6.3877 Y-2.3047
N25550 X-6.3878 Y-2.2919
N25555 X-6.3866 Y-2.2792
N25560 X-6.3842 Y-2.2665
N25565 X-6.3776 Y-2.2411
N25570 X-6.3707 Y-2.2241
N25575 X-6.3629 Y-2.2075
N25580 X-6.3536 Y-2.1917
N25585 X-6.3434 Y-2.1763
N25590 X-6.3308 Y-2.1602
N25595 X-6.3175 Y-2.1447
N25600 X-6.3031 Y-2.1303
N25605 X-6.288 Y-2.1164
N25610 X-6.2727 Y-2.1043
N25615 X-6.2568 Y-2.093
N25620 X-6.2485 Y-2.0879
N25625 X-6.24 Y-2.0832
N25630 X-6.2226 Y-2.0744
N25635 X-6.1938 Y-2.0597
N25640 X-6.1791 Y-2.0533
N25645 X-6.1641 Y-2.048
N25650 X-6.1487 Y-2.0441
N25655 X-6.1329 Y-2.0415
N25660 X-6.1169 Y-2.0397
N25665 X-6.1007 Y-2.0382
N25670 X-6.0821 Y-2.0391
N25675 X-6.0637 Y-2.0418
N25680 X-6.0556 Y-2.0438
N25685 X-6.0477 Y-2.0463
N25690 X-6.0401 Y-2.0496
N25695 X-6.0327 Y-2.0533
N25700 X-6.0255 Y-2.0579
N25705 X-6.0185 Y-2.0629
N25710 X-6.0057 Y-2.0742
N25715 X-6.0015 Y-2.078
N25720 X-5.997 Y-2.0814
N25725 X-5.992 Y-2.0837
N25730 X-5.9865 Y-2.0853
N25735 X-5.9696 Y-2.0784
N25740 X-5.9617 Y-2.0742
N25745 X-5.9541 Y-2.0692
N25750 X-5.947 Y-2.0636
N25755 X-5.9402 Y-2.0575
N25760 X-5.9269 Y-2.0446
N25765 X-5.909
N25770 X-5.967 Y-2.2392
N25775 X-5.9863
N25780 X-5.9846 Y-2.2211
N25785 X-5.9837 Y-2.203
N25790 X-5.9844 Y-2.1895
N25795 X-5.9861 Y-2.1762
N25800 X-5.9894 Y-2.1596
N25805 X-5.9915 Y-2.1515
N25810 X-5.9939 Y-2.1435
N25815 X-5.9968 Y-2.1357
N25820 X-6.0002 Y-2.128
N25825 X-6.0076 Y-2.113
N25830 X-6.0159 Y-2.1009
N25835 X-6.0204 Y-2.0952
N25840 X-6.0252 Y-2.0899
N25845 X-6.0304 Y-2.085
N25850 X-6.0361 Y-2.0806
N25855 X-6.048 Y-2.0722
N25860 X-6.0612 Y-2.0662
N25865 X-6.0679 Y-2.0637
N25870 X-6.0747 Y-2.0616
N25875 X-6.0817 Y-2.0602
N25880 X-6.0887 Y-2.0593
N25885 X-6.1032 Y-2.0583
N25890 X-6.1204 Y-2.0597
N25895 X-6.1289 Y-2.061
N25900 X-6.1371 Y-2.0629
N25905 X-6.1452 Y-2.0657
N25910 X-6.153 Y-2.0692
N25915 X-6.1682 Y-2.0774
N25920 X-6.1842 Y-2.0904
N25925 X-6.1917 Y-2.0973
N25930 X-6.1987 Y-2.1047
N25935 X-6.2052 Y-2.1126
N25940 X-6.2113 Y-2.1209
N25945 X-6.2227 Y-2.1381
N25950 X-6.2367 Y-2.164
N25955 X-6.2433 Y-2.1772
N25960 X-6.2495 Y-2.1905
N25965 X-6.2552 Y-2.2041
N25970 X-6.2605 Y-2.2178
N25975 X-6.2705 Y-2.2455
N25980 X-6.2809 Y-2.2788
N25985 X-6.2853 Y-2.2956
N25990 X-6.2893 Y-2.3126
N25995 X-6.2914 Y-2.3245
N26000 X-6.293 Y-2.3366
N26005 X-6.2936 Y-2.3486
N26010 X-6.2935 Y-2.3608
N26015 X-6.2922 Y-2.3702
N26020 X-6.2902 Y-2.3793
N26025 X-6.2872 Y-2.3882
N26030 X-6.2835 Y-2.3969
N26035 X-6.2772 Y-2.4031
N26040 X-6.2704 Y-2.4085
N26045 X-6.2628 Y-2.4129
N26050 X-6.2548 Y-2.4167
N26055 X-6.2437 Y-2.4204
N26060 X-6.2325 Y-2.4231
N26065 X-6.221 Y-2.4244
N26070 X-6.2093 Y-2.4249
N26075 X-6.1968 Y-2.4244
N26080 X-6.1844 Y-2.4233
N26085 X-6.1721 Y-2.4212
N26090 X-6.1599 Y-2.4186
N26095 X-6.1474 Y-2.4148
N26100 X-6.135 Y-2.4106
N26105 X-6.1231 Y-2.4054
N26110 X-6.1113 Y-2.3997
N26115 X-6.0993 Y-2.3929
N26120 X-6.0875 Y-2.3856
N26125 X-6.0763 Y-2.3776
N26130 X-6.0653 Y-2.3692
N26135 X-6.0484 Y-2.3542
N26140 X-6.0328 Y-2.3379
N26145 X-6.0156 Y-2.3159
N26150 X-5.9998 Y-2.2929
N26155 X-5.9803
N26160 X-5.9875 Y-2.3055
N26165 X-5.9951 Y-2.3178
N26170 X-6.0033 Y-2.3298
N26175 X-6.0119 Y-2.3414
N26180 X-6.0276 Y-2.3586
N26185 Z0.1606
N26190 G0 Z0.2
N26195 X-6.4896 Y-2.4165
N26200 Z0.1606
N26205 G1 Z-0.0394 F13.123
N26210 X-6.497 Y-2.4382 F39.37
N26215 X-6.7298
N26220 X-6.7224 Y-2.4165
N26225 X-6.688
N26230 X-6.6804 Y-2.4164
N26235 X-6.6729 Y-2.4157
N26240 X-6.6656 Y-2.4141
N26245 X-6.6584 Y-2.4118
N26250 X-6.6543 Y-2.4093
N26255 X-6.6507 Y-2.4062
N26260 X-6.648 Y-2.4024
N26265 X-6.6458 Y-2.398
N26270 X-6.6441 Y-2.3897
N26275 X-6.6438 Y-2.3811
N26280 X-6.6453 Y-2.3616
N26285 X-6.6476 Y-2.3422
N26290 X-6.6481 Y-2.3371
N26295 X-6.6492 Y-2.3294
N26300 X-6.6504 Y-2.3185
N26305 X-6.8042
N26310 X-6.8219 Y-2.3404
N26315 X-6.8267 Y-2.3476
N26320 X-6.8311 Y-2.355
N26325 X-6.8349 Y-2.3627
N26330 X-6.8382 Y-2.3707
N26335 X-6.8396 Y-2.3762
N26340 X-6.8405 Y-2.3817
N26345 X-6.8403 Y-2.3873
N26350 X-6.8396 Y-2.393
N26355 X-6.8378 Y-2.3981
N26360 X-6.8354 Y-2.4028
N26365 X-6.8319 Y-2.4068
N26370 X-6.8278 Y-2.4104
N26375 X-6.8236 Y-2.413
N26380 X-6.8189 Y-2.4147
N26385 X-6.8089 Y-2.4162
N26390 X-6.7988 Y-2.4169
N26395 X-6.806 Y-2.4382
N26400 X-6.9728
N26405 X-6.9656 Y-2.4172
N26410 X-6.9492 Y-2.4149
N26415 X-6.9412 Y-2.4131
N26420 X-6.9332 Y-2.4109
N26425 X-6.9202 Y-2.4051
N26430 X-6.9079 Y-2.398
N26435 X-6.8848 Y-2.38
N26440 X-6.8737 Y-2.3704
N26445 X-6.8631 Y-2.3603
N26450 X-6.8531 Y-2.3497
N26455 X-6.8435 Y-2.3386
N26460 X-6.825 Y-2.3157
N26465 X-6.6081 Y-2.0382
N26470 X-6.5907
N26475 X-6.5511 Y-2.379
N26480 X-6.5478 Y-2.3894
N26485 X-6.5431 Y-2.3992
N26490 X-6.5403 Y-2.4033
N26495 X-6.5371 Y-2.407
N26500 X-6.5333 Y-2.4099
N26505 X-6.529 Y-2.4125
N26510 X-6.5233 Y-2.4144
N26515 X-6.5175 Y-2.4157
N26520 X-6.5116 Y-2.4163
N26525 X-6.5056 Y-2.4165
N26530 X-6.4896
N26535 Z0.1606
N26540 G0 Z0.2
N26545 X-6.6674 Y-2.1387
N26550 Z0.1606
N26555 G1 Z-0.0394 F13.123
N26560 X-6.7904 Y-2.2974 F39.37
N26565 X-6.6506
N26570 X-6.6674 Y-2.1387
N26575 Z0.1606
N26580 G0 Z0.2
N26585 X-6.8736 Y-2.0669
N26590 Z0.1606
N26595 G1 Z-0.0394 F13.123
N26600 X-6.8933 F39.37
N26605 X-6.9076 Y-2.0678
N26610 X-6.9145 Y-2.0687
N26615 X-6.9213 Y-2.0703
N26620 X-6.9279 Y-2.0725
N26625 X-6.9343 Y-2.0754
N26630 X-6.9467 Y-2.0823
N26635 X-6.9572 Y-2.0927
N26640 X-6.962 Y-2.0982
N26645 X-6.9663 Y-2.104
N26650 X-6.9699 Y-2.1103
N26655 X-6.973 Y-2.1169
N26660 X-6.9785 Y-2.1307
N26665 X-7.0541 Y-2.3527
N26670 X-7.0578 Y-2.3649
N26675 X-7.0592 Y-2.3709
N26680 X-7.0599 Y-2.377
N26685 X-7.0597 Y-2.383
N26690 X-7.0587 Y-2.389
N26695 X-7.055 Y-2.401
N26700 X-7.0459 Y-2.4087
N26705 X-7.041 Y-2.4117
N26710 X-7.0357 Y-2.414
N26715 X-7.0302 Y-2.4154
N26720 X-7.0244 Y-2.4161
N26725 X-7.0123 Y-2.4165
N26730 X-6.9925
N26735 X-6.9999 Y-2.4382
N26740 X-7.258
N26745 X-7.2506 Y-2.4165
N26750 X-7.2286
N26755 X-7.2144 Y-2.4156
N26760 X-7.2074 Y-2.4147
N26765 X-7.2006 Y-2.4131
N26770 X-7.1941 Y-2.4109
N26775 X-7.1877 Y-2.408
N26780 X-7.1753 Y-2.4011
N26785 X-7.1648 Y-2.3907
N26790 X-7.16 Y-2.3852
N26795 X-7.1557 Y-2.3794
N26800 X-7.1521 Y-2.3731
N26805 X-7.1489 Y-2.3665
N26810 X-7.1434 Y-2.3527
N26815 X-7.057 Y-2.0988
N26820 X-7.0489
N26825 X-7.3281 Y-2.4382
N26830 X-7.3446
N26835 X-7.3953 Y-2.0999
N26840 X-7.387
N26845 X-7.4688 Y-2.3404
N26850 X-7.4718 Y-2.3505
N26855 X-7.4739 Y-2.3606
N26860 X-7.4743 Y-2.3657
N26865 Y-2.3709
N26870 X-7.4737 Y-2.3813
N26875 X-7.471 Y-2.389
N26880 X-7.4694 Y-2.3927
N26885 X-7.4673 Y-2.396
N26890 X-7.4648 Y-2.399
N26895 X-7.4619 Y-2.4018
N26900 X-7.4555 Y-2.4068
N26905 X-7.4445 Y-2.4113
N26910 X-7.4389 Y-2.4132
N26915 X-7.4332 Y-2.4146
N26920 X-7.4215 Y-2.4162
N26925 X-7.4096 Y-2.4168
N26930 X-7.4169 Y-2.4382
N26935 X-7.6073
N26940 X-7.5999 Y-2.4165
N26945 X-7.5906
N26950 X-7.5742 Y-2.415
N26955 X-7.5662 Y-2.4137
N26960 X-7.5585 Y-2.4117
N26965 X-7.5511 Y-2.4088
N26970 X-7.5439 Y-2.4051
N26975 X-7.5298 Y-2.3966
N26980 X-7.5175 Y-2.385
N26985 X-7.5118 Y-2.3788
N26990 X-7.5067 Y-2.3722
N26995 X-7.5024 Y-2.3652
N27000 X-7.4986 Y-2.3577
N27005 X-7.4919 Y-2.3421
N27010 X-7.42 Y-2.1307
N27015 X-7.4162 Y-2.1185
N27020 X-7.4148 Y-2.1125
N27025 X-7.4141 Y-2.1064
N27030 X-7.4143 Y-2.1003
N27035 X-7.4153 Y-2.0943
N27040 X-7.4189 Y-2.0823
N27045 X-7.4281 Y-2.0746
N27050 X-7.4331 Y-2.0716
N27055 X-7.4384 Y-2.0694
N27060 X-7.444 Y-2.068
N27065 X-7.4499 Y-2.0673
N27070 X-7.4621 Y-2.0669
N27075 X-7.481
N27080 X-7.4738 Y-2.0457
N27085 X-7.3052
N27090 X-7.2645 Y-2.3376
N27095 X-7.0263 Y-2.0457
N27100 X-6.8664
N27105 X-6.8736 Y-2.0669
N27110 Z0.1606
N27115 G0 Z0.2
N27120 X-5.7739 Y-3.1632
N27125 Z0.1606
N27130 G1 Z-0.0394 F13.123
N27135 X-5.655 F39.37
N27140 X-5.5689 Y-3.6443
N27145 X-5.4639 Y-3.1632
N27150 X-5.3258
N27155 X-5.225 Y-3.6524
N27160 X-5.1365 Y-3.1632
N27165 X-5.02
N27170 X-5.1594 Y-3.8632
N27175 X-5.2828
N27180 X-5.3974 Y-3.3397
N27185 X-5.5111 Y-3.8632
N27190 X-5.6363
N27195 X-5.7739 Y-3.1632
N27200 Z0.1606
N27205 G0 Z0.2
N27210 X-4.8908 Y-3.6607
N27215 Z0.1606
N27220 G1 Z-0.0394 F13.123
N27225 X-4.8952 Y-3.6436 F39.37
N27230 X-4.8987 Y-3.6261
N27235 X-4.9014 Y-3.6084
N27240 X-4.9035 Y-3.5905
N27245 X-4.9051 Y-3.5724
N27250 X-4.9063 Y-3.5542
N27255 X-4.908 Y-3.5175
N27260 X-4.9072 Y-3.491
N27265 X-4.906 Y-3.4646
N27270 X-4.9039 Y-3.4384
N27275 X-4.9023 Y-3.4254
N27280 X-4.9004 Y-3.4124
N27285 X-4.8979 Y-3.3996
N27290 X-4.895 Y-3.3868
N27295 X-4.8879 Y-3.3615
N27300 X-4.8797 Y-3.3365
N27305 X-4.8709 Y-3.3115
N27310 X-4.8619 Y-3.2939
N27315 X-4.8525 Y-3.2767
N27320 X-4.8423 Y-3.26
N27325 X-4.8369 Y-3.252
N27330 X-4.8311 Y-3.2443
N27335 X-4.8249 Y-3.2369
N27340 X-4.8183 Y-3.2298
N27345 X-4.8043 Y-3.2162
N27350 X-4.7895 Y-3.2034
N27355 X-4.7743 Y-3.1909
N27360 X-4.7573 Y-3.1819
N27365 X-4.7402 Y-3.1735
N27370 X-4.7228 Y-3.1661
N27375 X-4.7139 Y-3.1629
N27380 X-4.705 Y-3.1603
N27385 X-4.6958 Y-3.1581
N27390 X-4.6866 Y-3.1563
N27395 X-4.6678 Y-3.1538
N27400 X-4.6487 Y-3.1523
N27405 X-4.6296 Y-3.1513
N27410 X-4.6004 Y-3.1544
N27415 X-4.586 Y-3.1563
N27420 X-4.5717 Y-3.1586
N27425 X-4.5578 Y-3.1614
N27430 X-4.5441 Y-3.1649
N27435 X-4.5309 Y-3.1693
N27440 X-4.5181 Y-3.1747
N27445 X-4.5058 Y-3.1811
N27450 X-4.4939 Y-3.1884
N27455 X-4.4825 Y-3.1967
N27460 X-4.4713 Y-3.2056
N27465 X-4.4605 Y-3.215
N27470 X-4.4498 Y-3.2249
N27475 X-4.4288 Y-3.2454
N27480 X-4.4103 Y-3.2761
N27485 X-4.4014 Y-3.2916
N27490 X-4.393 Y-3.3073
N27495 X-4.3851 Y-3.3231
N27500 X-4.378 Y-3.3391
N27505 X-4.3719 Y-3.3555
N27510 X-4.3668 Y-3.3721
N27515 X-4.3626 Y-3.3891
N27520 X-4.3594 Y-3.4063
N27525 X-4.3569 Y-3.4238
N27530 X-4.355 Y-3.4415
N27535 X-4.3526 Y-3.4772
N27540 X-4.3512 Y-3.5132
N27545 X-4.3528 Y-3.5503
N27550 X-4.354 Y-3.5687
N27555 X-4.3555 Y-3.587
N27560 X-4.3576 Y-3.6051
N27565 X-4.3602 Y-3.623
N27570 X-4.3637 Y-3.6407
N27575 X-4.3681 Y-3.6581
N27580 X-4.3736 Y-3.6752
N27585 X-4.3801 Y-3.6919
N27590 X-4.3876 Y-3.7083
N27595 X-4.3958 Y-3.7245
N27600 X-4.4046 Y-3.7405
N27605 X-4.4139 Y-3.7563
N27610 X-4.4333 Y-3.7878
N27615 X-4.4539 Y-3.8072
N27620 X-4.4644 Y-3.8166
N27625 X-4.475 Y-3.8255
N27630 X-4.4859 Y-3.8339
N27635 X-4.4972 Y-3.8416
N27640 X-4.5088 Y-3.8485
N27645 X-4.5208 Y-3.8544
N27650 X-4.5333 Y-3.8593
N27655 X-4.5462 Y-3.8633
N27660 X-4.5595 Y-3.8665
N27665 X-4.573 Y-3.869
N27670 X-4.5869 Y-3.871
N27675 X-4.6008 Y-3.8726
N27680 X-4.6291 Y-3.8752
N27685 X-4.6574 Y-3.8727
N27690 X-4.6714 Y-3.8711
N27695 X-4.6853 Y-3.8692
N27700 X-4.6989 Y-3.8667
N27705 X-4.7122 Y-3.8636
N27710 X-4.7252 Y-3.8597
N27715 X-4.7377 Y-3.8548
N27720 X-4.7498 Y-3.849
N27725 X-4.7615 Y-3.8422
N27730 X-4.7728 Y-3.8345
N27735 X-4.7837 Y-3.8262
N27740 X-4.7945 Y-3.8173
N27745 X-4.805 Y-3.808
N27750 X-4.8258 Y-3.7887
N27755 X-4.8451 Y-3.7577
N27760 X-4.8544 Y-3.7421
N27765 X-4.8631 Y-3.7263
N27770 X-4.8714 Y-3.7103
N27775 X-4.8788 Y-3.6941
N27780 X-4.8853 Y-3.6776
N27785 X-4.8908 Y-3.6607
N27790 Z0.1606
N27795 G0 Z0.2
N27800 X-4.7886 Y-3.5127
N27805 Z0.1606
N27810 G1 Z-0.0394 F13.123
N27815 X-4.788 Y-3.5368 F39.37
N27820 X-4.7867 Y-3.5607
N27825 X-4.7843 Y-3.5843
N27830 X-4.7824 Y-3.5959
N27835 X-4.78 Y-3.6073
N27840 X-4.777 Y-3.6186
N27845 X-4.7734 Y-3.6297
N27850 X-4.7692 Y-3.6407
N27855 X-4.7644 Y-3.6515
N27860 X-4.7539 Y-3.6728
N27865 X-4.7427 Y-3.694
N27870 X-4.7311 Y-3.7066
N27875 X-4.7192 Y-3.7187
N27880 X-4.7131 Y-3.7243
N27885 X-4.7067 Y-3.7294
N27890 X-4.7 Y-3.7341
N27895 X-4.6931 Y-3.7383
N27900 X-4.6859 Y-3.7418
N27905 X-4.6783 Y-3.7447
N27910 X-4.6705 Y-3.7471
N27915 X-4.6624 Y-3.7491
N27920 X-4.6458 Y-3.7521
N27925 X-4.6289 Y-3.7544
N27930 X-4.612 Y-3.7521
N27935 X-4.5954 Y-3.7492
N27940 X-4.5874 Y-3.7473
N27945 X-4.5796 Y-3.7449
N27950 X-4.572 Y-3.742
N27955 X-4.5648 Y-3.7386
N27960 X-4.5579 Y-3.7345
N27965 X-4.5513 Y-3.7298
N27970 X-4.545 Y-3.7247
N27975 X-4.5388 Y-3.7191
N27980 X-4.527 Y-3.7071
N27985 X-4.5155 Y-3.6944
N27990 X-4.5044 Y-3.6729
N27995 X-4.494 Y-3.6512
N28000 X-4.4893 Y-3.6401
N28005 X-4.4852 Y-3.629
N28010 X-4.4816 Y-3.6177
N28015 X-4.4787 Y-3.6062
N28020 X-4.4763 Y-3.5946
N28025 X-4.4745 Y-3.5828
N28030 X-4.4722 Y-3.5589
N28035 X-4.4711 Y-3.5347
N28040 X-4.4706 Y-3.5104
N28045 X-4.4711 Y-3.4865
N28050 X-4.4721 Y-3.4629
N28055 X-4.4744 Y-3.4395
N28060 X-4.4761 Y-3.428
N28065 X-4.4784 Y-3.4166
N28070 X-4.4813 Y-3.4054
N28075 X-4.4847 Y-3.3943
N28080 X-4.4888 Y-3.3834
N28085 X-4.4933 Y-3.3727
N28090 X-4.5034 Y-3.3514
N28095 X-4.5143 Y-3.3303
N28100 X-4.526 Y-3.3178
N28105 X-4.538 Y-3.306
N28110 X-4.5442 Y-3.3005
N28115 X-4.5507 Y-3.2954
N28120 X-4.5574 Y-3.2909
N28125 X-4.5643 Y-3.2869
N28130 X-4.5717 Y-3.2836
N28135 X-4.5793 Y-3.2808
N28140 X-4.5871 Y-3.2786
N28145 X-4.5952 Y-3.2768
N28150 X-4.6119 Y-3.2741
N28155 X-4.6289 Y-3.2721
N28160 X-4.6459 Y-3.2741
N28165 X-4.6627 Y-3.2769
N28170 X-4.6708 Y-3.2787
N28175 X-4.6787 Y-3.281
N28180 X-4.6864 Y-3.2838
N28185 X-4.6937 Y-3.2871
N28190 X-4.7007 Y-3.2911
N28195 X-4.7075 Y-3.2957
N28200 X-4.714 Y-3.3008
N28205 X-4.7203 Y-3.3063
N28210 X-4.7324 Y-3.3182
N28215 X-4.7441 Y-3.3308
N28220 X-4.7552 Y-3.3521
N28225 X-4.7655 Y-3.3736
N28230 X-4.7701 Y-3.3844
N28235 X-4.7742 Y-3.3955
N28240 X-4.7777 Y-3.4066
N28245 X-4.7806 Y-3.418
N28250 X-4.7829 Y-3.4295
N28255 X-4.7847 Y-3.4411
N28260 X-4.787 Y-3.4647
N28265 X-4.7881 Y-3.4887
N28270 X-4.7886 Y-3.5127
N28275 Z0.1606
N28280 G0 Z0.2
N28285 X-4.1833 Y-3.5132
N28290 Z0.1606
N28295 G1 Z-0.0394 F13.123
N28300 Y-3.1632 F39.37
N28305 X-3.9393
N28310 X-3.9052 Y-3.1636
N28315 X-3.8882 Y-3.1644
N28320 X-3.8714 Y-3.1661
N28325 X-3.8547 Y-3.1688
N28330 X-3.8383 Y-3.1726
N28335 X-3.8056 Y-3.1821
N28340 X-3.7855 Y-3.1947
N28345 X-3.7761 Y-3.2017
N28350 X-3.7675 Y-3.2095
N28355 X-3.7597 Y-3.2181
N28360 X-3.7527 Y-3.2275
N28365 X-3.7397 Y-3.2475
N28370 X-3.7283 Y-3.2742
N28375 X-3.7235 Y-3.2877
N28380 X-3.7197 Y-3.3016
N28385 X-3.7171 Y-3.3156
N28390 X-3.7155 Y-3.33
N28395 X-3.7139 Y-3.359
N28400 X-3.7148 Y-3.3768
N28405 X-3.7162 Y-3.3944
N28410 X-3.7186 Y-3.4117
N28415 X-3.7203 Y-3.4202
N28420 X-3.7224 Y-3.4286
N28425 X-3.725 Y-3.4368
N28430 X-3.7282 Y-3.4449
N28435 X-3.7356 Y-3.4606
N28440 X-3.7442 Y-3.476
N28445 X-3.7533 Y-3.4913
N28450 X-3.7651 Y-3.5031
N28455 X-3.7771 Y-3.5144
N28460 X-3.7897 Y-3.5246
N28465 X-3.7964 Y-3.5292
N28470 X-3.8033 Y-3.5334
N28475 X-3.8104 Y-3.537
N28480 X-3.8178 Y-3.5403
N28485 X-3.8332 Y-3.5457
N28490 X-3.8491 Y-3.5502
N28495 X-3.8653 Y-3.5543
N28500 X-3.8484 Y-3.5674
N28505 X-3.8402 Y-3.5742
N28510 X-3.8323 Y-3.5813
N28515 X-3.8248 Y-3.5888
N28520 X-3.8176 Y-3.5966
N28525 X-3.8037 Y-3.6128
N28530 X-3.7855 Y-3.6403
N28535 X-3.7767 Y-3.6542
N28540 X-3.7683 Y-3.6684
N28545 X-3.7525 Y-3.6973
N28550 X-3.7373 Y-3.7267
N28555 X-3.6676 Y-3.8632
N28560 X-3.8059
N28565 X-3.8897 Y-3.7109
N28570 X-3.9041 Y-3.6845
N28575 X-3.919 Y-3.6583
N28580 X-3.9347 Y-3.6327
N28585 X-3.9513 Y-3.6075
N28590 X-3.9587 Y-3.5989
N28595 X-3.9667 Y-3.591
N28600 X-3.9711 Y-3.5876
N28605 X-3.9758 Y-3.5845
N28610 X-3.9856 Y-3.5789
N28615 X-3.9999 Y-3.5749
N28620 X-4.0071 Y-3.5734
N28625 X-4.0143 Y-3.5722
N28630 X-4.0291 Y-3.5712
N28635 X-4.0439 Y-3.571
N28640 X-4.0678
N28645 Y-3.8632
N28650 X-4.1833
N28655 Y-3.5132
N28660 Z0.1606
N28665 G0 Z0.2
N28670 X-4.0678 Y-3.4593
N28675 Z0.1606
N28680 G1 Z-0.0394 F13.123
N28685 X-3.9818 F39.37
N28690 X-3.9566 Y-3.4594
N28695 X-3.9314 Y-3.4586
N28700 X-3.9189 Y-3.4577
N28705 X-3.9064 Y-3.4562
N28710 X-3.8815 Y-3.4523
N28715 X-3.8711 Y-3.4475
N28720 X-3.8662 Y-3.4448
N28725 X-3.8616 Y-3.4415
N28730 X-3.8575 Y-3.4378
N28735 X-3.8537 Y-3.4335
N28740 X-3.8467 Y-3.4244
N28745 X-3.8405 Y-3.4111
N28750 X-3.838 Y-3.4044
N28755 X-3.836 Y-3.3975
N28760 X-3.8348 Y-3.3904
N28765 X-3.834 Y-3.3832
N28770 X-3.8333 Y-3.3685
N28775 X-3.834 Y-3.3544
N28780 X-3.8348 Y-3.3475
N28785 X-3.8361 Y-3.3407
N28790 X-3.838 Y-3.334
N28795 X-3.8406 Y-3.3275
N28800 X-3.8467 Y-3.3148
N28805 X-3.8541 Y-3.3057
N28810 X-3.8581 Y-3.3015
N28815 X-3.8624 Y-3.2977
N28820 X-3.8671 Y-3.2945
N28825 X-3.8722 Y-3.2917
N28830 X-3.883 Y-3.2869
N28835 X-3.9064 Y-3.2838
N28840 X-3.9181 Y-3.2827
N28845 X-3.9298 Y-3.2819
N28850 X-3.9534 Y-3.2815
N28855 X-3.977 Y-3.2816
N28860 X-4.0678
N28865 Y-3.4593
N28870 Z0.1606
N28875 G0 Z0.2
N28880 X-3.5269 Y-3.4632
N28885 Z0.1606
N28890 G1 Z-0.0394 F13.123
N28895 Y-3.1632 F39.37
N28900 X-3.4114
N28905 Y-3.4748
N28910 X-3.1767 Y-3.1632
N28915 X-3.0206
N28920 X-3.237 Y-3.4361
N28925 X-3.0091 Y-3.8632
N28930 X-3.1591
N28935 X-3.3174 Y-3.5343
N28940 X-3.4114 Y-3.6517
N28945 Y-3.8632
N28950 X-3.5269
N28955 Y-3.4632
N28960 Z0.1606
N28965 G0 Z0.2
N28970 X-2.8763 Y-3.8632
N28975 Z0.1606
N28980 G1 Z-0.0394 F13.123
N28985 Y-3.1632 F39.37
N28990 X-2.7608
N28995 Y-3.8632
N29000 X-2.8763
N29005 Z0.1606
N29010 G0 Z0.2
N29015 X-2.5719
N29020 Z0.1606
N29025 G1 Z-0.0394 F13.123
N29030 Y-3.1632 F39.37
N29035 X-2.4592
N29040 X-2.2243 Y-3.6307
N29045 Y-3.1632
N29050 X-2.1164
N29055 Y-3.8632
N29060 X-2.2329
N29065 X-2.464 Y-3.4067
N29070 Y-3.8632
N29075 X-2.5719
N29080 Z0.1606
N29085 G0 Z0.2
N29090 X-1.9164 Y-3.6607
N29095 Z0.1606
N29100 G1 Z-0.0394 F13.123
N29105 X-1.9235 Y-3.6367 F39.37
N29110 X-1.9265 Y-3.6246
N29115 X-1.929 Y-3.6124
N29120 X-1.9311 Y-3.6001
N29125 X-1.9328 Y-3.5877
N29130 X-1.9351 Y-3.5627
N29135 X-1.9365 Y-3.5375
N29140 X-1.9375 Y-3.5123
N29145 X-1.9366 Y-3.4868
N29150 X-1.9352 Y-3.4614
N29155 X-1.9329 Y-3.4362
N29160 X-1.9312 Y-3.4237
N29165 X-1.9291 Y-3.4112
N29170 X-1.9265 Y-3.3989
N29175 X-1.9235 Y-3.3867
N29180 X-1.9162 Y-3.3625
N29185 X-1.9079 Y-3.3385
N29190 X-1.899 Y-3.3146
N29195 X-1.8896 Y-3.2967
N29200 X-1.8799 Y-3.2792
N29205 X-1.8693 Y-3.2622
N29210 X-1.8636 Y-3.2541
N29215 X-1.8576 Y-3.2462
N29220 X-1.8513 Y-3.2387
N29225 X-1.8445 Y-3.2314
N29230 X-1.8301 Y-3.2176
N29235 X-1.8149 Y-3.2046
N29240 X-1.7992 Y-3.1919
N29245 X-1.7821 Y-3.1827
N29250 X-1.7647 Y-3.1741
N29255 X-1.747 Y-3.1666
N29260 X-1.7381 Y-3.1634
N29265 X-1.7289 Y-3.1606
N29270 X-1.7197 Y-3.1584
N29275 X-1.7103 Y-3.1566
N29280 X-1.6912 Y-3.154
N29285 X-1.6719 Y-3.1524
N29290 X-1.6524 Y-3.1513
N29295 X-1.6301 Y-3.1525
N29300 X-1.608 Y-3.1544
N29305 X-1.5971 Y-3.1557
N29310 X-1.5863 Y-3.1575
N29315 X-1.5757 Y-3.1598
N29320 X-1.5653 Y-3.1626
N29325 X-1.5551 Y-3.1661
N29330 X-1.5451 Y-3.1703
N29335 X-1.5353 Y-3.175
N29340 X-1.5256 Y-3.1801
N29345 X-1.5066 Y-3.1915
N29350 X-1.4879 Y-3.2036
N29355 X-1.4729 Y-3.22
N29360 X-1.4585 Y-3.2369
N29365 X-1.4518 Y-3.2455
N29370 X-1.4455 Y-3.2544
N29375 X-1.4397 Y-3.2636
N29380 X-1.4345 Y-3.2731
N29385 X-1.4299 Y-3.2829
N29390 X-1.4259 Y-3.2929
N29395 X-1.4223 Y-3.3033
N29400 X-1.4191 Y-3.3138
N29405 X-1.4134 Y-3.3353
N29410 X-1.4084 Y-3.3571
N29415 X-1.523 Y-3.3833
N29420 X-1.5303 Y-3.36
N29425 X-1.5346 Y-3.3488
N29430 X-1.5399 Y-3.3381
N29435 X-1.5463 Y-3.3281
N29440 X-1.5538 Y-3.3186
N29445 X-1.5703 Y-3.3007
N29450 X-1.589 Y-3.2885
N29455 X-1.5987 Y-3.2832
N29460 X-1.6087 Y-3.279
N29465 X-1.6192 Y-3.2761
N29470 X-1.6301 Y-3.2742
N29475 X-1.6524 Y-3.2721
N29480 X-1.6699 Y-3.274
N29485 X-1.6871 Y-3.2766
N29490 X-1.6955 Y-3.2783
N29495 X-1.7037 Y-3.2805
N29500 X-1.7116 Y-3.2832
N29505 X-1.7193 Y-3.2864
N29510 X-1.7266 Y-3.2903
N29515 X-1.7337 Y-3.2949
N29520 X-1.7405 Y-3.2999
N29525 X-1.7471 Y-3.3053
N29530 X-1.7598 Y-3.3171
N29535 X-1.7723 Y-3.3296
N29540 X-1.7836 Y-3.35
N29545 X-1.7941 Y-3.3706
N29550 X-1.7988 Y-3.381
N29555 X-1.803 Y-3.3916
N29560 X-1.8067 Y-3.4023
N29565 X-1.8097 Y-3.4133
N29570 X-1.812 Y-3.4244
N29575 X-1.8139 Y-3.4356
N29580 X-1.8163 Y-3.4585
N29585 X-1.8175 Y-3.4817
N29590 X-1.8181 Y-3.5051
N29595 X-1.8174 Y-3.5307
N29600 X-1.816 Y-3.5561
N29605 X-1.8148 Y-3.5686
N29610 X-1.8133 Y-3.5811
N29615 X-1.8112 Y-3.5934
N29620 X-1.8086 Y-3.6056
N29625 X-1.8054 Y-3.6176
N29630 X-1.8014 Y-3.6294
N29635 X-1.7969 Y-3.641
N29640 X-1.7918 Y-3.6525
N29645 X-1.7805 Y-3.6751
N29650 X-1.7684 Y-3.6975
N29655 X-1.7567 Y-3.7099
N29660 X-1.7446 Y-3.7217
N29665 X-1.7383 Y-3.727
N29670 X-1.7318 Y-3.732
N29675 X-1.7251 Y-3.7365
N29680 X-1.7181 Y-3.7403
N29685 X-1.7107 Y-3.7436
N29690 X-1.703 Y-3.7462
N29695 X-1.6951 Y-3.7483
N29700 X-1.687 Y-3.75
N29705 X-1.6704 Y-3.7525
N29710 X-1.6534 Y-3.7544
N29715 X-1.6352 Y-3.7529
N29720 X-1.6262 Y-3.7517
N29725 X-1.6174 Y-3.75
N29730 X-1.6086 Y-3.7477
N29735 X-1.6 Y-3.7449
N29740 X-1.5829 Y-3.7384
N29745 X-1.5653 Y-3.7295
N29750 X-1.5567 Y-3.7248
N29755 X-1.5484 Y-3.7196
N29760 X-1.5404 Y-3.7139
N29765 X-1.5327 Y-3.7078
N29770 X-1.5178 Y-3.6949
N29775 Y-3.6063
N29780 X-1.6505
N29785 Y-3.4879
N29790 X-1.4008
N29795 Y-3.7668
N29800 X-1.4246 Y-3.7899
N29805 X-1.437 Y-3.8008
N29810 X-1.4501 Y-3.8107
N29815 X-1.4639 Y-3.8197
N29820 X-1.4782 Y-3.828
N29825 X-1.5077 Y-3.8432
N29830 X-1.5413 Y-3.8564
N29835 X-1.5583 Y-3.8621
N29840 X-1.5755 Y-3.8668
N29845 X-1.593 Y-3.8702
N29850 X-1.6108 Y-3.8724
N29855 X-1.6467 Y-3.8752
N29860 X-1.6666 Y-3.8739
N29865 X-1.6863 Y-3.8722
N29870 X-1.7057 Y-3.8695
N29875 X-1.7153 Y-3.8676
N29880 X-1.7248 Y-3.8653
N29885 X-1.7341 Y-3.8624
N29890 X-1.7432 Y-3.8591
N29895 X-1.7613 Y-3.8514
N29900 X-1.779 Y-3.8427
N29905 X-1.7966 Y-3.8334
N29910 X-1.8129 Y-3.8206
N29915 X-1.8287 Y-3.8074
N29920 X-1.8436 Y-3.7934
N29925 X-1.8506 Y-3.7861
N29930 X-1.8571 Y-3.7784
N29935 X-1.8633 Y-3.7704
N29940 X-1.8692 Y-3.7621
N29945 X-1.88 Y-3.7447
N29950 X-1.8899 Y-3.7267
N29955 X-1.8995 Y-3.7083
N29960 X-1.9082 Y-3.6846
N29965 X-1.9164 Y-3.6607
N29970 Z0.1606
N29975 G0 Z0.2
N29980 X-0.9189 Y-3.6007
N29985 Z0.1606
N29990 G1 Z-0.0394 F13.123
N29995 Y-3.1632 F39.37
N30000 X-0.7456
N30005 X-0.6412 Y-3.6412
N30010 X-0.5377 Y-3.1632
N30015 X-0.3636
N30020 Y-3.8632
N30025 X-0.4715
N30030 Y-3.3117
N30035 X-0.5859 Y-3.8632
N30040 X-0.6974
N30045 X-0.811 Y-3.3117
N30050 Y-3.8632
N30055 X-0.9189
N30060 Y-3.6007
N30065 Z0.1606
N30070 G0 Z0.2
N30075 X-0.231 Y-3.8632
N30080 Z0.1606
N30085 G1 Z-0.0394 F13.123
N30090 X-0.0075 Y-3.1632 F39.37
N30095 X0.1152
N30100 X0.3453 Y-3.8632
N30105 X0.2197
N30110 X0.1694 Y-3.7047
N30115 X-0.0604
N30120 X-0.1078 Y-3.8632
N30125 X-0.231
N30130 Z0.1606
N30135 G0 Z0.2
N30140 X0.4841
N30145 Z0.1606
N30150 G1 Z-0.0394 F13.123
N30155 Y-3.1632 F39.37
N30160 X0.5967
N30165 X0.8317 Y-3.6307
N30170 Y-3.1632
N30175 X0.9396
N30180 Y-3.8632
N30185 X0.8231
N30190 X0.592 Y-3.4067
N30195 Y-3.8632
N30200 X0.4841
N30205 Z0.1606
N30210 G0 Z0.2
N30215 X0.1321 Y-3.5863
N30220 Z0.1606
N30225 G1 Z-0.0394 F13.123
N30230 X0.0528 Y-3.3265 F39.37
N30235 X-0.0249 Y-3.5863
N30240 X0.1321
N30245 Z0.1606
N30250 G0 Z0.2
N30255 X1.1361 Y-3.412
N30260 Z0.1606
N30265 G1 Z-0.0394 F13.123
N30270 X1.1156 Y-3.2816 F39.37
N30275 Y-3.1632
N30280 X1.2354
N30285 Y-3.2816
N30290 X1.2173 Y-3.412
N30295 X1.1361
N30300 Z0.1606
N30305 G0 Z0.2
N30310 X1.4 Y-3.3824
N30315 Z0.1606
N30320 G1 Z-0.0394 F13.123
N30325 X1.3986 Y-3.3706 F39.37
N30330 X1.3971 Y-3.3469
N30335 X1.399 Y-3.3199
N30340 X1.4007 Y-3.3067
N30345 X1.4033 Y-3.2936
N30350 X1.4071 Y-3.2809
N30355 X1.4119 Y-3.2684
N30360 X1.4231 Y-3.2438
N30365 X1.4375 Y-3.2229
N30370 X1.4454 Y-3.213
N30375 X1.4539 Y-3.2039
N30380 X1.4633 Y-3.1957
N30385 X1.4735 Y-3.1882
N30390 X1.495 Y-3.1747
N30395 X1.5223 Y-3.1641
N30400 X1.5361 Y-3.1597
N30405 X1.5501 Y-3.1563
N30410 X1.5644 Y-3.154
N30415 X1.5789 Y-3.1526
N30420 X1.6082 Y-3.1513
N30425 X1.63 Y-3.1525
N30430 X1.6515 Y-3.1544
N30435 X1.6621 Y-3.1559
N30440 X1.6726 Y-3.1577
N30445 X1.6828 Y-3.1601
N30450 X1.6929 Y-3.1631
N30455 X1.7027 Y-3.1668
N30460 X1.7122 Y-3.1711
N30465 X1.7215 Y-3.176
N30470 X1.7307 Y-3.1815
N30475 X1.7486 Y-3.1934
N30480 X1.7662 Y-3.2062
N30485 X1.7796 Y-3.2235
N30490 X1.7922 Y-3.2411
N30495 X1.7979 Y-3.2501
N30500 X1.8032 Y-3.2593
N30505 X1.8079 Y-3.2688
N30510 X1.8119 Y-3.2785
N30515 X1.8152 Y-3.2885
N30520 X1.8179 Y-3.2988
N30525 X1.8201 Y-3.3092
N30530 X1.8218 Y-3.3198
N30535 X1.8245 Y-3.3414
N30540 X1.8264 Y-3.3633
N30545 X1.7103 Y-3.3695
N30550 X1.7066 Y-3.3478
N30555 X1.7041 Y-3.3372
N30560 X1.7007 Y-3.3271
N30565 X1.6961 Y-3.3174
N30570 X1.6905 Y-3.3082
N30575 X1.6841 Y-3.2994
N30580 X1.6774 Y-3.2907
N30585 X1.6609 Y-3.2804
N30590 X1.6524 Y-3.2761
N30595 X1.6435 Y-3.2729
N30600 X1.6343 Y-3.2707
N30605 X1.6248 Y-3.2694
N30610 X1.6053 Y-3.2683
N30615 X1.5861 Y-3.2692
N30620 X1.5767 Y-3.2703
N30625 X1.5675 Y-3.2721
N30630 X1.5586 Y-3.275
N30635 X1.55 Y-3.2787
N30640 X1.5332 Y-3.2878
N30645 X1.5228 Y-3.2978
N30650 X1.5183 Y-3.3032
N30655 X1.5146 Y-3.309
N30660 X1.5119 Y-3.3153
N30665 X1.5101 Y-3.3221
N30670 X1.5079 Y-3.3363
N30675 X1.5098 Y-3.3502
N30680 X1.5114 Y-3.3568
N30685 X1.5138 Y-3.363
N30690 X1.5172 Y-3.3688
N30695 X1.5213 Y-3.3742
N30700 X1.5309 Y-3.3844
N30705 X1.5558 Y-3.3985
N30710 X1.5686 Y-3.4048
N30715 X1.5817 Y-3.4104
N30720 X1.5951 Y-3.4152
N30725 X1.6088 Y-3.4196
N30730 X1.6364 Y-3.4273
N30735 X1.6694 Y-3.4374
N30740 X1.6857 Y-3.4429
N30745 X1.7017 Y-3.449
N30750 X1.7174 Y-3.456
N30755 X1.7327 Y-3.4637
N30760 X1.7627 Y-3.4806
N30765 X1.7808 Y-3.4959
N30770 X1.7893 Y-3.5041
N30775 X1.7971 Y-3.5127
N30780 X1.8041 Y-3.5221
N30785 X1.8105 Y-3.532
N30790 X1.8221 Y-3.5527
N30795 X1.8313 Y-3.5787
N30800 X1.8352 Y-3.5918
N30805 X1.8382 Y-3.6051
N30810 X1.8402 Y-3.6186
N30815 X1.8414 Y-3.6323
N30820 X1.8426 Y-3.6599
N30825 X1.841 Y-3.681
N30830 X1.8386 Y-3.7019
N30835 X1.837 Y-3.7122
N30840 X1.835 Y-3.7223
N30845 X1.8324 Y-3.7322
N30850 X1.8293 Y-3.7419
N30855 X1.8255 Y-3.7514
N30860 X1.821 Y-3.7606
N30865 X1.8161 Y-3.7697
N30870 X1.8107 Y-3.7786
N30875 X1.799 Y-3.796
N30880 X1.7865 Y-3.8131
N30885 X1.7673 Y-3.828
N30890 X1.7477 Y-3.8419
N30895 X1.7376 Y-3.8482
N30900 X1.7273 Y-3.8538
N30905 X1.7167 Y-3.8588
N30910 X1.7059 Y-3.8629
N30915 X1.6947 Y-3.8661
N30920 X1.6832 Y-3.8687
N30925 X1.6715 Y-3.8707
N30930 X1.6597 Y-3.8722
N30935 X1.6355 Y-3.8741
N30940 X1.611 Y-3.8752
N30945 X1.5863 Y-3.8704
N30950 X1.5619 Y-3.8653
N30955 X1.5382 Y-3.8596
N30960 X1.5267 Y-3.8563
N30965 X1.5155 Y-3.8528
N30970 X1.5046 Y-3.849
N30975 X1.494 Y-3.8447
N30980 X1.4839 Y-3.8401
N30985 X1.4742 Y-3.835
N30990 X1.465 Y-3.8294
N30995 X1.4563 Y-3.8232
N31000 X1.4483 Y-3.8165
N31005 X1.4408 Y-3.8091
N31010 X1.4339 Y-3.8012
N31015 X1.4275 Y-3.7926
N31020 X1.4217 Y-3.7836
N31025 X1.4163 Y-3.774
N31030 X1.4114 Y-3.764
N31035 X1.4069 Y-3.7536
N31040 X1.4028 Y-3.7428
N31045 X1.399 Y-3.7317
N31050 X1.3922 Y-3.7086
N31055 X1.3864 Y-3.6846
N31060 X1.3811 Y-3.6599
N31065 X1.3761 Y-3.635
N31070 X1.4893 Y-3.6216
N31075 X1.4951 Y-3.6483
N31080 X1.4984 Y-3.6612
N31085 X1.5021 Y-3.6738
N31090 X1.5064 Y-3.6857
N31095 X1.5114 Y-3.6968
N31100 X1.5174 Y-3.7071
N31105 X1.5244 Y-3.7163
N31110 X1.5283 Y-3.7205
N31115 X1.5325 Y-3.7244
N31120 X1.5371 Y-3.7279
N31125 X1.5419 Y-3.7312
N31130 X1.5524 Y-3.7369
N31135 X1.5637 Y-3.7418
N31140 X1.5757 Y-3.7459
N31145 X1.5883 Y-3.7495
N31150 X1.6144 Y-3.7558
N31155 X1.6369 Y-3.7542
N31160 X1.6478 Y-3.7526
N31165 X1.6584 Y-3.7499
N31170 X1.6685 Y-3.7459
N31175 X1.6782 Y-3.7407
N31180 X1.6877 Y-3.7347
N31185 X1.697 Y-3.7283
N31190 X1.7097 Y-3.7136
N31195 X1.7151 Y-3.7059
N31200 X1.7195 Y-3.6977
N31205 X1.7226 Y-3.6889
N31210 X1.7247 Y-3.6796
N31215 X1.7271 Y-3.6603
N31220 X1.7264 Y-3.6497
N31225 X1.7257 Y-3.6444
N31230 X1.7247 Y-3.6393
N31235 X1.7232 Y-3.6343
N31240 X1.7212 Y-3.6294
N31245 X1.7166 Y-3.6198
N31250 X1.7099 Y-3.6114
N31255 X1.7063 Y-3.6074
N31260 X1.7025 Y-3.6038
N31265 X1.6939 Y-3.5977
N31270 X1.6846 Y-3.5923
N31275 X1.659 Y-3.5821
N31280 X1.6331 Y-3.5728
N31285 X1.6069 Y-3.5643
N31290 X1.5805 Y-3.5563
N31295 X1.552 Y-3.5472
N31300 X1.5379 Y-3.5421
N31305 X1.5242 Y-3.5365
N31310 X1.5108 Y-3.5302
N31315 X1.4977 Y-3.5231
N31320 X1.4721 Y-3.5077
N31325 X1.4555 Y-3.4927
N31330 X1.4478 Y-3.4849
N31335 X1.4406 Y-3.4765
N31340 X1.4341 Y-3.4676
N31345 X1.4282 Y-3.4582
N31350 X1.4174 Y-3.4387
N31355 X1.4088 Y-3.4166
N31360 X1.4051 Y-3.4054
N31365 X1.4021 Y-3.394
N31370 X1.4 Y-3.3824
N31375 Z0.1606
N31380 G0 Z0.2
N31385 X2.3173 Y-3.6382
N31390 Z0.1606
N31395 G1 Z-0.0394 F13.123
N31400 Y-3.1632 F39.37
N31405 X2.7108
N31410 Y-3.2816
N31415 X2.4329
N31420 Y-3.4473
N31425 X2.6735
N31430 Y-3.5657
N31435 X2.4329
N31440 Y-3.8632
N31445 X2.3173
N31450 Y-3.6382
N31455 Z0.1606
N31460 G0 Z0.2
N31465 X2.8834 Y-3.8632
N31470 Z0.1606
N31475 G1 Z-0.0394 F13.123
N31480 Y-3.1632 F39.37
N31485 X3.1274
N31490 X3.1616 Y-3.1636
N31495 X3.1785 Y-3.1644
N31500 X3.1953 Y-3.1661
N31505 X3.212 Y-3.1688
N31510 X3.2285 Y-3.1726
N31515 X3.2611 Y-3.1821
N31520 X3.2812 Y-3.1947
N31525 X3.2906 Y-3.2017
N31530 X3.2993 Y-3.2095
N31535 X3.307 Y-3.2181
N31540 X3.3141 Y-3.2275
N31545 X3.327 Y-3.2475
N31550 X3.3385 Y-3.2742
N31555 X3.3433 Y-3.2877
N31560 X3.3471 Y-3.3016
N31565 X3.3496 Y-3.3156
N31570 X3.3512 Y-3.33
N31575 X3.3528 Y-3.359
N31580 X3.3519 Y-3.3768
N31585 X3.3506 Y-3.3944
N31590 X3.3482 Y-3.4117
N31595 X3.3465 Y-3.4202
N31600 X3.3443 Y-3.4286
N31605 X3.3417 Y-3.4368
N31610 X3.3386 Y-3.4449
N31615 X3.3311 Y-3.4606
N31620 X3.3226 Y-3.476
N31625 X3.3134 Y-3.4913
N31630 X3.3017 Y-3.5031
N31635 X3.2896 Y-3.5144
N31640 X3.277 Y-3.5246
N31645 X3.2704 Y-3.5292
N31650 X3.2635 Y-3.5334
N31655 X3.2563 Y-3.537
N31660 X3.2489 Y-3.5403
N31665 X3.2336 Y-3.5457
N31670 X3.2176 Y-3.5502
N31675 X3.2015 Y-3.5543
N31680 X3.2183 Y-3.5674
N31685 X3.2265 Y-3.5742
N31690 X3.2344 Y-3.5813
N31695 X3.2419 Y-3.5888
N31700 X3.2491 Y-3.5966
N31705 X3.263 Y-3.6128
N31710 X3.2813 Y-3.6403
N31715 X3.2901 Y-3.6542
N31720 X3.2985 Y-3.6684
N31725 X3.3143 Y-3.6973
N31730 X3.3294 Y-3.7267
N31735 X3.3991 Y-3.8632
N31740 X3.2609
N31745 X3.177 Y-3.7109
N31750 X3.1626 Y-3.6845
N31755 X3.1478 Y-3.6583
N31760 X3.132 Y-3.6327
N31765 X3.1155 Y-3.6075
N31770 X3.1081 Y-3.5989
N31775 X3.1001 Y-3.591
N31780 X3.0957 Y-3.5876
N31785 X3.091 Y-3.5845
N31790 X3.0811 Y-3.5789
N31795 X3.0669 Y-3.5749
N31800 X3.0597 Y-3.5734
N31805 X3.0524 Y-3.5722
N31810 X3.0377 Y-3.5712
N31815 X3.0229 Y-3.571
N31820 X2.999
N31825 Y-3.8632
N31830 X2.8834
N31835 Z0.1606
N31840 G0 Z0.2
N31845 X2.999 Y-3.4593
N31850 Z0.1606
N31855 G1 Z-0.0394 F13.123
N31860 X3.0849 F39.37
N31865 X3.1102 Y-3.4594
N31870 X3.1353 Y-3.4586
N31875 X3.1479 Y-3.4577
N31880 X3.1603 Y-3.4562
N31885 X3.1852 Y-3.4523
N31890 X3.1957 Y-3.4475
N31895 X3.2006 Y-3.4448
N31900 X3.2051 Y-3.4415
N31905 X3.2093 Y-3.4378
N31910 X3.2131 Y-3.4335
N31915 X3.2201 Y-3.4244
N31920 X3.2262 Y-3.4111
N31925 X3.2288 Y-3.4044
N31930 X3.2307 Y-3.3975
N31935 X3.232 Y-3.3904
N31940 X3.2328 Y-3.3832
N31945 X3.2334 Y-3.3685
N31950 X3.2327 Y-3.3544
N31955 X3.232 Y-3.3475
N31960 X3.2307 Y-3.3407
N31965 X3.2287 Y-3.334
N31970 X3.2262 Y-3.3275
N31975 X3.2201 Y-3.3148
N31980 X3.2127 Y-3.3057
N31985 X3.2087 Y-3.3015
N31990 X3.2043 Y-3.2977
N31995 X3.1996 Y-3.2945
N32000 X3.1945 Y-3.2917
N32005 X3.1838 Y-3.2869
N32010 X3.1604 Y-3.2838
N32015 X3.1487 Y-3.2827
N32020 X3.1369 Y-3.2819
N32025 X3.1133 Y-3.2815
N32030 X3.0897 Y-3.2816
N32035 X2.999
N32040 Y-3.4593
N32045 Z0.1606
N32050 G0 Z0.2
N32055 X3.535 Y-3.4632
N32060 Z0.1606
N32065 G1 Z-0.0394 F13.123
N32070 Y-3.1632 F39.37
N32075 X3.6506
N32080 Y-3.8632
N32085 X3.535
N32090 Y-3.4632
N32095 Z0.1606
N32100 G0 Z0.2
N32105 X3.8385 Y-3.8632
N32110 Z0.1606
N32115 G1 Z-0.0394 F13.123
N32120 Y-3.1632 F39.37
N32125 X4.2644
N32130 Y-3.2816
N32135 X3.9541
N32140 Y-3.4368
N32145 X4.2425
N32150 Y-3.5548
N32155 X3.9541
N32160 Y-3.7448
N32165 X4.275
N32170 Y-3.8632
N32175 X3.8385
N32180 Z0.1606
N32185 G0 Z0.2
N32190 X4.4509
N32195 Z0.1606
N32200 G1 Z-0.0394 F13.123
N32205 Y-3.1632 F39.37
N32210 X4.5636
N32215 X4.7985 Y-3.6307
N32220 Y-3.1632
N32225 X4.9065
N32230 Y-3.8632
N32235 X4.79
N32240 X4.5589 Y-3.4067
N32245 Y-3.8632
N32250 X4.4509
N32255 Z0.1606
N32260 G0 Z0.2
N32265 X5.1044
N32270 Z0.1606
N32275 G1 Z-0.0394 F13.123
N32280 Y-3.1632 F39.37
N32285 X5.3157
N32290 X5.3466 Y-3.1638
N32295 X5.362 Y-3.1647
N32300 X5.3772 Y-3.1663
N32305 X5.3922 Y-3.1689
N32310 X5.4071 Y-3.1724
N32315 X5.4367 Y-3.1811
N32320 X5.458 Y-3.1931
N32325 X5.4682 Y-3.1996
N32330 X5.4778 Y-3.2068
N32335 X5.4869 Y-3.2148
N32340 X5.4955 Y-3.2233
N32345 X5.5118 Y-3.2415
N32350 X5.5291 Y-3.2672
N32355 X5.5371 Y-3.2804
N32360 X5.5443 Y-3.294
N32365 X5.5504 Y-3.308
N32370 X5.5559 Y-3.3224
N32375 X5.5657 Y-3.3518
N32380 X5.5747 Y-3.3935
N32385 X5.5784 Y-3.4144
N32390 X5.5813 Y-3.4354
N32395 X5.5831 Y-3.4565
N32400 X5.5843 Y-3.4778
N32405 X5.5853 Y-3.5204
N32410 X5.5841 Y-3.5604
N32415 X5.5828 Y-3.5803
N32420 X5.5808 Y-3.6001
N32425 X5.5778 Y-3.6197
N32430 X5.5739 Y-3.6393
N32435 X5.5648 Y-3.6782
N32440 X5.5551 Y-3.7064
N32445 X5.5497 Y-3.7203
N32450 X5.5437 Y-3.7338
N32455 X5.5369 Y-3.7469
N32460 X5.5293 Y-3.7596
N32465 X5.5128 Y-3.7844
N32470 X5.4962 Y-3.8023
N32475 X5.4875 Y-3.8108
N32480 X5.4783 Y-3.8185
N32485 X5.4685 Y-3.8255
N32490 X5.4581 Y-3.8318
N32495 X5.4367 Y-3.8434
N32500 X5.4088 Y-3.8525
N32505 X5.3946 Y-3.8563
N32510 X5.3804 Y-3.8592
N32515 X5.3659 Y-3.8611
N32520 X5.3514 Y-3.8622
N32525 X5.322 Y-3.8632
N32530 X5.1044
N32535 Z0.1606
N32540 G0 Z0.2
N32545 X5.22 Y-3.2816
N32550 Z0.1606
N32555 G1 Z-0.0394 F13.123
N32560 Y-3.7448 F39.37
N32565 X5.3069
N32570 X5.3275 Y-3.7446
N32575 X5.3377 Y-3.7441
N32580 X5.3479 Y-3.7432
N32585 X5.358 Y-3.7417
N32590 X5.368 Y-3.7396
N32595 X5.3878 Y-3.7343
N32600 X5.3996 Y-3.7283
N32605 X5.4052 Y-3.725
N32610 X5.4105 Y-3.7212
N32615 X5.4155 Y-3.717
N32620 X5.4201 Y-3.7124
N32625 X5.4289 Y-3.7026
N32630 X5.4379 Y-3.6868
N32635 X5.4419 Y-3.6787
N32640 X5.4454 Y-3.6704
N32645 X5.4484 Y-3.6619
N32650 X5.451 Y-3.6532
N32655 X5.4554 Y-3.6356
N32660 X5.4604 Y-3.6056
N32665 X5.4624 Y-3.5906
N32670 X5.4639 Y-3.5755
N32675 X5.4649 Y-3.5604
N32680 X5.4654 Y-3.5453
N32685 X5.4659 Y-3.5149
N32690 X5.4655 Y-3.484
N32695 X5.4649 Y-3.4686
N32700 X5.4639 Y-3.4533
N32705 X5.4624 Y-3.438
N32710 X5.4603 Y-3.4227
N32715 X5.4552 Y-3.3923
N32720 X5.4497 Y-3.3733
N32725 X5.4465 Y-3.364
N32730 X5.4427 Y-3.3549
N32735 X5.4382 Y-3.3463
N32740 X5.4331 Y-3.3379
N32745 X5.4217 Y-3.3217
N32750 X5.4098 Y-3.3103
N32755 X5.4035 Y-3.3051
N32760 X5.3968 Y-3.3005
N32765 X5.3897 Y-3.2966
N32770 X5.3822 Y-3.2933
N32775 X5.3666 Y-3.2878
N32780 X5.3432 Y-3.2845
N32785 X5.3315 Y-3.2832
N32790 X5.3197 Y-3.2824
N32795 X5.2961 Y-3.2816
N32800 X5.22
N32805 Z0.1606
N32810 G0 Z0.2
N32815 X5.2059 Y-2.4382
N32820 Z0.1606
N32825 G1 Z-0.0394 F13.123
N32830 X4.9544 F39.37
N32835 X4.9617 Y-2.4165
N32840 X4.978
N32845 X4.9922 Y-2.4156
N32850 X4.9992 Y-2.4147
N32855 X5.0061 Y-2.4132
N32860 X5.0126 Y-2.4109
N32865 X5.0191 Y-2.408
N32870 X5.0315 Y-2.4011
N32875 X5.0422 Y-2.3905
N32880 X5.047 Y-2.3849
N32885 X5.0513 Y-2.379
N32890 X5.055 Y-2.3726
N32895 X5.0581 Y-2.3659
N32900 X5.0637 Y-2.3519
N32905 X5.0761 Y-2.3256
N32910 X5.0814 Y-2.3131
N32915 X5.0861 Y-2.3004
N32920 X5.0985 Y-2.2641
N32925 X5.1098 Y-2.2292
N32930 X5.1208 Y-2.1943
N32935 X5.131 Y-2.1592
N32940 X5.1407 Y-2.1238
N32945 X5.1437 Y-2.1101
N32950 X5.1444 Y-2.1031
N32955 X5.1446 Y-2.096
N32960 X5.1439 Y-2.0918
N32965 X5.1428 Y-2.0877
N32970 X5.1407 Y-2.084
N32975 X5.1382 Y-2.0805
N32980 X5.1291 Y-2.0738
N32985 X5.1243 Y-2.0711
N32990 X5.1192 Y-2.0691
N32995 X5.1139 Y-2.0679
N33000 X5.1083 Y-2.0673
N33005 X5.0969 Y-2.0669
N33010 X5.0807
N33015 X5.0879 Y-2.0457
N33020 X5.3394
N33025 X5.3322 Y-2.0669
N33030 X5.3157
N33035 X5.3015 Y-2.0678
N33040 X5.2946 Y-2.0687
N33045 X5.2878 Y-2.0702
N33050 X5.2813 Y-2.0724
N33055 X5.2749 Y-2.0753
N33060 X5.2626 Y-2.0822
N33065 X5.252 Y-2.0926
N33070 X5.2472 Y-2.0981
N33075 X5.243 Y-2.104
N33080 X5.2394 Y-2.1103
N33085 X5.2363 Y-2.1169
N33090 X5.2308 Y-2.1307
N33095 X5.1553 Y-2.3527
N33100 X5.1515 Y-2.3649
N33105 X5.1501 Y-2.371
N33110 X5.1494 Y-2.377
N33115 X5.1495 Y-2.3831
N33120 X5.1506 Y-2.3891
N33125 X5.1542 Y-2.4011
N33130 X5.1633 Y-2.4087
N33135 X5.1681 Y-2.4118
N33140 X5.1733 Y-2.414
N33145 X5.1789 Y-2.4154
N33150 X5.1847 Y-2.4161
N33155 X5.1968 Y-2.4165
N33160 X5.2133
N33165 X5.2059 Y-2.4382
N33170 Z0.1606
N33175 G0 Z0.2
N33180 X4.9183 Y-2.4165
N33185 Z0.1606
N33190 G1 Z-0.0394 F13.123
N33195 X4.9109 Y-2.4382 F39.37
N33200 X4.6781
N33205 X4.6856 Y-2.4165
N33210 X4.72
N33215 X4.7276 Y-2.4164
N33220 X4.735 Y-2.4157
N33225 X4.7423 Y-2.4141
N33230 X4.7495 Y-2.4118
N33235 X4.7536 Y-2.4093
N33240 X4.7572 Y-2.4062
N33245 X4.76 Y-2.4024
N33250 X4.7621 Y-2.398
N33255 X4.7638 Y-2.3897
N33260 X4.7641 Y-2.3811
N33265 X4.7626 Y-2.3616
N33270 X4.7604 Y-2.3422
N33275 X4.7598 Y-2.3371
N33280 X4.7587 Y-2.3294
N33285 X4.7575 Y-2.3185
N33290 X4.6038
N33295 X4.5861 Y-2.3404
N33300 X4.5813 Y-2.3476
N33305 X4.5769 Y-2.355
N33310 X4.5731 Y-2.3627
N33315 X4.5697 Y-2.3707
N33320 X4.5683 Y-2.3762
N33325 X4.5675 Y-2.3817
N33330 X4.5676 Y-2.3873
N33335 X4.5683 Y-2.393
N33340 X4.5701 Y-2.3981
N33345 X4.5725 Y-2.4028
N33350 X4.576 Y-2.4068
N33355 X4.5801 Y-2.4104
N33360 X4.5844 Y-2.413
N33365 X4.589 Y-2.4147
N33370 X4.599 Y-2.4162
N33375 X4.6091 Y-2.4169
N33380 X4.6019 Y-2.4382
N33385 X4.4352
N33390 X4.4423 Y-2.4172
N33395 X4.4587 Y-2.4149
N33400 X4.4667 Y-2.4131
N33405 X4.4747 Y-2.4109
N33410 X4.4877 Y-2.4051
N33415 X4.5 Y-2.398
N33420 X4.5232 Y-2.38
N33425 X4.5343 Y-2.3704
N33430 X4.5448 Y-2.3603
N33435 X4.5548 Y-2.3497
N33440 X4.5644 Y-2.3386
N33445 X4.5829 Y-2.3157
N33450 X4.7998 Y-2.0382
N33455 X4.8173
N33460 X4.8568 Y-2.379
N33465 X4.8602 Y-2.3894
N33470 X4.8648 Y-2.3992
N33475 X4.8676 Y-2.4033
N33480 X4.8708 Y-2.407
N33485 X4.8746 Y-2.4099
N33490 X4.8789 Y-2.4125
N33495 X4.8846 Y-2.4144
N33500 X4.8904 Y-2.4157
N33505 X4.8964 Y-2.4163
N33510 X4.9024 Y-2.4165
N33515 X4.9183
N33520 Z0.1606
N33525 G0 Z0.2
N33530 X4.7405 Y-2.1387
N33535 Z0.1606
N33540 G1 Z-0.0394 F13.123
N33545 X4.6176 Y-2.2974 F39.37
N33550 X4.7573
N33555 X4.7405 Y-2.1387
N33560 Z0.1606
N33565 G0 Z0.2
N33570 X4.5343 Y-2.0669
N33575 Z0.1606
N33580 G1 Z-0.0394 F13.123
N33585 X4.5146 F39.37
N33590 X4.5004 Y-2.0678
N33595 X4.4934 Y-2.0687
N33600 X4.4866 Y-2.0703
N33605 X4.48 Y-2.0725
N33610 X4.4737 Y-2.0754
N33615 X4.4613 Y-2.0823
N33620 X4.4507 Y-2.0927
N33625 X4.4459 Y-2.0982
N33630 X4.4417 Y-2.104
N33635 X4.4381 Y-2.1103
N33640 X4.4349 Y-2.1169
N33645 X4.4294 Y-2.1307
N33650 X4.3539 Y-2.3527
N33655 X4.3501 Y-2.3649
N33660 X4.3487 Y-2.3709
N33665 X4.3481 Y-2.377
N33670 X4.3482 Y-2.383
N33675 X4.3493 Y-2.389
N33680 X4.353 Y-2.401
N33685 X4.3621 Y-2.4087
N33690 X4.367 Y-2.4117
N33695 X4.3722 Y-2.414
N33700 X4.3777 Y-2.4154
N33705 X4.3836 Y-2.4161
N33710 X4.3957 Y-2.4165
N33715 X4.4154
N33720 X4.408 Y-2.4382
N33725 X4.15
N33730 X4.1574 Y-2.4165
N33735 X4.1793
N33740 X4.1935 Y-2.4156
N33745 X4.2005 Y-2.4147
N33750 X4.2073 Y-2.4131
N33755 X4.2139 Y-2.4109
N33760 X4.2202 Y-2.408
N33765 X4.2326 Y-2.4011
N33770 X4.2431 Y-2.3907
N33775 X4.248 Y-2.3852
N33780 X4.2522 Y-2.3794
N33785 X4.2559 Y-2.3731
N33790 X4.259 Y-2.3665
N33795 X4.2645 Y-2.3527
N33800 X4.3509 Y-2.0988
N33805 X4.3591
N33810 X4.0798 Y-2.4382
N33815 X4.0633
N33820 X4.0126 Y-2.0999
N33825 X4.0209
N33830 X3.9391 Y-2.3404
N33835 X3.9361 Y-2.3505
N33840 X3.934 Y-2.3606
N33845 X3.9336 Y-2.3657
N33850 Y-2.3709
N33855 X3.9343 Y-2.3813
N33860 X3.9369 Y-2.389
N33865 X3.9386 Y-2.3927
N33870 X3.9406 Y-2.396
N33875 X3.9431 Y-2.399
N33880 X3.946 Y-2.4018
N33885 X3.9524 Y-2.4068
N33890 X3.9634 Y-2.4113
N33895 X3.969 Y-2.4132
N33900 X3.9747 Y-2.4146
N33905 X3.9864 Y-2.4162
N33910 X3.9983 Y-2.4168
N33915 X3.991 Y-2.4382
N33920 X3.8006
N33925 X3.808 Y-2.4165
N33930 X3.8174
N33935 X3.8337 Y-2.415
N33940 X3.8417 Y-2.4137
N33945 X3.8494 Y-2.4117
N33950 X3.8569 Y-2.4088
N33955 X3.8641 Y-2.4051
N33960 X3.8781 Y-2.3966
N33965 X3.8904 Y-2.385
N33970 X3.8961 Y-2.3788
N33975 X3.9012 Y-2.3722
N33980 X3.9056 Y-2.3652
N33985 X3.9094 Y-2.3577
N33990 X3.916 Y-2.3421
N33995 X3.9879 Y-2.1307
N34000 X3.9917 Y-2.1185
N34005 X3.9931 Y-2.1125
N34010 X3.9938 Y-2.1064
N34015 X3.9937 Y-2.1003
N34020 X3.9926 Y-2.0943
N34025 X3.9891 Y-2.0823
N34030 X3.9798 Y-2.0746
N34035 X3.9748 Y-2.0716
N34040 X3.9696 Y-2.0694
N34045 X3.9639 Y-2.068
N34050 X3.9581 Y-2.0673
N34055 X3.9459 Y-2.0669
N34060 X3.9269
N34065 X3.9341 Y-2.0457
N34070 X4.1027
N34075 X4.1434 Y-2.3376
N34080 X4.3817 Y-2.0457
N34085 X4.5415
N34090 X4.5343 Y-2.0669
N34095 Z0.1606
N34100 G0 Z0.2
N34105 X3.8265 Y-2.048
N34110 Z0.1606
N34115 G1 Z-0.0394 F13.123
N34120 X3.7696 Y-2.2236 F39.37
N34125 X3.7506
N34130 X3.7509 Y-2.1984
N34135 X3.7497 Y-2.1731
N34140 X3.7475 Y-2.159
N34145 X3.7437 Y-2.1451
N34150 X3.7357 Y-2.127
N34155 X3.7311 Y-2.1184
N34160 X3.7258 Y-2.1103
N34165 X3.7196 Y-2.1028
N34170 X3.7127 Y-2.0959
N34175 X3.6977 Y-2.083
N34180 X3.6804 Y-2.0736
N34185 X3.6716 Y-2.0696
N34190 X3.6625 Y-2.0664
N34195 X3.6532 Y-2.0641
N34200 X3.6435 Y-2.0627
N34205 X3.6239 Y-2.0611
N34210 X3.6125 Y-2.0618
N34215 X3.6012 Y-2.0632
N34220 X3.5901 Y-2.0657
N34225 X3.5791 Y-2.0689
N34230 X3.5683 Y-2.0729
N34235 X3.5577 Y-2.0775
N34240 X3.5478 Y-2.0832
N34245 X3.5381 Y-2.0895
N34250 X3.5231 Y-2.1027
N34255 X3.5159 Y-2.1097
N34260 X3.5092 Y-2.117
N34265 X3.503 Y-2.1247
N34270 X3.4972 Y-2.1328
N34275 X3.4862 Y-2.1496
N34280 X3.4733 Y-2.1741
N34285 X3.4671 Y-2.1865
N34290 X3.4614 Y-2.1991
N34295 X3.4512 Y-2.2248
N34300 X3.4418 Y-2.2508
N34305 X3.4359 Y-2.2694
N34310 X3.4307 Y-2.2883
N34315 X3.427 Y-2.304
N34320 X3.4241 Y-2.3199
N34325 X3.4224 Y-2.3336
N34330 X3.4215 Y-2.3474
N34335 Y-2.3589
N34340 X3.4229 Y-2.3703
N34345 X3.4269 Y-2.3819
N34350 X3.4297 Y-2.3873
N34355 X3.4329 Y-2.3926
N34360 X3.4368 Y-2.3977
N34365 X3.4411 Y-2.4024
N34370 X3.4459 Y-2.4065
N34375 X3.451 Y-2.4103
N34380 X3.4571 Y-2.4138
N34385 X3.4634 Y-2.417
N34390 X3.47 Y-2.4194
N34395 X3.4768 Y-2.4214
N34400 X3.4926 Y-2.4241
N34405 X3.5087 Y-2.4249
N34410 X3.5205 Y-2.4244
N34415 X3.5323 Y-2.4234
N34420 X3.5439 Y-2.4215
N34425 X3.5555 Y-2.4192
N34430 X3.5667 Y-2.4162
N34435 X3.5776 Y-2.4128
N34440 X3.5883 Y-2.4084
N34445 X3.5987 Y-2.4036
N34450 X3.611 Y-2.3949
N34455 X3.6166 Y-2.3902
N34460 X3.6217 Y-2.385
N34465 X3.626 Y-2.3792
N34470 X3.6297 Y-2.3729
N34475 X3.6362 Y-2.3594
N34480 X3.6429 Y-2.3398
N34485 X3.6456 Y-2.3263
N34490 X3.6467 Y-2.3198
N34495 X3.6474 Y-2.3135
N34500 X3.6476 Y-2.3076
N34505 X3.6471 Y-2.3021
N34510 X3.6459 Y-2.2971
N34515 X3.6438 Y-2.2928
N34520 X3.6408 Y-2.2891
N34525 X3.6368 Y-2.286
N34530 X3.632 Y-2.2835
N34535 X3.6266 Y-2.2814
N34540 X3.6206 Y-2.2798
N34545 X3.6142 Y-2.2783
N34550 X3.6008 Y-2.2759
N34555 X3.5622
N34560 X3.5694 Y-2.2548
N34565 X3.8417
N34570 X3.8345 Y-2.2759
N34575 X3.8199
N34580 X3.8057 Y-2.2769
N34585 X3.7988 Y-2.2778
N34590 X3.792 Y-2.2793
N34595 X3.7854 Y-2.2816
N34600 X3.779 Y-2.2845
N34605 X3.7666 Y-2.2914
N34610 X3.7561 Y-2.3017
N34615 X3.7513 Y-2.3072
N34620 X3.7471 Y-2.3131
N34625 X3.7434 Y-2.3194
N34630 X3.7403 Y-2.326
N34635 X3.7348 Y-2.3398
N34640 X3.7024 Y-2.4349
N34645 X3.6842
N34650 X3.6808 Y-2.4304
N34655 X3.6771 Y-2.4262
N34660 X3.6728 Y-2.4225
N34665 X3.6682 Y-2.4193
N34670 X3.6635 Y-2.4176
N34675 X3.6587 Y-2.4165
N34680 X3.6488 Y-2.4158
N34685 X3.6379 Y-2.4163
N34690 X3.6272 Y-2.418
N34695 X3.6116 Y-2.4223
N34700 X3.5963 Y-2.4277
N34705 X3.5699 Y-2.4357
N34710 X3.5431 Y-2.4422
N34715 X3.5318 Y-2.4439
N34720 X3.5205 Y-2.4452
N34725 X3.4977 Y-2.446
N34730 X3.4755 Y-2.4451
N34735 X3.4645 Y-2.4442
N34740 X3.4536 Y-2.4427
N34745 X3.4429 Y-2.4405
N34750 X3.4322 Y-2.4378
N34755 X3.411 Y-2.4313
N34760 X3.3942 Y-2.4234
N34765 X3.3861 Y-2.419
N34770 X3.3784 Y-2.4141
N34775 X3.3711 Y-2.4085
N34780 X3.3643 Y-2.4024
N34785 X3.3513 Y-2.3891
N34790 X3.3413 Y-2.3744
N34795 X3.3369 Y-2.3668
N34800 X3.3332 Y-2.3589
N34805 X3.3302 Y-2.3506
N34810 X3.3278 Y-2.3421
N34815 X3.3242 Y-2.3247
N34820 X3.3234 Y-2.3044
N34825 X3.3236 Y-2.2943
N34830 X3.3244 Y-2.2842
N34835 X3.3261 Y-2.2743
N34840 X3.3284 Y-2.2644
N34845 X3.3339 Y-2.2448
N34850 X3.339 Y-2.2316
N34855 X3.3446 Y-2.2186
N34860 X3.3511 Y-2.2061
N34865 X3.3581 Y-2.1938
N34870 X3.366 Y-2.1815
N34875 X3.3745 Y-2.1696
N34880 X3.3836 Y-2.1582
N34885 X3.3932 Y-2.1471
N34890 X3.4039 Y-2.1362
N34895 X3.415 Y-2.1257
N34900 X3.4266 Y-2.1158
N34905 X3.4386 Y-2.1062
N34910 X3.4531 Y-2.0961
N34915 X3.4679 Y-2.0866
N34920 X3.4833 Y-2.0779
N34925 X3.4991 Y-2.0698
N34930 X3.5145 Y-2.063
N34935 X3.5301 Y-2.0568
N34940 X3.5461 Y-2.0516
N34945 X3.5623 Y-2.0469
N34950 X3.5774 Y-2.0436
N34955 X3.5926 Y-2.0409
N34960 X3.6079 Y-2.0395
N34965 X3.6233 Y-2.0388
N34970 X3.6371 Y-2.0393
N34975 X3.6508 Y-2.0406
N34980 X3.6643 Y-2.043
N34985 X3.6778 Y-2.0462
N34990 X3.6915 Y-2.051
N34995 X3.7049 Y-2.0564
N35000 X3.7178 Y-2.0629
N35005 X3.7305 Y-2.0699
N35010 X3.737 Y-2.0739
N35015 X3.7437 Y-2.0773
N35020 X3.7507 Y-2.0798
N35025 X3.7581 Y-2.0816
N35030 X3.7632 Y-2.0808
N35035 X3.7681 Y-2.0794
N35040 X3.7727 Y-2.0772
N35045 X3.7771 Y-2.0746
N35050 X3.7852 Y-2.0685
N35055 X3.793 Y-2.062
N35060 X3.8077 Y-2.048
N35065 X3.8265
N35070 Z0.1606
N35075 G0 Z0.2
N35080 X3.2714 Y-2.1539
N35085 Z0.1606
N35090 G1 Z-0.0394 F13.123
N35095 X3.2733 Y-2.1772 F39.37
N35100 X3.2735 Y-2.1888
N35105 X3.2729 Y-2.2003
N35110 X3.2713 Y-2.2117
N35115 X3.2688 Y-2.2231
N35120 X3.2627 Y-2.2457
N35125 X3.2514 Y-2.273
N35130 X3.2452 Y-2.2863
N35135 X3.2383 Y-2.2992
N35140 X3.2305 Y-2.3116
N35145 X3.2221 Y-2.3236
N35150 X3.2041 Y-2.3471
N35155 X3.1854 Y-2.3671
N35160 X3.1757 Y-2.3766
N35165 X3.1655 Y-2.3856
N35170 X3.1547 Y-2.3939
N35175 X3.1435 Y-2.4015
N35180 X3.1201 Y-2.4158
N35185 X3.0994 Y-2.4249
N35190 X3.0888 Y-2.4289
N35195 X3.0781 Y-2.4322
N35200 X3.0672 Y-2.4346
N35205 X3.0561 Y-2.4362
N35210 X3.0335 Y-2.4382
N35215 X3.0225 Y-2.4377
N35220 X3.0172 Y-2.437
N35225 X3.0121 Y-2.4357
N35230 X3.0073 Y-2.4336
N35235 X3.0029 Y-2.4307
N35240 X2.9945 Y-2.4237
N35245 X2.9907 Y-2.4145
N35250 X2.9893 Y-2.4098
N35255 X2.9888 Y-2.4051
N35260 X2.9889 Y-2.4003
N35265 X2.9897 Y-2.3955
N35270 X2.9923 Y-2.3857
N35275 X2.9957 Y-2.3777
N35280 X2.9995 Y-2.3699
N35285 X3.0041 Y-2.3625
N35290 X3.009 Y-2.3553
N35295 X3. Y-2.3681
N35300 X2.9906 Y-2.3805
N35305 X2.9801 Y-2.3921
N35310 X2.969 Y-2.4031
N35315 X2.9591 Y-2.4109
N35320 X2.9489 Y-2.4182
N35325 X2.9382 Y-2.4248
N35330 X2.9272 Y-2.4308
N35335 X2.9195 Y-2.4338
N35340 X2.9116 Y-2.4362
N35345 X2.9035 Y-2.4375
N35350 X2.8953 Y-2.4382
N35355 X2.8861 Y-2.4371
N35360 X2.8818 Y-2.4361
N35365 X2.8779 Y-2.4344
N35370 X2.8744 Y-2.432
N35375 X2.8713 Y-2.4289
N35380 X2.8657 Y-2.4216
N35385 X2.8628 Y-2.4096
N35390 X2.8621 Y-2.4035
N35395 Y-2.3975
N35400 X2.8629 Y-2.3915
N35405 X2.8642 Y-2.3855
N35410 X2.8679 Y-2.3735
N35415 X2.8761 Y-2.3533
N35420 X2.8806 Y-2.3433
N35425 X2.8855 Y-2.3336
N35430 X2.8909 Y-2.3242
N35435 X2.8966 Y-2.315
N35440 X2.9088 Y-2.2968
N35445 X2.9229 Y-2.2788
N35450 X2.9377 Y-2.2614
N35455 X2.9456 Y-2.2532
N35460 X2.9538 Y-2.2453
N35465 X2.9707 Y-2.2299
N35470 X2.987 Y-2.2171
N35475 X3.0038 Y-2.205
N35480 X3.0214 Y-2.1943
N35485 X3.0396 Y-2.1844
N35490 X3.0486 Y-2.1804
N35495 X3.0578 Y-2.1771
N35500 X3.0674 Y-2.1751
N35505 X3.0772 Y-2.1741
N35510 X3.0844 Y-2.1746
N35515 X3.0878 Y-2.1753
N35520 X3.0911 Y-2.1763
N35525 X3.0941 Y-2.1779
N35530 X3.0969 Y-2.1799
N35535 X3.1022 Y-2.1848
N35540 X3.105 Y-2.1922
N35545 X3.1059 Y-2.196
N35550 X3.1062 Y-2.1998
N35555 X3.1059 Y-2.2036
N35560 X3.1051 Y-2.2075
N35565 X3.1028 Y-2.2152
N35570 X3.1163 Y-2.1838
N35575 X3.1913 Y-2.1813
N35580 X3.0842 Y-2.3534
N35585 X3.0727 Y-2.3724
N35590 X3.0678 Y-2.3823
N35595 X3.0633 Y-2.3925
N35600 X3.0625 Y-2.3953
N35605 X3.0623 Y-2.3981
N35610 X3.0629 Y-2.4008
N35615 X3.064 Y-2.4034
N35620 X3.066 Y-2.4055
N35625 X3.0682 Y-2.4069
N35630 X3.0709 Y-2.4076
N35635 X3.0737 Y-2.4079
N35640 X3.087 Y-2.4051
N35645 X3.0935 Y-2.4032
N35650 X3.0998 Y-2.4009
N35655 X3.112 Y-2.3949
N35660 X3.1238 Y-2.3881
N35665 X3.1419 Y-2.3758
N35670 X3.1507 Y-2.3693
N35675 X3.159 Y-2.3623
N35680 X3.167 Y-2.3548
N35685 X3.1746 Y-2.347
N35690 X3.1892 Y-2.3306
N35695 X3.2031 Y-2.312
N35700 X3.2097 Y-2.3024
N35705 X3.2157 Y-2.2926
N35710 X3.2212 Y-2.2824
N35715 X3.226 Y-2.2718
N35720 X3.2349 Y-2.2503
N35725 X3.2391 Y-2.2355
N35730 X3.2427 Y-2.2208
N35735 X3.2451 Y-2.2062
N35740 X3.2456 Y-2.1989
N35745 X3.2457 Y-2.1917
N35750 X3.2451 Y-2.1845
N35755 X3.2439 Y-2.1773
N35760 X3.2422 Y-2.1702
N35765 X3.2401 Y-2.1632
N35770 X3.2348 Y-2.1491
N35775 X3.2288 Y-2.1351
N35780 X3.2184 Y-2.1244
N35785 X3.2076 Y-2.1144
N35790 X3.202 Y-2.1099
N35795 X3.1962 Y-2.1058
N35800 X3.1901 Y-2.1022
N35805 X3.1838 Y-2.0992
N35810 X3.1772 Y-2.0968
N35815 X3.1703 Y-2.0949
N35820 X3.1561 Y-2.0923
N35825 X3.1413 Y-2.0909
N35830 X3.1263 Y-2.09
N35835 X3.0939 Y-2.0925
N35840 X3.078 Y-2.0946
N35845 X3.0622 Y-2.0977
N35850 X3.0468 Y-2.1021
N35855 X3.0316 Y-2.1074
N35860 X3.0015 Y-2.1196
N35865 X2.9707 Y-2.1372
N35870 X2.9558 Y-2.1467
N35875 X2.9416 Y-2.157
N35880 X2.9281 Y-2.1683
N35885 X2.9152 Y-2.1804
N35890 X2.8904 Y-2.2058
N35895 X2.8683 Y-2.2338
N35900 X2.858 Y-2.2482
N35905 X2.8485 Y-2.2631
N35910 X2.8401 Y-2.2785
N35915 X2.8325 Y-2.2945
N35920 X2.8187 Y-2.3274
N35925 X2.8134 Y-2.3459
N35930 X2.8089 Y-2.3644
N35935 X2.8071 Y-2.3737
N35940 X2.8058 Y-2.3829
N35945 X2.8051 Y-2.392
N35950 X2.805 Y-2.4011
N35955 X2.8056 Y-2.4101
N35960 X2.807 Y-2.4191
N35965 X2.8091 Y-2.4281
N35970 X2.8118 Y-2.437
N35975 X2.8183 Y-2.4547
N35980 X2.8257 Y-2.4724
N35985 X2.8383 Y-2.4856
N35990 X2.8514 Y-2.4979
N35995 X2.8581 Y-2.5035
N36000 X2.8652 Y-2.5086
N36005 X2.8725 Y-2.5131
N36010 X2.8802 Y-2.5168
N36015 X2.8882 Y-2.5199
N36020 X2.8965 Y-2.5223
N36025 X2.9051 Y-2.5242
N36030 X2.9138 Y-2.5256
N36035 X2.9319 Y-2.5275
N36040 X2.9502 Y-2.5287
N36045 X2.9689 Y-2.5273
N36050 X2.9876 Y-2.5254
N36055 X3.0059 Y-2.5226
N36060 X3.0239 Y-2.5185
N36065 X3.0416 Y-2.5128
N36070 X3.0588 Y-2.5059
N36075 X3.0759 Y-2.4982
N36080 X3.0928 Y-2.49
N36085 X3.1098 Y-2.4792
N36090 X3.1266 Y-2.468
N36095 X3.1427 Y-2.4563
N36100 X3.1581 Y-2.4436
N36105 X3.1724 Y-2.4297
N36110 X3.1858 Y-2.4149
N36115 X3.1987 Y-2.3994
N36120 X3.2113 Y-2.3837
N36125 X3.2374
N36130 X3.2228 Y-2.4026
N36135 X3.2078 Y-2.4211
N36140 X3.1922 Y-2.439
N36145 X3.184 Y-2.4476
N36150 X3.1756 Y-2.4558
N36155 X3.1669 Y-2.4637
N36160 X3.1578 Y-2.4713
N36165 X3.1389 Y-2.4856
N36170 X3.1193 Y-2.4991
N36175 X3.0994 Y-2.5123
N36180 X3.0806 Y-2.5213
N36185 X3.0616 Y-2.5299
N36190 X3.0424 Y-2.5375
N36195 X3.0327 Y-2.5408
N36200 X3.0229 Y-2.5436
N36205 X3.0129 Y-2.5461
N36210 X3.0029 Y-2.5481
N36215 X2.9825 Y-2.5511
N36220 X2.9618 Y-2.5531
N36225 X2.941 Y-2.5546
N36230 X2.9192 Y-2.5532
N36235 X2.8977 Y-2.5509
N36240 X2.8873 Y-2.5492
N36245 X2.8771 Y-2.5469
N36250 X2.8672 Y-2.5441
N36255 X2.8576 Y-2.5404
N36260 X2.8485 Y-2.536
N36265 X2.8398 Y-2.5307
N36270 X2.8314 Y-2.5246
N36275 X2.8233 Y-2.518
N36280 X2.8154 Y-2.5108
N36285 X2.8077 Y-2.5033
N36290 X2.7926 Y-2.4876
N36295 X2.7837 Y-2.467
N36300 X2.7758 Y-2.4464
N36305 X2.7726 Y-2.436
N36310 X2.77 Y-2.4255
N36315 X2.7683 Y-2.415
N36320 X2.7674 Y-2.4044
N36325 Y-2.3938
N36330 X2.7682 Y-2.3831
N36335 X2.7696 Y-2.3723
N36340 X2.7716 Y-2.3615
N36345 X2.7768 Y-2.3398
N36350 X2.7829 Y-2.3181
N36355 X2.7978 Y-2.2826
N36360 X2.8061 Y-2.2654
N36365 X2.8153 Y-2.2487
N36370 X2.8256 Y-2.2327
N36375 X2.8369 Y-2.2172
N36380 X2.8609 Y-2.1872
N36385 X2.889 Y-2.1595
N36390 X2.9035 Y-2.1465
N36395 X2.9188 Y-2.1343
N36400 X2.9349 Y-2.1233
N36405 X2.9517 Y-2.1132
N36410 X2.9864 Y-2.0946
N36415 X3.0211 Y-2.0812
N36420 X3.0387 Y-2.0754
N36425 X3.0565 Y-2.0706
N36430 X3.0746 Y-2.0672
N36435 X3.0929 Y-2.0649
N36440 X3.13 Y-2.0622
N36445 X3.1554 Y-2.0635
N36450 X3.168 Y-2.0649
N36455 X3.1802 Y-2.0672
N36460 X3.1922 Y-2.0707
N36465 X3.2039 Y-2.0753
N36470 X3.2268 Y-2.0863
N36475 X3.2351 Y-2.093
N36480 X3.243 Y-2.0999
N36485 X3.2502 Y-2.1072
N36490 X3.2564 Y-2.1152
N36495 X3.2614 Y-2.1241
N36500 X3.2653 Y-2.1337
N36505 X3.2685 Y-2.1437
N36510 X3.2714 Y-2.1539
N36515 Z0.1606
N36520 G0 Z0.2
N36525 X3.0782 Y-2.2067
N36530 Z0.1606
N36535 G1 Z-0.0394 F13.123
N36540 X3.0766 Y-2.2053 F39.37
N36545 X3.0745 Y-2.2044
N36550 X3.0709 Y-2.205
N36555 X3.0674 Y-2.206
N36560 X3.061 Y-2.2093
N36565 X3.053 Y-2.2157
N36570 X3.0455 Y-2.2225
N36575 X3.0315 Y-2.2373
N36580 X3.0192 Y-2.2518
N36585 X3.0073 Y-2.2667
N36590 X2.996 Y-2.2821
N36595 X2.9852 Y-2.2978
N36600 X2.9755 Y-2.3126
N36605 X2.9665 Y-2.3277
N36610 X2.9586 Y-2.3435
N36615 X2.9516 Y-2.3597
N36620 X2.9496 Y-2.3671
N36625 X2.9495 Y-2.3708
N36630 X2.95 Y-2.3746
N36635 X2.9518 Y-2.3775
N36640 X2.9532 Y-2.3784
N36645 X2.9548 Y-2.3789
N36650 X2.962 Y-2.3766
N36655 X2.969 Y-2.3737
N36660 X2.9821 Y-2.3661
N36665 X2.9965 Y-2.3521
N36670 X3.0102 Y-2.3375
N36675 X3.0231 Y-2.3221
N36680 X3.0354 Y-2.3062
N36685 X3.0477 Y-2.2892
N36690 X3.0535 Y-2.2805
N36695 X3.0589 Y-2.2717
N36700 X3.0639 Y-2.2625
N36705 X3.0685 Y-2.2531
N36710 X3.0768 Y-2.234
N36715 X3.0787 Y-2.2283
N36720 X3.0801 Y-2.2226
N36725 X3.0805 Y-2.2168
N36730 X3.0801 Y-2.2109
N36735 X3.0793 Y-2.2086
N36740 X3.0782 Y-2.2067
N36745 Z0.1606
N36750 G0 Z0.2
N36755 X2.8608 Y-2.0669
N36760 Z0.1606
N36765 G1 Z-0.0394 F13.123
N36770 X2.8512 F39.37
N36775 X2.833 Y-2.0688
N36780 X2.8241 Y-2.0704
N36785 X2.8156 Y-2.0729
N36790 X2.8075 Y-2.0765
N36795 X2.7997 Y-2.0809
N36800 X2.7846 Y-2.0913
N36805 X2.77 Y-2.1073
N36810 X2.7634 Y-2.1156
N36815 X2.7575 Y-2.1245
N36820 X2.7524 Y-2.1338
N36825 X2.7479 Y-2.1436
N36830 X2.7399 Y-2.1637
N36835 X2.6452 Y-2.4421
N36840 X2.6281
N36845 X2.4221 Y-2.1037
N36850 X2.3469 Y-2.3248
N36855 X2.343 Y-2.3372
N36860 X2.3397 Y-2.3497
N36865 X2.3379 Y-2.3624
N36870 X2.3371 Y-2.3754
N36875 X2.3387 Y-2.3842
N36880 X2.3399 Y-2.3884
N36885 X2.3416 Y-2.3924
N36890 X2.3438 Y-2.3961
N36895 X2.3465 Y-2.3996
N36900 X2.3527 Y-2.4061
N36905 X2.3594 Y-2.4094
N36910 X2.3663 Y-2.4119
N36915 X2.3735 Y-2.4134
N36920 X2.3809 Y-2.4145
N36925 X2.3988 Y-2.4164
N36930 X2.4169 Y-2.4173
N36935 X2.4097 Y-2.4382
N36940 X2.1994
N36945 X2.2065 Y-2.4174
N36950 X2.2208 Y-2.4163
N36955 X2.235 Y-2.4145
N36960 X2.2489 Y-2.4112
N36965 X2.2626 Y-2.407
N36970 X2.2724 Y-2.4022
N36975 X2.2817 Y-2.3966
N36980 X2.2899 Y-2.3896
N36985 X2.2976 Y-2.3818
N36990 X2.3047 Y-2.3721
N36995 X2.311 Y-2.3619
N37000 X2.316 Y-2.3511
N37005 X2.3204 Y-2.3398
N37010 X2.3938 Y-2.1241
N37015 X2.396 Y-2.1165
N37020 X2.3974 Y-2.1089
N37025 X2.3973 Y-2.1011
N37030 X2.3962 Y-2.0933
N37035 X2.3934 Y-2.0872
N37040 X2.3898 Y-2.0818
N37045 X2.3848 Y-2.0775
N37050 X2.3791 Y-2.0739
N37055 X2.3704 Y-2.0706
N37060 X2.3615 Y-2.0683
N37065 X2.3523 Y-2.0672
N37070 X2.343 Y-2.0669
N37075 X2.3325
N37080 X2.3397 Y-2.0457
N37085 X2.5009
N37090 X2.6646 Y-2.3205
N37095 X2.7187 Y-2.1616
N37100 X2.7223 Y-2.1494
N37105 X2.7251 Y-2.137
N37110 X2.7258 Y-2.1307
N37115 X2.7261 Y-2.1244
N37120 X2.726 Y-2.1116
N37125 X2.7238 Y-2.102
N37130 X2.7223 Y-2.0974
N37135 X2.7204 Y-2.093
N37140 X2.7178 Y-2.0891
N37145 X2.7147 Y-2.0853
N37150 X2.7077 Y-2.0784
N37155 X2.7005 Y-2.0738
N37160 X2.6925 Y-2.0708
N37165 X2.6768 Y-2.068
N37170 X2.6608 Y-2.0665
N37175 X2.6679 Y-2.0457
N37180 X2.868
N37185 X2.8608 Y-2.0669
N37190 Z0.1606
N37195 G0 Z0.2
N37200 X2.2226 Y-2.048
N37205 Z0.1606
N37210 G1 Z-0.0394 F13.123
N37215 X2.1657 Y-2.2236 F39.37
N37220 X2.1467
N37225 X2.147 Y-2.1984
N37230 X2.1458 Y-2.1731
N37235 X2.1436 Y-2.159
N37240 X2.1398 Y-2.1451
N37245 X2.1318 Y-2.127
N37250 X2.1272 Y-2.1184
N37255 X2.1219 Y-2.1103
N37260 X2.1157 Y-2.1028
N37265 X2.1088 Y-2.0959
N37270 X2.0938 Y-2.083
N37275 X2.0765 Y-2.0736
N37280 X2.0677 Y-2.0696
N37285 X2.0586 Y-2.0664
N37290 X2.0493 Y-2.0641
N37295 X2.0396 Y-2.0627
N37300 X2.02 Y-2.0611
N37305 X2.0086 Y-2.0618
N37310 X1.9973 Y-2.0632
N37315 X1.9862 Y-2.0657
N37320 X1.9752 Y-2.0689
N37325 X1.9644 Y-2.0729
N37330 X1.9539 Y-2.0775
N37335 X1.9439 Y-2.0832
N37340 X1.9342 Y-2.0895
N37345 X1.9192 Y-2.1027
N37350 X1.912 Y-2.1097
N37355 X1.9053 Y-2.117
N37360 X1.8991 Y-2.1247
N37365 X1.8933 Y-2.1328
N37370 X1.8823 Y-2.1496
N37375 X1.8694 Y-2.1741
N37380 X1.8632 Y-2.1865
N37385 X1.8575 Y-2.1991
N37390 X1.8473 Y-2.2248
N37395 X1.8379 Y-2.2508
N37400 X1.832 Y-2.2694
N37405 X1.8268 Y-2.2883
N37410 X1.8231 Y-2.304
N37415 X1.8202 Y-2.3199
N37420 X1.8185 Y-2.3336
N37425 X1.8176 Y-2.3474
N37430 Y-2.3589
N37435 X1.819 Y-2.3703
N37440 X1.823 Y-2.3819
N37445 X1.8258 Y-2.3873
N37450 X1.829 Y-2.3926
N37455 X1.8329 Y-2.3977
N37460 X1.8372 Y-2.4024
N37465 X1.842 Y-2.4065
N37470 X1.8471 Y-2.4103
N37475 X1.8532 Y-2.4138
N37480 X1.8595 Y-2.417
N37485 X1.8661 Y-2.4194
N37490 X1.8729 Y-2.4214
N37495 X1.8887 Y-2.4241
N37500 X1.9048 Y-2.4249
N37505 X1.9166 Y-2.4244
N37510 X1.9284 Y-2.4234
N37515 X1.94 Y-2.4215
N37520 X1.9516 Y-2.4192
N37525 X1.9628 Y-2.4162
N37530 X1.9737 Y-2.4128
N37535 X1.9844 Y-2.4084
N37540 X1.9948 Y-2.4036
N37545 X2.0071 Y-2.3949
N37550 X2.0127 Y-2.3902
N37555 X2.0178 Y-2.385
N37560 X2.0221 Y-2.3792
N37565 X2.0258 Y-2.3729
N37570 X2.0323 Y-2.3594
N37575 X2.039 Y-2.3398
N37580 X2.0417 Y-2.3263
N37585 X2.0428 Y-2.3198
N37590 X2.0435 Y-2.3135
N37595 X2.0437 Y-2.3076
N37600 X2.0432 Y-2.3021
N37605 X2.042 Y-2.2971
N37610 X2.0399 Y-2.2928
N37615 X2.0369 Y-2.2891
N37620 X2.0329 Y-2.286
N37625 X2.0281 Y-2.2835
N37630 X2.0227 Y-2.2814
N37635 X2.0167 Y-2.2798
N37640 X2.0103 Y-2.2783
N37645 X1.9969 Y-2.2759
N37650 X1.9583
N37655 X1.9655 Y-2.2548
N37660 X2.2378
N37665 X2.2306 Y-2.2759
N37670 X2.216
N37675 X2.2018 Y-2.2769
N37680 X2.1949 Y-2.2778
N37685 X2.1881 Y-2.2793
N37690 X2.1815 Y-2.2816
N37695 X2.1751 Y-2.2845
N37700 X2.1627 Y-2.2914
N37705 X2.1522 Y-2.3017
N37710 X2.1474 Y-2.3072
N37715 X2.1432 Y-2.3131
N37720 X2.1395 Y-2.3194
N37725 X2.1364 Y-2.326
N37730 X2.1309 Y-2.3398
N37735 X2.0985 Y-2.4349
N37740 X2.0803
N37745 X2.0769 Y-2.4304
N37750 X2.0732 Y-2.4262
N37755 X2.0689 Y-2.4225
N37760 X2.0643 Y-2.4193
N37765 X2.0596 Y-2.4176
N37770 X2.0548 Y-2.4165
N37775 X2.0449 Y-2.4158
N37780 X2.034 Y-2.4163
N37785 X2.0233 Y-2.418
N37790 X2.0077 Y-2.4223
N37795 X1.9924 Y-2.4277
N37800 X1.966 Y-2.4357
N37805 X1.9392 Y-2.4422
N37810 X1.9279 Y-2.4439
N37815 X1.9166 Y-2.4452
N37820 X1.8938 Y-2.446
N37825 X1.8716 Y-2.4451
N37830 X1.8606 Y-2.4442
N37835 X1.8497 Y-2.4427
N37840 X1.839 Y-2.4405
N37845 X1.8283 Y-2.4378
N37850 X1.8071 Y-2.4313
N37855 X1.7903 Y-2.4234
N37860 X1.7822 Y-2.419
N37865 X1.7745 Y-2.4141
N37870 X1.7672 Y-2.4085
N37875 X1.7604 Y-2.4024
N37880 X1.7474 Y-2.3891
N37885 X1.7374 Y-2.3744
N37890 X1.733 Y-2.3668
N37895 X1.7293 Y-2.3589
N37900 X1.7263 Y-2.3506
N37905 X1.7239 Y-2.3421
N37910 X1.7203 Y-2.3247
N37915 X1.7195 Y-2.3044
N37920 X1.7197 Y-2.2943
N37925 X1.7206 Y-2.2842
N37930 X1.7222 Y-2.2743
N37935 X1.7245 Y-2.2644
N37940 X1.73 Y-2.2448
N37945 X1.7351 Y-2.2316
N37950 X1.7407 Y-2.2186
N37955 X1.7472 Y-2.2061
N37960 X1.7542 Y-2.1938
N37965 X1.7621 Y-2.1815
N37970 X1.7706 Y-2.1696
N37975 X1.7797 Y-2.1582
N37980 X1.7893 Y-2.1471
N37985 X1.8 Y-2.1362
N37990 X1.8111 Y-2.1257
N37995 X1.8227 Y-2.1158
N38000 X1.8347 Y-2.1062
N38005 X1.8492 Y-2.0961
N38010 X1.864 Y-2.0866
N38015 X1.8794 Y-2.0779
N38020 X1.8952 Y-2.0698
N38025 X1.9106 Y-2.063
N38030 X1.9262 Y-2.0568
N38035 X1.9422 Y-2.0516
N38040 X1.9584 Y-2.0469
N38045 X1.9735 Y-2.0436
N38050 X1.9887 Y-2.0409
N38055 X2.004 Y-2.0395
N38060 X2.0194 Y-2.0388
N38065 X2.0332 Y-2.0393
N38070 X2.0469 Y-2.0406
N38075 X2.0604 Y-2.043
N38080 X2.0739 Y-2.0462
N38085 X2.0876 Y-2.051
N38090 X2.101 Y-2.0564
N38095 X2.1139 Y-2.0629
N38100 X2.1266 Y-2.0699
N38105 X2.1331 Y-2.0739
N38110 X2.1398 Y-2.0773
N38115 X2.1468 Y-2.0798
N38120 X2.1542 Y-2.0816
N38125 X2.1593 Y-2.0808
N38130 X2.1642 Y-2.0794
N38135 X2.1688 Y-2.0772
N38140 X2.1732 Y-2.0746
N38145 X2.1813 Y-2.0685
N38150 X2.1891 Y-2.062
N38155 X2.2038 Y-2.048
N38160 X2.2226
N38165 Z0.1606
N38170 G0 Z0.2
N38175 X1.7271 Y-2.0457
N38180 Z0.1606
N38185 G1 Z-0.0394 F13.123
N38190 X1.7199 Y-2.0669 F39.37
N38195 X1.7034
N38200 X1.6893 Y-2.0678
N38205 X1.6823 Y-2.0687
N38210 X1.6756 Y-2.0702
N38215 X1.669 Y-2.0724
N38220 X1.6627 Y-2.0753
N38225 X1.6503 Y-2.0822
N38230 X1.6398 Y-2.0926
N38235 X1.635 Y-2.0981
N38240 X1.6308 Y-2.104
N38245 X1.6272 Y-2.1103
N38250 X1.624 Y-2.1169
N38255 X1.6185 Y-2.1307
N38260 X1.543 Y-2.3527
N38265 X1.5392 Y-2.3649
N38270 X1.5378 Y-2.371
N38275 X1.5371 Y-2.377
N38280 X1.5373 Y-2.3831
N38285 X1.5383 Y-2.3891
N38290 X1.5419 Y-2.4011
N38295 X1.551 Y-2.4087
N38300 X1.5559 Y-2.4118
N38305 X1.5611 Y-2.414
N38310 X1.5667 Y-2.4154
N38315 X1.5725 Y-2.4161
N38320 X1.5845 Y-2.4165
N38325 X1.601
N38330 X1.5936 Y-2.4382
N38335 X1.3421
N38340 X1.3495 Y-2.4165
N38345 X1.3657
N38350 X1.38 Y-2.4156
N38355 X1.387 Y-2.4147
N38360 X1.3938 Y-2.4132
N38365 X1.4004 Y-2.4109
N38370 X1.4068 Y-2.408
N38375 X1.4193 Y-2.4011
N38380 X1.4299 Y-2.3905
N38385 X1.4348 Y-2.3849
N38390 X1.439 Y-2.379
N38395 X1.4427 Y-2.3726
N38400 X1.4459 Y-2.3659
N38405 X1.4514 Y-2.3519
N38410 X1.4639 Y-2.3256
N38415 X1.4691 Y-2.3131
N38420 X1.4739 Y-2.3004
N38425 X1.4862 Y-2.2641
N38430 X1.4976 Y-2.2292
N38435 X1.5085 Y-2.1943
N38440 X1.5188 Y-2.1592
N38445 X1.5285 Y-2.1238
N38450 X1.5315 Y-2.1101
N38455 X1.5321 Y-2.1031
N38460 X1.5323 Y-2.096
N38465 X1.5317 Y-2.0918
N38470 X1.5305 Y-2.0877
N38475 X1.5285 Y-2.084
N38480 X1.526 Y-2.0805
N38485 X1.5169 Y-2.0738
N38490 X1.5121 Y-2.0711
N38495 X1.507 Y-2.0691
N38500 X1.5016 Y-2.0679
N38505 X1.4961 Y-2.0673
N38510 X1.4846 Y-2.0669
N38515 X1.4684
N38520 X1.4756 Y-2.0457
N38525 X1.7271
N38530 Z0.1606
N38535 G0 Z0.2
N38540 X1.3005 Y-2.376
N38545 Z0.1606
N38550 G1 Z-0.0394 F13.123
N38555 X1.2911 Y-2.386 F39.37
N38560 X1.2807 Y-2.395
N38565 X1.2698 Y-2.4036
N38570 X1.2556 Y-2.4131
N38575 X1.2483 Y-2.4176
N38580 X1.2408 Y-2.4217
N38585 X1.2331 Y-2.4253
N38590 X1.2252 Y-2.4286
N38595 X1.209 Y-2.4345
N38600 X1.191 Y-2.4391
N38605 X1.1819 Y-2.4411
N38610 X1.1728 Y-2.4426
N38615 X1.1543 Y-2.4444
N38620 X1.1357 Y-2.4452
N38625 X1.1233 Y-2.4449
N38630 X1.1109 Y-2.444
N38635 X1.0987 Y-2.4422
N38640 X1.0865 Y-2.4398
N38645 X1.0739 Y-2.436
N38650 X1.0615 Y-2.4315
N38655 X1.0495 Y-2.4262
N38660 X1.0377 Y-2.4204
N38665 X1.0224 Y-2.414
N38670 X1.0068 Y-2.4084
N38675 X0.9974 Y-2.4062
N38680 X0.9877 Y-2.4054
N38685 X0.9792 Y-2.4061
N38690 X0.9709 Y-2.4077
N38695 X0.963 Y-2.4107
N38700 X0.9554 Y-2.4145
N38705 X0.9473 Y-2.4208
N38710 X0.9399 Y-2.4278
N38715 X0.9338 Y-2.4359
N38720 X0.9283 Y-2.4446
N38725 X0.9085
N38730 X0.9723 Y-2.2571
N38735 X0.9925
N38740 X0.9893 Y-2.2794
N38745 X0.9885 Y-2.2904
N38750 X0.9887 Y-2.3014
N38755 X0.9902 Y-2.3123
N38760 X0.9928 Y-2.323
N38765 X1. Y-2.3443
N38770 X1.0072 Y-2.3557
N38775 X1.0152 Y-2.3664
N38780 X1.0245 Y-2.3761
N38785 X1.0346 Y-2.3851
N38790 X1.0466 Y-2.3939
N38795 X1.0591 Y-2.4018
N38800 X1.0724 Y-2.4084
N38805 X1.0862 Y-2.4142
N38810 X1.1003 Y-2.4186
N38815 X1.1145 Y-2.4219
N38820 X1.1291 Y-2.4237
N38825 X1.1438 Y-2.4246
N38830 X1.1563 Y-2.424
N38835 X1.1686 Y-2.4226
N38840 X1.1808 Y-2.4198
N38845 X1.1928 Y-2.4163
N38850 X1.2034 Y-2.412
N38855 X1.2137 Y-2.407
N38860 X1.2233 Y-2.4008
N38865 X1.2324 Y-2.3938
N38870 X1.2394 Y-2.3868
N38875 X1.2456 Y-2.3793
N38880 X1.2505 Y-2.3708
N38885 X1.2545 Y-2.3618
N38890 X1.2564 Y-2.3532
N38895 X1.2569 Y-2.3489
N38900 X1.2568 Y-2.3447
N38905 X1.256 Y-2.3406
N38910 X1.2546 Y-2.3365
N38915 X1.2509 Y-2.3285
N38920 X1.2444 Y-2.3213
N38925 X1.2366 Y-2.3156
N38930 X1.2237 Y-2.3087
N38935 X1.2102 Y-2.3031
N38940 X1.1869 Y-2.295
N38945 X1.1632 Y-2.2877
N38950 X1.1384 Y-2.2803
N38955 X1.1188 Y-2.2745
N38960 X1.0992 Y-2.2683
N38965 X1.0799 Y-2.2613
N38970 X1.0609 Y-2.2537
N38975 X1.0505 Y-2.2494
N38980 X1.0404 Y-2.2446
N38985 X1.0308 Y-2.2389
N38990 X1.0215 Y-2.2326
N38995 X1.0156 Y-2.2269
N39000 X1.0103 Y-2.2209
N39005 X1.0061 Y-2.214
N39010 X1.0025 Y-2.2067
N39015 X0.9988 Y-2.1936
N39020 X0.9975 Y-2.1871
N39025 X0.997 Y-2.1806
N39030 X0.9973 Y-2.174
N39035 X0.9984 Y-2.1674
N39040 X1.0016 Y-2.1542
N39045 X1.009 Y-2.1374
N39050 X1.0131 Y-2.1294
N39055 X1.0179 Y-2.1216
N39060 X1.0232 Y-2.1144
N39065 X1.0291 Y-2.1074
N39070 X1.0418 Y-2.0942
N39075 X1.0576 Y-2.0815
N39080 X1.0658 Y-2.0756
N39085 X1.0742 Y-2.0701
N39090 X1.083 Y-2.0653
N39095 X1.0921 Y-2.0609
N39100 X1.1107 Y-2.0529
N39105 X1.1309 Y-2.0467
N39110 X1.141 Y-2.0441
N39115 X1.1513 Y-2.0419
N39120 X1.1616 Y-2.0404
N39125 X1.1721 Y-2.0394
N39130 X1.1931 Y-2.0382
N39135 X1.2088 Y-2.0394
N39140 X1.2243 Y-2.041
N39145 X1.2396 Y-2.0434
N39150 X1.2546 Y-2.047
N39155 X1.2691 Y-2.052
N39160 X1.2832 Y-2.0583
N39165 X1.2972 Y-2.0654
N39170 X1.311 Y-2.0729
N39175 X1.3175 Y-2.0767
N39180 X1.3241 Y-2.0801
N39185 X1.3311 Y-2.0827
N39190 X1.3384 Y-2.0846
N39195 X1.3502 Y-2.0801
N39200 X1.3556 Y-2.0772
N39205 X1.3603 Y-2.0735
N39210 X1.3646 Y-2.069
N39215 X1.3684 Y-2.0641
N39220 X1.3754 Y-2.0533
N39225 X1.395
N39230 X1.3468 Y-2.1949
N39235 X1.3275
N39240 X1.3266 Y-2.1755
N39245 X1.3257 Y-2.1658
N39250 X1.3244 Y-2.1562
N39255 X1.3224 Y-2.1468
N39260 X1.3198 Y-2.1374
N39265 X1.3136 Y-2.119
N39270 X1.308 Y-2.1102
N39275 X1.3016 Y-2.102
N39280 X1.2942 Y-2.0947
N39285 X1.286 Y-2.0881
N39290 X1.2755 Y-2.0814
N39295 X1.2646 Y-2.0754
N39300 X1.2531 Y-2.0707
N39305 X1.2412 Y-2.0666
N39310 X1.2275 Y-2.0633
N39315 X1.2137 Y-2.0607
N39320 X1.1997 Y-2.0594
N39325 X1.1856 Y-2.0588
N39330 X1.1754 Y-2.0592
N39335 X1.1653 Y-2.0602
N39340 X1.1553 Y-2.0622
N39345 X1.1454 Y-2.0647
N39350 X1.1364 Y-2.0681
N39355 X1.1277 Y-2.0719
N39360 X1.1194 Y-2.0767
N39365 X1.1114 Y-2.082
N39370 X1.1015 Y-2.0904
N39375 X1.0926 Y-2.0998
N39380 X1.0863 Y-2.1087
N39385 X1.0816 Y-2.1186
N39390 X1.0799 Y-2.1266
N39395 X1.0796 Y-2.1305
N39400 X1.0797 Y-2.1344
N39405 X1.0806 Y-2.1382
N39410 X1.082 Y-2.1419
N39415 X1.0857 Y-2.1491
N39420 X1.0917 Y-2.1551
N39425 X1.0988 Y-2.1598
N39430 X1.1123 Y-2.1664
N39435 X1.1264 Y-2.1716
N39440 X1.1516 Y-2.1792
N39445 X1.177 Y-2.1862
N39450 X1.1831 Y-2.1881
N39455 X1.1892 Y-2.1897
N39460 X1.1946 Y-2.1928
N39465 X1.2209 Y-2.1986
N39470 X1.2392 Y-2.2038
N39475 X1.2574 Y-2.2096
N39480 X1.2752 Y-2.2163
N39485 X1.2927 Y-2.2236
N39490 X1.3028 Y-2.2297
N39495 X1.3076 Y-2.233
N39500 X1.3121 Y-2.2366
N39505 X1.3162 Y-2.2406
N39510 X1.3201 Y-2.2449
N39515 X1.3274 Y-2.2541
N39520 X1.3314 Y-2.2612
N39525 X1.3347 Y-2.2687
N39530 X1.3367 Y-2.2765
N39535 X1.338 Y-2.2847
N39540 X1.3381 Y-2.2947
N39545 X1.3374 Y-2.3045
N39550 X1.3354 Y-2.3142
N39555 X1.3326 Y-2.3238
N39560 X1.328 Y-2.3349
N39565 X1.3228 Y-2.3456
N39570 X1.3164 Y-2.3557
N39575 X1.3095 Y-2.3655
N39580 X1.3005 Y-2.376
N39585 Z0.1606
N39590 G0 Z0.2
N39595 X0.9642 Y-2.0457
N39600 Z0.1606
N39605 G1 Z-0.0394 F13.123
N39610 X0.9102 Y-2.2044 F39.37
N39615 X0.8919
N39620 X0.893 Y-2.1739
N39625 X0.8927 Y-2.1587
N39630 X0.8918 Y-2.1434
N39635 X0.8902 Y-2.1341
N39640 X0.888 Y-2.1249
N39645 X0.8848 Y-2.116
N39650 X0.8811 Y-2.1072
N39655 X0.8767 Y-2.0995
N39660 X0.8716 Y-2.0923
N39665 X0.8653 Y-2.0862
N39670 X0.8582 Y-2.0808
N39675 X0.8394 Y-2.0745
N39680 X0.8299 Y-2.0718
N39685 X0.8203 Y-2.0698
N39690 X0.8106 Y-2.0684
N39695 X0.8007 Y-2.0676
N39700 X0.7808 Y-2.0669
N39705 X0.7116
N39710 X0.6538 Y-2.237
N39715 X0.6681
N39720 X0.6794 Y-2.2354
N39725 X0.6904 Y-2.2335
N39730 X0.7012 Y-2.2308
N39735 X0.7113 Y-2.2268
N39740 X0.7209 Y-2.2215
N39745 X0.73 Y-2.2152
N39750 X0.7474 Y-2.2007
N39755 X0.7571 Y-2.1902
N39760 X0.7662 Y-2.1793
N39765 X0.7744 Y-2.1676
N39770 X0.782 Y-2.1555
N39775 X0.7925 Y-2.136
N39780 X0.802 Y-2.1161
N39785 X0.8224
N39790 X0.7335 Y-2.3774
N39795 X0.7132
N39800 X0.7167 Y-2.3565
N39805 X0.7192 Y-2.3353
N39810 X0.7199 Y-2.3212
N39815 X0.719 Y-2.3072
N39820 X0.7164 Y-2.296
N39825 X0.7124 Y-2.2853
N39830 X0.7072 Y-2.2786
N39835 X0.7017 Y-2.2724
N39840 X0.6958 Y-2.2671
N39845 X0.6925 Y-2.2649
N39850 X0.6891 Y-2.263
N39855 X0.6817 Y-2.2604
N39860 X0.6737 Y-2.2589
N39865 X0.6653 Y-2.258
N39870 X0.6568 Y-2.2576
N39875 X0.6468
N39880 X0.5925 Y-2.4171
N39885 X0.6495
N39890 X0.6747 Y-2.4162
N39895 X0.6873 Y-2.4149
N39900 X0.6998 Y-2.4132
N39905 X0.7107 Y-2.411
N39910 X0.7215 Y-2.4085
N39915 X0.7321 Y-2.4051
N39920 X0.7426 Y-2.4014
N39925 X0.7527 Y-2.3968
N39930 X0.7626 Y-2.3919
N39935 X0.7722 Y-2.3864
N39940 X0.7816 Y-2.3805
N39945 X0.7978 Y-2.3686
N39950 X0.8056 Y-2.3623
N39955 X0.8131 Y-2.3557
N39960 X0.8203 Y-2.3487
N39965 X0.8271 Y-2.3413
N39970 X0.8401 Y-2.326
N39975 X0.8596 Y-2.2986
N39980 X0.8778 Y-2.2702
N39985 X0.8979
N39990 X0.8408 Y-2.4382
N39995 X0.4146
N40000 X0.421 Y-2.4171
N40005 X0.4369
N40010 X0.4518 Y-2.4147
N40015 X0.4662 Y-2.4116
N40020 X0.473 Y-2.4096
N40025 X0.4795 Y-2.4071
N40030 X0.4855 Y-2.404
N40035 X0.4911 Y-2.4003
N40040 X0.4962 Y-2.3959
N40045 X0.5008 Y-2.3909
N40050 X0.505 Y-2.3853
N40055 X0.5089 Y-2.3793
N40060 X0.516 Y-2.3664
N40065 X0.5226 Y-2.3527
N40070 X0.5981 Y-2.1307
N40075 X0.6019 Y-2.1185
N40080 X0.6033 Y-2.1125
N40085 X0.604 Y-2.1064
N40090 X0.6038 Y-2.1003
N40095 X0.6028 Y-2.0943
N40100 X0.5992 Y-2.0823
N40105 X0.5899 Y-2.0746
N40110 X0.585 Y-2.0716
N40115 X0.5797 Y-2.0694
N40120 X0.5741 Y-2.068
N40125 X0.5682 Y-2.0673
N40130 X0.556 Y-2.0669
N40135 X0.5401
N40140 X0.5473 Y-2.0457
N40145 X0.9642
N40150 Z0.1606
N40155 G0 Z0.2
N40160 X0.4169 Y-2.1252
N40165 Z0.1606
N40170 G1 Z-0.0394 F13.123
N40175 X0.4207 Y-2.1329 F39.37
N40180 X0.424 Y-2.1408
N40185 X0.4265 Y-2.1489
N40190 X0.4285 Y-2.1573
N40195 X0.4315 Y-2.1743
N40200 X0.432 Y-2.1929
N40205 X0.4318 Y-2.2022
N40210 X0.431 Y-2.2114
N40215 X0.4295 Y-2.2205
N40220 X0.4275 Y-2.2296
N40225 X0.4225 Y-2.2476
N40230 X0.4141 Y-2.2681
N40235 X0.4095 Y-2.2781
N40240 X0.4044 Y-2.2878
N40245 X0.3987 Y-2.2972
N40250 X0.3925 Y-2.3064
N40255 X0.3793 Y-2.3241
N40260 X0.3636 Y-2.3412
N40265 X0.3555 Y-2.3494
N40270 X0.347 Y-2.3573
N40275 X0.3382 Y-2.3646
N40280 X0.329 Y-2.3716
N40285 X0.3101 Y-2.385
N40290 X0.2892 Y-2.397
N40295 X0.2785 Y-2.4026
N40300 X0.2677 Y-2.4078
N40305 X0.2567 Y-2.4125
N40310 X0.2454 Y-2.4167
N40315 X0.2226 Y-2.4244
N40320 X0.1987 Y-2.4302
N40325 X0.1867 Y-2.4327
N40330 X0.1746 Y-2.4348
N40335 X0.1624 Y-2.4362
N40340 X0.1502 Y-2.4371
N40345 X0.1256 Y-2.4382
N40350 X-0.1509
N40355 X-0.1435 Y-2.4165
N40360 X-0.1241
N40365 X-0.1098 Y-2.4156
N40370 X-0.1028 Y-2.4147
N40375 X-0.096 Y-2.4132
N40380 X-0.0894 Y-2.4109
N40385 X-0.083 Y-2.408
N40390 X-0.0705 Y-2.4011
N40395 X-0.06 Y-2.3907
N40400 X-0.0552 Y-2.3852
N40405 X-0.0509 Y-2.3794
N40410 X-0.0473 Y-2.3731
N40415 X-0.0441 Y-2.3665
N40420 X-0.0386 Y-2.3527
N40425 X0.0369 Y-2.1307
N40430 X0.0407 Y-2.1185
N40435 X0.0421 Y-2.1125
N40440 X0.0428 Y-2.1064
N40445 X0.0427 Y-2.1003
N40450 X0.0416 Y-2.0943
N40455 X0.038 Y-2.0823
N40460 X0.0288 Y-2.0746
N40465 X0.0238 Y-2.0716
N40470 X0.0186 Y-2.0694
N40475 X0.0129 Y-2.068
N40480 X0.007 Y-2.0673
N40485 X-0.0051 Y-2.0669
N40490 X-0.0246
N40495 X-0.0174 Y-2.0457
N40500 X0.2411
N40505 X0.2677 Y-2.0466
N40510 X0.2809 Y-2.0475
N40515 X0.294 Y-2.049
N40520 X0.307 Y-2.0513
N40525 X0.3198 Y-2.0543
N40530 X0.3454 Y-2.0616
N40535 X0.3638 Y-2.0702
N40540 X0.3726 Y-2.0751
N40545 X0.3809 Y-2.0807
N40550 X0.3884 Y-2.0872
N40555 X0.3954 Y-2.0945
N40560 X0.4083 Y-2.1102
N40565 X0.4169 Y-2.1252
N40570 Z0.1606
N40575 G0 Z0.2
N40580 X0.1386 Y-2.1019
N40585 Z0.1606
N40590 G1 Z-0.0394 F13.123
N40595 X0.0316 Y-2.4165 F39.37
N40600 X0.0994
N40605 X0.1261 Y-2.4158
N40610 X0.1394 Y-2.4146
N40615 X0.1527 Y-2.4131
N40620 X0.1631 Y-2.4111
N40625 X0.1734 Y-2.4088
N40630 X0.1834 Y-2.4056
N40635 X0.1933 Y-2.402
N40640 X0.2022 Y-2.3978
N40645 X0.2109 Y-2.3931
N40650 X0.2191 Y-2.3878
N40655 X0.2271 Y-2.382
N40660 X0.2424 Y-2.3674
N40665 X0.2571 Y-2.3524
N40670 X0.2708 Y-2.3366
N40675 X0.2771 Y-2.3284
N40680 X0.2829 Y-2.3199
N40685 X0.2883 Y-2.311
N40690 X0.2932 Y-2.3019
N40695 X0.3023 Y-2.283
N40700 X0.3104 Y-2.2635
N40705 X0.318 Y-2.2438
N40710 X0.3225 Y-2.2295
N40715 X0.3265 Y-2.2151
N40720 X0.3297 Y-2.2004
N40725 X0.3323 Y-2.1857
N40730 X0.3336 Y-2.1737
N40735 X0.3343 Y-2.1617
N40740 X0.3339 Y-2.1498
N40745 X0.3328 Y-2.1378
N40750 X0.3306 Y-2.1273
N40755 X0.3277 Y-2.117
N40760 X0.3237 Y-2.1071
N40765 X0.3192 Y-2.0974
N40770 X0.3089 Y-2.0888
N40775 X0.2976 Y-2.0816
N40780 X0.2895 Y-2.0777
N40785 X0.2812 Y-2.0745
N40790 X0.2726 Y-2.0722
N40795 X0.2638 Y-2.0704
N40800 X0.2512 Y-2.0688
N40805 X0.2387 Y-2.0676
N40810 X0.2134 Y-2.0669
N40815 X0.1505
N40820 X0.1386 Y-2.1019
N40825 Z0.1606
N40830 G0 Z0.2
N40835 X-0.2851 Y-2.1743
N40840 Z0.1606
N40845 G1 Z-0.0394 F13.123
N40850 X-0.2922 Y-2.1952 F39.37
N40855 X-0.3093 Y-2.1966
N40860 X-0.3262 Y-2.1996
N40865 X-0.3401 Y-2.2045
N40870 X-0.3534 Y-2.211
N40875 X-0.3685 Y-2.2201
N40880 X-0.3826 Y-2.2309
N40885 X-0.4014 Y-2.2486
N40890 X-0.4194 Y-2.2674
N40895 X-0.438 Y-2.2871
N40900 X-0.4573 Y-2.3064
N40905 X-0.4748 Y-2.3225
N40910 X-0.4932 Y-2.3376
N40915 X-0.4863 Y-2.3481
N40920 X-0.4788 Y-2.3582
N40925 X-0.4704 Y-2.3674
N40930 X-0.4612 Y-2.3761
N40935 X-0.4534 Y-2.3813
N40940 X-0.4493 Y-2.3835
N40945 X-0.4451 Y-2.3854
N40950 X-0.4408 Y-2.3867
N40955 X-0.4362 Y-2.3876
N40960 X-0.4269 Y-2.3886
N40965 X-0.4201 Y-2.3879
N40970 X-0.4135 Y-2.3866
N40975 X-0.4071 Y-2.3842
N40980 X-0.4009 Y-2.3813
N40985 X-0.3942 Y-2.3774
N40990 X-0.3878 Y-2.3731
N40995 X-0.3818 Y-2.3682
N41000 X-0.3762 Y-2.3629
N41005 X-0.3648 Y-2.3499
N41010 X-0.355 Y-2.3358
N41015 X-0.3438 Y-2.3135
N41020 X-0.3341 Y-2.2906
N41025 X-0.3134
N41030 X-0.3201 Y-2.3066
N41035 X-0.3271 Y-2.3224
N41040 X-0.335 Y-2.3379
N41045 X-0.3435 Y-2.353
N41050 X-0.3512 Y-2.3639
N41055 X-0.3594 Y-2.3743
N41060 X-0.3684 Y-2.3841
N41065 X-0.378 Y-2.3934
N41070 X-0.3919 Y-2.4049
N41075 X-0.399 Y-2.4103
N41080 X-0.4064 Y-2.4154
N41085 X-0.4141 Y-2.42
N41090 X-0.422 Y-2.4243
N41095 X-0.4382 Y-2.4322
N41100 X-0.4539 Y-2.4379
N41105 X-0.4618 Y-2.4403
N41110 X-0.4698 Y-2.4423
N41115 X-0.478 Y-2.4438
N41120 X-0.4862 Y-2.4448
N41125 X-0.5029 Y-2.446
N41130 X-0.5154 Y-2.4454
N41135 X-0.5276 Y-2.4439
N41140 X-0.5336 Y-2.4424
N41145 X-0.5395 Y-2.4405
N41150 X-0.5511 Y-2.4359
N41155 X-0.5623 Y-2.4286
N41160 X-0.5727 Y-2.4205
N41165 X-0.5822 Y-2.4113
N41170 X-0.5911 Y-2.4014
N41175 X-0.6115 Y-2.4112
N41180 X-0.6323 Y-2.4202
N41185 X-0.6536 Y-2.4278
N41190 X-0.6752 Y-2.4345
N41195 X-0.6954 Y-2.4391
N41200 X-0.7158 Y-2.4427
N41205 X-0.7364 Y-2.4446
N41210 X-0.7571 Y-2.4455
N41215 X-0.7735 Y-2.445
N41220 X-0.7899 Y-2.4437
N41225 X-0.8061 Y-2.4411
N41230 X-0.8221 Y-2.4377
N41235 X-0.8342 Y-2.434
N41240 X-0.8458 Y-2.4293
N41245 X-0.8513 Y-2.4263
N41250 X-0.8566 Y-2.4229
N41255 X-0.8667 Y-2.4154
N41260 X-0.8723 Y-2.4084
N41265 X-0.8774 Y-2.4013
N41270 X-0.8814 Y-2.3939
N41275 X-0.8829 Y-2.3901
N41280 X-0.8839 Y-2.3862
N41285 X-0.8845 Y-2.3822
N41290 X-0.8846 Y-2.3781
N41295 X-0.8839 Y-2.3696
N41300 X-0.8823 Y-2.3609
N41305 X-0.8802 Y-2.3521
N41310 X-0.8722 Y-2.3355
N41315 X-0.8676 Y-2.3277
N41320 X-0.8623 Y-2.3205
N41325 X-0.8561 Y-2.314
N41330 X-0.8493 Y-2.308
N41335 X-0.8344 Y-2.297
N41340 X-0.825 Y-2.2879
N41345 X-0.8152 Y-2.2795
N41350 X-0.8046 Y-2.2719
N41355 X-0.7935 Y-2.265
N41360 X-0.7722 Y-2.2548
N41365 X-0.7502 Y-2.2459
N41370 X-0.7187 Y-2.235
N41375 X-0.6868 Y-2.2251
N41380 X-0.6636 Y-2.2186
N41385 X-0.6644 Y-2.2017
N41390 Y-2.1933
N41395 X-0.6639 Y-2.1849
N41400 X-0.6627 Y-2.1767
N41405 X-0.661 Y-2.1684
N41410 X-0.6566 Y-2.1521
N41415 X-0.6504 Y-2.1366
N41420 X-0.6469 Y-2.1291
N41425 X-0.6431 Y-2.1217
N41430 X-0.6388 Y-2.1147
N41435 X-0.6342 Y-2.1078
N41440 X-0.6243 Y-2.0944
N41445 X-0.6133 Y-2.0825
N41450 X-0.6077 Y-2.0769
N41455 X-0.6017 Y-2.0715
N41460 X-0.5954 Y-2.0666
N41465 X-0.5888 Y-2.062
N41470 X-0.5752 Y-2.0533
N41475 X-0.5621 Y-2.0471
N41480 X-0.5554 Y-2.0445
N41485 X-0.5486 Y-2.0422
N41490 X-0.5416 Y-2.0406
N41495 X-0.5345 Y-2.0396
N41500 X-0.5201 Y-2.0382
N41505 X-0.5056 Y-2.0395
N41510 X-0.4987 Y-2.0409
N41515 X-0.4922 Y-2.0432
N41520 X-0.4863 Y-2.0466
N41525 X-0.481 Y-2.051
N41530 X-0.4711 Y-2.0615
N41535 X-0.4658 Y-2.0759
N41540 X-0.464 Y-2.0831
N41545 X-0.4633 Y-2.0904
N41550 X-0.4637 Y-2.0978
N41555 X-0.4649 Y-2.1052
N41560 X-0.4689 Y-2.1201
N41565 X-0.4726 Y-2.1295
N41570 X-0.477 Y-2.1385
N41575 X-0.4823 Y-2.1469
N41580 X-0.4882 Y-2.1551
N41585 X-0.4954 Y-2.1629
N41590 X-0.503 Y-2.1701
N41595 X-0.5114 Y-2.1766
N41600 X-0.5201 Y-2.1826
N41605 X-0.5305 Y-2.1885
N41610 X-0.5411 Y-2.1938
N41615 X-0.5521 Y-2.1983
N41620 X-0.5634 Y-2.2022
N41625 X-0.5551 Y-2.2126
N41630 X-0.5403 Y-2.2454
N41635 X-0.5243 Y-2.2775
N41640 X-0.5022 Y-2.3236
N41645 X-0.477 Y-2.3001
N41650 X-0.465 Y-2.2878
N41655 X-0.4532 Y-2.2752
N41660 X-0.4459 Y-2.2664
N41665 X-0.4392 Y-2.2572
N41670 X-0.4336 Y-2.2473
N41675 X-0.4289 Y-2.2369
N41680 X-0.4269 Y-2.2289
N41685 X-0.4264 Y-2.225
N41690 X-0.4265 Y-2.2212
N41695 X-0.4273 Y-2.2175
N41700 X-0.4288 Y-2.2139
N41705 X-0.4328 Y-2.2068
N41710 X-0.441 Y-2.2013
N41715 X-0.4452 Y-2.1991
N41720 X-0.4496 Y-2.1975
N41725 X-0.4543 Y-2.1964
N41730 X-0.4591 Y-2.1959
N41735 X-0.469 Y-2.1955
N41740 X-0.4887
N41745 X-0.4816 Y-2.1743
N41750 X-0.2851
N41755 Z0.1606
N41760 G0 Z0.2
N41765 X-0.682 Y-2.2435
N41770 Z0.1606
N41775 G1 Z-0.0394 F13.123
N41780 X-0.7011 Y-2.2512 F39.37
N41785 X-0.7181 Y-2.2594
N41790 X-0.7346 Y-2.2687
N41795 X-0.7458 Y-2.2785
N41800 X-0.7509 Y-2.2838
N41805 X-0.7555 Y-2.2895
N41810 X-0.7594 Y-2.2956
N41815 X-0.7628 Y-2.3021
N41820 X-0.7687 Y-2.3158
N41825 X-0.7723 Y-2.3289
N41830 X-0.7741 Y-2.3423
N41835 X-0.7742 Y-2.3547
N41840 X-0.7725 Y-2.367
N41845 X-0.7689 Y-2.3778
N41850 X-0.7635 Y-2.3878
N41855 X-0.7572 Y-2.3943
N41860 X-0.7506 Y-2.4003
N41865 X-0.7437 Y-2.4055
N41870 X-0.7362 Y-2.4094
N41875 X-0.7281 Y-2.412
N41880 X-0.7195 Y-2.4135
N41885 X-0.7014 Y-2.4148
N41890 X-0.6912 Y-2.4144
N41895 X-0.681 Y-2.4135
N41900 X-0.671 Y-2.4117
N41905 X-0.661 Y-2.4094
N41910 X-0.6473 Y-2.405
N41915 X-0.6337 Y-2.4003
N41920 X-0.6072 Y-2.3892
N41925 X-0.5986 Y-2.3869
N41930 X-0.6111 Y-2.3694
N41935 X-0.6169 Y-2.3605
N41940 X-0.6224 Y-2.3513
N41945 X-0.632 Y-2.3322
N41950 X-0.6408 Y-2.3127
N41955 X-0.6487 Y-2.2923
N41960 X-0.6557 Y-2.2716
N41965 X-0.66 Y-2.2542
N41970 X-0.6627 Y-2.2364
N41975 X-0.682 Y-2.2435
N41980 Z0.1606
N41985 G0 Z0.2
N41990 X-0.5681 Y-2.186
N41995 Z0.1606
N42000 G1 Z-0.0394 F13.123
N42005 X-0.5594 Y-2.1821 F39.37
N42010 X-0.5508 Y-2.1777
N42015 X-0.5428 Y-2.1726
N42020 X-0.535 Y-2.1669
N42025 X-0.5294 Y-2.1615
N42030 X-0.5245 Y-2.1557
N42035 X-0.5207 Y-2.149
N42040 X-0.5175 Y-2.1419
N42045 X-0.5155 Y-2.1344
N42050 X-0.514 Y-2.1268
N42055 X-0.5126 Y-2.1114
N42060 Y-2.1035
N42065 X-0.5131 Y-2.0956
N42070 X-0.5144 Y-2.0879
N42075 X-0.5164 Y-2.0803
N42080 X-0.5199 Y-2.0726
N42085 X-0.522 Y-2.0692
N42090 X-0.5246 Y-2.0664
N42095 X-0.5277 Y-2.0644
N42100 X-0.5314 Y-2.0629
N42105 X-0.5395 Y-2.0611
N42110 X-0.5467 Y-2.062
N42115 X-0.5536 Y-2.0638
N42120 X-0.5599 Y-2.0671
N42125 X-0.566 Y-2.0711
N42130 X-0.5717 Y-2.0761
N42135 X-0.5768 Y-2.0817
N42140 X-0.5807 Y-2.0881
N42145 X-0.5839 Y-2.0951
N42150 X-0.5856 Y-2.1022
N42155 X-0.5867 Y-2.1094
N42160 X-0.5866 Y-2.1166
N42165 X-0.5859 Y-2.1239
N42170 X-0.5834 Y-2.1359
N42175 X-0.5804 Y-2.1478
N42180 X-0.5728 Y-2.1711
N42185 X-0.5681 Y-2.186
N42190 Z0.1606
N42195 G0 Z0.2
N42200 X-1.0242 Y-2.0533
N42205 Z0.1606
N42210 G1 Z-0.0394 F13.123
N42215 X-1.0724 Y-2.1949 F39.37
N42220 X-1.0918
N42225 X-1.0927 Y-2.1755
N42230 X-1.0935 Y-2.1658
N42235 X-1.0948 Y-2.1562
N42240 X-1.0968 Y-2.1468
N42245 X-1.0994 Y-2.1374
N42250 X-1.1056 Y-2.119
N42255 X-1.1112 Y-2.1102
N42260 X-1.1176 Y-2.102
N42265 X-1.125 Y-2.0947
N42270 X-1.1332 Y-2.0881
N42275 X-1.1437 Y-2.0814
N42280 X-1.1547 Y-2.0754
N42285 X-1.1662 Y-2.0707
N42290 X-1.178 Y-2.0666
N42295 X-1.1917 Y-2.0633
N42300 X-1.2055 Y-2.0607
N42305 X-1.2195 Y-2.0594
N42310 X-1.2336 Y-2.0588
N42315 X-1.2438 Y-2.0592
N42320 X-1.2539 Y-2.0602
N42325 X-1.2639 Y-2.0622
N42330 X-1.2738 Y-2.0647
N42335 X-1.2828 Y-2.0681
N42340 X-1.2915 Y-2.0719
N42345 X-1.2998 Y-2.0767
N42350 X-1.3078 Y-2.082
N42355 X-1.3178 Y-2.0904
N42360 X-1.3266 Y-2.0998
N42365 X-1.3329 Y-2.1087
N42370 X-1.3376 Y-2.1186
N42375 X-1.3393 Y-2.1266
N42380 X-1.3397 Y-2.1305
N42385 X-1.3395 Y-2.1344
N42390 X-1.3386 Y-2.1382
N42395 X-1.3372 Y-2.1419
N42400 X-1.3335 Y-2.1491
N42405 X-1.3275 Y-2.1551
N42410 X-1.3204 Y-2.1598
N42415 X-1.3069 Y-2.1664
N42420 X-1.2928 Y-2.1716
N42425 X-1.2676 Y-2.1792
N42430 X-1.2422 Y-2.1862
N42435 X-1.2361 Y-2.1881
N42440 X-1.23 Y-2.1897
N42445 X-1.2246 Y-2.1928
N42450 X-1.1983 Y-2.1986
N42455 X-1.18 Y-2.2038
N42460 X-1.1619 Y-2.2096
N42465 X-1.1441 Y-2.2163
N42470 X-1.1265 Y-2.2236
N42475 X-1.1164 Y-2.2297
N42480 X-1.1116 Y-2.233
N42485 X-1.1071 Y-2.2366
N42490 X-1.103 Y-2.2406
N42495 X-1.0991 Y-2.2449
N42500 X-1.0918 Y-2.2541
N42505 X-1.0878 Y-2.2612
N42510 X-1.0845 Y-2.2687
N42515 X-1.0825 Y-2.2765
N42520 X-1.0812 Y-2.2847
N42525 X-1.0811 Y-2.2947
N42530 X-1.0818 Y-2.3045
N42535 X-1.0838 Y-2.3142
N42540 X-1.0866 Y-2.3238
N42545 X-1.0912 Y-2.3349
N42550 X-1.0964 Y-2.3456
N42555 X-1.1028 Y-2.3557
N42560 X-1.1097 Y-2.3655
N42565 X-1.1187 Y-2.376
N42570 X-1.1282 Y-2.386
N42575 X-1.1385 Y-2.395
N42580 X-1.1494 Y-2.4036
N42585 X-1.1636 Y-2.4131
N42590 X-1.1709 Y-2.4176
N42595 X-1.1784 Y-2.4217
N42600 X-1.1861 Y-2.4253
N42605 X-1.194 Y-2.4286
N42610 X-1.2102 Y-2.4345
N42615 X-1.2282 Y-2.4391
N42620 X-1.2373 Y-2.4411
N42625 X-1.2464 Y-2.4426
N42630 X-1.2649 Y-2.4444
N42635 X-1.2835 Y-2.4452
N42640 X-1.2959 Y-2.4449
N42645 X-1.3083 Y-2.444
N42650 X-1.3205 Y-2.4422
N42655 X-1.3327 Y-2.4398
N42660 X-1.3453 Y-2.436
N42665 X-1.3577 Y-2.4315
N42670 X-1.3697 Y-2.4262
N42675 X-1.3815 Y-2.4204
N42680 X-1.3968 Y-2.414
N42685 X-1.4124 Y-2.4084
N42690 X-1.4219 Y-2.4062
N42695 X-1.4315 Y-2.4054
N42700 X-1.44 Y-2.4061
N42705 X-1.4483 Y-2.4077
N42710 X-1.4562 Y-2.4107
N42715 X-1.4638 Y-2.4145
N42720 X-1.4719 Y-2.4208
N42725 X-1.4793 Y-2.4278
N42730 X-1.4854 Y-2.4359
N42735 X-1.4909 Y-2.4446
N42740 X-1.5107
N42745 X-1.4469 Y-2.2571
N42750 X-1.4267
N42755 X-1.4299 Y-2.2794
N42760 X-1.4307 Y-2.2904
N42765 X-1.4305 Y-2.3014
N42770 X-1.429 Y-2.3123
N42775 X-1.4264 Y-2.323
N42780 X-1.4192 Y-2.3443
N42785 X-1.412 Y-2.3557
N42790 X-1.404 Y-2.3664
N42795 X-1.3947 Y-2.3761
N42800 X-1.3846 Y-2.3851
N42805 X-1.3726 Y-2.3939
N42810 X-1.3601 Y-2.4018
N42815 X-1.3468 Y-2.4084
N42820 X-1.333 Y-2.4142
N42825 X-1.319 Y-2.4186
N42830 X-1.3047 Y-2.4219
N42835 X-1.2901 Y-2.4237
N42840 X-1.2754 Y-2.4246
N42845 X-1.2629 Y-2.424
N42850 X-1.2506 Y-2.4226
N42855 X-1.2384 Y-2.4198
N42860 X-1.2264 Y-2.4163
N42865 X-1.2158 Y-2.412
N42870 X-1.2055 Y-2.407
N42875 X-1.196 Y-2.4008
N42880 X-1.1868 Y-2.3938
N42885 X-1.1798 Y-2.3868
N42890 X-1.1736 Y-2.3793
N42895 X-1.1687 Y-2.3708
N42900 X-1.1647 Y-2.3618
N42905 X-1.1628 Y-2.3532
N42910 X-1.1623 Y-2.3489
N42915 X-1.1624 Y-2.3447
N42920 X-1.1632 Y-2.3406
N42925 X-1.1646 Y-2.3365
N42930 X-1.1683 Y-2.3285
N42935 X-1.1748 Y-2.3213
N42940 X-1.1826 Y-2.3156
N42945 X-1.1955 Y-2.3087
N42950 X-1.209 Y-2.3031
N42955 X-1.2324 Y-2.295
N42960 X-1.256 Y-2.2877
N42965 X-1.2808 Y-2.2803
N42970 X-1.3005 Y-2.2745
N42975 X-1.32 Y-2.2683
N42980 X-1.3393 Y-2.2613
N42985 X-1.3583 Y-2.2537
N42990 X-1.3687 Y-2.2494
N42995 X-1.3788 Y-2.2446
N43000 X-1.3885 Y-2.2389
N43005 X-1.3977 Y-2.2326
N43010 X-1.4036 Y-2.2269
N43015 X-1.4089 Y-2.2209
N43020 X-1.4131 Y-2.214
N43025 X-1.4167 Y-2.2067
N43030 X-1.4204 Y-2.1936
N43035 X-1.4217 Y-2.1871
N43040 X-1.4222 Y-2.1806
N43045 X-1.4219 Y-2.174
N43050 X-1.4209 Y-2.1674
N43055 X-1.4177 Y-2.1542
N43060 X-1.4102 Y-2.1374
N43065 X-1.4061 Y-2.1294
N43070 X-1.4014 Y-2.1216
N43075 X-1.396 Y-2.1144
N43080 X-1.3901 Y-2.1074
N43085 X-1.3774 Y-2.0942
N43090 X-1.3616 Y-2.0815
N43095 X-1.3534 Y-2.0756
N43100 X-1.345 Y-2.0701
N43105 X-1.3362 Y-2.0653
N43110 X-1.3271 Y-2.0609
N43115 X-1.3085 Y-2.0529
N43120 X-1.2883 Y-2.0467
N43125 X-1.2782 Y-2.0441
N43130 X-1.2679 Y-2.0419
N43135 X-1.2576 Y-2.0404
N43140 X-1.2471 Y-2.0394
N43145 X-1.2261 Y-2.0382
N43150 X-1.2104 Y-2.0394
N43155 X-1.1949 Y-2.041
N43160 X-1.1796 Y-2.0434
N43165 X-1.1646 Y-2.047
N43170 X-1.1501 Y-2.052
N43175 X-1.136 Y-2.0583
N43180 X-1.1221 Y-2.0654
N43185 X-1.1083 Y-2.0729
N43190 X-1.1017 Y-2.0767
N43195 X-1.0951 Y-2.0801
N43200 X-1.0881 Y-2.0827
N43205 X-1.0808 Y-2.0846
N43210 X-1.069 Y-2.0801
N43215 X-1.0636 Y-2.0772
N43220 X-1.0589 Y-2.0735
N43225 X-1.0546 Y-2.069
N43230 X-1.0508 Y-2.0641
N43235 X-1.0438 Y-2.0533
N43240 X-1.0242
N43245 Z0.1606
N43250 G0 Z0.2
N43255 X-0.5045 Y2.3698
N43260 Z0.1606
N43265 G1 Z-0.0394 F13.123
N43270 X-0.5212 Y2.3723 F39.37
N43275 X-0.5376 Y2.3755
N43280 X-0.5538 Y2.3796
N43285 X-0.5696 Y2.3847
N43290 X-0.5851 Y2.3908
N43295 X-0.6004 Y2.3978
N43300 X-0.6154 Y2.4055
N43305 X-0.6302 Y2.4138
N43310 X-0.6448 Y2.4226
N43315 X-0.6739 Y2.4409
N43320 X-0.6952 Y2.4649
N43325 X-0.7055 Y2.4771
N43330 X-0.7154 Y2.4894
N43335 X-0.7248 Y2.5021
N43340 X-0.7335 Y2.515
N43345 X-0.7414 Y2.5284
N43350 X-0.7484 Y2.5422
N43355 X-0.7544 Y2.5564
N43360 X-0.7596 Y2.5711
N43365 X-0.7641 Y2.5861
N43370 X-0.768 Y2.6014
N43375 X-0.7746 Y2.6327
N43380 X-0.7801 Y2.6644
N43385 X-0.6083 Y2.6811
N43390 X-0.6043 Y2.6632
N43395 X-0.5999 Y2.6455
N43400 X-0.5945 Y2.6284
N43405 X-0.5913 Y2.62
N43410 X-0.5877 Y2.6119
N43415 X-0.5836 Y2.604
N43420 X-0.5791 Y2.5964
N43425 X-0.5688 Y2.5818
N43430 X-0.5573 Y2.5677
N43435 X-0.5453 Y2.554
N43440 X-0.5307 Y2.5445
N43445 X-0.516 Y2.5357
N43450 X-0.5008 Y2.528
N43455 X-0.4931 Y2.5248
N43460 X-0.4851 Y2.5221
N43465 X-0.477 Y2.5199
N43470 X-0.4687 Y2.5181
N43475 X-0.4519 Y2.5157
N43480 X-0.4346 Y2.5143
N43485 X-0.4173 Y2.5134
N43490 X-0.4 Y2.5139
N43495 X-0.3829 Y2.515
N43500 X-0.366 Y2.5169
N43505 X-0.3577 Y2.5184
N43510 X-0.3496 Y2.5203
N43515 X-0.3416 Y2.5227
N43520 X-0.3337 Y2.5256
N43525 X-0.3184 Y2.5326
N43530 X-0.3034 Y2.5407
N43535 X-0.2886 Y2.5495
N43540 X-0.2796 Y2.5583
N43545 X-0.2711 Y2.5673
N43550 X-0.2634 Y2.5767
N43555 X-0.2601 Y2.5816
N43560 X-0.2571 Y2.5868
N43565 X-0.2546 Y2.5922
N43570 X-0.2525 Y2.5977
N43575 X-0.2493 Y2.6094
N43580 X-0.2471 Y2.6216
N43585 X-0.2454 Y2.634
N43590 X-0.2467 Y2.6483
N43595 X-0.2478 Y2.6553
N43600 X-0.2497 Y2.662
N43605 X-0.2524 Y2.6685
N43610 X-0.2557 Y2.6747
N43615 X-0.2636 Y2.6868
N43620 X-0.2777 Y2.6991
N43625 X-0.2851 Y2.7048
N43630 X-0.2928 Y2.7098
N43635 X-0.3011 Y2.7141
N43640 X-0.3096 Y2.7179
N43645 X-0.3271 Y2.7247
N43650 X-0.3623 Y2.7351
N43655 X-0.3975 Y2.7449
N43660 X-0.4686 Y2.7629
N43665 X-0.4953 Y2.7697
N43670 X-0.5218 Y2.7771
N43675 X-0.5479 Y2.7853
N43680 X-0.5607 Y2.7899
N43685 X-0.5734 Y2.7949
N43690 X-0.5858 Y2.8004
N43695 X-0.598 Y2.8064
N43700 X-0.61 Y2.8128
N43705 X-0.6218 Y2.8197
N43710 X-0.645 Y2.8342
N43715 X-0.6679 Y2.8494
N43720 X-0.6852 Y2.8682
N43725 X-0.7016 Y2.8873
N43730 X-0.7091 Y2.8972
N43735 X-0.7161 Y2.9073
N43740 X-0.7224 Y2.9177
N43745 X-0.7279 Y2.9285
N43750 X-0.7325 Y2.9397
N43755 X-0.7363 Y2.9513
N43760 X-0.7394 Y2.9632
N43765 X-0.7419 Y2.9753
N43770 X-0.7457 Y3.0002
N43775 X-0.7485 Y3.0255
N43780 X-0.7472 Y3.0422
N43785 X-0.7454 Y3.0587
N43790 X-0.7428 Y3.0749
N43795 X-0.741 Y3.0829
N43800 X-0.7389 Y3.0908
N43805 X-0.7333 Y3.1062
N43810 X-0.7265 Y3.1212
N43815 X-0.7188 Y3.1359
N43820 X-0.7106 Y3.1505
N43825 X-0.6995 Y3.1647
N43830 X-0.688 Y3.1784
N43835 X-0.6759 Y3.1914
N43840 X-0.6695 Y3.1974
N43845 X-0.6628 Y3.2031
N43850 X-0.6558 Y3.2084
N43855 X-0.6485 Y3.2134
N43860 X-0.6333 Y3.2226
N43865 X-0.6175 Y3.2311
N43870 X-0.6014 Y3.2392
N43875 X-0.5805 Y3.2462
N43880 X-0.5595 Y3.2529
N43885 X-0.5383 Y3.2586
N43890 X-0.5169 Y3.263
N43895 X-0.4952 Y3.266
N43900 X-0.4733 Y3.2679
N43905 X-0.4292 Y3.2696
N43910 X-0.3957 Y3.2685
N43915 X-0.3626 Y3.2664
N43920 X-0.3462 Y3.2647
N43925 X-0.33 Y3.2624
N43930 X-0.314 Y3.2594
N43935 X-0.2983 Y3.2556
N43940 X-0.2829 Y3.2509
N43945 X-0.2677 Y3.2451
N43950 X-0.2529 Y3.2385
N43955 X-0.2383 Y3.2312
N43960 X-0.2238 Y3.2232
N43965 X-0.2096 Y3.2149
N43970 X-0.1812 Y3.1974
N43975 X-0.1625 Y3.1769
N43980 X-0.1535 Y3.1664
N43985 X-0.1449 Y3.1559
N43990 X-0.1367 Y3.145
N43995 X-0.1292 Y3.1339
N44000 X-0.1225 Y3.1225
N44005 X-0.1166 Y3.1106
N44010 X-0.1116 Y3.0983
N44015 X-0.1075 Y3.0857
N44020 X-0.1041 Y3.0726
N44025 X-0.1013 Y3.0594
N44030 X-0.0971 Y3.0322
N44035 X-0.0938 Y3.0046
N44040 X-0.2704 Y2.9968
N44045 X-0.2733 Y3.0106
N44050 X-0.2766 Y3.0242
N44055 X-0.2806 Y3.0374
N44060 X-0.2858 Y3.05
N44065 X-0.2889 Y3.056
N44070 X-0.2925 Y3.0618
N44075 X-0.3006 Y3.0729
N44080 X-0.3096 Y3.0835
N44085 X-0.3191 Y3.0938
N44090 X-0.3321 Y3.1011
N44095 X-0.3452 Y3.1078
N44100 X-0.3586 Y3.1136
N44105 X-0.3654 Y3.1159
N44110 X-0.3724 Y3.1178
N44115 X-0.3867 Y3.1206
N44120 X-0.4012 Y3.1222
N44125 X-0.4161 Y3.123
N44130 X-0.431 Y3.1234
N44135 X-0.447 Y3.1228
N44140 X-0.4629 Y3.1218
N44145 X-0.4786 Y3.12
N44150 X-0.4939 Y3.117
N44155 X-0.5014 Y3.1149
N44160 X-0.5088 Y3.1124
N44165 X-0.5233 Y3.1064
N44170 X-0.5375 Y3.0993
N44175 X-0.5516 Y3.0917
N44180 X-0.5633 Y3.0806
N44185 X-0.5684 Y3.0746
N44190 X-0.5725 Y3.0682
N44195 X-0.5754 Y3.0611
N44200 X-0.5774 Y3.0535
N44205 X-0.5796 Y3.0374
N44210 X-0.5773 Y3.0221
N44215 X-0.5754 Y3.0147
N44220 X-0.5727 Y3.0079
N44225 X-0.5688 Y3.0015
N44230 X-0.5641 Y2.9955
N44235 X-0.5533 Y2.9843
N44240 X-0.5342 Y2.974
N44245 X-0.5149 Y2.9642
N44250 X-0.4952 Y2.9553
N44255 X-0.475 Y2.9477
N44260 X-0.4544 Y2.9413
N44265 X-0.4334 Y2.9357
N44270 X-0.391 Y2.9258
N44275 X-0.3421 Y2.9137
N44280 X-0.3178 Y2.9071
N44285 X-0.2938 Y2.8999
N44290 X-0.27 Y2.8917
N44295 X-0.2466 Y2.8826
N44300 X-0.2003 Y2.8629
N44305 X-0.186 Y2.8541
N44310 X-0.172 Y2.8451
N44315 X-0.1585 Y2.8355
N44320 X-0.1459 Y2.825
N44325 X-0.1343 Y2.8133
N44330 X-0.1236 Y2.8007
N44335 X-0.1135 Y2.7875
N44340 X-0.1036 Y2.7739
N44345 X-0.0956 Y2.7574
N44350 X-0.088 Y2.7409
N44355 X-0.0815 Y2.724
N44360 X-0.0787 Y2.7154
N44365 X-0.0764 Y2.7068
N44370 X-0.0729 Y2.6891
N44375 X-0.0708 Y2.6711
N44380 X-0.0695 Y2.6529
N44385 X-0.0687 Y2.6346
N44390 X-0.0701 Y2.6158
N44395 X-0.0721 Y2.5972
N44400 X-0.075 Y2.579
N44405 X-0.0769 Y2.57
N44410 X-0.0793 Y2.5611
N44415 X-0.0822 Y2.5524
N44420 X-0.0854 Y2.5437
N44425 X-0.093 Y2.5268
N44430 X-0.1015 Y2.5102
N44435 X-0.1105 Y2.4937
N44440 X-0.1224 Y2.4781
N44445 X-0.1347 Y2.4629
N44450 X-0.1478 Y2.4486
N44455 X-0.1547 Y2.4419
N44460 X-0.1619 Y2.4357
N44465 X-0.1695 Y2.4298
N44470 X-0.1773 Y2.4243
N44475 X-0.1939 Y2.4142
N44480 X-0.2111 Y2.4049
N44485 X-0.2286 Y2.3961
N44490 X-0.2518 Y2.3886
N44495 X-0.2751 Y2.3816
N44500 X-0.2985 Y2.3755
N44505 X-0.3103 Y2.3729
N44510 X-0.3222 Y2.3708
N44515 X-0.3462 Y2.3677
N44520 X-0.3703 Y2.3659
N44525 X-0.3947 Y2.3648
N44530 X-0.419 Y2.3642
N44535 X-0.4535 Y2.3656
N44540 X-0.4877 Y2.368
N44545 X-0.5045 Y2.3698
N44550 Z0.1606
N44555 G0 Z0.2
N44560 X0.0746 Y2.6672
N44565 Z0.1606
N44570 G1 Z-0.0394 F13.123
N44575 Y3.2547 F39.37
N44580 X0.2512
N44585 Y2.3797
N44590 X0.0746
N44595 Y2.6672
N44600 Z0.1606
N44605 G0 Z0.2
N44610 X0.4404 Y2.5871
N44615 Z0.1606
N44620 G1 Z-0.0394 F13.123
N44625 X0.4291 Y2.6151 F39.37
N44630 X0.4185 Y2.6433
N44635 X0.4136 Y2.6575
N44640 X0.4091 Y2.6718
N44645 X0.405 Y2.6862
N44650 X0.4015 Y2.7007
N44655 X0.3987 Y2.7153
N44660 X0.3963 Y2.7301
N44665 X0.3929 Y2.7599
N44670 X0.3907 Y2.79
N44675 X0.3891 Y2.8202
N44680 X0.3907 Y2.8519
N44685 X0.393 Y2.8834
N44690 X0.3947 Y2.8991
N44695 X0.3967 Y2.9146
N44700 X0.3993 Y2.93
N44705 X0.4025 Y2.9453
N44710 X0.4064 Y2.9604
N44715 X0.4109 Y2.9754
N44720 X0.4159 Y2.9902
N44725 X0.4215 Y3.0049
N44730 X0.4336 Y3.0341
N44735 X0.4464 Y3.0631
N44740 X0.4627 Y3.0882
N44745 X0.4796 Y3.1128
N44750 X0.4885 Y3.1246
N44755 X0.4977 Y3.1361
N44760 X0.5074 Y3.1471
N44765 X0.5176 Y3.1576
N44770 X0.5284 Y3.1674
N44775 X0.5397 Y3.1768
N44780 X0.5514 Y3.1857
N44785 X0.5635 Y3.1942
N44790 X0.5885 Y3.2104
N44795 X0.6141 Y3.226
N44800 X0.6393 Y3.2362
N44805 X0.6646 Y3.2457
N44810 X0.6773 Y3.25
N44815 X0.6902 Y3.254
N44820 X0.7031 Y3.2574
N44825 X0.7162 Y3.2603
N44830 X0.7293 Y3.2627
N44835 X0.7426 Y3.2646
N44840 X0.7694 Y3.2672
N44845 X0.7965 Y3.2687
N44850 X0.8236 Y3.2696
N44855 X0.8575 Y3.2684
N44860 X0.8912 Y3.2662
N44865 X0.9078 Y3.2646
N44870 X0.9243 Y3.2624
N44875 X0.9406 Y3.2595
N44880 X0.9567 Y3.2559
N44885 X0.9726 Y3.2513
N44890 X0.9881 Y3.2459
N44895 X1.0035 Y3.2397
N44900 X1.0187 Y3.2328
N44905 X1.0337 Y3.2254
N44910 X1.0486 Y3.2176
N44915 X1.0782 Y3.2013
N44920 X1.0994 Y3.1817
N44925 X1.1198 Y3.1617
N44930 X1.1294 Y3.1513
N44935 X1.1385 Y3.1406
N44940 X1.147 Y3.1295
N44945 X1.1547 Y3.1179
N44950 X1.1616 Y3.1058
N44955 X1.1679 Y3.0933
N44960 X1.1735 Y3.0804
N44965 X1.1786 Y3.0672
N44970 X1.1877 Y3.04
N44975 X1.1961 Y3.0124
N44980 X1.0206 Y2.9795
N44985 X1.0151 Y2.9944
N44990 X1.0091 Y3.0091
N44995 X1.0024 Y3.0231
N45000 X0.9986 Y3.0299
N45005 X0.9945 Y3.0364
N45010 X0.99 Y3.0426
N45015 X0.9851 Y3.0486
N45020 X0.9744 Y3.06
N45025 X0.9629 Y3.0708
N45030 X0.951 Y3.0813
N45035 X0.9363 Y3.0898
N45040 X0.9214 Y3.0978
N45045 X0.9061 Y3.1048
N45050 X0.8984 Y3.1077
N45055 X0.8904 Y3.1102
N45060 X0.8824 Y3.1123
N45065 X0.8742 Y3.1139
N45070 X0.8576 Y3.1163
N45075 X0.8407 Y3.1177
N45080 X0.8236 Y3.1186
N45085 X0.7977 Y3.1166
N45090 X0.7721 Y3.1138
N45095 X0.7595 Y3.1117
N45100 X0.7472 Y3.1091
N45105 X0.7352 Y3.1058
N45110 X0.7234 Y3.1018
N45115 X0.7121 Y3.0968
N45120 X0.7011 Y3.091
N45125 X0.6903 Y3.0845
N45130 X0.6799 Y3.0774
N45135 X0.6595 Y3.0618
N45140 X0.6395 Y3.0452
N45145 X0.6231 Y3.0206
N45150 X0.6152 Y3.0082
N45155 X0.6078 Y2.9956
N45160 X0.6009 Y2.9829
N45165 X0.5946 Y2.9699
N45170 X0.5892 Y2.9567
N45175 X0.5847 Y2.9432
N45180 X0.5811 Y2.9293
N45185 X0.5782 Y2.9152
N45190 X0.576 Y2.9009
N45195 X0.5744 Y2.8864
N45200 X0.5723 Y2.857
N45205 X0.5711 Y2.8273
N45210 X0.5722 Y2.7957
N45215 X0.5742 Y2.7644
N45220 X0.5759 Y2.7489
N45225 X0.578 Y2.7336
N45230 X0.5809 Y2.7186
N45235 X0.5845 Y2.7037
N45240 X0.5891 Y2.6892
N45245 X0.5946 Y2.675
N45250 X0.6009 Y2.661
N45255 X0.608 Y2.6473
N45260 X0.6156 Y2.6337
N45265 X0.6236 Y2.6203
N45270 X0.6404 Y2.5937
N45275 X0.6598 Y2.5764
N45280 X0.6796 Y2.5602
N45285 X0.6898 Y2.5527
N45290 X0.7003 Y2.5458
N45295 X0.7111 Y2.5397
N45300 X0.7223 Y2.5344
N45305 X0.7338 Y2.5301
N45310 X0.7457 Y2.5265
N45315 X0.758 Y2.5236
N45320 X0.7704 Y2.5214
N45325 X0.7959 Y2.5181
N45330 X0.8218 Y2.5158
N45335 X0.8504 Y2.5176
N45340 X0.8645 Y2.5191
N45345 X0.8785 Y2.5214
N45350 X0.8923 Y2.5246
N45355 X0.906 Y2.5285
N45360 X0.9331 Y2.5376
N45365 X0.9584 Y2.5484
N45370 X0.9708 Y2.5542
N45375 X0.983 Y2.5605
N45380 X0.9948 Y2.5674
N45385 X1.0063 Y2.5748
N45390 X1.0289 Y2.5904
N45395 Y2.7014
N45400 X0.8266
N45405 Y2.8488
N45410 X1.2074
N45415 Y2.5003
N45420 X1.1891 Y2.4855
N45425 X1.1705 Y2.4711
N45430 X1.1515 Y2.4575
N45435 X1.1417 Y2.4511
N45440 X1.1317 Y2.4451
N45445 X1.1111 Y2.4341
N45450 X1.0899 Y2.424
N45455 X1.0465 Y2.4057
N45460 X1.0206 Y2.3969
N45465 X0.9945 Y2.3886
N45470 X0.9683 Y2.3812
N45475 X0.9551 Y2.378
N45480 X0.9418 Y2.3752
N45485 X0.9284 Y2.3729
N45490 X0.9149 Y2.371
N45495 X0.8878 Y2.3681
N45500 X0.8605 Y2.3662
N45505 X0.8332 Y2.3648
N45510 X0.8019 Y2.3663
N45515 X0.7707 Y2.3686
N45520 X0.7553 Y2.3702
N45525 X0.7399 Y2.3722
N45530 X0.7247 Y2.3748
N45535 X0.7097 Y2.378
N45540 X0.6948 Y2.3818
N45545 X0.68 Y2.3864
N45550 X0.6655 Y2.3915
N45555 X0.651 Y2.3971
N45560 X0.6223 Y2.4094
N45565 X0.5938 Y2.4224
N45570 X0.5699 Y2.4385
N45575 X0.5466 Y2.4552
N45580 X0.5353 Y2.464
N45585 X0.5244 Y2.4731
N45590 X0.514 Y2.4826
N45595 X0.5042 Y2.4926
N45600 X0.4949 Y2.5032
N45605 X0.4861 Y2.5143
N45610 X0.4778 Y2.5258
N45615 X0.4699 Y2.5376
N45620 X0.4549 Y2.5621
N45625 X0.4404 Y2.5871
N45630 Z0.1606
N45635 G0 Z0.2
N45640 X1.3721 Y2.7047
N45645 Z0.1606
N45650 G1 Z-0.0394 F13.123
N45655 Y3.2547 F39.37
N45660 X1.544
N45665 X1.9021 Y2.6704
N45670 Y3.2547
N45675 X2.0663
N45680 Y2.3797
N45685 X1.889
N45690 X1.5363 Y2.9503
N45695 Y2.3797
N45700 X1.3721
N45705 Y2.7047
N45710 Z0.1606
N45715 G0 Z0.2
N45720 X1.4779 Y3.7335
N45725 Z0.1606
N45730 G1 Z-0.0394 F13.123
N45735 X1.4564 Y3.7355 F39.37
N45740 X1.435 Y3.738
N45745 X1.414 Y3.7413
N45750 X1.3933 Y3.7455
N45755 X1.3731 Y3.7508
N45760 X1.3533 Y3.7574
N45765 X1.3437 Y3.7612
N45770 X1.3341 Y3.7654
N45775 X1.3155 Y3.7748
N45780 X1.2974 Y3.7854
N45785 X1.2796 Y3.797
N45790 X1.2622 Y3.8094
N45795 X1.245 Y3.8224
N45800 X1.211 Y3.8495
N45805 X1.1844 Y3.886
N45810 X1.1715 Y3.9044
N45815 X1.1594 Y3.9231
N45820 X1.148 Y3.9421
N45825 X1.1376 Y3.9614
N45830 X1.1285 Y3.9812
N45835 X1.1208 Y4.0015
N45840 X1.1145 Y4.0224
N45845 X1.1095 Y4.0437
N45850 X1.1056 Y4.0654
N45855 X1.1025 Y4.0874
N45860 X1.1002 Y4.1097
N45865 X1.0984 Y4.1322
N45870 X1.0958 Y4.1774
N45875 X1.0966 Y4.2063
N45880 X1.098 Y4.235
N45885 X1.1003 Y4.2635
N45890 X1.1021 Y4.2777
N45895 X1.1042 Y4.2918
N45900 X1.1069 Y4.3058
N45905 X1.1101 Y4.3197
N45910 X1.1176 Y4.3473
N45915 X1.1264 Y4.3746
N45920 X1.1358 Y4.4019
N45925 X1.1525 Y4.4343
N45930 X1.1615 Y4.4502
N45935 X1.1712 Y4.4655
N45940 X1.1818 Y4.4802
N45945 X1.1932 Y4.4943
N45950 X1.2172 Y4.5218
N45955 X1.2428 Y4.5455
N45960 X1.256 Y4.5567
N45965 X1.2698 Y4.567
N45970 X1.2843 Y4.5764
N45975 X1.2993 Y4.5849
N45980 X1.3304 Y4.6006
N45985 X1.3533 Y4.6085
N45990 X1.3763 Y4.6159
N45995 X1.3994 Y4.6224
N46000 X1.4111 Y4.6251
N46005 X1.4229 Y4.6274
N46010 X1.4466 Y4.6309
N46015 X1.4706 Y4.633
N46020 X1.4947 Y4.6343
N46025 X1.519 Y4.6352
N46030 X1.5623 Y4.632
N46035 X1.5838 Y4.63
N46040 X1.6051 Y4.6274
N46045 X1.6261 Y4.624
N46050 X1.6468 Y4.6198
N46055 X1.6669 Y4.6144
N46060 X1.6866 Y4.6078
N46065 X1.7057 Y4.5997
N46070 X1.7243 Y4.5902
N46075 X1.7424 Y4.5795
N46080 X1.7601 Y4.5679
N46085 X1.7774 Y4.5554
N46090 X1.7946 Y4.5424
N46095 X1.8284 Y4.5153
N46100 X1.8554 Y4.4781
N46105 X1.8683 Y4.4593
N46110 X1.8807 Y4.4403
N46115 X1.8922 Y4.421
N46120 X1.9026 Y4.4013
N46125 X1.9118 Y4.3811
N46130 X1.9159 Y4.3709
N46135 X1.9196 Y4.3605
N46140 X1.9259 Y4.3393
N46145 X1.9309 Y4.3176
N46150 X1.9348 Y4.2956
N46155 X1.9379 Y4.2731
N46160 X1.9402 Y4.2505
N46165 X1.9419 Y4.2276
N46170 X1.9445 Y4.1816
N46175 X1.9419 Y4.1359
N46180 X1.9402 Y4.1132
N46185 X1.9379 Y4.0907
N46190 X1.9349 Y4.0685
N46195 X1.931 Y4.0465
N46200 X1.926 Y4.025
N46205 X1.9197 Y4.0039
N46210 X1.916 Y3.9936
N46215 X1.912 Y3.9834
N46220 X1.9029 Y3.9634
N46225 X1.8925 Y3.9438
N46230 X1.8811 Y3.9246
N46235 X1.8689 Y3.9057
N46240 X1.856 Y3.887
N46245 X1.8293 Y3.8501
N46250 X1.7957 Y3.823
N46255 X1.7786 Y3.81
N46260 X1.7613 Y3.7976
N46265 X1.7438 Y3.7859
N46270 X1.7258 Y3.7753
N46275 X1.7073 Y3.7658
N46280 X1.6883 Y3.7578
N46285 X1.6687 Y3.7511
N46290 X1.6486 Y3.7458
N46295 X1.6281 Y3.7416
N46300 X1.6071 Y3.7382
N46305 X1.586 Y3.7356
N46310 X1.5645 Y3.7336
N46315 X1.5214 Y3.7304
N46320 X1.4779 Y3.7335
N46325 Z0.1606
N46330 G0 Z0.2
N46335 X0.9441 Y4.2193
N46340 Z0.1606
N46345 G1 Z-0.0394 F13.123
N46350 X0.829 Y3.7453 F39.37
N46355 X0.6416
N46360 X0.4673 Y4.3995
N46365 X0.2936 Y3.7453
N46370 X0.102
N46375 X-0.1069 Y4.6203
N46380 X0.074
N46385 X0.2059 Y4.0193
N46390 X0.3658 Y4.6203
N46395 X0.5759
N46400 X0.7293 Y4.0091
N46405 X0.8636 Y4.6203
N46410 X1.0415
N46415 X0.9441 Y4.2193
N46420 Z0.1606
N46425 G0 Z0.2
N46430 X-0.5116 Y3.7453
N46435 Z0.1606
N46440 G1 Z-0.0394 F13.123
N46445 X-1.1771 F39.37
N46450 Y4.6203
N46455 X-0.5283
N46460 Y4.4723
N46465 X-1.0004
N46470 Y4.2783
N46475 X-0.5611
N46480 Y4.1309
N46485 X-1.0004
N46490 Y3.8927
N46495 X-0.5116
N46500 Y3.7453
N46505 Z0.1606
N46510 G0 Z0.2
N46515 X1.2827 Y4.1076
N46520 Z0.1606
N46525 G1 Z-0.0394 F13.123
N46530 X1.2849 Y4.0929 F39.37
N46535 X1.2878 Y4.0783
N46540 X1.2914 Y4.064
N46545 X1.296 Y4.05
N46550 X1.3014 Y4.0363
N46555 X1.3077 Y4.0229
N46560 X1.3146 Y4.0096
N46565 X1.3221 Y3.9966
N46570 X1.33 Y3.9837
N46575 X1.3465 Y3.9581
N46580 X1.3651 Y3.9413
N46585 X1.3841 Y3.9255
N46590 X1.3939 Y3.9182
N46595 X1.404 Y3.9115
N46600 X1.4143 Y3.9055
N46605 X1.425 Y3.9003
N46610 X1.4361 Y3.8959
N46615 X1.4475 Y3.8924
N46620 X1.4593 Y3.8895
N46625 X1.4713 Y3.8872
N46630 X1.4958 Y3.8839
N46635 X1.5208 Y3.8814
N46640 X1.5456 Y3.8838
N46645 X1.57 Y3.8871
N46650 X1.5819 Y3.8894
N46655 X1.5936 Y3.8922
N46660 X1.605 Y3.8957
N46665 X1.616 Y3.9
N46670 X1.6267 Y3.9052
N46675 X1.637 Y3.9112
N46680 X1.647 Y3.9178
N46685 X1.6567 Y3.9251
N46690 X1.6756 Y3.9408
N46695 X1.6941 Y3.9575
N46700 X1.7105 Y3.9835
N46705 X1.7184 Y3.9966
N46710 X1.7258 Y4.0099
N46715 X1.7327 Y4.0233
N46720 X1.7389 Y4.0369
N46725 X1.7443 Y4.0508
N46730 X1.7488 Y4.065
N46735 X1.7524 Y4.0795
N46740 X1.7551 Y4.0943
N46745 X1.7573 Y4.1092
N46750 X1.7589 Y4.1243
N46755 X1.7608 Y4.1549
N46760 X1.7619 Y4.1858
N46765 X1.7609 Y4.2161
N46770 X1.759 Y4.2462
N46775 X1.7575 Y4.2611
N46780 X1.7554 Y4.2757
N46785 X1.7527 Y4.2902
N46790 X1.7493 Y4.3044
N46795 X1.7449 Y4.3184
N46800 X1.7397 Y4.3321
N46805 X1.7336 Y4.3455
N46810 X1.7269 Y4.3587
N46815 X1.7196 Y4.3717
N46820 X1.712 Y4.3846
N46825 X1.6959 Y4.4102
N46830 X1.6771 Y4.4267
N46835 X1.658 Y4.4422
N46840 X1.6481 Y4.4494
N46845 X1.638 Y4.4559
N46850 X1.6275 Y4.4617
N46855 X1.6167 Y4.4668
N46860 X1.6056 Y4.4709
N46865 X1.5941 Y4.4743
N46870 X1.5823 Y4.4769
N46875 X1.5703 Y4.4791
N46880 X1.5457 Y4.4821
N46885 X1.5208 Y4.4842
N46890 X1.4957 Y4.482
N46895 X1.4709 Y4.4789
N46900 X1.4589 Y4.4767
N46905 X1.447 Y4.474
N46910 X1.4355 Y4.4706
N46915 X1.4242 Y4.4664
N46920 X1.4134 Y4.4613
N46925 X1.4029 Y4.4554
N46930 X1.3927 Y4.4488
N46935 X1.3828 Y4.4417
N46940 X1.3636 Y4.4259
N46945 X1.3447 Y4.4093
N46950 X1.3285 Y4.3836
N46955 X1.3207 Y4.3706
N46960 X1.3133 Y4.3575
N46965 X1.3065 Y4.3442
N46970 X1.3004 Y4.3307
N46975 X1.2951 Y4.317
N46980 X1.2907 Y4.3029
N46985 X1.2872 Y4.2886
N46990 X1.2844 Y4.274
N46995 X1.2823 Y4.2592
N47000 X1.2808 Y4.2443
N47005 X1.2789 Y4.214
N47010 X1.2778 Y4.1834
N47015 X1.279 Y4.1528
N47020 X1.2811 Y4.1226
N47025 X1.2827 Y4.1076
N47030 Z0.1606
N47035 G0 Z0.2
N47040 X2.083 Y4.1828
N47045 Z0.1606
N47050 G1 Z-0.0394 F13.123
N47055 Y4.6203 F39.37
N47060 X2.4548
N47065 X2.5065 Y4.6198
N47070 X2.5322 Y4.6187
N47075 X2.5578 Y4.6167
N47080 X2.5832 Y4.6133
N47085 X2.6085 Y4.6085
N47090 X2.6336 Y4.6029
N47095 X2.6587 Y4.5967
N47100 X2.674 Y4.5894
N47105 X2.689 Y4.5817
N47110 X2.7033 Y4.5731
N47115 X2.7101 Y4.5685
N47120 X2.7166 Y4.5634
N47125 X2.7228 Y4.558
N47130 X2.7287 Y4.5522
N47135 X2.7398 Y4.5397
N47140 X2.7503 Y4.5265
N47145 X2.7604 Y4.5129
N47150 X2.7689 Y4.4967
N47155 X2.7769 Y4.4804
N47160 X2.7839 Y4.4637
N47165 X2.7869 Y4.4553
N47170 X2.7895 Y4.4467
N47175 X2.7917 Y4.438
N47180 X2.7934 Y4.4293
N47185 X2.7959 Y4.4114
N47190 X2.7975 Y4.3933
N47195 X2.7986 Y4.375
N47200 X2.797 Y4.3526
N47205 X2.7947 Y4.3305
N47210 X2.7931 Y4.3196
N47215 X2.791 Y4.3089
N47220 X2.7884 Y4.2983
N47225 X2.7852 Y4.288
N47230 X2.7813 Y4.278
N47235 X2.7767 Y4.2681
N47240 X2.7716 Y4.2585
N47245 X2.766 Y4.2491
N47250 X2.7537 Y4.2306
N47255 X2.7407 Y4.2124
N47260 X2.7219 Y4.1965
N47265 X2.7027 Y4.1815
N47270 X2.6928 Y4.1744
N47275 X2.6827 Y4.1679
N47280 X2.6723 Y4.162
N47285 X2.6616 Y4.1567
N47290 X2.6505 Y4.1521
N47295 X2.6392 Y4.1481
N47300 X2.6276 Y4.1446
N47305 X2.6159 Y4.1415
N47310 X2.5919 Y4.1361
N47315 X2.5676 Y4.1315
N47320 X2.5931 Y4.1155
N47325 X2.6056 Y4.1071
N47330 X2.6176 Y4.0982
N47335 X2.6293 Y4.0888
N47340 X2.6405 Y4.0788
N47345 X2.6623 Y4.0581
N47350 X2.6896 Y4.0242
N47355 X2.7029 Y4.0069
N47360 X2.7156 Y3.9892
N47365 X2.7278 Y3.9712
N47370 X2.7397 Y3.953
N47375 X2.7628 Y3.916
N47380 X2.8697 Y3.7453
N47385 X2.6584
N47390 X2.5306 Y3.9357
N47395 X2.5087 Y3.9688
N47400 X2.4861 Y4.0015
N47405 X2.4744 Y4.0175
N47410 X2.4623 Y4.0333
N47415 X2.4375 Y4.0643
N47420 X2.4257 Y4.0756
N47425 X2.4196 Y4.0809
N47430 X2.4131 Y4.0857
N47435 X2.4063 Y4.09
N47440 X2.3992 Y4.0939
N47445 X2.3844 Y4.1007
N47450 X2.3625 Y4.1057
N47455 X2.3515 Y4.1076
N47460 X2.3404 Y4.1091
N47465 X2.3292 Y4.1099
N47470 X2.318 Y4.1104
N47475 X2.2955 Y4.1106
N47480 X2.2597
N47485 Y3.7453
N47490 X2.083
N47495 Y4.1828
N47500 Z0.1606
N47505 G0 Z0.2
N47510 X2.2597 Y4.2502
N47515 Z0.1606
N47520 G1 Z-0.0394 F13.123
N47525 X2.3904 F39.37
N47530 X2.4303 Y4.25
N47535 X2.4503 Y4.2503
N47540 X2.4701 Y4.2511
N47545 X2.49 Y4.2526
N47550 X2.5097 Y4.2549
N47555 X2.5491 Y4.261
N47560 X2.5637 Y4.2674
N47565 X2.5706 Y4.2711
N47570 X2.577 Y4.2754
N47575 X2.5829 Y4.2804
N47580 X2.5884 Y4.2859
N47585 X2.5987 Y4.298
N47590 X2.6067 Y4.3134
N47595 X2.61 Y4.3213
N47600 X2.6126 Y4.3294
N47605 X2.6144 Y4.3378
N47610 X2.6155 Y4.3463
N47615 X2.6166 Y4.3637
N47620 X2.6151 Y4.383
N47625 X2.6137 Y4.3924
N47630 X2.6114 Y4.4016
N47635 X2.6079 Y4.4103
N47640 X2.6035 Y4.4187
N47645 X2.593 Y4.435
N47650 X2.5786 Y4.4477
N47655 X2.5709 Y4.4533
N47660 X2.5629 Y4.458
N47665 X2.5542 Y4.4618
N47670 X2.5452 Y4.4647
N47675 X2.5265 Y4.4693
N47680 X2.4943 Y4.4711
N47685 X2.462 Y4.4721
N47690 X2.3975 Y4.4723
N47695 X2.2597
N47700 Y4.2502
N47705 Z0.1606
N47710 G0 Z0.2
N47715 X2.9675 Y4.2453
N47720 Z0.1606
N47725 G1 Z-0.0394 F13.123
N47730 Y4.6203 F39.37
N47735 X3.1442
N47740 Y4.2318
N47745 X3.5011 Y4.6203
N47750 X3.7387
N47755 X3.4092 Y4.2795
N47760 X3.7566 Y3.7453
N47765 X3.528
N47770 X3.2875 Y4.1559
N47775 X3.1442 Y4.0097
N47780 Y3.7453
N47785 X2.9675
N47790 Y4.2453
N47795 Z0.1606
N47800 G0 Z0.2
N47805 X3.8172 Y3.9594
N47810 Z0.1606
N47815 G1 Z-0.0394 F13.123
N47820 X3.8153 Y3.967 F39.37
N47825 X3.8087 Y3.9983
N47830 X3.8032 Y4.03
N47835 X3.975 Y4.0467
N47840 X3.979 Y4.0288
N47845 X3.9834 Y4.0111
N47850 X3.9888 Y3.994
N47855 X3.992 Y3.9856
N47860 X3.9956 Y3.9775
N47865 X3.9996 Y3.9696
N47870 X4.0042 Y3.962
N47875 X4.0145 Y3.9474
N47880 X4.026 Y3.9333
N47885 X4.038 Y3.9196
N47890 X4.0526 Y3.9102
N47895 X4.0673 Y3.9013
N47900 X4.0825 Y3.8936
N47905 X4.0902 Y3.8904
N47910 X4.0982 Y3.8877
N47915 X4.1063 Y3.8855
N47920 X4.1146 Y3.8838
N47925 X4.1315 Y3.8813
N47930 X4.1487 Y3.8799
N47935 X4.1661 Y3.879
N47940 X4.1833 Y3.8796
N47945 X4.2004 Y3.8806
N47950 X4.2173 Y3.8826
N47955 X4.2256 Y3.884
N47960 X4.2337 Y3.8859
N47965 X4.2417 Y3.8883
N47970 X4.2496 Y3.8912
N47975 X4.2649 Y3.8982
N47980 X4.2799 Y3.9064
N47985 X4.2947 Y3.9151
N47990 X4.3037 Y3.9239
N47995 X4.3122 Y3.9329
N48000 X4.3198 Y3.9423
N48005 X4.3232 Y3.9473
N48010 X4.3262 Y3.9524
N48015 X4.3287 Y3.9578
N48020 X4.3308 Y3.9633
N48025 X4.334 Y3.975
N48030 X4.3362 Y3.9872
N48035 X4.338 Y3.9996
N48040 X4.3367 Y4.0139
N48045 X4.3355 Y4.0209
N48050 X4.3336 Y4.0276
N48055 X4.3309 Y4.0341
N48060 X4.3276 Y4.0404
N48065 X4.3197 Y4.0524
N48070 X4.3056 Y4.0648
N48075 X4.2983 Y4.0704
N48080 X4.2905 Y4.0754
N48085 X4.2822 Y4.0797
N48090 X4.2737 Y4.0835
N48095 X4.2562 Y4.0903
N48100 X4.2211 Y4.1007
N48105 X4.1857 Y4.1106
N48110 X4.1147 Y4.1285
N48115 X4.088 Y4.1354
N48120 X4.0615 Y4.1427
N48125 X4.0354 Y4.1509
N48130 X4.0226 Y4.1556
N48135 X4.0099 Y4.1606
N48140 X3.9975 Y4.166
N48145 X3.9853 Y4.172
N48150 X3.9733 Y4.1784
N48155 X3.9615 Y4.1853
N48160 X3.9383 Y4.1998
N48165 X3.9154 Y4.215
N48170 X3.8981 Y4.2338
N48175 X3.8817 Y4.2529
N48180 X3.8742 Y4.2628
N48185 X3.8672 Y4.2729
N48190 X3.8609 Y4.2833
N48195 X3.8554 Y4.2941
N48200 X3.8508 Y4.3053
N48205 X3.847 Y4.3169
N48210 X3.8439 Y4.3288
N48215 X3.8414 Y4.3409
N48220 X3.8376 Y4.3658
N48225 X3.8348 Y4.3911
N48230 X3.8361 Y4.4078
N48235 X3.8379 Y4.4243
N48240 X3.8405 Y4.4406
N48245 X3.8423 Y4.4485
N48250 X3.8445 Y4.4564
N48255 X3.85 Y4.4718
N48260 X3.8569 Y4.4868
N48265 X3.8646 Y4.5015
N48270 X3.8727 Y4.5161
N48275 X3.8838 Y4.5303
N48280 X3.8953 Y4.544
N48285 X3.9074 Y4.557
N48290 X3.9139 Y4.563
N48295 X3.9206 Y4.5687
N48300 X3.9275 Y4.5741
N48305 X3.9348 Y4.5791
N48310 X3.95 Y4.5883
N48315 X3.9658 Y4.5967
N48320 X3.9819 Y4.6048
N48325 X4.0028 Y4.6119
N48330 X4.0239 Y4.6185
N48335 X4.045 Y4.6242
N48340 X4.0664 Y4.6287
N48345 X4.0881 Y4.6317
N48350 X4.11 Y4.6335
N48355 X4.1541 Y4.6352
N48360 X4.1876 Y4.6341
N48365 X4.2207 Y4.632
N48370 X4.2371 Y4.6303
N48375 X4.2533 Y4.628
N48380 X4.2693 Y4.625
N48385 X4.285 Y4.6213
N48390 X4.3005 Y4.6165
N48395 X4.3156 Y4.6107
N48400 X4.3304 Y4.6041
N48405 X4.345 Y4.5968
N48410 X4.3594 Y4.5889
N48415 X4.3737 Y4.5805
N48420 X4.4021 Y4.563
N48425 X4.4208 Y4.5425
N48430 X4.4298 Y4.532
N48435 X4.4384 Y4.5215
N48440 X4.4466 Y4.5107
N48445 X4.4541 Y4.4996
N48450 X4.4609 Y4.4881
N48455 X4.4667 Y4.4762
N48460 X4.4717 Y4.4639
N48465 X4.4758 Y4.4513
N48470 X4.4792 Y4.4383
N48475 X4.482 Y4.425
N48480 X4.4862 Y4.3978
N48485 X4.4895 Y4.3702
N48490 X4.3129 Y4.3625
N48495 X4.31 Y4.3763
N48500 X4.3067 Y4.3899
N48505 X4.3027 Y4.4031
N48510 X4.2975 Y4.4157
N48515 X4.2944 Y4.4217
N48520 X4.2908 Y4.4275
N48525 X4.2827 Y4.4385
N48530 X4.2737 Y4.4491
N48535 X4.2642 Y4.4594
N48540 X4.2513 Y4.4667
N48545 X4.2381 Y4.4734
N48550 X4.2247 Y4.4792
N48555 X4.2179 Y4.4815
N48560 X4.2109 Y4.4835
N48565 X4.1967 Y4.4862
N48570 X4.182 Y4.4878
N48575 X4.1672 Y4.4886
N48580 X4.1523 Y4.489
N48585 X4.1363 Y4.4884
N48590 X4.1204 Y4.4874
N48595 X4.1047 Y4.4857
N48600 X4.0894 Y4.4826
N48605 X4.0819 Y4.4806
N48610 X4.0745 Y4.478
N48615 X4.06 Y4.472
N48620 X4.0458 Y4.4649
N48625 X4.0318 Y4.4574
N48630 X4.02 Y4.4463
N48635 X4.0149 Y4.4403
N48640 X4.0108 Y4.4338
N48645 X4.0079 Y4.4267
N48650 X4.0059 Y4.4191
N48655 X4.0037 Y4.4031
N48660 X4.006 Y4.3877
N48665 X4.0079 Y4.3804
N48670 X4.0106 Y4.3735
N48675 X4.0145 Y4.3671
N48680 X4.0192 Y4.3611
N48685 X4.03 Y4.3499
N48690 X4.0491 Y4.3396
N48695 X4.0684 Y4.3298
N48700 X4.0881 Y4.3209
N48705 X4.1083 Y4.3133
N48710 X4.1289 Y4.3069
N48715 X4.1499 Y4.3013
N48720 X4.1923 Y4.2915
N48725 X4.2412 Y4.2794
N48730 X4.2655 Y4.2728
N48735 X4.2895 Y4.2655
N48740 X4.3133 Y4.2573
N48745 X4.3367 Y4.2482
N48750 X4.383 Y4.2285
N48755 X4.3973 Y4.2198
N48760 X4.4113 Y4.2107
N48765 X4.4248 Y4.2011
N48770 X4.4374 Y4.1906
N48775 X4.449 Y4.1789
N48780 X4.4597 Y4.1663
N48785 X4.4698 Y4.1531
N48790 X4.4797 Y4.1395
N48795 X4.4877 Y4.1231
N48800 X4.4953 Y4.1065
N48805 X4.5018 Y4.0896
N48810 X4.5046 Y4.0811
N48815 X4.5069 Y4.0724
N48820 X4.5104 Y4.0547
N48825 X4.5125 Y4.0367
N48830 X4.5138 Y4.0185
N48835 X4.5146 Y4.0002
N48840 X4.5132 Y3.9815
N48845 X4.5112 Y3.9629
N48850 X4.5083 Y3.9446
N48855 X4.5064 Y3.9356
N48860 X4.504 Y3.9267
N48865 X4.5011 Y3.918
N48870 X4.4979 Y3.9094
N48875 X4.4903 Y3.8924
N48880 X4.4818 Y3.8758
N48885 X4.4728 Y3.8593
N48890 X4.4609 Y3.8437
N48895 X4.4486 Y3.8285
N48900 X4.4356 Y3.8142
N48905 X4.4287 Y3.8076
N48910 X4.4214 Y3.8013
N48915 X4.4139 Y3.7954
N48920 X4.406 Y3.7899
N48925 X4.3894 Y3.7798
N48930 X4.3722 Y3.7705
N48935 X4.3546 Y3.7617
N48940 X4.3315 Y3.7542
N48945 X4.3082 Y3.7472
N48950 X4.2848 Y3.7411
N48955 X4.273 Y3.7386
N48960 X4.2611 Y3.7364
N48965 X4.2371 Y3.7334
N48970 X4.213 Y3.7315
N48975 X4.1887 Y3.7304
N48980 X4.1643 Y3.7298
N48985 X4.1298 Y3.7312
N48990 X4.0956 Y3.7336
N48995 X4.0788 Y3.7355
N49000 X4.0621 Y3.7379
N49005 X4.0457 Y3.7412
N49010 X4.0295 Y3.7453
N49015 X4.0137 Y3.7503
N49020 X3.9981 Y3.7564
N49025 X3.9829 Y3.7634
N49030 X3.968 Y3.7711
N49035 X3.9531 Y3.7794
N49040 X3.9385 Y3.7882
N49045 X3.9094 Y3.8065
N49050 X3.8881 Y3.8305
N49055 X3.8778 Y3.8427
N49060 X3.8679 Y3.855
N49065 X3.8585 Y3.8677
N49070 X3.8498 Y3.8806
N49075 X3.8419 Y3.894
N49080 X3.8349 Y3.9078
N49085 X3.8289 Y3.9221
N49090 X3.8237 Y3.9367
N49095 X3.8192 Y3.9517
N49100 X3.8172 Y3.9594
N49105 Z0.1606
N49110 G0 Z0.2
N49115 X4.9676 Y3.9852
N49120 Z0.1606
N49125 G1 Z-0.0394 F13.123
N49130 X4.9693 Y4.0057 F39.37
N49135 X4.9715 Y4.0259
N49140 X4.975 Y4.0458
N49145 X4.9773 Y4.0555
N49150 X4.9802 Y4.0651
N49155 X4.9835 Y4.0744
N49160 X4.9875 Y4.0836
N49165 X4.9966 Y4.1016
N49170 X5.0069 Y4.1192
N49175 X5.0178 Y4.1365
N49180 X5.0339 Y4.1544
N49185 X5.0504 Y4.1719
N49190 X5.0676 Y4.1884
N49195 X5.0765 Y4.1962
N49200 X5.0858 Y4.2036
N49205 X5.0954 Y4.2106
N49210 X5.1052 Y4.2174
N49215 X5.1255 Y4.23
N49220 X5.1464 Y4.2418
N49225 X5.1676 Y4.2532
N49230 X5.1485 Y4.2771
N49235 X5.1393 Y4.2893
N49240 X5.1306 Y4.3017
N49245 X5.1224 Y4.3145
N49250 X5.1147 Y4.3276
N49255 X5.1001 Y4.3544
N49260 X5.091 Y4.3763
N49265 X5.087 Y4.3874
N49270 X5.0837 Y4.3987
N49275 X5.0813 Y4.4102
N49280 X5.0796 Y4.4218
N49285 X5.0774 Y4.4454
N49290 X5.0797 Y4.4649
N49295 X5.0828 Y4.4841
N49300 X5.0848 Y4.4934
N49305 X5.0872 Y4.5025
N49310 X5.0902 Y4.5113
N49315 X5.0939 Y4.5199
N49320 X5.0982 Y4.5281
N49325 X5.1032 Y4.5361
N49330 X5.1087 Y4.5438
N49335 X5.1146 Y4.5513
N49340 X5.1275 Y4.5658
N49345 X5.141 Y4.58
N49350 X5.1617 Y4.5931
N49355 X5.1826 Y4.6054
N49360 X5.1932 Y4.6109
N49365 X5.204 Y4.616
N49370 X5.215 Y4.6204
N49375 X5.2263 Y4.624
N49380 X5.2378 Y4.627
N49385 X5.2495 Y4.6293
N49390 X5.2613 Y4.6311
N49395 X5.2733 Y4.6324
N49400 X5.2976 Y4.6342
N49405 X5.3222 Y4.6352
N49410 X5.3464 Y4.634
N49415 X5.3704 Y4.632
N49420 X5.3822 Y4.6306
N49425 X5.3938 Y4.6286
N49430 X5.4053 Y4.6261
N49435 X5.4165 Y4.623
N49440 X5.4275 Y4.6191
N49445 X5.4383 Y4.6145
N49450 X5.4488 Y4.6093
N49455 X5.4591 Y4.6035
N49460 X5.4794 Y4.5909
N49465 X5.4994 Y4.5773
N49470 X5.5131 Y4.5622
N49475 X5.5261 Y4.5468
N49480 X5.5322 Y4.5389
N49485 X5.5377 Y4.5307
N49490 X5.5427 Y4.5223
N49495 X5.547 Y4.5137
N49500 X5.5507 Y4.5046
N49505 X5.5537 Y4.4954
N49510 X5.5561 Y4.4858
N49515 X5.5581 Y4.4761
N49520 X5.5611 Y4.4561
N49525 X5.5633 Y4.4359
N49530 X5.5606 Y4.409
N49535 X5.5584 Y4.3959
N49540 X5.5551 Y4.3831
N49545 X5.5504 Y4.3707
N49550 X5.5448 Y4.3586
N49555 X5.5317 Y4.335
N49560 X5.5178 Y4.3191
N49565 X5.5036 Y4.3035
N49570 X5.4889 Y4.2887
N49575 X5.4732 Y4.2748
N49580 X5.4566 Y4.262
N49585 X5.4394 Y4.2499
N49590 X5.4039 Y4.227
N49595 X5.5257 Y4.0664
N49600 X5.5372 Y4.0905
N49605 X5.5426 Y4.1027
N49610 X5.5474 Y4.115
N49615 X5.5517 Y4.1276
N49620 X5.5556 Y4.1404
N49625 X5.5627 Y4.1661
N49630 X5.7143 Y4.1315
N49635 X5.7057 Y4.1016
N49640 X5.6965 Y4.0719
N49645 X5.6862 Y4.0426
N49650 X5.6749 Y4.0136
N49655 X5.6672 Y3.9973
N49660 X5.6588 Y3.9814
N49665 X5.6493 Y3.9661
N49670 X5.6391 Y3.9512
N49675 X5.6565 Y3.936
N49680 X5.6744 Y3.9212
N49685 X5.6928 Y3.9072
N49690 X5.7116 Y3.8936
N49695 X5.7275 Y3.8825
N49700 X5.7436 Y3.8717
N49705 X5.7601 Y3.8617
N49710 X5.777 Y3.8521
N49715 X5.6755 Y3.7226
N49720 X5.6371 Y3.744
N49725 X5.6184 Y3.7553
N49730 X5.6002 Y3.7674
N49735 X5.5826 Y3.7805
N49740 X5.5656 Y3.7942
N49745 X5.5323 Y3.8229
N49750 X5.5063 Y3.8017
N49755 X5.4929 Y3.7917
N49760 X5.4791 Y3.7824
N49765 X5.4648 Y3.7741
N49770 X5.4499 Y3.7664
N49775 X5.4194 Y3.7525
N49780 X5.3847 Y3.7423
N49785 X5.3672 Y3.738
N49790 X5.3495 Y3.7347
N49795 X5.3317 Y3.7325
N49800 X5.3136 Y3.7311
N49805 X5.2774 Y3.7298
N49810 X5.2429 Y3.7317
N49815 X5.2258 Y3.733
N49820 X5.2088 Y3.7347
N49825 X5.1921 Y3.7371
N49830 X5.1757 Y3.7401
N49835 X5.1596 Y3.7441
N49840 X5.1439 Y3.749
N49845 X5.1287 Y3.7551
N49850 X5.1139 Y3.7624
N49855 X5.0996 Y3.7707
N49860 X5.0856 Y3.7799
N49865 X5.0718 Y3.7898
N49870 X5.0583 Y3.8001
N49875 X5.0315 Y3.8217
N49880 X5.0178 Y3.8399
N49885 X5.0048 Y3.8584
N49890 X4.9988 Y3.8679
N49895 X4.9932 Y3.8775
N49900 X4.9882 Y3.8873
N49905 X4.9839 Y3.8974
N49910 X4.9802 Y3.9077
N49915 X4.9772 Y3.9183
N49920 X4.9748 Y3.9292
N49925 X4.9728 Y3.9402
N49930 X4.9698 Y3.9626
N49935 X4.9676 Y3.9852
N49940 Z0.1606
N49945 G0 Z0.2
N49950 X5.4254 Y3.9351
N49955 Z0.1606
N49960 G1 Z-0.0394 F13.123
N49965 X5.2547 Y4.1458 F39.37
N49970 X5.2301 Y4.1318
N49975 X5.2183 Y4.1242
N49980 X5.207 Y4.1159
N49985 X5.1965 Y4.1067
N49990 X5.1867 Y4.0967
N49995 X5.1682 Y4.0754
N50000 X5.1565 Y4.0558
N50005 X5.1515 Y4.0458
N50010 X5.1473 Y4.0355
N50015 X5.1442 Y4.0248
N50020 X5.1421 Y4.0138
N50025 X5.1395 Y3.9912
N50030 X5.1406 Y3.9787
N50035 X5.142 Y3.9665
N50040 X5.1443 Y3.9545
N50045 X5.1459 Y3.9487
N50050 X5.1479 Y3.9431
N50055 X5.1503 Y3.9376
N50060 X5.1531 Y3.9323
N50065 X5.1597 Y3.9221
N50070 X5.1671 Y3.9123
N50075 X5.175 Y3.9026
N50080 X5.1856 Y3.8947
N50085 X5.1964 Y3.8874
N50090 X5.2075 Y3.8809
N50095 X5.2132 Y3.8782
N50100 X5.2191 Y3.8759
N50105 X5.2313 Y3.8725
N50110 X5.2441 Y3.8704
N50115 X5.257 Y3.8691
N50120 X5.2702 Y3.8683
N50125 X5.2897 Y3.8695
N50130 X5.2994 Y3.8705
N50135 X5.3089 Y3.8722
N50140 X5.3183 Y3.8744
N50145 X5.3276 Y3.8772
N50150 X5.3461 Y3.8838
N50155 X5.3672 Y3.8946
N50160 X5.3775 Y3.9004
N50165 X5.3876 Y3.9066
N50170 X5.3973 Y3.9133
N50175 X5.4068 Y3.9204
N50180 X5.4254 Y3.9351
N50185 Z0.1606
N50190 G0 Z0.2
N50195 X5.3204 Y4.3278
N50200 Z0.1606
N50205 G1 Z-0.0394 F13.123
N50210 X5.3657 Y4.3625 F39.37
N50215 X5.3752 Y4.3702
N50220 X5.3843 Y4.3781
N50225 X5.3926 Y4.3865
N50230 X5.3998 Y4.3955
N50235 X5.4029 Y4.4004
N50240 X5.4056 Y4.4054
N50245 X5.4098 Y4.4163
N50250 X5.4131 Y4.4277
N50255 X5.4159 Y4.4394
N50260 X5.4139 Y4.455
N50265 X5.4122 Y4.4624
N50270 X5.4097 Y4.4695
N50275 X5.4062 Y4.4761
N50280 X5.4018 Y4.4824
N50285 X5.3917 Y4.4944
N50290 X5.377 Y4.5045
N50295 X5.3693 Y4.5088
N50300 X5.3613 Y4.5121
N50305 X5.3529 Y4.5143
N50310 X5.3443 Y4.5157
N50315 X5.3263 Y4.517
N50320 X5.3094 Y4.5159
N50325 X5.3011 Y4.5148
N50330 X5.2931 Y4.5128
N50335 X5.2854 Y4.5099
N50340 X5.278 Y4.5061
N50345 X5.2637 Y4.497
N50350 X5.2544 Y4.4872
N50355 X5.2504 Y4.482
N50360 X5.2471 Y4.4764
N50365 X5.2447 Y4.4704
N50370 X5.243 Y4.4641
N50375 X5.241 Y4.4508
N50380 X5.2432 Y4.4402
N50385 X5.2459 Y4.4298
N50390 X5.2492 Y4.4197
N50395 X5.2536 Y4.4102
N50400 X5.2591 Y4.4011
N50405 X5.2654 Y4.3924
N50410 X5.2792 Y4.3756
N50415 X5.3204 Y4.3278
N50420 Z0.1606
N50425 G0 Z0.2
N50430 X5.376 Y-2.0457
N50435 Z0.1606
N50440 G1 Z-0.0394 F13.123
N50445 X5.6474 F39.37
N50450 X5.6403 Y-2.0669
N50455 X5.6069
N50460 X5.5927 Y-2.0678
N50465 X5.5857 Y-2.0687
N50470 X5.579 Y-2.0702
N50475 X5.5724 Y-2.0724
N50480 X5.5661 Y-2.0753
N50485 X5.5537 Y-2.0822
N50490 X5.5432 Y-2.0926
N50495 X5.5384 Y-2.0981
N50500 X5.5342 Y-2.104
N50505 X5.5306 Y-2.1103
N50510 X5.5274 Y-2.1169
N50515 X5.522 Y-2.1307
N50520 X5.4245 Y-2.4171
N50525 X5.5175
N50530 X5.5322 Y-2.416
N50535 X5.5394 Y-2.4151
N50540 X5.5466 Y-2.4138
N50545 X5.5536 Y-2.412
N50550 X5.5606 Y-2.4097
N50555 X5.5744 Y-2.4047
N50560 X5.5889 Y-2.3976
N50565 X5.6028 Y-2.3897
N50570 X5.6159 Y-2.3806
N50575 X5.6286 Y-2.3707
N50580 X5.6439 Y-2.3566
N50585 X5.6586 Y-2.342
N50590 X5.673 Y-2.3256
N50595 X5.6863 Y-2.3083
N50600 X5.7035 Y-2.2836
N50605 X5.7198 Y-2.2584
N50610 X5.74
N50615 X5.6788 Y-2.4382
N50620 X5.2428
N50625 X5.2492 Y-2.4171
N50630 X5.2689
N50635 X5.2839 Y-2.4147
N50640 X5.2982 Y-2.4116
N50645 X5.305 Y-2.4096
N50650 X5.3115 Y-2.4071
N50655 X5.3176 Y-2.404
N50660 X5.3231 Y-2.4003
N50665 X5.3282 Y-2.3959
N50670 X5.3328 Y-2.3909
N50675 X5.337 Y-2.3853
N50680 X5.3409 Y-2.3793
N50685 X5.348 Y-2.3664
N50690 X5.3546 Y-2.3527
N50695 X5.4301 Y-2.1307
N50700 X5.4328 Y-2.1172
N50705 X5.4339 Y-2.1107
N50710 X5.4346 Y-2.1045
N50715 X5.4347 Y-2.0985
N50720 X5.4343 Y-2.0931
N50725 X5.4331 Y-2.0881
N50730 X5.431 Y-2.0837
N50735 X5.428 Y-2.08
N50740 X5.424 Y-2.077
N50745 X5.4192 Y-2.0745
N50750 X5.4137 Y-2.0724
N50755 X5.4078 Y-2.0707
N50760 X5.4014 Y-2.0693
N50765 X5.388 Y-2.0669
N50770 X5.3688
N50775 X5.376 Y-2.0457
N50780 Z0.1606
N50785 G0 Z0.2
N50790 X5.7895 Y-2.3754
N50795 Z0.1606
N50800 G1 Z-0.0394 F13.123
N50805 X5.793 Y-2.3712 F39.37
N50810 X5.7969 Y-2.3673
N50815 X5.8054 Y-2.3598
N50820 X5.8144 Y-2.3538
N50825 X5.8192 Y-2.3511
N50830 X5.824 Y-2.3489
N50835 X5.8291 Y-2.3473
N50840 X5.8343 Y-2.3461
N50845 X5.8452 Y-2.3447
N50850 X5.8543 Y-2.3456
N50855 X5.8587 Y-2.3465
N50860 X5.8629 Y-2.3479
N50865 X5.8667 Y-2.35
N50870 X5.8702 Y-2.3527
N50875 X5.8768 Y-2.3592
N50880 X5.8806 Y-2.3678
N50885 X5.882 Y-2.3722
N50890 X5.8827 Y-2.3766
N50895 X5.8826 Y-2.3811
N50900 X5.882 Y-2.3857
N50905 X5.8797 Y-2.3949
N50910 X5.8748 Y-2.4053
N50915 X5.872 Y-2.4102
N50920 X5.8689 Y-2.4148
N50925 X5.8652 Y-2.419
N50930 X5.8612 Y-2.423
N50935 X5.8525 Y-2.4304
N50940 X5.8432 Y-2.4364
N50945 X5.8384 Y-2.439
N50950 X5.8335 Y-2.4411
N50955 X5.8283 Y-2.4427
N50960 X5.823 Y-2.4438
N50965 X5.812 Y-2.4452
N50970 X5.8031 Y-2.4442
N50975 X5.7989 Y-2.4433
N50980 X5.7949 Y-2.4418
N50985 X5.7913 Y-2.4396
N50990 X5.788 Y-2.4368
N50995 X5.7818 Y-2.4303
N51000 X5.7781 Y-2.4217
N51005 X5.7768 Y-2.4174
N51010 X5.7761 Y-2.413
N51015 Y-2.4086
N51020 X5.7767 Y-2.4041
N51025 X5.7789 Y-2.3949
N51030 X5.7837 Y-2.3848
N51035 X5.7864 Y-2.38
N51040 X5.7895 Y-2.3754
N51045 Z0.1606
N51050 G0 Z0.2
N51055 X6.0256 Y-2.3175
N51060 Z0.1606
N51065 G1 Z-0.0394 F13.123
N51070 X6.0243 Y-2.3047 F39.37
N51075 X6.0241 Y-2.2919
N51080 X6.0254 Y-2.2792
N51085 X6.0278 Y-2.2665
N51090 X6.0344 Y-2.2411
N51095 X6.0413 Y-2.2241
N51100 X6.0491 Y-2.2075
N51105 X6.0584 Y-2.1917
N51110 X6.0685 Y-2.1763
N51115 X6.0811 Y-2.1602
N51120 X6.0944 Y-2.1447
N51125 X6.1089 Y-2.1303
N51130 X6.124 Y-2.1164
N51135 X6.1393 Y-2.1043
N51140 X6.1552 Y-2.093
N51145 X6.1634 Y-2.0879
N51150 X6.172 Y-2.0832
N51155 X6.1894 Y-2.0744
N51160 X6.2182 Y-2.0597
N51165 X6.2329 Y-2.0533
N51170 X6.2479 Y-2.048
N51175 X6.2633 Y-2.0441
N51180 X6.2791 Y-2.0415
N51185 X6.2951 Y-2.0397
N51190 X6.3113 Y-2.0382
N51195 X6.3299 Y-2.0391
N51200 X6.3483 Y-2.0418
N51205 X6.3564 Y-2.0438
N51210 X6.3643 Y-2.0463
N51215 X6.3719 Y-2.0496
N51220 X6.3793 Y-2.0533
N51225 X6.3865 Y-2.0579
N51230 X6.3934 Y-2.0629
N51235 X6.4062 Y-2.0742
N51240 X6.4105 Y-2.078
N51245 X6.415 Y-2.0814
N51250 X6.42 Y-2.0837
N51255 X6.4254 Y-2.0853
N51260 X6.4423 Y-2.0784
N51265 X6.4503 Y-2.0742
N51270 X6.4578 Y-2.0692
N51275 X6.465 Y-2.0636
N51280 X6.4718 Y-2.0575
N51285 X6.485 Y-2.0446
N51290 X6.503
N51295 X6.445 Y-2.2392
N51300 X6.4257
N51305 X6.4274 Y-2.2211
N51310 X6.4283 Y-2.203
N51315 X6.4276 Y-2.1895
N51320 X6.4258 Y-2.1762
N51325 X6.4225 Y-2.1596
N51330 X6.4205 Y-2.1515
N51335 X6.4181 Y-2.1435
N51340 X6.4152 Y-2.1357
N51345 X6.4118 Y-2.128
N51350 X6.4043 Y-2.113
N51355 X6.3961 Y-2.1009
N51360 X6.3916 Y-2.0952
N51365 X6.3868 Y-2.0899
N51370 X6.3815 Y-2.085
N51375 X6.3759 Y-2.0806
N51380 X6.3639 Y-2.0722
N51385 X6.3508 Y-2.0662
N51390 X6.3441 Y-2.0637
N51395 X6.3373 Y-2.0616
N51400 X6.3303 Y-2.0602
N51405 X6.3232 Y-2.0593
N51410 X6.3088 Y-2.0583
N51415 X6.2915 Y-2.0597
N51420 X6.2831 Y-2.061
N51425 X6.2748 Y-2.0629
N51430 X6.2668 Y-2.0657
N51435 X6.259 Y-2.0692
N51440 X6.2437 Y-2.0774
N51445 X6.2278 Y-2.0904
N51450 X6.2202 Y-2.0973
N51455 X6.2132 Y-2.1047
N51460 X6.2067 Y-2.1126
N51465 X6.2007 Y-2.1209
N51470 X6.1893 Y-2.1381
N51475 X6.1753 Y-2.164
N51480 X6.1687 Y-2.1772
N51485 X6.1625 Y-2.1905
N51490 X6.1568 Y-2.2041
N51495 X6.1515 Y-2.2178
N51500 X6.1415 Y-2.2455
N51505 X6.131 Y-2.2788
N51510 X6.1267 Y-2.2956
N51515 X6.1227 Y-2.3126
N51520 X6.1206 Y-2.3245
N51525 X6.1189 Y-2.3366
N51530 X6.1184 Y-2.3486
N51535 X6.1185 Y-2.3608
N51540 X6.1198 Y-2.3702
N51545 X6.1217 Y-2.3793
N51550 X6.1248 Y-2.3882
N51555 X6.1285 Y-2.3969
N51560 X6.1348 Y-2.4031
N51565 X6.1416 Y-2.4085
N51570 X6.1492 Y-2.4129
N51575 X6.1571 Y-2.4167
N51580 X6.1682 Y-2.4204
N51585 X6.1795 Y-2.4231
N51590 X6.191 Y-2.4244
N51595 X6.2027 Y-2.4249
N51600 X6.2152 Y-2.4244
N51605 X6.2276 Y-2.4233
N51610 X6.2399 Y-2.4212
N51615 X6.2521 Y-2.4186
N51620 X6.2646 Y-2.4148
N51625 X6.2769 Y-2.4106
N51630 X6.2889 Y-2.4054
N51635 X6.3006 Y-2.3997
N51640 X6.3127 Y-2.3929
N51645 X6.3244 Y-2.3856
N51650 X6.3357 Y-2.3776
N51655 X6.3467 Y-2.3692
N51660 X6.3635 Y-2.3542
N51665 X6.3791 Y-2.3379
N51670 X6.3963 Y-2.3159
N51675 X6.4122 Y-2.2929
N51680 X6.4317
N51685 X6.4244 Y-2.3055
N51690 X6.4169 Y-2.3178
N51695 X6.4087 Y-2.3298
N51700 X6.4 Y-2.3414
N51705 X6.3843 Y-2.3586
N51710 X6.3673 Y-2.3746
N51715 X6.3474 Y-2.3895
N51720 X6.3272 Y-2.4037
N51725 X6.3169 Y-2.4103
N51730 X6.3065 Y-2.4164
N51735 X6.2957 Y-2.422
N51740 X6.2848 Y-2.4269
N51745 X6.2735 Y-2.431
N51750 X6.262 Y-2.4345
N51755 X6.2502 Y-2.4373
N51760 X6.2383 Y-2.4397
N51765 X6.2139 Y-2.4433
N51770 X6.1892 Y-2.446
N51775 X6.1622 Y-2.4442
N51780 X6.1489 Y-2.4425
N51785 X6.136 Y-2.4397
N51790 X6.1234 Y-2.4357
N51795 X6.1111 Y-2.4305
N51800 X6.087 Y-2.4183
N51805 X6.0682 Y-2.403
N51810 X6.0596 Y-2.3948
N51815 X6.0519 Y-2.3859
N51820 X6.0454 Y-2.3761
N51825 X6.0398 Y-2.3655
N51830 X6.0303 Y-2.3433
N51835 X6.0277 Y-2.3304
N51840 X6.0256 Y-2.3175
N51845 Z0.1606
N51850 G0 Z0.2
N51855 X6.5107 Y-2.2909
N51860 Z0.1606
N51865 G1 Z-0.0394 F13.123
N51870 X6.5114 Y-2.2811 F39.37
N51875 X6.5129 Y-2.2712
N51880 X6.515 Y-2.2615
N51885 X6.5204 Y-2.2421
N51890 X6.5328 Y-2.214
N51895 X6.5397 Y-2.2004
N51900 X6.5475 Y-2.1874
N51905 X6.5563 Y-2.175
N51910 X6.566 Y-2.1632
N51915 X6.5867 Y-2.1404
N51920 X6.6118 Y-2.1183
N51925 X6.6248 Y-2.1078
N51930 X6.6383 Y-2.098
N51935 X6.6524 Y-2.0891
N51940 X6.6669 Y-2.081
N51945 X6.6969 Y-2.0658
N51950 X6.727 Y-2.0544
N51955 X6.7422 Y-2.0495
N51960 X6.7576 Y-2.0455
N51965 X6.7733 Y-2.0426
N51970 X6.7892 Y-2.0406
N51975 X6.8213 Y-2.0382
N51980 X6.8454 Y-2.0393
N51985 X6.8574 Y-2.0404
N51990 X6.8692 Y-2.0421
N51995 X6.8809 Y-2.0447
N52000 X6.8924 Y-2.048
N52005 X6.9153 Y-2.0558
N52010 X6.9333 Y-2.0655
N52015 X6.9419 Y-2.0708
N52020 X6.9499 Y-2.0768
N52025 X6.9573 Y-2.0836
N52030 X6.9641 Y-2.091
N52035 X6.9769 Y-2.1069
N52040 X6.9851 Y-2.1219
N52045 X6.9888 Y-2.1296
N52050 X6.9919 Y-2.1375
N52055 X6.9943 Y-2.1456
N52060 X6.9961 Y-2.1539
N52065 X6.999 Y-2.1708
N52070 X6.9994 Y-2.1891
N52075 X6.9992 Y-2.1982
N52080 X6.9984 Y-2.2073
N52085 X6.9969 Y-2.2162
N52090 X6.9949 Y-2.2251
N52095 X6.99 Y-2.2428
N52100 X6.9777 Y-2.2709
N52105 X6.9708 Y-2.2845
N52110 X6.963 Y-2.2976
N52115 X6.9543 Y-2.31
N52120 X6.9446 Y-2.3219
N52125 X6.924 Y-2.3447
N52130 X6.8989 Y-2.3667
N52135 X6.886 Y-2.3771
N52140 X6.8726 Y-2.3867
N52145 X6.8585 Y-2.3955
N52150 X6.844 Y-2.4035
N52155 X6.8141 Y-2.4184
N52160 X6.7835 Y-2.4296
N52165 X6.768 Y-2.4345
N52170 X6.7523 Y-2.4385
N52175 X6.7363 Y-2.4413
N52180 X6.7202 Y-2.4432
N52185 X6.6876 Y-2.4455
N52190 X6.6656 Y-2.4445
N52195 X6.6546 Y-2.4435
N52200 X6.6438 Y-2.442
N52205 X6.6331 Y-2.4398
N52210 X6.6225 Y-2.4369
N52215 X6.6015 Y-2.4302
N52220 X6.5844 Y-2.4219
N52225 X6.5762 Y-2.4173
N52230 X6.5683 Y-2.4122
N52235 X6.561 Y-2.4065
N52240 X6.554 Y-2.4002
N52245 X6.5407 Y-2.3867
N52250 X6.5304 Y-2.3716
N52255 X6.5257 Y-2.3639
N52260 X6.5218 Y-2.3558
N52265 X6.5186 Y-2.3474
N52270 X6.516 Y-2.3388
N52275 X6.5119 Y-2.321
N52280 X6.5107 Y-2.3009
N52285 Y-2.2909
N52290 Z0.1606
N52295 G0 Z0.2
N52300 X6.8211 Y-2.0594
N52305 Z0.1606
N52310 G1 Z-0.0394 F13.123
N52315 X6.8091 Y-2.0601 F39.37
N52320 X6.7972 Y-2.0615
N52325 X6.7855 Y-2.0641
N52330 X6.7739 Y-2.0675
N52335 X6.7625 Y-2.0721
N52340 X6.7515 Y-2.0774
N52345 X6.741 Y-2.0837
N52350 X6.7309 Y-2.0907
N52355 X6.7201 Y-2.0998
N52360 X6.7096 Y-2.1093
N52365 X6.6999 Y-2.1195
N52370 X6.6905 Y-2.1301
N52375 X6.6811 Y-2.1423
N52380 X6.6721 Y-2.1549
N52385 X6.6639 Y-2.1679
N52390 X6.6561 Y-2.1813
N52395 X6.6486 Y-2.1963
N52400 X6.6415 Y-2.2115
N52405 X6.6353 Y-2.227
N52410 X6.6295 Y-2.2428
N52415 X6.6238 Y-2.2612
N52420 X6.6189 Y-2.2799
N52425 X6.6154 Y-2.2988
N52430 X6.613 Y-2.318
N52435 X6.6125 Y-2.3326
N52440 X6.6131 Y-2.3471
N52445 X6.6141 Y-2.3542
N52450 X6.6156 Y-2.3614
N52455 X6.6193 Y-2.3755
N52460 X6.6241 Y-2.3862
N52465 X6.6268 Y-2.3912
N52470 X6.63 Y-2.396
N52475 X6.6336 Y-2.4004
N52480 X6.6377 Y-2.4044
N52485 X6.6467 Y-2.4119
N52490 X6.6578 Y-2.4174
N52495 X6.6635 Y-2.4198
N52500 X6.6693 Y-2.4216
N52505 X6.6752 Y-2.4228
N52510 X6.6813 Y-2.4236
N52515 X6.6938 Y-2.4243
N52520 X6.7134 Y-2.4224
N52525 X6.7231 Y-2.4209
N52530 X6.7325 Y-2.4186
N52535 X6.7417 Y-2.4153
N52540 X6.7507 Y-2.4114
N52545 X6.7682 Y-2.4023
N52550 X6.7869 Y-2.3888
N52555 X6.7958 Y-2.3816
N52560 X6.8043 Y-2.3739
N52565 X6.8122 Y-2.3656
N52570 X6.8196 Y-2.3569
N52575 X6.8339 Y-2.3388
N52580 X6.8487 Y-2.3151
N52585 X6.8557 Y-2.3031
N52590 X6.8622 Y-2.2908
N52595 X6.868 Y-2.2782
N52600 X6.8733 Y-2.2654
N52605 X6.8832 Y-2.2393
N52610 X6.8885 Y-2.2221
N52615 X6.893 Y-2.2048
N52620 X6.8961 Y-2.1872
N52625 X6.8984 Y-2.1695
N52630 X6.899 Y-2.1552
N52635 X6.8986 Y-2.141
N52640 X6.8977 Y-2.134
N52645 X6.8965 Y-2.127
N52650 X6.8932 Y-2.1131
N52655 X6.8888 Y-2.1023
N52660 X6.8862 Y-2.0971
N52665 X6.8833 Y-2.0922
N52670 X6.8798 Y-2.0876
N52675 X6.876 Y-2.0832
N52680 X6.8676 Y-2.0751
N52685 X6.8628 Y-2.0716
N52690 X6.8577 Y-2.0685
N52695 X6.8468 Y-2.0638
N52700 X6.8405 Y-2.062
N52705 X6.8342 Y-2.0605
N52710 X6.8277 Y-2.0597
N52715 X6.8211 Y-2.0594
N52720 Z0.1606
N52725 G0 Z0.2
N52730 X7.0996 Y-2.0669
N52735 Z0.1606
N52740 G1 Z-0.0394 F13.123
N52745 X7.1069 Y-2.0457 F39.37
N52750 X7.2754
N52755 X7.3161 Y-2.3376
N52760 X7.5544 Y-2.0457
N52765 X7.7143
N52770 X7.707 Y-2.0669
N52775 X7.6873
N52780 X7.6731 Y-2.0678
N52785 X7.6661 Y-2.0687
N52790 X7.6593 Y-2.0703
N52795 X7.6528 Y-2.0725
N52800 X7.6464 Y-2.0754
N52805 X7.634 Y-2.0823
N52810 X7.6235 Y-2.0927
N52815 X7.6187 Y-2.0982
N52820 X7.6144 Y-2.104
N52825 X7.6108 Y-2.1103
N52830 X7.6076 Y-2.1169
N52835 X7.6021 Y-2.1307
N52840 X7.5266 Y-2.3527
N52845 X7.5228 Y-2.3649
N52850 X7.5215 Y-2.3709
N52855 X7.5208 Y-2.377
N52860 X7.5209 Y-2.383
N52865 X7.522 Y-2.389
N52870 X7.5257 Y-2.401
N52875 X7.5348 Y-2.4087
N52880 X7.5397 Y-2.4117
N52885 X7.5449 Y-2.414
N52890 X7.5505 Y-2.4154
N52895 X7.5563 Y-2.4161
N52900 X7.5684 Y-2.4165
N52905 X7.5881
N52910 X7.5807 Y-2.4382
N52915 X7.3227
N52920 X7.3301 Y-2.4165
N52925 X7.352
N52930 X7.3663 Y-2.4156
N52935 X7.3732 Y-2.4147
N52940 X7.38 Y-2.4131
N52945 X7.3866 Y-2.4109
N52950 X7.393 Y-2.408
N52955 X7.4054 Y-2.4011
N52960 X7.4159 Y-2.3907
N52965 X7.4207 Y-2.3852
N52970 X7.425 Y-2.3794
N52975 X7.4286 Y-2.3731
N52980 X7.4317 Y-2.3665
N52985 X7.4372 Y-2.3527
N52990 X7.5236 Y-2.0988
N52995 X7.5318
N53000 X7.2525 Y-2.4382
N53005 X7.236
N53010 X7.1854 Y-2.0999
N53015 X7.1937
N53020 X7.1119 Y-2.3404
N53025 X7.1089 Y-2.3505
N53030 X7.1067 Y-2.3606
N53035 X7.1063 Y-2.3657
N53040 Y-2.3709
N53045 X7.107 Y-2.3813
N53050 X7.1096 Y-2.389
N53055 X7.1113 Y-2.3927
N53060 X7.1133 Y-2.396
N53065 X7.1158 Y-2.399
N53070 X7.1187 Y-2.4018
N53075 X7.1252 Y-2.4068
N53080 X7.1361 Y-2.4113
N53085 X7.1417 Y-2.4132
N53090 X7.1474 Y-2.4146
N53095 X7.1591 Y-2.4162
N53100 X7.1711 Y-2.4168
N53105 X7.1638 Y-2.4382
N53110 X6.9733
N53115 X6.9807 Y-2.4165
N53120 X6.9901
N53125 X7.0065 Y-2.415
N53130 X7.0144 Y-2.4137
N53135 X7.0222 Y-2.4117
N53140 X7.0296 Y-2.4088
N53145 X7.0368 Y-2.4051
N53150 X7.0508 Y-2.3966
N53155 X7.0631 Y-2.385
N53160 X7.0689 Y-2.3788
N53165 X7.0739 Y-2.3722
N53170 X7.0783 Y-2.3652
N53175 X7.0821 Y-2.3577
N53180 X7.0887 Y-2.3421
N53185 X7.1606 Y-2.1307
N53190 X7.1644 Y-2.1185
N53195 X7.1658 Y-2.1125
N53200 X7.1665 Y-2.1064
N53205 X7.1664 Y-2.1003
N53210 X7.1654 Y-2.0943
N53215 X7.1618 Y-2.0823
N53220 X7.1525 Y-2.0746
N53225 X7.1476 Y-2.0716
N53230 X7.1423 Y-2.0694
N53235 X7.1367 Y-2.068
N53240 X7.1308 Y-2.0673
N53245 X7.1186 Y-2.0669
N53250 X7.0996
N53255 Z0.1606
N53260 G0 Z0.2
N53265 X-4.5839 Y4.0915
N53270 Z0.1606
N53275 G1 Z-0.0394 F13.123
N53280 X-4.7045 Y4.4162 F39.37
N53285 X-4.8227 Y4.0915
N53290 X-4.5839
N53295 Z0.1606
N53300 G0 Z0.6
N53305 M5
N53310 G54 G0 Z0.
N53315 M30
%- bridges67
- bridges67
03 Sep 2025 13:30
Replied by bridges67 on topic Program cnc linux
Program cnc linux
Category: Milling Machines
I tried to up load a jpg file but it kept saying didn't load.
03 Sep 2025 12:40 - 03 Sep 2025 12:41
Replied by andypugh on topic Program cnc linux
Program cnc linux
If the preview is correct, but the physical part is rotated and flipped, it may be that your axis directions are configured wrongly.
Jogging X+ should move the _tool_ to the right relative to the _work_
Jogging Y+ should move the tool away from the operator relative to the work.
Or, if you prefer:
Y+ = North
Y- = South
X+ = East
X- = West.
But everything describes the motion of the tool relative to the work, not the motion of the work relative to the world.
It can be confusing with moving-table machines, for example a standard bed mill will be table-left for X+.
Another possibility is that you have a rotation offset in the work coordinate system.
G10 L2 R0 in the MDI tab should fix that.
linuxcnc.org/docs/html/gcode/coordinates.html
Or, if you prefer:
Y+ = North
Y- = South
X+ = East
X- = West.
Time to create page: 0.610 seconds
