  • Hakan
  • Hakan
09 Jun 2025 22:38 - 09 Jun 2025 22:52
Replied by Hakan on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
Run the "lcec_configgen" command and compare.
Also check for relevant error messages from the command "sudo dmesg"
Edit, and according to the xml you attached, output 8 to 15 is in syncmanager 1, but you'll see that.
  • PCW
  • PCW's Avatar
09 Jun 2025 22:32 - 09 Jun 2025 22:34
Replied by PCW on topic Encoder for rigid tapping
Category: HAL
Sounds like you have the encoder component set to counter mode
rather than quadrature mode (counter mode set to 1 rather than 0)
( another hint is your scaling, a 50 PPR encoder is 200 counts/turn
in 4x quadrature )
man encoder
  • russkinch
  • russkinch's Avatar
09 Jun 2025 22:12
Encoder for rigid tapping was created by russkinch
Category: HAL
I have a 50p/r encoder with A, B & Z. It threads perfect and can thread at 1000rpm no hassles. I am trying to do rigid tapping, but when I use G33.1, it taps to the right depth, but when the chuck reverses, the tap goes in more and not out. Its like the stepper is not being told to reverse direction.
In my HAL file I have the three inputs setup (net spindle-phase-a encoder.0-phase-A) etc, I have the scale set to 50 and encoder mode set to 1. When I turn the chuck by hand, the position in HAL view rises by 1 for every 1 revolution of the chuck, but if I turn the chuck in the opposite direction, it carries on increasing and not count down. Is this correct? My encoder is an incremental Omron E6B2-CWZ6C. I am using a prallel port BOB (blue). Nema32 stepper motors and can control my spindle speed via the VFD (Bosch)
Any help is greatly appreciated.
  • jay
  • jay
09 Jun 2025 21:57
Replied by jay on topic Career in LinuxCNC/machine building
I appreciate the recomendation. Is it common that guys in the forums who have been building cnc machines for years (for a living) actually have one of these degrees?
Thank you
  • jay
  • jay
09 Jun 2025 21:50
Yes, in fact I have been considering this exact business. I looked for a local apprenticeship, but couldn't find anyone doing this kind of work locally. A guy on youtube has some great videos. It fits my interests and skills - I wonder how I could find my chances of getting customers. While I do not have a large truck, I can certainly factor that into the costs. If anyone here is involved in this kind of business please let me know the pros and cons.
Thank you langdons
  • jay
  • jay
09 Jun 2025 21:43
Excellent idea, you're getting the wheels turning. This gives me something to research. If anyone else here is doing this, please chime in.
  • jay
  • jay
09 Jun 2025 21:41
Thank you, sir. I should've clarified: while I'm currently in the Eastern US, I didn't mean to ask others to tell me about the market in my area (I feel like that would be asking you to do my homework); I just meant I would like to know how to research the market in my area - what should I be looking for (assets, pitfalls, etc).
  • beauxnez
  • beauxnez
09 Jun 2025 20:10 - 09 Jun 2025 20:15
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
I managed to remove the emergency
I configured the card 10.10.10.11
All that remains is to test with stepper motors,I have a plasma CNC, it will be complicated for a beginner to have the plasmac interface?
  • beauxnez
  • beauxnez
09 Jun 2025 20:06
Replied by beauxnez on topic cnc sur bordeaux
cnc sur bordeaux
Category: Français
Envoie moi un sms au 0699361110 quand tu vois ce message
je t'ai envoyer un sms?
  • beauxnez
  • beauxnez
09 Jun 2025 20:03
For card configuration?
adresse =10.10.10.10
network mask = 24 ??
network mask =  ???
  • beauxnez
  • beauxnez
09 Jun 2025 19:53
09 Jun 2025 19:49
Replied by tommylight on topic Board for reading 3 encoders
You can get Mesa from Germany or Portugal, so no customs nor VAT as they are in Europe and the VAT is already included:
www.welectron.com
www.eusurplus.com
And yes, i also think Remora can do 1 encoder from what i read about it, so you might ask in their topic if anyone can help add more.
Might also want to check the hal2udp project on github, it has no encoders but should be fairly easy to add them as it uses ESP32.
  • unknown
  • unknown
09 Jun 2025 19:37
Replied by unknown on topic Flyback diode mesa 7i95t
Category: Driver Boards
The function of an optocoupler is to completely isolate one side of a circuit from another. Hence the large no copper regions under the device.
No amount of filtering, hoping nor thinking will provide this if the same supply is used or if 2 different supplied are used and their grounds connected.
Pickup a book, read & learn.
Eventually your mis advice will end with someone with less knowledge and experience than yourself having a bad time.
Those unseen electrons moving around can bite.
Displaying 13576 - 13590 out of 17419 results.
Time to create page: 0.459 seconds
