  • Aciera
  • Aciera's Avatar
02 Aug 2024 18:33
Replied by Aciera on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
I buy and use professional devices, I pay money for these devices. I only shared this to prevent anyone from getting hurt. Because I can't do something I did a week ago a week later. For example, who can guess that something that worked a week ago won't work a week later. And since I worked it before, I could start a new job thinking it would work again and I could be disappointed. My aim is to prevent others from falling into these situations. .
People like you just make me sad I'm just glad there are not too many like you around here.
  • Aciera
  • Aciera's Avatar
02 Aug 2024 18:20
Replied by Aciera on topic How to put a password on the exit button
Category: Gmoccapy
How can I put a password on the exit button?
You would have to modify the gmoccapy source code for this.
How do I check the g code renewal key from Classicladder?
you can't as there is no hal pin or state tag that reflects the reload action. You would need to handle this in the GUI source code.
  • meister
  • meister
02 Aug 2024 18:17
we have 2 buffers like this:
reg [31:0] tx_data;
reg [31:0] rx_data;
when a packet is received on port 2390 (UDP),
it should be written to rx_data and the data from tx_data
directly send back to the sender.
thats all in the first step.
later we need a check if the received package have the correct ID
I am one step further with the w5500,
the problem is here:
        end else if (state == STATE_RX_START) begin
            rx_buffer_read_pointer <= rx_buffer_read_pointer + data_read[7:0];
            if (rx_size == (BUFFER_SIZE_RX+HEADER_SIZE)) begin
                stat <= 3;
                rx_buffer_valid <= 1;
                current_instruction <= {8'd0, rx_buffer_read_pointer, BSB_S0_RX_RWB_READ};
                spi_clk <= 1'b0;
                state <= STATE_PULLING_DATA;
                spi_chip_select_n <= 1'b0;
                spi_clock_count <= 10'd0;
                is_busy <= 1'b1;
            end else begin
                stat <= rx_size;
                rx_buffer_valid <= 0;
                state <= STATE_RX_WRITE_PTR1;
                is_busy <= 1'b1;
            end
rx_size is only 8bit, so it will not send back a package and then we get the timeout
  • Aciera
  • Aciera's Avatar
02 Aug 2024 18:11
Category: EtherCAT
I installed it on another computer a few weeks ago and there was no problem.
I think Linuxcnc's ethercat support can be turned off by someone who provides this support whenever they want.
I think Linuxcnc is not suitable for professional use because an installation that could be done last week cannot be done this week.
For example, let's imagine a person who is building a machine with Linux, everything is finished and it is at the operating stage. There is an ethercat problem right now and it can't be solved. How can it wait for it to be fixed? It can't wait, that's why it doesn't use Linuxcnc, it uses professional devices. Yes, Linuxcnc may be free, but it doesn't matter if it is free if it doesn't work when it should.
Well look at what happened to all those pros using Windows a couple of weeks ago.
I'm sorry but this kind of consumer attitude is not helpful, if you need 100% reliability and availability then you may want to consider investing the 20 or 30 grand in a professional solution.
You may not be aware of this but pretty much everything here is the result of donated time. Made available to the public to enable people like you build things they could not otherwise dream of making, this forum included. Where is your contribution to warrant such a fit?
  • Moutomation
  • Moutomation
02 Aug 2024 18:08 - 06 Aug 2024 18:13
Replied by Moutomation on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
Linuxcnc is best cnc
  • scottlaird
  • scottlaird's Avatar
02 Aug 2024 18:01
Replied by scottlaird on topic New LinuxCNC-Ethercat git tree
Category: EtherCAT
Sorry, just saw this. Digital works, analog doesnt? Have you tested both the analog in and out, or just the out?
I'll double check the code vs the specs and see if anything leaps out.
  • scottlaird
02 Aug 2024 17:57
Replied by scottlaird on topic linuxcnc 2.9.2 ethercat problem
Category: EtherCAT
IIRC, the Ethercat people just did a major version upgrade after literally years of leading up to it. We should probably either pin LCEC to v 1.5.x or see what it takes to fix whatever upgrade problems are happening. I'll take a look at it later today if possible.
The larger issues are kind of complex, and discussing them would get in the way of fixing the short-term bug. I'll just say that if you really want to depend on something in a production environment, then you either want to be paying someone for dependable support, have the ability to fix just about anything yourself, or be able to live without it for a while. This isn't LinuxCNC-specific, or really specific to any technology at all.
I don't know of anyone offering this level of support for LinuxCNC today, but I've never really looked.
  • Aciera
  • Aciera's Avatar
02 Aug 2024 17:55 - 02 Aug 2024 19:47
Replied by Aciera on topic Error at startup
Error at startup
Category: Configuration Tools
Seems to be an error message that pops up when secure boot is enabled.
See:
forum.linuxcnc.org/9-installing-linuxcnc...i-o-privileges-error
Here is a post by dewey (confirming the issue of secure boot and parallel port):
www.forum.linuxcnc.org/9-installing-linu...o-make-setuid#244223
According to this the issue was supposedly fixed a while ago.
github.com/LinuxCNC/linuxcnc/issues/1272
  • Moutomation
  • Moutomation
02 Aug 2024 17:54 - 06 Aug 2024 18:13
Category: EtherCAT
rodw is very helpful to everyone regarding ethercat.
  • Mecanix
  • Mecanix
02 Aug 2024 17:24 - 02 Aug 2024 17:25
at the moment, i try to debug a little bit the old w5500 driver and found out that it do not receive the last package
I'll standby. That's awesome news to hear, I know you'll figure it out with time. Oh man!!
ps. yes gigabit phy. Correct. If you need the bitstream, shoot an addy I can email -or- a drag & drop box.
  • Mecanix
  • Mecanix
02 Aug 2024 17:20
@meister
A 1000 meg base ethernet/phy onto "rgmii_txc & rgmii_rxc" buffers. Have a look and let us know if RIO can deal these two buffers.
Let's get this lag over with and league up a notch!
Synthesized, Placed and Routed Code in hands. If interested, DM an address I can send bitstream source too [16mb].
RTL8211FD Schematic attached (pdf). Same real-estate as the wizzy part, 10x performance increase though.
  • RLA
  • RLA
02 Aug 2024 17:16
Hardware needed to switch from mach 3 6 axis to linuxcnc 9 axis
Hi...new here..I have a home built cnc running mach 3.. 6 axis and need to quickly switch to linuxcnc to take advantage of the 9 axis that I will need for an upcoming project. done some reading to be confident it should not be a problem but i am not real clear on what i will need to order in terms of hardware...I currently go from typical BOB to Ethernet smooth stepper which seems like need to be replaced...currently steppers but may want closed loop also..Also pc requirements?
If anyone can list what would be required I would be so grateful as I do not have much time to research...
Thanks,
Rick
  • meister
  • meister
02 Aug 2024 17:14
puhh, realy gigabit ? hmm, if it's work
i can run LAN8720 & RTL8201F on the tangprimer, so there is allready code for it as a base
  • JamesHoward
  • JamesHoward
02 Aug 2024 17:06 - 02 Aug 2024 17:18
Replied by JamesHoward on topic Is a parport fast enough?
I know Chats algo's arent perfect.. Its like a highschooler still.
I guess it's more like a hallucinating 8 year old who read too many twitter and youtube comments and thinks he knows everything about the world. And of course, don't listen to the people who wrote these algorithms, because they do anything in their power to pump up the hype.
And sure, these bots can be valuable in some niche area's such as sorting through huge amounts of data which would be impossible for humans, but for many things they're not better than mostly random guesses at the moment.
I will actually have to respectfully disagree to this one. "High"schooler I think would be pretty relevant. I have never seen and 8 year old whip up a 1000 word arduino sketch in under 5 minutes. That is one thing that I do use GPT for. It is actually pretty decent at C code... I have lots of microcontroller running of its code. And its also better at finding things on the net than, I hate to say it, Google...... Im sorry oh great oracle, please dont smite me for saying it.....
  • Moutomation
  • Moutomation
02 Aug 2024 16:46 - 06 Aug 2024 18:12
linuxcnc 2.9.2 ethercat problem was created by Moutomation
Category: EtherCAT
Displaying 24541 - 24555 out of 24577 results.
Time to create page: 0.427 seconds
