  • rodw
  • rodw's Avatar
04 Feb 2026 23:06
Replied by rodw on topic Building from source for Trixie
Category: Installing LinuxCNC
I have done a video on this. There is a bookmark for cloning and compiling.
Master branch build process has been updated but I think there is a typo in the docs. Now getting dependencies is done the debian way with a single command line. This is an amazing improvement :)
  • rodw
  • rodw's Avatar
04 Feb 2026 22:54
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
So I reverted to Dominic's original component cia402.comp based on feedback here so I could get back to basics
Now I have learnt/refreshed my knowledge about ethercat, I used halshow to list all of the lcec pins and noticed the familiar value of 561 but it was on the wrong pin. Checking the XML, I had included a torque pin but there is no PDO or SDO for it (I had tested this earlier with raw ethercat command line commands). So I deleted the entry in my xml. Everything is now mapped correctly. But only Drive/Joint 0 works correctly. lcec and cia402 follow each other but motion only happens on X (Joint/Drive 0)
Joint position/fb follow lcec and cia402 when jogging but for some reason the 3 higher drives don't move.
I've attached the revised XML and my CIA402 hal and ini files. I don't tthink I have mapped anything incorrectly in hal
  • Ismacr63
  • Ismacr63
04 Feb 2026 22:38
Replied by Ismacr63 on topic T3D-L20A-RABF configuration help
Category: Turning
Tomorrow I'll do a new axis configuration to test and compare the hal and ini files again. Would my hal file be correct for normal operation?
  • PCW
  • PCW's Avatar
04 Feb 2026 22:30 - 04 Feb 2026 22:34
Mesa 7i90HD no comunication/ update erprobte on 2nd mesa (Solved)
Category: Driver Boards
Yeah, if you just used the seveni90 project you will get a EPP configuration.
if you used the seveni90spi project you will get a SPI configuration and if you used
the seveni90ssrm project you will get a SSerial configuration.
(There is one more 7I90 option: hm2serial)
So unless you made some build error its likely you have loaded EPP configurations
The best way out is probably to get  JTAG programmer, program the FPGA with a working
bitfile with the desired interface and then use mesaflash to restore the EEPROM contents
04 Feb 2026 22:30
Replied by tommylight on topic initramfs-tools error (sudo apt upgrade)
Check the error, does it mention somewhere "raspi" ?
Is this the 2.9.8 version?
04 Feb 2026 22:25
Replied by tommylight on topic Building from source for Trixie
The only 2.10 deb i can find is from buster, so quite old, here
buildbot.linuxcnc.org/dists/buster/maste...reempt/binary-amd64/
  • tar_san
  • tar_san
04 Feb 2026 22:22
I installed from Official LCNC ISO to N150 PC , and right after did this,
sudo apt update sudo apt upgrade
I got error ,
dpkg  initramfs-tools error (--configure):
error exit status 1
My questions are
1) Is it OK to use LCNC in this situation ?
2) Are there any ways to solve this error ?
  • PCW
  • PCW's Avatar
04 Feb 2026 22:15
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Do you get near 0V on the analog output
when the 7I97T is powered but LinuxCNC is not running?
  • persei8
  • persei8's Avatar
04 Feb 2026 21:59
Replied by persei8 on topic Building from source for Trixie
Thanks tommylight but I'm trying to build from master branch. Probably should have mentioned that.
Jim
  • PCW
  • PCW's Avatar
04 Feb 2026 21:56
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
What program  printed the error message?
Are you using the latest mesaflash?
Could you JTAG program the FPGA chip and get Ethernet access?
If so what does
mesaflash --device Ethernet --addr [card_ip_addr] --verbose
print?
  • Hakan
  • Hakan
04 Feb 2026 21:19
Replied by Hakan on topic Forum Fehler, ... :-(
Category: Deutsch
Yes it has been going on for a long time.
Very long latency, it is almost like it isn't using a RT kernel.
  • Hakan
  • Hakan
04 Feb 2026 18:24
Stepperonline Y series/ YAKO YKD2608PE configuration
Category: EtherCAT
That seems to be ok.
The error message is in the output from the linuxcnc command
And if you look in the ethercat-conf.xml you find the word BLANK
In place of BLANK there should be one of the hal types u32, s32, float-ieee, bit.
Have a look at the ethercat-conf.xml in this example I often refer to
github.com/dbraun1981/hal-cia402/tree/main/example
Modify both the halType and the halPin .
This example also shows how you use the cia402 component to
connect the servo drives to the joints.
  • NWE
  • NWE's Avatar
04 Feb 2026 18:21
Replied by NWE on topic Help please - Linear Scale only homing
Category: Basic Configuration
Perfect, thanks! I skimmed over that page too fast trying to find index only homing and overlooked that detail. I guess I was depending too much on searches which were not getting me anywhere.
04 Feb 2026 17:58
linuxcnc.org/dists/trixie/2.9-uspace/bin...pace_2.9.8_amd64.deb
Download and double click to install with gdebi, and in case gdebi is missing:
sudo apt update
sudo apt install gdebi
04 Feb 2026 17:53
Replied by tommylight on topic T3D-L20A-RABF configuration help
Category: Turning
There is nothing pertaining to spindle in the ini file, not sure if that is the issue, but it is easier to make a new config with the spindle included using stepconf wizard.
Displaying 2881 - 2895 out of 17282 results.
Time to create page: 0.356 seconds
