Stepperonline Y series/ YAKO YKD2608PE configuration
  • IndeeSales
  • IndeeSales's Avatar Topic Author
  • Visitor
  • Visitor
29 Jan 2026 22:25 #342178 by IndeeSales
Hello I have been trying to get theses stepper drives configured along with a beckhoff EK1100 and have had no luck at all. I have followed the Ethercat step by step instructions and seem to have hit a wall. Any help would be appreciated. Attached is my pdos and ethercat slaves
File Name: ethercatslaves.txt
File Size:0 KB
File Name: ethercatpdos.txt
File Size:4 KB
30 Jan 2026 17:28 - 30 Jan 2026 17:29 #342219 by Hakan
The output of the command "lcec_configgen" is usually a good starting point.
Last edit: 30 Jan 2026 17:29 by Hakan.
The following user(s) said Thank You: IndeeSales
31 Jan 2026 09:06 #342244 by rodw
yes you need to write an XML file now
  • IndeeSales
  • Visitor
  • Visitor
04 Feb 2026 16:15 #342398 by IndeeSales
So i have created my XML and a halfile which i think has some problems but i cant seem to get it to load i have attached the report and all my configs
File Name: Ethercat.hal
File Size:5 KB
File Name: ethercat-conf.xml
File Size:5 KB
File Name: linuxcnc.txt
File Size:6 KB
  • Moderator
  • Moderator
04 Feb 2026 17:40 #342405 by tommylight
loadusr -W lcec_conf /home/pi/linuxcnc/configs/sim.qtdragon.qtdragon_multi_joint/ethercat-conf.xml
Are you sure that is the correct path to the xml file?
04 Feb 2026 18:24 #342412 by Hakan
That seems to be ok.
The error message is in the output from the linuxcnc command
And if you look in the ethercat-conf.xml you find the word BLANK
In place of BLANK there should be one of the hal types u32, s32, float-ieee, bit.
Have a look at the ethercat-conf.xml in this example I often refer to
github.com/dbraun1981/hal-cia402/tree/main/example
Modify both the halType and the halPin .
This example also shows how you use the cia402 component to
connect the servo drives to the joints.
The following user(s) said Thank You: tommylight, IndeeSales
05 Feb 2026 02:59 #342433 by rodw
the pin names in your XML are what are used in hal. Yours are completely different so it won't work. Bring them into line.
05 Feb 2026 15:35 #342474 by IndeeSales
Okay first of all thank you for all your help with this, I am very new to this and have watched countless hours of youtube on ethercat and a having a hard time finding solutions to errors. I have another error
Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO entry registration failed
I want to thank everyone again for the help, I had lost hope on my project until now.
  • Moderator
  • Moderator
05 Feb 2026 16:46 #342480 by tommylight
@IndeeSales,
Is something wrong with your account as i see it has been disabled twice till now?
05 Feb 2026 18:06 #342486 by Hakan
Let's see what the EtherCAT master writes in the syslog when you try to start linuxcnc.
Can you please post the say last 30 lines from syslog? Command "sudo dmesg | tail -30"
Only the ones from EtherCAT are of interest.
Time to create page: 0.571 seconds
