  • Nator
  • Nator
22 Dec 2025 12:12
DM556 vs DM556 with DSP was created by Nator
Hi everybody,
since I am planning to update a Wabeco CC-F1210 with something quite up to date hardware I saw the DM556 and thought those would fit quite good. But there are so many "versions" of that thing.
Probably the most differences are in the following 2 models:
www.omc-stepperonline.com/digital-steppe...stepper-motor-dm556t
and the leadshine version:
www.omc-stepperonline.com/leadshine-digi...-stepper-motor-dm556
Is the new functionaliy of the leadshine worth the buck? Does anyone has real experience with both?
regards Han
  • Nator
  • Nator
22 Dec 2025 12:06
Replied by Nator on topic PicoBOB-DLX
PicoBOB-DLX
Category: Driver Boards
Thank you all!
  • JuFu
  • JuFu
22 Dec 2025 11:39
USER section in Probe Basic was created by JuFu
Category: QtPyVCP
Hello, I'm a beginner in Probe Basic UI and want to add some machine specific buttons in the USER section of the UI screen.
I understand that the layout is designed by using Qt Designer but have no glue whow to link/connect the button with the hal pin or signal of the machine.
Any advise ot link to a helpful YT video is apreciated. I could not find a YT tutorial or step-by-step guide/documentation.
  • NT4Boy
  • NT4Boy
22 Dec 2025 11:34 - 22 Dec 2025 11:42
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
I've been distracted by configuring a CAM post for this machine, and kind of blown away, that after months of learning, I can decide on a strategy, select tools speeds feed etc, and output the NC code from the CAM system and linuxcnc, parses it without comment. Not only that the machine runs the code and the the part is to drawing. Just excellent.
The orient.svg chart, while I get some of what it is telling me, i cannot understand how I need to convert it into hal statements. I thought by now I would get this stuff but I don't. which ones are loadrt, addf, setp and net ?
Sorry to be a dunce.
Could I ask for some pointers please?
  • DerKlotz
  • DerKlotz
22 Dec 2025 11:13
Replied by DerKlotz on topic SolidCAM 2021 circular pocket not generated
Category: CAD CAM
Thank you very much
  • MaHa
  • MaHa
22 Dec 2025 10:52
Category: CAD CAM
It's the xy allowance 0.25mm , using a 6mm tool machining 6.05
  • DerKlotz
  • DerKlotz
22 Dec 2025 10:38
Category: CAD CAM
Hello,
i just started with SolidCAM and try my first job -> attached photos..
All working toolpathes are blackish and one not working toolpath is blueish. Here i want a 6.05mm hole/4mm deep. Tool should be a 6mm end mill.
Tried many things but still don´t work.
Please help
  • jazzkramer
  • jazzkramer
22 Dec 2025 00:14 - 22 Dec 2025 00:26
Limit and home swithces with multiplexing with diodes and mux16 component?
Category: Basic Configuration
..AND, I see now, Mesa page says 7i84 is obsolite, there is the 7i84U now..
AND differences are:
1. Field outputs can be set to sourcing, sinking, or push pull modes on a per output basis.
2. Field outputs do not require flyback diodes for inductive loads regardless of load current.
3. 500 mA output current
So, nice! :)
Thanks! :)
  • jazzkramer
  • jazzkramer
22 Dec 2025 00:04 - 22 Dec 2025 00:12
Thank you Tommylight,
looking at the 7i84 specs pdf, it seams the easiest solution.
Inputs and outputs works from 5V to 28V so it's ok (and yes you're right about the half/half voltage, as stated in the pdf).
There are two version of this board:
sourcing outputs: (7I84)
or sinking outputs: (7I84D)
I will use inputs only for now, but... I have to decide which one is better for any possible future expansion...
Any ideas? Better sourcing or a sinking outputs?
(Post Scriptum: probably Sourcing is better?)
  • rodw
  • rodw's Avatar
21 Dec 2025 23:35
LinuxCNC latency and jitter improvements with PREEMPT_RT kernel parameter tuning
I also cover RT tuning in this video
What's not immediately clear that the servo thread and base thread are the only RT components used by Linuxcnc so that is why you only see one core in use.
  • jmelson
  • jmelson
21 Dec 2025 22:20
Pico Universal PWM Won't boot Random pins not working
The load fail red led does come on and stay on when I boot up linuxcnc and get the error messages. also the green estop ok led is lit as well. Prior to starting linuxcnc the light is off.
OH, didn't read closely enough!  If you are saying the Load Fail LED only stays on after LinuxCNC starts?  I know of NO WAY LinuxCNC can turn this light on, except by maybe causing a fluctuation of the 12 V supply.
Please give a bit more detail.
Jon
  • jmelson
  • jmelson
21 Dec 2025 22:17
Jon,
This is the killer problem!  The FPGA is not accepting the load of its program.  It is somewhat unlikely the EPROM has gone bad, but possible.  First, check that the +12V supply is operating properly, and does not have excessive ripple.  Without a valid program in the FPGA, nothing will ever work.  If the power supply is good, then it is possible the FPGA has been damaged, or one of the regulators on the board has gone bad or is overloaded.  You can check from the wide tab of U31 to one of the G terminals of P2.
That should read +3.3 V.  Then check the wide tab of U32, that should read +1.2V.  If either of these is out of range, something got popped.  You can also check for correct power up with the parallel port cable disconnected.  D4 (Load Fail) should blink once and then stay out.
Jon
21 Dec 2025 22:11
You can also use a simple BOB on the expansion header, adding 5 more inputs (limited by BOB, not by Mesa).
And for RS422 see Mesa 7i84, it has 32 inputs and 16 outputs that work with 24V, but also work with 5V, i am pretty sure you can have half of IO with 5V and the other half with 12V or 24V or any combination of voltages as half and half. You might want to wait for confirmation of the half/half thing from PCW as i did something like that several years ago and i am a bit fuzzy.
  • jazzkramer
  • jazzkramer
21 Dec 2025 21:40
Thanks PCW,
that's interesting... so maybe I better think about an expansion card to connect more inputs... I Know 7i96 has RS-422/RS485 and there are cards expansion with many I/Os...
I will think about. My limit switches works at 24V but I can think for a solution if this card works at a lower voltage...
  • PCW
  • PCW's Avatar
21 Dec 2025 21:21
A disadvantage of multiplexing is that the switch detection will be slower (by a factor of the servo thread period times the multiplex depth)
You could also use the parallel expansion port to add 17 more inputs (though 5V only and probable should have 220 Ohm or so
series resistors for protection)
Displaying 5311 - 5325 out of 16970 results.
Time to create page: 0.253 seconds
